The Sandman
Urgestein
thats what I would call hardcore-binning.
Während andere noch booten, sind die einen schon im Windoof
Every test will help us.Many thanks for the effort and time.
I wanted to watercool it, too, since I have a lot of radiators just lying around. But I hardcore fail to build a 462 bracket. I tried soldering picture related onto a waterblock but apparently I am too stupid to get it to actually hold on to it (the innermost holes are for socket 462).Zalman 7000 will fit onto the Asus, but will not fit on the NF7. The Zalman is able to handle my 2.7ghz xp-m at 1.85V just fine. Besides that i run watercooling or even a thermalright si-128se with a diy bracket. The ifx 14 won‘t fit though.
You, sir, might be a certified genius.Just a quick thought: what if your FireGL cards are made for Mac? Those cards afaik got a pc incompatible bios.
- My FireGL X3 has Infineon Ram, they have lower specs then Samsung Ram on a X800XT Card, therefore in Graphiccelerator set Memory Clock to 279Mhz, click on "save!" and start ATI Multi Flasher. If we run stock memory clock with this bios and Infineon Ram, it gives a lot of artifacts.
understandable. As the most Radeon 9700/ 9800 cards are expensive, I would try to get a cheaper Medion 9800XXL / 9800XL card. Here in Germany they're less pricier then the other brands. Other solution could be buying a X1650 AGP card.Beginning to despair, here. Won't get nearly as powerful an authentic 2002 or 2003 card at this price point
It is like this: My German writing and talking is not that good. Reading is not a real big issue.just to note, as you‘re new to this thread: the reason we talk in english from time to time is that we got some international members in here. If you‘re from germany, german is fine too
Thanks!So, ein paar BIOS Versionen zum rumspielen. Diese BIOS Verionen sind für das LP A und NF7 (v2).
Die jeweiligen Versionen unterscheiden sich nur durch den register offset 48h (b0d0f3) ---> B2B=66 --->B2C=65--->B2D=69--->B2E=75
die register tweaks vom B2D entpsprechen den Werten aus dem LPB. Mit diesen Werten liefen meine TCCD Riegel auf dem NF7 bisher besser als mit den anderen.
B2E ist eine Testversion. Ich kann mich nicht mehr genau daran erinnern wo ich den Wert 75 gesehen habe. Glaube Abit.
