kingVoklee
So mein Upgrade ist fertig bestellt![]()
1800X, Asus Crosshair VI, 16GB 3200er CL14 und Samsung 960 Evo 1TB
Sehr ähnlich zu mir. Bei mir allerdings 32GB, dafür nur 500er Evo
nur so als info..
falls sich jemand schon irgendwelche parts für sein neues ryzen sys bestellen will:
bei alternate gibts aktuell bis 100€ 25% rabatt, ab 100€ 25€ rabatt AUF ALLES.
Werd das einfach mal ausm "overclockers uk"-Forum copy pasten. Was ihr davon haltet ist eure Sache.
"Some drop of info from the AIDA dev:Many review sites have problems, as a lot of boards have buggy BIOS etc, which the manufacturers trying to iron out as fast as they can. Plus there is some strange things going on with the Ryzens cache/memory latency, it's very high. The speed is great, but the latency is not so much, sources yet unknown."
"Apparently there is a hardware fault with the ryzen cpus which will require re-manufacturing...."
heißt das man kriegt unter 100€ einkauf 25% rabatt und ab 100+€ 25€ nur? oder lieg ich da falsch?
I’ve decided to provide some recommendations on DDR4 limitations concerning AM4 currently.
As it stands the AMD code has restricted RAM tuning options which means many RAM kits at launch will not be compatible. This is the same for our competitors also.
What we recommend is the following:
If fully populating a system with 4 DIMMs (2DPC), use memory up to a max of 2400MHz.
If using 1DPC (2 DIMMs) ensure they are installed in A2/B2 and use memory up to max of 3200MHz.
The indication I have received from HQ is that AMD has focused all their efforts on CPU performance so far and will release updated code in 1~2 months when we expect improved DDR4 compatibility and performance.”
In short if filling all 4 DIMM’s set your speed to 2400MHz and work up from there.
If using 2 DIMM’s put them in the A2/B2 slots and a max of 3200MHz should be possible.
In our testing only the Crosshair board achieved 3000-3200MHz, the others were in the 2400-2666MHz range.
BIOS updates will come!
bei Alternate würde ich nichtmal nochmal bestellen, selbst wenn es 50% Rabatt gibt...
- - - Updated - - -
schreib doch bitte dazu dass beide Aussagen von verschiedenen Usern stammt.
später ist aber leider zu spät, da einige User einfach nicht alles lesen und sich daraus sonstwas zusammenreimen.
lol 25 euro bei nem einkauf um die 500-750 euro ist dann auch wieder wurst^^
AMD hat hinter geschlossenen Türen schon verlauten lassen, das wohl noch Optimierungen am Ram/Timings/Cache kommen. Quelle find ich dazu grade nicht mehr... CB oder Videocardz müsste es gewesen sein.
weiso bestellt 6 teile je 25 rabatt bestellst einfach 6 mal .... cpu mainboard gehäuse netzteil ram cpu kühler wen nötig fertig oder geht das nicht ;D
Das ist das Topmodell.
Habs editiert, damit sich nicht eingemacht wird.
dass sowohl Kauf von Kaby Lake als auch Ryzen-Vorbestellung beides schon irgendwie riskante Investitionen sind. So kommt's mir jedenfalls vor.
da ist aber jemand gleich eingeschnappt![]()
Hier und da zieht er dem 6900er ab, dann fällt er woanders mal komplett um .. kurioses Verhalten. Und ja nochmal: Beta-Tester sein nervt^^ AMD Ryzen 7: 1800X, 1700X 1700 ab 359 Euro ab 2. März mit 52 % ΔIPC - Seite 62 - ComputerBase Forum
Bios.
Ich such die Quelle nochmal und editiere ggf. dann rein, wenn ich sie finde.
EDIT:
PSA: AMD B350 motherboards do not support SLI | VideoCardz.com
so geil wie die ganzen Intel/Nvidia Fanboys aus den Löchern kommen wenn es selbe/mehr Leistung für weniger Geld gibt![]()
Sr,y aber das ist doch alles nur PC-Hardware für paar Hundert € und kein 10 000€ Aktienkauf oder ein teures Auto ohne Garantie oder ein Haus. Da würden manche dann wohl sofort tot umfallen wenn sie beim CPU Kauf schon so abgehen.
Zudem hat/wird man auch nicht wirklich was verloren sondern auch eine schnelle CPU erhalten.
Um es kurz zu machen: Die Biosse seien eher noch im Betastatus. Ramfunktionalität eine Lotterie. Bei Ihnen hat der beiliegende 3200er Ram (vom AMD Pressekit) nicht mit 3200 funktioniert.
Das liest sich als könnte es gut möglich sein dass in ~2 Monaten durch Bios Updates dann 3600MHz bei Dual Kits möglich wird?
Das wäre geil da ich ein 3600er Trident Z RGB Kit geholt hab![]()
So ganz stimmt das ja nicht um ehrlich zu sein.Weil die vielleicht endlich mal auf die perf/watt metric warten?
Also die 1000K$ Intel Leistung erkaufe ich mir gerne für die Hälfte, dann aber auch bitte mit der selben perf/watt (gerne auch weniger...), aber da schweigt sich AMD ja bis dato noch zu tote! Nicht eine einzigste geleakte Slide noch irgendwelche Kommentare seitens AMD dazu...bei Polaris wetterte man immerhin mit einer 2x perf/watt Steigerung.
Um ehrlich zu sein, wäre so eine Slide in Bezug auf Zen mal mehr wert als irgendwelche AotS Benchmarks...
