[Sammelthread] ASRock AB350 Fatal1ty K4 | AB350 Pro 4 | AB350M Pro 4 | (AMD B350)
Sammelthread für Asrock B350 Boards
(Fatal1ty K4 Gaming , AB350 Pro 4 , AB350M Pro 4 , AB350M , AB350M-HDV)
Bilder:
- Spezifikationen:
Code:
[LIST]
[*][COLOR=#FFFFFF]Gaming Armor[/COLOR]
[B]Memory
- 15μ Gold Contact in DIMM Slots
[B]Audio
- Creative Sound Blaster™ Cinema 3[/B][/B]
[*][COLOR=#FFFFFF][B]Unique Feature[/B][/COLOR]
[B]ASRock Super Alloy
- Premium Power Choke
- Matte Black PCB
- High Density Glass Fabric PCB
- 2oz Copper PCB
[B]ASRock Steel Slots
[B]ASRock Ultra M.2 (PCIe Gen3 x4)
[B]ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
[B]ASRock Live Update & APP Shop[/B][/B][/B][/B][/B]
[*][COLOR=#FFFFFF][B]CPU[/B][/COLOR]
[B]- Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
- Digi Power design
- 9 Power Phase design
- Supports 95W Air Cooling[/B]
[*][COLOR=#FFFFFF][B]Chipset[/B][/COLOR]
[B]- AMD Promontory B350[/B]
[*][COLOR=#FFFFFF][B]Memory[/B][/COLOR]
[B]- Dual Channel DDR4 Memory Technology
- 4 x DDR4 DIMM Slots
- AMD Ryzen series CPUs support DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC & non-ECC, un-buffered memory[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- AMD 7[SUP]th[/SUP] Gen A-Series APUs support DDR4 2133 ECC & non-ECC, un-buffered memory[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- Max. capacity of system memory: 64GB[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]
[COLOR=#AAAAAA][COLOR=red][FONT=inherit]*[/FONT][/COLOR]Please refer to Memory Support List on ASRock's website for more information.
Please refer to below table for DDR4 UDIMM maximum frequency support.
A-Series APUs:[TABLE="class: Table, width: 979"]
[TR]
[TH="colspan: 4, align: center"]UDIMM Memory Slot[/TH]
[TH="align: center"]Frequency(MHZ)[/TH]
[/TR]
[TR]
[TH]A1[/TH]
[TH="align: center"]A2[/TH]
[TH="width: 20%, align: center"]B1[/TH]
[TH="width: 20%, align: center"]B2[/TH]
[/TR]
[TR]
[TD]-[/TD]
[TD]SR[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]2400[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]DR[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]2400[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]SR[/TD]
[TD]-[/TD]
[TD]SR[/TD]
[TD]2400[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]DR[/TD]
[TD]-[/TD]
[TD]DR[/TD]
[TD]2133[/TD]
[/TR]
[TR]
[TD]SR[/TD]
[TD]SR[/TD]
[TD]SR[/TD]
[TD]SR[/TD]
[TD]1866[/TD]
[/TR]
[TR]
[TD]SR/DR[/TD]
[TD]DR[/TD]
[TD]SR/DR[/TD]
[TD]DR[/TD]
[TD]1866[/TD]
[/TR]
[/TABLE]
Ryzen Series CPUs:[TABLE="class: Table, width: 979"]
[TR]
[/TR]
[TR]
[TH]A1[/TH]
[/TR]
[TR]
[TD]-[/TD]
[TD]SR[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]2667[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]DR[/TD]
[TD]-[/TD]
[TD]-[/TD]
[TD]2667[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]SR[/TD]
[TD]-[/TD]
[TD]SR[/TD]
[TD]2667[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]DR[/TD]
[TD]-[/TD]
[TD]DR[/TD]
[TD]2400-2667[/TD]
[/TR]
[TR]
[TD]SR[/TD]
[TD]SR[/TD]
[TD]SR[/TD]
[TD]SR[/TD]
[TD]2133-2400[/TD]
[/TR]
[TR]
[TD]SR/DR[/TD]
[TD]DR[/TD]
[TD]SR/DR[/TD]
[TD]DR[/TD]
[TD]1866-2133[/TD]
[/TR]
[/TABLE]
SR: Single rank DIMM, 1Rx4 or 1Rx8 on DIMM module label
DR: Dual rank DIMM, 2Rx4 or 2Rx8 on DIMM module label
[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows[SUP]®[/SUP] 32-bit OS. For Windows[SUP]®[/SUP] 64-bit OS with 64-bit CPU, there is no such limitation.[/COLOR]
[/B]
[*][COLOR=#FFFFFF][B]BIOS[/B][/COLOR]
[B]- 128Mb AMI UEFI Legal BIOS with multilingual GUI support
- Supports "Plug and Play"
- ACPI 5.1 compliance wake up events
- Supports jumperfree
- SMBIOS 2.3 support
- DRAM Voltage multi-adjustment[/B]
[*][COLOR=#FFFFFF][B]Graphics[/B][/COLOR]
[B]- Integrated AMD Radeon™ R7/R5 Series Graphics in A-series APU
- DirectX 12, Pixel Shader 5.0
- Max. shared memory 2GB
- Three graphics output options: D-Sub, DVI-D and HDMI
- Supports Triple Monitor
- Supports HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
- Supports DVI-D with max. resolution up to 1920x1200 @ 60Hz
- Supports D-Sub with max. resolution up to 1920x1200 @ 60Hz
- Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Port (Compliant HDMI monitor is required)
- Supports HDCP with DVI-D and HDMI Ports
- Supports Full HD 1080p Blu-ray (BD) playback with DVI-D and HDMI Ports[/B]
[*][COLOR=#FFFFFF][B]Audio[/B][/COLOR]
[B]- 7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- Premium Blu-ray Audio support
- Supports Surge Protection
- ELNA Audio Caps
- PCB Isolate Shielding
- Individual PCB Layers for R/L Audio Channel
- Supports Creative Sound Blaster™ Cinema 3
[COLOR=#AAAAAA][COLOR=red][FONT=inherit]*[/FONT][/COLOR]To configure 7.1 CH HD Audio, it is required to use an HD front panel audio module and enable the multi-channel audio feature through the audio driver.[/COLOR]
[/B]
[*][COLOR=#FFFFFF][B]LAN[/B][/COLOR]
[B]- PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111GR
- Supports Wake-On-LAN
- Supports Lightning/ESD Protection
- Supports LAN Cable Detection
- Supports Energy Efficient Ethernet 802.3az
- Supports PXE[/B]
[*][COLOR=#FFFFFF][B]Slots[/B][/COLOR]
[B]- 1 x PCI Express 3.0 x16 Slot (PCIE2: x16 mode)[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 1 x PCI Express 3.0 x16 Slot (PCIE4: x4 mode)[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 4 x PCI Express 2.0 x1 Slots
[COLOR=#AAAAAA][COLOR=red][FONT=inherit]*[/FONT][/COLOR]Supports NVMe SSD as boot disks
AMD Ryzen series CPUs support PCIE2: x16 mode
AMD 7[SUP]th[/SUP] A-Series APUs support PCIE2: x8 mode
[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]AMD Ryzen series CPUs support PCIE4: x4 mode
AMD 7[SUP]th[/SUP] A-Series APUs support PCIE4: x2 mode
If M2_1 is occupied, PCIE4 will be disabled.[/COLOR]
[/B]
[*][COLOR=#FFFFFF][B]Storage[/B][/COLOR]
[B]- 4 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 2 x SATA3 6.0 Gb/s Connectors by ASMedia ASM1061, support NCQ, AHCI and Hot Plug
- 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280/22110 M.2 SATA3 6.0 Gb/s module[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]
[COLOR=#AAAAAA][COLOR=red][FONT=inherit]*[/FONT][/COLOR]M2_2 and SATA3_3 share lanes. If either one of them is in use, the other one will be disabled.
[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]If M2_1 is occupied, PCIE4 will be disabled.
Supports ASRock U.2 Kit[/COLOR]
[/B]
[*][COLOR=#FFFFFF][B]Connector[/B][/COLOR]
[B]- 1 x COM Port Header
- 1 x TPM Header
- 1 x Power LED and Speaker Header
- 1 x RGB LED Header[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 1 x AMD Fan LED Header
- 1 x CPU Fan Connector (4-pin)[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 3 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]
- 1 x 24 pin ATX Power Connector
- 1 x 8 pin 12V Power Connector
- 1 x Front Panel Audio Connector
- 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
- 1 x USB 3.0 Header (Supports 2 USB 3.0 ports) (Supports ESD Protection)
[COLOR=#AAAAAA][COLOR=red][FONT=inherit]*[/FONT][/COLOR]Supports up to 12V/3A, 36W LED Strip
[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
[COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR][COLOR=red][FONT=inherit]*[/FONT][/COLOR]CHA_FAN2 and CHA_FAN3 can auto detect if 3-pin or 4-pin fan is in use.[/COLOR]
[/B]
[*][COLOR=#FFFFFF][B]Rear Panel I/O[/B][/COLOR]
[B]- 1 x PS/2 Mouse/Keyboard Port
- 1 x D-Sub Port
- 1 x DVI-D Port
- 1 x HDMI Port
- 2 x USB 2.0 Ports (Supports ESD Protection)[COLOR=red][FONT=inherit]*[/FONT][/COLOR] 1 x Fatal1ty Mouse Port (USB 2.0) is included
- 1 x USB 3.0 Type-C Port (Supports ESD Protection)
- 5 x USB 3.0 Ports (Supports ESD Protection)
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- HD Audio Jacks: Line in / Front Speaker / Microphone[/B]
[*][COLOR=#FFFFFF][B]Software and UEFI[/B][/COLOR]
[B]Software
- ASRock RGB LED
- ASRock Key Master
- ASRock APP Charger
- ASRock XFast LAN[COLOR=red][FONT=inherit]*[/FONT][/COLOR]
[B]UEFI
- ASRock Full HD UEFI
- ASRock Instant Flash
- ASRock Internet Flash
- ASRock Crashless BIOS
- ASRock Easy RAID Installer
[COLOR=#AAAAAA][COLOR=red][FONT=inherit]*[/FONT][/COLOR]These utilities can be downloaded from ASRock Live Update & APP Shop.[/COLOR]
[/B][/B]
[*][COLOR=#FFFFFF][B]Support CD[/B][/COLOR]
[B]- Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar[/B]
[*][COLOR=#FFFFFF][B]Accessories[/B][/COLOR]
[B]- Quick Installation Guide, Support CD, I/O Shield
- 2 x SATA Data Cables
- 2 x Screws for M.2 Sockets[/B]
[*][COLOR=#FFFFFF][B]Hardware Monitor[/B][/COLOR]
[B]- CPU/Chassis temperature sensing
- CPU/Chassis Fan Tachometer
- CPU/Chassis Quiet Fan
- CPU/Chassis Fan multi-speed control
- Voltage monitoring: +12V, +5V, +3.3V, Vcore[/B]
[*][COLOR=#FFFFFF][B]Form Factor[/B][/COLOR]
[B]- ATX Form Factor: 12.0-in x 8.8-in, 30.5 cm x 22.4 cm
- Solid Capacitor design[/B]
[/LIST]
CPU Kühler Kompatibilität:
RAM Kompatibilität:
Corsair CMK32GX4M2A2400C14 Vengeance LPX 32GB
- Corsair CMK16GX4M2B3000C15 Vengeance LPX 16GB
QVL Liste von Asrock
Link zur Hersteller Seite
Preise
BIOS Versionen:
3.20:
1.Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes.
2.Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature.
3.With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
PS1. Windows update is available for version P3.00 or later.
3.00:
Update AGESA to 1.0.0.6a
2.60: Update AGESA to 1.0.0.6.
2.50: Update Agesa Version string "SummitPI-AM4 1.0.0.4a"
2.22: Improve ASMedia SATA port compatibility for Windows 7. (BETA Version)
2.20 : 1.Ryzen 5 ready. 2.Support DDR4 Voltage control in Ryzen Master. 3.Precision Boost - Adjusts clock speeds in 25MHz increments in BIOS setup.
1.44 : Add CPU Voltage item in BIOS setup. (BETA Version)
1.43 : 1.Add DRAM timing item in OC Tweaker. 2.Add CPU Voltage item in OC Tweaker. ( BETA Version )
1.42 : 1.Improve XMP DRAM compatibility. 2.Add Simultaneous Multi-Threading(SMT) item in BIOS setup. ( BETA Version )
1.41 : Add Enable RGB LED option. ( BETA Version )
1.40 : 1.Add Instant flash function. 2.Add "CPU Frequency Multiplier Change" item.
Das ist wirklich seltsam.
Das würde aber deine extrem lange Bootzeit erklären, das Board sucht die laufwerke kann sie aber nicht finden.
Ich vermute das Board hat einen Knacks.
Den Verdacht hab ich langsam auch, denke ich werde nachher mal mindfactory kontaktieren und ein neues anfordern. Jetzt wo ich drüber nachdenke macht es Sinn das es so lange braucht
Gesendet von meinem ONEPLUS A3003 mit Tapatalk
Tauchen die Laufwerke im Systemstart Menue auf.
Wenn ja, Bootlaufwerk festlegen und win installieren.
Nein, es wird kein Laufwerk angezeigt bis ich im Windows bin. Der erste wirkliche Start erfolgte auch erst als ich meine alte ssd angeschlossen habe auf der Windows schon installiert war. Konnte damit dann starten und aus dem Betrieb heraus einmal neu installieren aber ich konnte kein Laufwerk auswählen
Einen Biosreset wie weiter oben empfohlen hast du schon versucht?
Kann mir jemand RAM empfehlen der Problemlos auf 3200 MHz läuft und am besten noch einigermaßen Luft nach oben hat? Vllt sogar 3600er für Ryzen 2xxx ?
Ne auf 3200 krieg ich sie einfach nicht wirklich richtig zum laufen und für ein mögliches CPU Upgrade möchte ich dann mit dem RAM gewappnet sein.. der wird hier denke ich auch wieder das Bottleneck werden.
Will mich nicht zu früh freuen, aber bislang bin ich mit dem 4.70er Bios sehr zufrieden. Es wurde in jedem Fall am Memory Training geschraubt. Den Speicher den ich hier erwähnt hatte und der nicht lief, läuft jetzt bislang ca eine Stunde fehlerfrei. Zudem gabs anders als noch bei 4.50 und 3.30 kein Gezicke beim ersten Start. Der Ram wurde auf "Auto" sofort richtig erkannt und das XMP geladen. In den vorherigen Versionen die ich getestet habe, hatte das System erst ein paar mal neugestartet ehe ich ins UEFI konnte und dann waren nur 2133Mhz eingestellt.
Ich berichte mal weiter wie es sich verhält.
Edit: Natürlich zu früh gefreut.:d PAGE_FAULT Bluescreen. Denke ich werde auf B450 und Ryzen 2 wechseln. Hab keine Lust mehr auf Summit Ridge.
Neue Finale BIOSe :)
Moin JZ_,
ich habe eben eines meiner AB350M Pro4 mit dem neuen BIOS versehen und seitdem bootet die Kiste nur noch, wenn ich die Virtualiserung deaktiviere (SVM-Mode und SR-IOV Support). Lasse ich diese beiden Optionen weg, die ich für Hyper-V benötige, so startet Server 2016 nicht richtig und hängt beim Windows Bootlogo fest. Danach erfolgt entweder "Inaccessable boot device" oder ein reboot.
Defaults habe ich geladen, alle Laufwerke bis auf die System-SDD (2,5er) abgezogen. Fun fact, wenn der Boot nicht durchläuft und es zu einem reboot kommt, dann zeigt das BIOS anstelle der 2x 8GB Samsung DDR4 ECC insgesamt nur einen Riegel in der Größe von 56065MB an...
Hat jemand ähnliche Probleme mit den Einstellungen?
Woran kann es liegen das sich auf meinem System die Option BankGroupSwap nicht aktivieren lässt?
Ich habe die Option im Uefi explizit erlaubt, trotzdem wird es als disabled im RTC angezeigt und auch die Leistung ist nicht auf dem erwarteten Niveau.
@Optikks:
Was ich schon paar mal gelesen habe ist, das man im Bios unter CSM>Launch Storage OpROM Policy die Einstellung auf "UEFI only" umstellen soll. Das habe ich bei meinem Board gleich von vorne herein so eingestellt und keine Probleme gehabt. Wohl gemerkt das ich eine Samsung 960 und keine Intel habe. Vielleicht hilfts bei dir ....
@Optikks:
Danke für die Hilfe aber ich hab das Board jetzt zurück geschickt und mir ein Gigabyte geholt. Das lief direkt ab dem ersten Start nahezu perfekt. Musste lediglich den RAM per Hand auf seinen takt bringen. Jetzt ist der Boot auch wieder schneller als das der Bildschirm überhaupt etwas anzeigt
ich habe seit Monaten mit meinem RAM CMK16GX4M2B3000C15 und dem Motherboard zu kämpfen.
Kann mir jemand sagen, wie ich den RAM Stabil auf 29XX hochbekomme oder ist das gar nicht möglich?
Danke und Gruß
DonLux
Willkommen im Club!
Du hast leider auch die Corsairs mit Hynix-Speicherbausteinen (vermutlich doch auch in der Version "ver 5.30", oder?) und die Dinger laufen nicht besonders gut mit Ryzen.
Die Situation ist mit den neuesten BIOS-Versionen ab 4.xx aufwärts allerdings besser geworden. Meine Corsairs wollen absolut nicht mit 2933 MHz starten, aber dafür funktioniert 2800 MHz mit CL 14 jetzt 99% stabil.
Frohes ausprobieren & Grüße,
fisch
Warum holst du dir Speicher der noch niedriger spezifiziert ist oO
Moin,
kann man bitte jemand gegentesten, ob die Kombination aus Server 2016 und aktivierter Hyper-V-Rolle und dem aktuellen BIOS läuft? Ich habe alle mir bekannten Server 2016-Versionen inkl. Preview durchprobiert, aber der Rechner bootet nicht mehr, wenn die Rolle aktiviert wurde. Bei Windows 10 geht das weiterhin.
Es müsste also ein Bug/Feature im BIOS seit Version 4.30 sein, da alle vorherigen Versionen in der Konstellation funktionierten.
Mit dem BIOS 4.7 läuft bei mir alles wie es soll.
Nur beim starten habe ich ab und an das Problem, dass er kein bootbares Device findet. Nach einem Neustart über STRG+ALT+ENTF klappt aber alles.
Wenn dieser Bug noch entfernt wird, dann bin ich rundum zufrieden.
Weiß man ob die neuen CPUs (2700X) auf dem ASRock AB350M Pro4 laufen ? Ist da nochmal ein Update fürs BIOS zu erwarten, obwohl der 2400G schon untersützt wird ?
Mein Leidensweg geht weiter. Heute den Ryzen 5 2600 auf meinem A320M Pro4 mit 4.70er Bios installiert.
Und siehe da, ich habe immer noch Probleme (Blue-Screens) mit Ram der auf der offiziellen QVL Liste angegeben ist mit gerade mal 2400 Mhz ans laufen zu bringen. Es muss also definitiv am Board liegen. Hätte nicht gedacht dass der A320 derartig miserabel bzw. ASRock es derartig verbockt hat. Ich habe mir jetzt ein Gigabyte Board bestellt. Dort gibts auch schon ein Bios seit letzter Woche mit AGESA PinnaclePI-1.0.0.2a. Bin echt ziemlich enttäuscht von ASRock. Werde in jedem Fall auch mal ein Support Ticket anlegen und hören was die dazu sagen, dass bei 7 Bios Updates, 2 CPUs und 4 Ram Kits keine Kombination dabei war mit der ich teils teuren Trident z Ram stabil mit 2400 Mhz betreiben konnte. Nur mein Patriot Ram mit 2400 @1.35V läuft stabil.:wall:
[Sammelthread] Gigabyte (GA-) AB350N-Gaming WIFI | AB350M-Gaming 3 | AB350-Gaming | AB350-Gaming 3 - Seite 5
Irgendwas wird bei dir derbe faul sein, denn sonst hätte ich es hier schon längst festgestellt. Die Kombination aller deiner Teile ist das Problem oder es liegt ein Defekt vor :/
- - - Updated - - -
@JZ_
Hattest Du eventuell Zeit mal wegen Hyper-V zu gucken?
Was war da nochmal ?
@JZ_
Wenn bei dem AB350M Pro4 BIOS 3.40 oder höher installiert war, dann schlug der Bootvorgang von Server 2016 (egal welche Version) fehl, wenn bei Server 2016 die Rolle "Hyper-V" installiert war. Wie ich mittlerweile weiß, tritt diese Problem nur auf, wenn man einen Ryten 1xxx verwendet. Verwendet man einen Ryzen 2xxx, dann bootet Server 2016 inkl. Hyper-V ordnugsgemäß.
Will man Server 2016 mit der Rolle Hyper-V, so gilt:
Ist ein Ryzen 1xxx verbaut ==> BIOS 3.40 oder älter.
Ist ein Ryzen 2xxx verbaut ==> BIOS 3.70 oder neuer (was man ja eh wegen Ryzen 2xxx benötigt).
Zum Board an sich: ich habe gerade einen Ryzen 7 2700x verbaut und HWiNFO zeigt mir folgendes an:
Ist das nicht schon viel zu heiß? Bei mir liegt oft Dauerlast an.
