[Sammelthread] Asrock AB350 Gaming-ITX/ac | X370 Gaming-ITX/ac
  • Ersteller Gelöschtes Mitglied 189576
  • Erstellt am
Sammelthread Asrock AB350 Gaming-ITX/ac | X370 Gaming-ITX/ac​
die beiden Mini-ITX AM4 von Asrock
Inhaltsverzeichnis:
  • Technische Daten
  • Preisvergleich
  • Fragen / Antworten
  • RAM Kompatibilität
  • Berichte & Reviews
  • aktuelle BIOS Versionen
Technische Daten
AB350 Gaming-ITX:
Code:
[table="width: 500"]
[tr]
	[td]Gaming Armor[/td]
	[td]Power
- Hi-Density Power Connector (8 pin)
Memory
- 15μ Gold Contact in DIMM Slots
VGA Card
- 15μ Gold Contact in VGA PCIe Slot (PCIE1)
Internet
- Intel® LAN
Cooling
- 2oz Copper PCB
Audio
- Creative Sound Blaster™ Cinema 3[/td]
[/tr]
[tr]
	[td]Unique Feature[/td]
	[td]ASRock Super Alloy
- Premium Power Choke
- Dual-N MOSFET
- Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
- Matte Black PCB
- High Density Glass Fabric PCB
- 2oz Copper PCB
Intel® 802.11ac WiFi
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop[/td]
[/tr]
[tr]
	[td]CPU[/td]
	[td]- Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
- Digi Power design
- 8 Power Phase design
- Supports 95W Water Cooling[/td]
[/tr]
[tr]
	[td]Chipset[/td]
	[td]- AMD Promontory B350[/td]
[/tr]
[tr]
	[td]Memory[/td]
	[td]- Dual Channel DDR4 Memory Technology
- 2 x DDR4 DIMM Slots
- AMD Ryzen series CPUs support DDR4 3466+(OC) / 3200(OC) / 2933(OC) / 2667 / 2400 / 2133 ECC & non-ECC, un-buffered memory*
- AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
- Max. capacity of system memory: 32GB**
- 15μ Gold Contact in DIMM Slots[/td]
[/tr]
[tr]
	[td]BIOS[/td]
	[td]- 128Mb AMI UEFI Legal BIOS with GUI support
- Supports "Plug and Play"
- ACPI 5.1 compliance wake up events
- Supports jumperfree
- SMBIOS 2.3 support
- CPU, DRAM, PCH 1.05V, PROM 2.5V, Voltage Multi-adjustment[/td]
[/tr]
[tr]
	[td]Graphics[/td]
	[td]- Integrated AMD Radeon™ R-Series Graphics in A-series APU*
- DirectX 12, Pixel Shader 5.0
- Max. shared memory 2GB
- Supports 2 x HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
- Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Ports (Compliant HDMI monitor is required)
- Supports HDCP with HDMI Ports
- Supports Full HD 1080p Blu-ray (BD) playback with HDMI Ports[/td]
[/tr]
[tr]
	[td]Audio[/td]
	[td]- 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
- Premium Blu-ray Audio support
- Supports Surge Protection
- Nichicon Fine Gold Series Audio Caps
- 120dB SNR DAC with Differential Amplifier
- Pure Power-In
- Direct Drive Technology
- PCB Isolate Shielding
- Impedance Sensing on Line Out port
- Individual PCB Layers for R/L Audio Channel
- Gold Audio Jacks
- Supports Creative Sound Blaster™ Cinema 3[/td]
[/tr]
[tr]
	[td]LAN[/td]
	[td]- Gigabit LAN 10/100/1000 Mb/s
- GigaLAN Intel® I211AT
- Supports Wake-On-LAN
- Supports Lightning/ESD Protection
- Supports Energy Efficient Ethernet 802.3az
- Supports PXE[/td]
[/tr]
[tr]
	[td]Wireless LAN[/td]
	[td]- Intel® 802.11ac WiFi Module (Free Bundle)
- Supports IEEE 802.11a/b/g/n/ac
- Supports Dual-Band (2.4/5 GHz)
- Supports high speed wireless connections up to 433Mbps
- Supports Bluetooth 4.2 / 3.0 + High speed class II[/td]
[/tr]
[tr]
	[td]Slots[/td]
	[td]AMD Ryzen series CPUs
- 1 x PCI Express 3.0 x16 Slot (PCIE1: x16 mode)*
AMD 7th A-Series APUs
- 1 x PCI Express 3.0 x16 Slot (PCIE1: x8 mode)*
- 1 x Vertical M.2 Socket (Key E) with the bundled WiFi-802.11ac module (on the rear I/O)
*Supports NVMe SSD as boot disks[/td]
[/tr]
[tr]
	[td]Storage[/td]
	[td]- 4 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
- 1 x Ultra M.2 Socket, supports M Key type 2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
[/tr]
[tr]
	[td]Connector[/td]
	[td]- 1 x LPC Header
- 1 x AMD Fan LED Header
- 1 x CPU Fan Connector (4-pin)*
- 1 x Chassis Fan Connector (4-pin)
- 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)*
- 1 x 24 pin ATX Power Connector
- 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
- 1 x Front Panel Audio Connector
- 1 x AMD LED Fan USB Header
- 1 x USB 2.0 Header (Supports 2 USB 2.0 ports) (Supports ESD Protection)
- 1 x USB 3.0 Header (Supports 2 USB 3.0 ports) (Supports ESD Protection)
*The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
**The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
CHA_FAN1/W_PUMP can auto detect if 3-pin or 4-pin fan is in use.[/td]
[/tr]
[tr]
	[td]Rear Panel I/O[/td]
	[td]- 2 x Antenna Ports
- 1 x PS/2 Mouse/Keyboard Port
- 2 x HDMI Ports
- 1 x Optical SPDIF Out Port
- 2 x USB 2.0 Ports (Supports ESD Protection)*
- 1 x USB 3.0 Type-A Port (Supports ESD Protection)
- 1 x USB 3.0 Type-C Port (Supports ESD Protection)
- 2 x USB 3.0 Ports (Supports ESD Protection)
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)[/td]
[/tr]
[tr]
	[td]Software and UEFI[/td]
	[td]Software
- ASRock F-Stream
- ASRock RGB LED
- ASRock Key Master
- ASRock APP Charger
- ASRock XFast LAN*
UEFI
- ASRock Full HD UEFI
- ASRock Instant Flash
- ASRock Internet Flash
- ASRock Crashless BIOS
- ASRock Easy RAID Installer[/td]
[/tr]
[tr]
	[td]Support CD[/td]
	[td]- Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar[/td]
[/tr]
[tr]
	[td]Accessories[/td]
	[td]- Quick Installation Guide, Support CD, I/O Shield
- 2 x SATA Data Cables
- 2 x ASRock WiFi 2.4/5 GHz Antennas
- 1 x Screw for M.2 Socket[/td]
[/tr]
[tr]
	[td]Hardware Monitor[/td]
	[td]- Temperature Sensing: CPU, Chassis, Chassis Optional/Water Pump Fans
- Fan Tachometer: CPU, Chassis, Chassis Optional/Water Pump Fans
- Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, Chassis, Chassis Optional/Water Pump Fans
- Fan Multi-Speed Control: CPU, Chassis, Chassis Optional/Water Pump Fans
- Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore[/td]
[/tr]
[tr]
	[td]Form Factor[/td]
	[td]- Mini-ITX Form Factor: 6.7-in x 6.7-in, 17.0 cm x 17.0 cm
- 2oz Copper PCB[/td]
[/tr]
[tr]
	[td]OS[/td]
	[td]- Microsoft® Windows® 10 64-bit
* For the updated Windows® 10 driver, please visit ASRock's website for details: http://www.asrock.com
[/td]
[/tr]
[tr]
	[td]Certifications[/td]
	[td]- FCC, CE
- ErP/EuP ready (ErP/EuP ready power supply is required)[/td]
[/tr]
[/table]
X370 Gaming-ITX
Code:
[tr]
	[td]Power
Memory
VGA Card
Internet
- Intel® LAN
Cooling
- 2oz Copper PCB
Audio
[/tr]
[tr]
- Dual-N MOSFET
- Matte Black PCB
- 2oz Copper PCB
ASRock Steel Slots
[/tr]
[tr]
	[td]CPU[/td]
- Digi Power design
[/tr]
[tr]
	[td]Chipset[/td]
	[td]- AMD Promontory X370[/td]
[/tr]
[tr]
	[td]Memory[/td]
- AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory**
[/tr]
[tr]
	[td]BIOS[/td]
[/tr]
[tr]
	[td]Graphics[/td]
[/tr]
[tr]
	[td]Audio[/td]
- Pure Power-In
- Gold Audio Jacks
[/tr]
[tr]
	[td]LAN[/td]
- Supports PXE[/td]
[/tr]
[tr]
- Supports high speed wireless connections up to 867Mbps
- 2 antennas to support 2 (Transmit) x 2 (Receive) diversity technology
[/tr]
[tr]
	[td]Slots[/td]
[/tr]
[tr]
	[td]Storage[/td]
[/tr]
[tr]
	[td]Connector[/td]
- 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)**
[/tr]
[tr]
- 2 x HDMI Ports
[/tr]
[tr]
	[td]Software
- ASRock F-Stream
- ASRock RGB LED
- ASRock Key Master
- ASRock XFast LAN*
UEFI
[/tr]
[tr]
	[td]Support CD[/td]
[/tr]
[tr]
- 1 x ASRock WiFi 2.4/5 GHz Antenna
[/tr]
[tr]
[/tr]
[tr]
[/tr]
[tr]
	[td]OS[/td]
[/td]
[/tr]
[tr]
	[td]- FCC, CE
[/tr]
[/table]
Preisvergleich
AB350 Gaming-ITX/ac: ASRock Fatal1ty AB350 Gaming-ITX/ac Preisvergleich geizhals.eu EU
X370 Gaming-ITX/ac: ASRock Fatal1ty X370 Gaming-ITX/ac Preisvergleich geizhals.eu EU
Fragen und Antworten:
  • Was ist der Unterschied zwischen dem AB350 und X370?
    Da ein ITX Board nicht die kompletten Vorteile von X370 nützen kann, unterscheiden sich die beiden nur gering. Das X370 hat schnelleres WLAN und erlaubt PCIe Bifurcation
    edit 17.8.2017: Die beiden haben nun doch andere VRM Komponenten, wie br0da herausgefunden hat:
    FDPC5030 = AB350; SM7341EH = X370
    ASRocks X370 und B350 mini-ITX unterscheidet doch mehr, als der Kühlkörper (anfangs): VRM on the new AM4 motherboards - Page 251
    Die FETs im Vergleich:
    RDS(on) max​
    Rise + Fall Time
    FDPC5030Q1:
    5.0 mOhm @ VGS = 10 V @ ID = 17A
    6.5 mOhm @ VGS = 4.5V @ ID = 14 A
    Q2:
    2.4 mOhm @ VGS = 10V @ ID = 25 A
    3.0 mOhm @ VGS = 4.5V @ ID = 22 A
    Q1: 20ns
    Q2: 20ns
    SM7341EHQ1:
    3.9mOhm @ VGS = 10V @ ID = 24A
    6.5mOhm @ VGS = 4.5V @ ID = 24A
    Q2:
    1.2mOhm @ VGS =10V @ ID = 24A
    2mOhm @ VGS =4.5V @ ID = 24A
    Q1: 18.6ns
    Q2: 39ns
  • Wie unterschieden sich die VRM Kühler?
    alt: https://abload.de/img/img_15572ssdc.jpg
    neu: https://abload.de/img/fullsizerenderfaujg.jpg
  • Ich habe noch den alten VRM-Kühler, was kann ich tun?
    Schreibt den Asrock Support an! Der Support will danach noch eine Rechnung und die Seriennummer vom Board.
    ASRock > Support Request Form
  • Welchen RAM habt ihr getestet?
    Dazu habe ich ein 16GB Trident Z 3200MHz CL14 Kit. F4-3200C14D-16GTZ
    Mit den XMP Profil konnte ich den Ram nicht starten. Wenn ich jedoch die Spannung auf 1.4V erhöhe, die command rate auf 1T setze, Geardown Mode und BankGroupSwap deaktiviere, dann läuft er und es gab nach 2 Stunden Memtest64 keine Fehler.
    Als RAM habe ich Kingston KVR21E15D8K2/16I
    Corsair CMK16GX4M2A2400C14 funktioniert ebenfalls einwandfrei, ist direkt mit 2400Mhz gestartet.
    Aber ne kleine Info, ich habe diesen RAM hier beim Kollegen auf einen AB350 am Laufen:
    GWW416GB3000C15DC
    Dieser hat Samsung D-Die und ist Dualranked. Er läuft auf 3000Mhz mit 15-17-17-35 bei 1,35v, das läuft tadellos. Haben gestern was probiert und sind am Ende bei 1,35v auf 3200mhz bei 17-19-19-38 gekommen. Dualranked sollte er so schnell sein wie 3400-3500er Singlerank.
RAM Kompatibilität
Asrock gibt folgenden Arbeitsspeicher auf der Homepage an (Update 7.10.2017; 27 neue Einträge):
Code:
DDR4	3000	4GB	ADATA	KM4B4GX2A-3000-15-16-16-36-0			SS		2pcs	v
DDR4	2800	16GB	ADATA	AX4U2800316G16			SS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-SRD			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-QRD			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400316G16-BBF			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BRD			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-QWZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-QRZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-DWZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BRZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BBZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-BWZ			DS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-DRD			SS		2pcs
DDR4	2400	8GB	ADATA	AX4U2400W8G16-DRZ			DS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-DRZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-SBF			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BBF			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-QWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BBZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-BRZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-DWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-SWZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-QRZ			SS		2pcs
DDR4	2400	4GB	ADATA	AX4U2400W4G16-SRZ			SS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-QRZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-QWZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SRZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-BRZ	ADATA		DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-DWZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SBF			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SWZ			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-QRD			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-DRD			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-SRD			DS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-BWZ			SS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-BRD			SS		2pcs
DDR4	2400	16GB	ADATA	AX4U2400316G16-DRZ			DS		2pcs
DDR4	2133	8GB	ADATA	AD4E2133W8G15-BHYA (ECC)			SS		2pcs
DDR4	2400	8GB	Apacer	AU08GGB24CEYBGC			SS		2pcs
DDR4	2133	8GB	Apacer	78.C1GM3.AF10B	Hynix		DS		2pcs
DDR4	3000	8GB	Avexir	AVD4UZ130001608G-4BZ1RR			SS		2pcs	v
DDR4	2400	8GB	Avexir	AVD4UZ124001608G-1COR			SS		2pcs
DDR4	2400	4GB	Avexir	AVD4UZ124001604G-1COB			SS		2pcs
DDR4	3000	8GB	Corsair	CMD32GX4M4B3000C15 (Hynix-M)			SS		2pcs	v
DDR4	2800	8GB	Corsair	CMK32GX4M4A2800C16			DS		2pcs
DDR4	2800	8GB	Corsair	CMD32GX4M4A2800C16			DS		2pcs
DDR4	2800	4GB	Corsair	CMD16GX4M4A2800C16			SS		2pcs
DDR4	2666	8GB	Corsair	CMD32GX4M4A2666C15 ver4.23			DS		2pcs
DDR4	2666	8GB	Corsair	CMD32GX4M4A2666C16			DS		2pcs
DDR4	2666	8GB	Corsair	CMK32GX4M4A2666C16			DS		2pcs
DDR4	2666	8GB	Corsair	CMK32GX4M4A2666C16 ver 5.30			SS		2pcs
DDR4	2666	4GB	Corsair	CMD16GX4M4A2666C15			SS		2pcs
DDR4	2666	4GB	Corsair	CMK16GX4M4A2666C16			SS		2pcs
DDR4	2666	4GB	Corsair	CMD16GX4M4A2666C16			SS		2pcs
DDR4	2400	8GB	Corsair	CMK32GX4M2A2400C14			SS		2pcs
DDR4	2133	4GB	Corsair	CMV4GX4M1A2133C15			SS		2pcs
DDR4	2666	8GB	Crucial	BLT8G4D26AFTA.16FAD			SS		2pcs
DDR4	2666	4GB	Crucial	BLE4G4D26AFEA.8FAD			SS		2pcs
DDR4	2400	8GB	Crucial	CT8G4WFD824A.18FB1 (ECC)			SS		2pcs
DDR4	2133	8GB	Crucial	CT8G4DFS8213.8FB1			SS		2pcs
DDR4	2133	8GB	Crucial	CT8G4DFD8213.16FA2			SS		2pcs
DDR4	2133	8GB	Crucial	CT8G4DFD8213.C16FAD11			SS		2pcs
DDR4	2133	4GB	Crucial	CT4G4DFS8213.8FA1			SS		2pcs
DDR4	2133	16GB	Crucial	CT16G4DFD8213.16FB1			SS		2pcs
DDR4	3066	8GB	G.Skill	F4-4133C19D-16GTZKWC			SS		2pcs	v
DDR4	3066	8GB	G.Skill	F4-4000C18D-16GTZR			SS		2pcs	v
DDR4	3000	4GB	G.Skill	F4-3000C15Q-16GRR			SS		2pcs	v
DDR4	2933	8GB	G.Skill	F4-3200C16D-16GTZB			SS		2pcs	v
DDR4	2933	8GB	G.Skill	F4-4266C19D-16GTZR			SS		2pcs	v
DDR4	2933	8GB	G.Skill	F4-3466C16D-16GTZSK			SS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3333C16D-32GTZSK			DS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3200C14D-32GTZR			DS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3866C18D-32GTZR			DS		2pcs	v
DDR4	2933	16GB	G.Skill	F4-3200C15D-32GTZR			DS		2pcs	v
DDR4	2400	8GB	G.Skill	F4-2400C16D-16GFXR			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GFX			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GFXR			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GFT			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C16D-16GFX			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C15D-16GBTZR			SS		2pcs
DDR4	2400	8GB	G.Skill	F4-2400C16D-16GFT			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C15D-8GFT			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C16D-8GFT			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C16D-8GFXR			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C16D-8GFX			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C15D-8GFXR			SS		2pcs
DDR4	2400	4GB	G.Skill	F4-2400C15D-8GFX			SS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C16D-32GFXR			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C16D-32GFT			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C15D-32GFX			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C15D-32GFXR			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C16D-32GFX			DS		2pcs
DDR4	2400	16GB	G.Skill	F4-2400C15D-32GFT			DS		2pcs
DDR4	2133	8GB	G.Skill	F4-2133C15D-16GFT			SS		2pcs
DDR4	2133	8GB	G.Skill	F4-2133C15D-16GFXR			SS		2pcs
DDR4	2133	8GB	G.Skill	F4-2133C15D-16GFX			SS		2pcs
DDR4	2133	4GB	G.Skill	F4-2133C15D-8GFX			SS		2pcs
DDR4	2133	4GB	G.Skill	F4-2133C15D-8GFXR			SS		2pcs
DDR4	2133	4GB	G.Skill	F4-2133C15D-8GFT			SS		2pcs
DDR4	2133	16GB	G.Skill	F4-2133C15D-32GFX			DS		2pcs
DDR4	2133	16GB	G.Skill	F4-2133C15D-32GFT			DS		2pcs
DDR4	2133	16GB	G.Skill	F4-2133C15D-32GFXR			DS		2pcs
DDR4	2400	4GB	Geil	GWB48GB2400C14DC			SS		2pcs
DDR4	2133	8GB	Geil	GP48GB2133C15SC			SS		2pcs
DDR4	2666	8GB	HyperX	HX426C15FB/8			DS		2pcs
DDR4	2666	8GB	HyperX	HX426C13SB2K4/32			DS		2pcs
DDR4	2666	8GB	HyperX	HX426C13PB3/8	Hynix M-die		SS		2pcs
DDR4	2666	8GB	HyperX	HX426C13PB3K4/32	Hynix M-die		SS		2pcs
DDR4	2666	8GB	HyperX	HX426C13PB3K2/16	Hynix M-die		SS		2pcs
DDR4	2666	16GB	HyperX	HX426C13PB3/16	Hynix M-die		DS		2pcs
DDR4	2666	16GB	HyperX	HX426C13PB3K2/32	Hynix M-die		DS		2pcs
DDR4	2666	16GB	HyperX	HX426C13PB3K4/64	Hynix M-die		DS		2pcs
DDR4	2400	8GB	HyperX	HX424C15FB2K4/32			SS		2pcs
DDR4	2400	8GB	HyperX	HX424C12PB3K4/32	Hynix M-die		SS		2pcs
DDR4	2400	8GB	HyperX	HX424C12PB3K2/16	Hynix M-die		SS		2pcs
DDR4	2400	8GB	HyperX	HX424C12PB3/8	Hynix M-die		SS		2pcs
DDR4	2400	4GB	HyperX	HX424C15FBK4/16			SS		2pcs
DDR4	2400	16GB	HyperX	HX424C15FBK4/64			DS		2pcs
DDR4	2400	16GB	HyperX	HX424C12PB3K2/32	Hynix M-die		DS		2pcs
DDR4	2400	16GB	HyperX	HX424C12PB3/16	Hynix M-die		DS		2pcs
DDR4	2133	8GB	HyperX	HX421C14FB2K4/32			SS		2pcs
DDR4	2133	8GB	HyperX	HX421C14FB/8			DS		2pcs
DDR4	2400	8GB	J&A	JAD4U24001608-8M			SS		2pcs
DDR4	2400	4GB	J&A	JAD4U24001608-4M			SS		2pcs
DDR4	2133	4GB	J&A	JAD4U21331508-4M			SS		2pcs
DDR4	2666	8GB	Kingston	KVR26N19S8/8	Micron D-die		SS		2pcs
DDR4	2666	8GB	Kingston	KVR26N19S8/8	Micron H-die		SS		2pcs
DDR4	2666	16GB	Kingston	KVR26N19D8/16	Micron D-die		DS		2pcs
DDR4	2666	16GB	Kingston	KVR26N19D8/16	Micron H-die		DS		2pcs
DDR4	2400	8GB	Kingston	KVR24N17S8/8			SS		2pcs
DDR4	2400	8GB	Kingston	HX424C15FBK4/32			SS		2pcs
DDR4	2400	8GB	Kingston	HX424C15FB2/8			SS		2pcs
DDR4	2400	4GB	Kingston	KVR24N17S8/4	Micron		SS		2pcs
DDR4	2133	8GB	Kingston	KVR21N15S8/8			SS		2pcs
DDR4	2133	8GB	Kingston	KVR21N15D8/8			DS		2pcs
DDR4	2133	4GB	Kingston	KVR21N15S8/4			SS		2pcs
DDR4	2133	16GB	Kingston	KVR21N15D8/16			DS		2pcs
DDR4	3000	8GB	KLEVV	IM44GU88A30-FGGHMZ			SS		2pcs	v
DDR4	3000	8GB	KLEVV	IM44GU88A30-FGGHMB			SS		2pcs	v
DDR4	3000	4GB	KLEVV	IM44GU48A30-GIIHMC			SS		2pcs	v
DDR4	3000	4GB	KLEVV	KM4Z4GX1A-3000-15-16-16-36-1			SS		2pcs	v
DDR4	3000	4GB	KLEVV	KM4B4GX1A-3000-15-16-16-36-0			SS		2pcs	v
DDR4	3000	4GB	KLEVV	KM4Z4GX2A-3000-15-16-16-36-1			SS		2pcs	v
DDR4	2666	8GB	KLEVV	KM4Z8GX1N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	8GB	KLEVV	KM4Z8GX2N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	4GB	KLEVV	KM4Z4GX2N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	4GB	KLEVV	KM4Z4GX1N-2666-15-15-15-35-1			SS		2pcs
DDR4	2666	16GB	KLEVV	KM4Z16X1N-2666-15-15-15-35-0			DS		2pcs
DDR4	2666	16GB	KLEVV	KM4Z16X2N-2666-15-15-15-35-0			DS		2pcs
DDR4	2400	8GB	KLEVV	KM4Z8GX2N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	8GB	KLEVV	KM4Z8GX1N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	4GB	KLEVV	KM4Z4GX2N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	4GB	KLEVV	KM4Z4GX1N-2400-15-15-15-35-1			SS		2pcs
DDR4	2400	16GB	KLEVV	KM4Z16X2N-2400-15-15-15-35-0			DS		2pcs
DDR4	2400	16GB	KLEVV	KM4Z16X1N-2400-15-15-15-35-0			DS		2pcs
DDR4	2133	8GB	KLEVV	IMA41GU6MFR8N-TF1			SS		2pcs
DDR4	3000	8GB	Neo Forza	NFMUD480E8-3000DH2A			SS		2pcs
DDR4	2800	4GB	Panram	PUD42800C164G4NJW			SS		2pcs
DDR4	2666	8GB	Panram	W4U2666PS-8G			SS		2pcs
DDR4	2666	16GB	Panram	W4U2666PS-16G			DS		2pcs
DDR4	2400	8GB	Panram	PUD42400C158G4NJW			DS		2pcs
DDR4	2400	8GB	Panram	W4U2400PS-8G			SS		2pcs
DDR4	2133	8GB	Panram	W4U2133PS-8G			SS		2pcs
DDR4	3333	8GB	Patriot	PV416G340C6K (11BF2)			SS		2pcs	v
DDR4	3333	4GB	Patriot	PV48G340C6K (11E2)			SS		2pcs	v
DDR4	3333	4GB	Patriot	PV48G360C7K (11E1)			SS		2pcs	v
DDR4	3200	8GB	Patriot	PV416G360C7K (11BF1)			SS		2pcs	v
DDR4	3200	8GB	Patriot	PV416G320C6K (11BF2)			SS		2pcs	v
DDR4	3200	4GB	Patriot	PV48G320C6K (11EC2)			SS		2pcs	v
DDR4	3200	4GB	Patriot	PV48G320C6K (11D1)	Samsung 11D1		SS		2pcs	v
DDR4	3000	4GB	Patriot	PV48G300C6K (14M1)			SS		2pcs	v
DDR4	2933	8GB	Patriot	PV416G300C6K (11BF2)			SS		2pcs	v
DDR4	2933	4GB	Patriot	PV48G300C6K (11EC2)			SS		2pcs	v
DDR4	2400	8GB	Patriot	PSD48G240081			SS		2pcs
DDR4	2400	8GB	Patriot	PVE416G240C5KRD (11BF2)			SS		2pcs
DDR4	2400	4GB	Patriot	PSD44G240081			SS		2pcs
DDR4	2400	4GB	Patriot	PVE48G240C5KRD (11EC2)			SS		2pcs
DDR4	2400	16GB	Patriot	PSD416G24002			DS		2pcs
DDR4	2133	8GB	Patriot	PSD48G21332			SS		2pcs
DDR4	2133	4GB	Patriot	PSD44G213381			SS		2pcs
DDR4	2400	4GB	Samsung	M378A5244CB0-CRC			SS		2pcs
DDR4	2133	8GB	Samsung	M378A5143DB0-CPB			SS		2pcs
DDR4	2133	8GB	Samsung	M391A1G43EB1-CPBQ (ECC)			SS		2pcs
DDR4	2133	4GB	Samsung	M378A5143EB1-CPB			SS		2pcs
DDR4	2133	4GB	Samsung	M378A1G43DB0-CPB			SS		2pcs
DDR4	2133	8GB	Silicon Power	SP008GBLFU213N01			SS		2pcs
DDR4	2666	8GB	Team	TFWD48G2666C15BBK			SS		2pcs
DDR4	2400	8GB	Team	TED48G2400C16BK			SS		2pcs
DDR4	2400	4GB	Team	TED44G2400C16BK			SS		2pcs
DDR4	2133	8GB	Transcend	TS1GLH64V1H			DS		2pcs
DDR4	2400	8GB	UMAX	84G48GA3SP-24MSPGNGFY7B			SS		2pcs
DDR4	2400	8GB	UMAX	84G48GA3CP-241MCALGFY7J1			SS		2pcs
DDR4	2400	16GB	UMAX	84G416A3CP-241MCGNGFY7B			DS		2pcs
DDR4	2400	16GB	UMAX	84G416A3CP-241MCGNGFY7J1			DS		2pcs
DDR4	2133	8GB	UMAX	RMUM8GD42131024			SS		2pcs
DDR4	2133	8GB	UMAX	RMUM8GD42133512			SS		2pcs
DDR4	2133	4GB	UMAX	RMUM4GD421333512			SS		2pcs
DDR4	2133	4GB	UMAX	RMUM4GD42133512			SS		2pcs
DDR4	2400	8GB	V-Color	TD8G16C17-UH			DS		2pcs
DDR4	2400	8GB	V-Color	TC48G24S817			SS		2pcs
DDR4	2133	8GB	V-Color	TC48G21S815-iMS			SS		2pcs
DDR4	2133	8GB	V-Color	TD8G8C15-093E			SS		2pcs
Berichte & Reviews
https://smallformfactor.net/reviews/motherboards/fatal1ty-asrocks-x370-ab350-gaming-itxac-motherboards-reviewed
deutsches Video-Review: ASRock Fatal1ty AB350 Gaming-ITX/ac - Quick Review - YouTube
16.03.2018 - Aktuell gibt es einen Bug mit den Raven Ridge CPUs die bei WLAN Nutzung zur Instabilität führen. Dazu solltet ihr mal einen Blick in die Beta BIOS werfen. (4.51A)
Links zu den neusten BIOS Versionen findet ihr hier:
AB350: ASRock > Fatal1ty AB350 Gaming-ITX/ac
X370: ASRock > Fatal1ty X370 Gaming-ITX/ac
Wer noch eine ältere Version nutzt und auf 4.0 oder höher möchte, bitte das Bridge BIOS nicht vergessen.
Wisst ihr was man gegen Cold Boot Probleme machen kann?
Der 3200er RAM macht scheinbar Probleme... nach jedem Start resettet er sich.
Keine probleme selbst 3600er Ram läuft mit XMP, ansonsten das Übliche vorgehen, wichtig ist den ram mal mit 50-60Ohm zu testen, in dem bereich laufen viele Riegel optimal.
Mein 3200er-Kit läuft in dem Board nur mit 1,4v stabil.
Ansonsten das Übliche: SOC-Voltage erhöhen und Timings lockern.
Ich habe 3600er GSkill Ripjaws mit Samsung bdie, die laufen XMP 3600Mhz Stable bei 1,35V und stock SOC, aber nur wenn man den wiederstand auf 53,3ohm setzt.
Timings runter ist ganz schlecht. Ryzen profitiert enorm von Timings, 3333er mit 14er Timings ist schneller als 3600er mit CL17.
Benutzt doch mal bitte alle den Ryzen DRAM CALCULATOR, das ding funktioniert schon fast zu perferkt.
@Pirate85:
Danke!
Habe das "AM4 Advanced Boot Training" ausgeschaltet & seitdem bootet er sauber :)
@xXx-Eagleone-xXx
Wo findet man die Widerstand Einstellungen?
Wenn es darum geht, den RAM zunächst mal stabil zum laufen zu bringen, sind Spannung und Timings eigentlich immer die erste Wahl.
Die Widerstände sind aber in der Tat auch extrem wichtig. Auch Command Rate (2T) und Gear Down Mode (Enabled) bringen Stabilität.
Ich nutze den DRAM Calculator und habe ebenfalls B-Dies. Es ist jedoch ein großer Unterschied, ob man 2x8GB oder 2x16GB (wie in meinem Fall) verbaut hat.
Mein RAM läuft nur mit 1,4v stabil auf 3200MHz, dann aber immerhin mit 14-13-13-26-42-1T (DRAM Calc: "Fast").
Genau genommen kann ich einen Tradeoff zwischen +70mv SOC-Voltage und +50mv DRAM-Voltage beobachten.
Der Speicher verkraftet das mit hoher Wahrscheinlichkeit, bei der CPU bin ich mir da nicht so sicher.
(Robert Hallock/AMD empfiehlt max. 1,1v SOC-Voltage für den täglichen Gebrauch.)
Einfach ein XMP laden hat für mich (mit dem AB350) noch nie funktioniert (booten ja, stable nein).
Er meint ProcODT (Processor On-Die Termination). Du findest die Option entweder unter "DRAM Timing Configuration" (Asrock-Mode) oder unter AMD CBS > UMC Common Options.
53 Ohm führen bei mir sofort zum BSOD, ich nutze 60 Ohm. Du solltest auch die RTT-Werte anpassen, wenn du ProcODT veränderst (ProcODT max. 80 Ohm!).
ich hab mir auch das Asrock AB350 Gaming-ITX/ac gegönnt.
Leider habe ich das Problem, dass meine sata m.2-SSD bei AHCI nicht erkannt wird,also einfach nicht auftaucht , weder im Bios noch als Boot device.
Wenn ich von AHCI auf RAID wechsele wird die SSD zwar erkannt aber beim booten hänge ich im loop mit "unaccessable boot device" fest.
Rest des Systems ist ein Athlon 950 und Gskill F4-3200C16D-16GTZ, übergangsweise eine alte AMD 6950 und eben die Kingston M.2 SATA G2 120GB.
Hat jemand nen Ratschlag was ich machen kann?
Hab das Board mit Bios 3.10 bekommen.
Da hat das Booten in Windows funktioniert.
Unter 3.60 hats auch noch geklappt.
Mit 4.40 komme ich nur noch in den Boot loop und die SSD wird nicht mehr erkannt.
Im UEFI im Reiter Boot: testweise FastBoot deaktivieren. Weiter unten das CSM deaktivieren. In den BootOptionPriorities die anderen SSD deaktivieren und bei Nummer 1 die M2.SSD eintragen.
Die M.2 SSD sitzt richtig/Schraube ist nicht zu fest?
Das einzige angeschlossene Laufwerk ist die m.2-ssd.
Davon hab ich ja mit allem bis 4.40 problemlos booten können, daher geh ich mal davon aus, dass die richtig verbaut ist:)
Das andere teste ich gleich mal.
Danke.
Habe heute mein Board geflasht und konnte das System erfolgreich mit einem 2200G starten. :) Mein PC-Händler hat mir für den Flashvorgang eine neue original eingeschweißte ältere APU geliehen. Top der Mann! Das gibt ordentlich etwas in die Kaffeekasse.
Nun habe ich jedoch das Problem das mein Windows-System immer nach ein paar Minuten einfriert und ich nur einen blauen Screen ohne Text sehe. Nur noch ein Neustart hilft. Jemand eine Idee? Werde den PC wohl am Montag ansonsten mal zur Fehlersuche weggeben müssen.
In welcher Reihenfolge hast du die Treiber installiert?
Hab bereits gelesen, dass man möglichst zuerst den Chipset Treiber (Chipset
) & danach erst den Raven Ridge Treiber installieren soll (Support page | AMD)
So hab ich das auch mit meinem 2400G gemacht und es funktionierte auf Anhieb. Bluescreens kommen ganz selten mal vor, wenn man die Vega Grafikkarte übertaktet und bestimmte Spiele versucht damit zu starten. Ansonsten rennt es sauber. Probier einfach nochmal eine cleane Windows-Installation, bevor du den PC abgibst.
Habe dieses All-In Paket mit VGA-Treiber von der AsRock Homepage genommen und installiert.
Ich hoffe das Video hilft
Ziemlich wahrscheinlich ist das All-In Paket noch nicht auf Raven Ridge angepasst.
In China/Asien ist gerade Neujahrsfest und das wird noch etwas dauern, bis Asrock ein neues AIO Paket veröffentlicht.
Deshalb rate ich dir derzeit eindeutig zu den Treibern von der AMD Seite :)
edit: es steht sogar da, dass es am 24.1 veröffentlicht wurde. Der erste Raven Ridge Treiber kam erst am 12. Februar.
Vielen Dank euch beiden für die Hilfe!
Da nehme ich schon vorbildlich die Treiber von der Homepage und dann so etwas. :d Eine Windows-Neuinstallation ist wahrscheinlich nun am Besten, weil der PC ja immer einfriert oder was meint ihr? Würde eventuell auch diese Reparatur-Option im Setup ausreichen?
@matrickz
Die von dir verlinkten Treiber sind die passenden, welche ich benutzen kann? :)
Ja, es gibt derzeit tatsächlich erst einen Raven Ridge Treiber. Muss also passen :)
Den AM4 Chipset Treiber hab ich dir auch verlinkt.
Eine Neuinstallation muss nicht unbedingt nötig sein, wäre aber am sichersten.
Du kannst mit DDU deine alten Videotreiber löschen & schauen ob die Freezes weg gehen. Die Frage ist halt, was alles von dem All-in-One noch über bleibt. Ich persönlich würd da einfach neu installieren.
Dankeschön für die Infos!
Baue PCs schon seit Jahren selber zusammen aber Raven Ridge treibt es echt auf die spitze. :d Habe extra die Treiber von der Homepage genommen (normal lade ich mir immer die neusten Treiber runter) das die älteren Herrschaften keine Probleme haben und dann ist genau das Gegenteil eingetreten.
Werde dann eine Neuinstallation vornehmen. Die Reparaturfunktion während der Win10 Installation kann ich nicht verwenden?
Installier aber direkt gleich die neuste Windows 10 Version wie der Typ in dem Video gesagt hat. Updaten von einer älteren Version wie zB 1703 soll ja auch Probleme machen.
Hatte ich gelesen. Habe extra vor ein paar Tagen erst einen USB-Stick mit dem neusten Windows (per Media Creation Tool) selbst erstellt.
Hallo zusammen,
ich habe Probleme mit dem AB350 und einem Ryzen 1700 und wollte mal fragen ob diese auch jemand hat.
Folgendes System:
Processor: AMD Ryzen 7 1700
Motherboard Model: ASRock AB350 Gaming-ITX/ac
RAM:2x G.Skill DIMM 8GB DDR4-2400 (F4-2400C15-8GNT)
Video Card: ASUS ROG STRIX RX 470 4G GAMING OC
PSU: Corsair SF450
CPU Cooler: Noctua NH-L9x65 SE-AM4
Gehäuse: Silverstone Sugo SG05
SSD: SanDisk Extreme Pro 480GB (SDSSDXPS480G)
Betriebssystem: Microsoft Windows 10 Professional (x64) Build 16299.248 (1709/RS3)
GPU, SSD sind aus einem altem System und haben dort Einwandfrei funktioniert. Die Restlichen Komponenten sind von Sommer/Herbst letzten Jahres.
Folgendes Verhalten: Wenn ich alles in den Default Einstellungen (Bios sowie in allen Treiber) laufen lasse und GPU und CPU gleichzeitig belaste (bspw. Prime + Furmark, Unigine Benchmark, Spiele, etc.) Stürzt der PC nach einigen Sekunden/Minuten hart ab. Das heißt er geht komplett aus, als ob man den Stromstecker ziehen würde.
Belaste ich bspw. nur die CPU (Prime95, Handbrake, Cinebench, etc.) läuft der PC Problemlos (getestet über ca. 15h) durch. Belaste ich die Grafikkarte alleine (Furmark) läuft auch so der PC Störungsfrei durch (getestet über 5h+).
In den Monaten habe ich mehrere Sachen ausprobiert die ich mal versuche alle aufzulisten:
GPU Takt von 1.250MHz auf 1.100/1.000MHz gesenkt
Zuerst war mein Verdacht das die GPU beim Systemwechsel was abbekommen hat. Also mal GPU Takt (über Radeon Treiber) runtergenommen. Daraufhin läuft der Rechner auch mal 4h bei gleichzeitiger CPU+GPU Belastung. Doch manchmal stürzt er trotzdem hart ab.
PSU gewechselt
Vorher war noch das Original Netzteil von Silverstone (350Watt Version) im PC verbaut. Ich dachte das bei diesem vl. eine Spannung einbricht und habe dieses daher gegen ein Corsair SF450 getauscht. Tests nochmal mitStandardeinstellungen (CPU+GPU) durchgeführt und wieder abstürze nach ein paar Sekunden/Minuten. Nach heruntertakten der GPU läuft er länger, es kommt aber trotzdem zu sporadischen Abstürzen.
RAM getestett
Daraufhin habe ich einmal über Nacht Memtest und einmal den Windows Speichertest durchlaufen lassen. Beides zeigte keine Fehler.
Daraufhin mal die beiden Riegel einzeln in jedem der beiden Steckplätze probiert. Bei Defaulteinstellungen (GPU+CPU) stürzt das System wieder nach ein paar Sekunden/Minuten ab. Nach heruntertakten der GPU läuft er länger, es kommt aber trotzdem zu sporadischen Abstürzen.
RAM auf 2133MHz
Testweise RAM auf 2133MHz gestellt. CPU und GPU in Defaulteinstellungen. Pc stürzt nach paar Sekunden/Minuten hart ab.
Verdacht das Grafikkarte Defekt
Also dachte ich die Grafikkarte ist defekt. Also einmal zum Händler mit Vor-Ort-Reparatur gegangen und dort die Grafikkarte in einem Testsystem laufen lassen. Grafikkarte läuft in Defaulteinstellungen in Furmark und Unigine ohne Probleme durch. Also höchstwahrscheinlich doch nicht defekt. Diese lief ja auch im alten PC Einwandfrei.
Mainboard getauscht
Verdacht das vl. die Spannungsversorgung der CPU auf dem Board instabil/Defekt ist. Also einmal Motherboard getauscht. Bei Defaulteinstellungen (GPU+CPU) stürzt das System wieder nach ein paar Sekunden/Minuten ab. Nach heruntertakten der GPU läuft er länger, es kommt aber trotzdem zu sporadischen Abstürzen.
Deaktivieren AMD Turbo Core Technology
Viel bleibt jetzt nicht mehr übrig. Also Verdacht das die CPU vl. mal auf 3,7GHz hochtaktet (Boost) und das in Verbindung mit der Grafikkarte das System in den Tod reist. Daraufhin AMD Turbo Core Technologie im Bios abgeschaltet. GPU auf Standardeisntellungen. System stürzt wieder nach ein paar Sekunden/Minuten ab.
CPU heruntertakten/Undervolten
Als Versuch mal den VCore Offset auf -100mV gestellt und GPU in Defaulteinstellungen laufen lassen. CPU Frequenz auf Maximal 3GHz beschränkt und System läuft etwas länger durch. Stürzt aber trotzdem sporadisch ab.
Daraufhin hab ich den VCore weiter abgesenkt so das er am Ende bei 1,008V laut CPU-Z liegt. GPU in Defaulteinstellungen. System läuft länger, stürzt aber trotzdem sporadisch ab.
CPU Undervolten und GPU undervolten
CPU Takt bei 3GHz und GPU Takt auf Standard, aber beide Undervolten. CPU bei 1,008V (hab verschiedene Spannungen zwischen 1,008V und 1,2V probiert) und GPU bei 1,050V. System läuft stabiler aber stürzt trotzdem ab. Manchmal auch schon ein paar Sekunden nach dem ich ein Spiel gestartet habe.
Temperaturprobleme bei CPU und GPU kann ich soweit ausschließen. Die GPU kommt mit Undervolting nicht über 65°C (Furmark mehrere Stunden) und die CPU Hört bei ~60°C auf (mehrere Stunden Prime95). Auch stürzt er in Defaulteinstellungen ja manchmal nach nichtmal 5 Sekunden ab. Da haben die Temperaturen noch kaum die 60°C überschritten (über HWInfo überprüft).
Am stabilsten war das System als ich die GPU auf 1GHz und 1,050V festgesetzt habe. Da konnte ich auch mal 2-3 Wochen am Stück normal Arbeiten. Zu abstürzen kam es dann aber trotzdem.
Was mir auffällt ist das bei gleichzeitiger Belastung der CPU und GPU ich ein sehr lautes Spulenfiepen aus dem PC vernehme. Ich kann aber nicht unterscheiden ob es vom Netzteil oder von der Grafikkarte kommt.
Was ich mich jetzt frage ob vl. das Board an irgendeiner Stelle wegen Überlast abschaltet. Ansonsten bleibt mein letzter Verdacht das die CPU kaputt ist oder doch das Netzteil zu schwach. Aber dass das Netzteil zu schwach ist glaube ich fast nicht.
Die Komponenten sind jetzt nicht unbedingt sooo die Stromverschweder, aber teste mal, wenns geht, ein stärkeres Netzteil.
Klingt für mich irgendwie nach Netzteil oder Stromversorgung.
Und schau dir mal den Netzteilstecker sowie die Buchsen auf dem Mainboard genau an.
Hatte mal was vergleichbares - da war mri irgendwas zwischen einen der Nezteilpins und die Mainbaordbuchse gefallen.
Hat zu genau solchen Abstürzen unter Volllast geführt.
Auch wenns bei allem was du schon hin und her gewechselt hast unwahrscheinlich ist...
Kannst du dir mal eine deutlich sparsamere Grafikkarte ausleihen und damit testen?
Ich werde mal schauen ob sich da etwas finden lässt. Aber befürchte ebenso dass sich da nichts finden wird.
So direkt habe ich leider keinen Zugang. Aber für den Netzteiltest bringe ich es in ein Fachgeschäft zum einmaligen Test bevor ich umsonst ein neues Netzteil kaufe. Da kann man vl. auch eine schwächere Grafikkarte einbauen.
Mach mal HW Info auf nebenbei und beobachte genau die 12V spannung unter last! Wenn die vom absturz einknickt, weist du bescheid, ansonsten alles ausbauen und nochmal sorgfältig einbauen, try und error methode.
Das könnte in die Richtung meiner geschilderten Probleme (post#1074) gehen.
Ich habe per DDU die AMD-Treiber im abgesicherten Modus komplett deinstalliert und dann die aktuellen neu drauf gezogen.
Seitdem ist das Spulenfiepen weg, das System hängt sich nicht mehr komplett auf, nur der Grafikkartentreiber hängt manchmal, wenn ich den Rechner aus dem StandBy aufwecke.
Auch der AppShop funktioniert wieder.
...ach ja, Virenscanner hatte ich vor diesen Schritten deinstalliert...hatte den Verdacht, daß Avira evtl. die Treiberinstallation behindert.
Hallo allerseits!
Ich bin gerade dabei mir ein System mit Ryzen 2400G zusammenzustellen und irgendwie scheint das ASRock B350 ITX das einzige board zu sein, welches in Frage kommt. Alternativ habe ich das MSI im Auge gehabt aber scheibar ist das zum OCen nicht optimal?
Meine Konfiguration scheitert aber permanent am RAM, in der QVL Liste von ASRock stehen, eh klar, nur die hoffnungslos überteuerten Module drinnen aber es kann ja nicht sein, dass die gleichen Samsung Chips in den FlareX funktioniern und z.B. in den Ripjaws nicht?! Außerdem scheint diese Liste von ASRock nicht wirklich aktualisiert zu werden oder wird der Support mit den neuen BIOS Versionen nicht verbessert? Viele der Riegel in der Liste schaffen angeblich keine 3200 (selbst welche die deutlich höher eingestuft sind) ?!
Ich würde jetzt mal gern ein paar Erfahrungen hören, welche Riegel funktionieren denn nun wirklich mit 3200 außer den FlareX? Von den Specs her gibt es ja ettliche andere Module die gleich sind > F4-3200C14D-16GVK z.B. aber auch aus der TridentZ Reihe sowie diverse Module anderer Hersteller!? Ich seh nicht ein warum ich für einen blöden Aufkleber auf den FlareX 30 € mehr zahlen soll zumal die ohnehin schon sau teuer sind...
Bitte mal um eure Meinung bzw. Erfahrungen!? Btw. den DDR4 Thread hab ich gelesen bzw. die Liste durchforstet und dabei sind mir eben einige aufgefallen die eben auch passen und funktionieren SOLLTEN!?
LG
Samsung B-Dies laufen mit hoher Wahrscheinlichkeit mit 3200 MHz (und mehr). Dank der Microcode-Updates (neue BIOS-Versionen) hat sich aber auch die Kompatibilität anderer Chips deutlich verbessert.
Eine Garantie, dass ein bestimmtes Kit läuft, gibt es leider nicht.
Nicht jedes Produkt einer Serie wie Trident Z besitzt die gleichen Chips. Hier findest du mehr Informationen: https://www.reddit.com/r/Amd/comments/62vp2g/clearing_up_any_samsung_bdie_confusion_eg_on/
Hi
danke für die Info, also ist die Liste auf der ASRock Seite sicher auch nicht ganz aktuell wie vermutet.
Viel wichtiger ist mir dann aber, dass ich mit meiner Annahme, dass die Chips und Timings der Module ausschlaggebend sind, richtig liege. Sprich Samsung Chips mit 14er Timings sollten auf jeden Fall laufen, egal von welchem Hersteller!?
Die Liste habe ich mir ja angesehen, bzw. die hier im Forum und dort habe ich eben die besagten Ripjaws rausgepickt. Diese sollten exklusiv mit b-dies bestückt sein und entsprechen von den specs her exakt den FlareX nur sind sie bei uns immerhin um 20 € günstiger als die FlareX.
Ich würd natürlich lieber welche um 190€ kaufen aber da seh ich derzeit keine Chance stabil und sicher 3200 zu fahren und ich will wirklich schnellen RAM weil ich den Rechner auch zum zocken haben will.
LG
Die Liste wurde schon länger nicht aktualisiert. Wird sie vlt. auch nie wieder :).
Da liegst du richtig, die Chips sind ausschlaggebend. Etwas besseres als B-Dies kannst du momentan für Ryzen nicht erwerben.
Die Timings sind in dem Sinne nicht wichtig (für die Kompatibilität), allerdings sind CL14-Module häufig mit B-Dies bestückt (etwa bei allen Trident Z). Das hat dann auch seinen Preis.
Die Ripjaws (F4-3200C14D-16GVK) sollten laufen.
Ich habe noch nen Satz 16Gb Trident Z 4000er mit B-Dies rumfliegen falls einer braucht. Farbe: Weiß :wink:
Die Treiber habe ich schon einmal neu Installiert. Leider hat dies keine Verbesserung gebracht. Ich habe mal ein bischen mit AIDA64 Stresstest herumgespielt mit folgendem Ergebnis:
Bei "Stress CPU/FPU/Cache" ist es egal ob ich diese einzeln oder in irgendeiner Kombination miteinander ausführe. Das System bleibt stabil und stürzt nicht ab.
Kombiniere ich "Stress CPU/FPU/Cache" und "Stress GPU" miteinander kam innerhalb von 15 Minuten auch kein absturz. Länger habe ich es erstmal nicht laufen lassen.
Einmal habe ich "Stress CPU/FPU/Cache" und "Stress Memory" parallel laufen lassen. Dann (nach etwa 50 Sekunden) habe ich den Radeon Treiber aufgemacht um etwas nachzuschauen und das System ist abgestürzt. Also dachte ich das es vieleicht an der Kombination CPU+RAM liegt.
Daraufhin habe ich diese Kombination nochmal laufen lassen. Es gab aber diesmal über 10 Minuten keinen Fehler.
kann mir vielleicht jemand sagen wo und ob ich dieses Mainboard in Deutschland mit dem Sticker käuflich erwerben kann?
Ich finde es einfach nur unmöglich 13,90 € für eine BIOS Aktualisierung zahlen zu müssen (wobei die Wahrscheinlichkeit dass ich einen Rückläufer bekommen könnte gegeben ist)
