Bitteschön:
********* Change Log For V1.45 Firmware
2008-2-16
1 Fix SSD HDD cannot be used in SAS controller
2008-3-3
1 Fix ARC1680/1212 identify 1st level enc error
2 Fix ARC1680/1212 select HDD for creating raidset, garbage chars are
displayed
2008-3-7
1 Add 3 seconds delay to exclude SMP enclosure
2008-3-13
1 Add RESCUE raidset function in VT100
2 InbandSAS:use lun127 for SAS inband device
3 SAS:fix if LUN0 is null, system cannot see volumes
4 Fix ARC1201 Identify Drive LED bug
5 Fix ARC1201 IP Address On LCD
2008-3-14
1 LSI SAS firmware 1.22.1.0 is used
2 Add display of RAID state during selection for deletion
3 Add diaplay of IOP34X/LSI expander's revision
4 Fix ARC1201 ROAMing problem
5 Build V1.45 2008-3-14
********* Change Log For V1.46 Firmware
2008-3-17
1 Fix ARC1680 4G support:OS corrupted during boot.
2008-3-21
1 Add ARC1680IX-12A support
2 ARC1680:fix JBOD link LED and JBOD activity LED
3 ARC1680:fix GuiMisc to support 1680TRANSPORT to be updated from DOS gui
4 Fix nflash.exe to update 1680TRANSPORT
2008-3-24
1 Fix ARC1160/1130+1GB SDRAM problem, improve driver strength
2008-3-25
1 ARC1680:Fix JBOD link LED do not turn on for DELL MD1000
2008-3-27
1 ARC1680
isable NCQ if intel transport V4.1.13.2 is used
2008-4-1
1 Fix LCD panel display error (some * is displayed in words)
2008-4-28
1 Fix ARC1200/1201 do not initialized properly (Host issue linkdown)
2 Controller time related
(A) Timezone default to Taipei
(B) Add gui to set UTC time
(C) NTP set rtc time if NTP time got
(D) If app got NtpSupported, use UTC time to sync RTC
2008-4-29
1 ARC1680IX-12A 512MB memory support
2 Fix ARC5020 USB problem for MAC usb support
2008-5-5
1 Fix GUI check R5060 volume error
2008-5-15
1 Correct offline raid warning message
2008-5-27
1 NEW_BATTERY_BACKUP_HPI
nly enable BBM if return from power loss during
system init
2008-6-4
1 Modify IOP321 model's SDRAM init:
2008-6-10
1 Fix SQLIOSIM test failed
2 Add mute beeper if LCD panel ESC is pressed
3 SuperMicro SAS933EL2 enclosure and ARC1680 compatiblity:
unknown errors are reported for FAN and HDD temp
skip error report for them
2008-6-11
1 Add EMPTY_SLOT_LED_SETTING for ARC1680 to patch AIC SES backplane problem
if we request HDD missing, TWIN SES sometimes will set RED led on and may
keep it on even we request it off (to fix this problem, set empty slot
LED to OFF)
2008-6-16
1 Fix ARC1680IX-8 LED error
2008-6-19
1 Add ARC1680LP 512MB support
2008-6-25
1 ARC5020
(A) Add SMTP port setting
(B) Fix if more than 4 volumes are created, system just detect only one
(C) Fix if foreground init/failed volume can be detected
(D) JBOD mode hang
(E) Ethernet may lockup if link down/up
2008-7-3
1 ARC1680+MR25.2-S032G
(A)2.2.14.0/2.3.3.0 transport firmware can work with it (no frame timeout)
(B)4.1.13.2 transport firmware will generate F3 (local reject error)
2008-7-18
1 ARC1212
(A) Use V4.3.1.0 intel transport firmware
(B) Fix SQLIOSIM problem
2008-7-22
1 Add SMARTTOOLS support for all PCI/PCIX/PCIE sata raid adapter
2 Add multiple rebuild and scheduled volume check for all pci adapter
2008-7-25
1 All model, decrease the LOGIN warning level
2 Modify the date code format to two digit (ie 2008-2-2 to 2008-02-02)
3 Improve scheduled volume check,
(A) Add time to check display in volume information display
(B) If time & date is not set, disable scheduler
(C) If vol time is set without time & date set, use 0
2008-8-6
1 Add PMC expnader support
2008-8-7
1 Build 1.46 for ARC11xx/12xx
