[Sammelthread] Asrock AOD790GX/128M (AMD 790GX)
ASRock AOD790GX/128M, 790GX
1. Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
2. Supports CPU up to 140W
3. ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
4. AMD 790GX + SB750 Chipsets
5. AM3 CPU Ready!
* FSB 2600 MHz (5.2 GT/s)
* Supports AMD OverDrive™ with ACC feature (Advanced Clock Calibration)
* Supports Hyper-Transport 3.0 (HT 3.0) Technology
* Supports Dual Channel DDR2 1066 with AM2+ CPU , and DDR2 800/667/533 with AM2 CPU, with 4 DIMM slots, maximum capacity up to 16GB
* Integrated AMD Radeon HD 3300 graphics, DX10 class iGPU, Pixel Shader 4.0, Max. shared memory 512MB
* Integrated 128MB side port memory for iGPU
* Supports ATI™ CrossFire™ and Hybrid CrossFireX™
* 2 x PCI Express 2.0 x16 slots (green @ x16 mode, blue @ x8 mode)
* 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 5, RAID 10 and JBOD), NCQ, AHCI and Hot Plug functions
* 1 x eSATAII 3.0 Gb/s connector
* 2 x IEEE1394 ports (one port on back panel, one header on board)
* PCIE Gigabit LAN 10/100/1000 Mb/s
* Three VGA Output options: D-Sub, DVI-D and HDMI with DVI-to-HDMI Converter
* Supports HDCP function
* Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
* 1 x USB/WiFi header
* Supports Smart BIOS, ASRock OC Tuner, Intelligent Energy Saver, Extra ESD Protection
* Free Bundle: 1 x ASRock XFire Switch Card, 1 x DVI-to-HDMI Converter
* 7.1 CH Windows® Vista™ Premium Level HD Audio, DAC with 110dB dynamic range (ALC890 Audio Codec)
* Windows® Vista™ Premium 2008 Logo Ready
* I/O Panel: 1 x VGA/D-Sub Port, 1 x VGA/DVI-D Port, 1 x eSATAII Port, 1 x IEEE 1394 Port, 1 x RJ-45 LAN Port with LED, 6 x USB 2.0 Ports
2. FAQ - Frequently Asked Questions
- "Lassen sich 3 Pin Lüfter steuern?"
Nein das geht nicht.
- "Ist der Sideportspeicher alleine nutzbar?."
Jawohl das ist möglich.
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
http://www.asrock.com/mb/download.asp?Model=AOD790GX/128M&s=AM2+
3.2 Reviews
http://www.pctreiber.net/thread.php?threadid=10224
http://www.cpu3d.com/review/5844-1/asrock-aod790gx-128m-motherboard/introduction.html
http://www.thinkcomputers.org/index.php?x=reviews&id=850
http://my.ocworkbench.com/2008/asrock/AOD790GX-128M/g1.htm
http://www.amdzone.com/index.php/reviews/66/10542-asrock-aod790gx128mb
3.3 Interessantes:
- Sideportspeicher ist alleine nutzbar
- Asrock OC Tuner unter Windows zum Übertakten
- Stromsparender als der Vorgänger 780G
- DVI auf HDMI Adapter im Lieferumfang enthalten
3.4. Overclocking
4. Preise
http://preisvergleich.hardwareluxx.de/deutschland/a365733.html
http://www.hardwareschotte.de/hardware/preise/proid_9775432/preis_ASROCK+AOD790GX128M
http://www.preistrend.de/suchen.php?q=AOD790GX&s=0&a=&z=&x=0&y=0
http://www.google.de/products?q=ASRock+AOD790GX&hl=de&scoring=p
5. Bekannte Probleme:
unter XP ist die 2D Performance bei allen 7er Chipsätzen nicht sehr hoch. Den Treiber aktualisieren bringt etwas. Ganz schlimm ist es mit Treibern unter dem 8.12er!
6. Fixes:
Lüfteregelung mit Speedfan:
http://www.hardwareluxx.de/community/showpost.php?p=13259216&postcount=587
7. Bios:
1.70er Version ist aktuell, doch gibt es hier Probleme mit der Core-Freischaltung
kannst du mir mal deine Bios Einstellungen sagen.Vielleicht habe ich nach dem reset nur irgend eine Einstellung vergessen.Habe zwar schon alles durch probiert aber man weis ja nie.
Auch wenn das Problem geklärt ist will ich ein wenig Wissen verbreiten: Schuld daran war die Option "SurroundView".
Das ist ne Funktion von ATi/AMD um eine externe GraKa mit der OnBoard-Grafik zusammen nutzen zu können und so mehr Monitorausgänge bereitstellen zu können. Sprich die HD4670 und die HD3300 können nebeneinander existieren :)
Schaltest du die Option ab, dann wird die OnBoard-Grafik beim einstecken einer GraKa abgeschaltet ;)
@Hurzpfurz Wenn's mir Recht ist, nur 1920x1080. Aber des sollte eh in der Boardbeschreibung stehen, bzw. den Spezifikationen.
Es könnte die Möglichkeit bestehen, dass es aber geht, wenn z.Bsp. die anderen Ausgänge deaktiviert sind. Will aber nichts behaupten.
Wo habt ihr euer AOD790GX gekauft und welche BIOS Version hatte es?
Wenn das Board mit BIOS Version 1.0 geliefert wird, muss man dann einen anderen CPU zum flashen der BIOS nehmen?
Und auch meine zweite Beschwerde des Boards möchte ich klären. Besteht das Problem des Nichterkennens der Festplatte, mit Tools wie Speedfan, Everest und ähnlichen Programmen, weiter?
In welchem Modus laufen deine Festplatten? RAID, AHCI oder IDE? Bei RAID und AHCI ist es vollkommen normal, dass diese nicht erkannt werden und bei jedem Chipsatz und jedem Mainboard gleich.
Nur im IDE-Modus können die Programme die Festplatten erkennen...
EDIT: Hab meins von Mindfactory.de und das hatte das aktuelle 1.40er drauf...
Alles klar, Danke!
Mit BIOS Version 1.4 sollte der Phenom II 940 BE ja wenigstens von Anfang an laufen oder?
@g33ko Nö, das ist nicht normal! Ich habe ja noch das ASUS P5B mit INTEL Chipsatz und im AHCI Modus werden alle Festplatten von Everest und Konsorten erkannt! Beim AOD790GX mit AHCI wie beschrieben nicht.
@arkos In der Beschreibung steht nur etwas von DVI-D...
@techtekk
ab bios version 1,3 wert Phonem II 940 BE erkant.
und ja da runter muss eventuell mit ein anderem cpu bios geuppt werden
Bei meinen Intel-Chipsätzen (der letzte war ein 945er) wurde das nie im AHCI Modus angezeigt.
Ist definitiv ne Chipsatz-/Treibersache ;)
Wenn ich es dir doch sage, es wird im AHCI Modus angezeigt.
Ich habe AHCI im BIOS eingeschaltet und Everest bzw. Speedfan erkennen meine Platten!
Ja, das sagte ich doch -.-
Das wird ne Treibersache sein, Standard ist es jedenfalls nicht so! Dein P5B bzw. der passende Chipsatz wird eher Ausnahme sein als Regel.
Ich kenne es von AMD, NVidia und den alten Intels so, dass es nicht anzeigbar ist und die Platten nicht gefunden werden...
Ne Frage. Der eSATA... muss der mit nem SATA Kabel überbrückt weerden? Oder ist des wie bei anderen Boards dort abzweigbar, wenn man den eSATA nicht braucht. ...
Kann eigentlich selber nachschauen. Wenn auf dem Board ne grade Anzahl von SATA Ports sind, dann muss er überbrückt werden.
Shiii... der muss tatsächlich überbrückt werden. Jetzt verwundert's mich gar nicht mehr, hat irgendwo mal einer gesagt, der eSATA funktioniere bei ihm nicht. Weiss aber nicht mehr genau, ob's gerade bi diesem Board war, oder bei nem anderen AsRock.
Es gibt eben auch Hersteller, die vorne fünf Ports haben und am Hinteren kann man, zur internen Verwendung den SATA abzwacken.
Naja, ich find die Methode aber gut...mein Gigabyte MA78GM-S2H hatte intern nur 5 Steckplätze und hinten einen eSATA, da find ich die Lösung von ASRock doch besser, weil z.B. meine Wenigkeit keine eSATA Festplatte besitzt ;)
Hab da ein pro. mit Tastatur wenn ich den Rechner ab schalte leuchten die Numer lock und Caps lock tasten.
weis einer wo ich was änder muss das die nicht leuchten bei abgeschaltetem PC.
hurzpfurz;11466630... das ist nicht normal! Ich habe ja noch das ASUS P5B mit INTEL Chipsatz und im AHCI Modus werden alle Festplatten von Everest und Konsorten erkannt! Beim AOD790GX mit AHCI wie beschrieben nicht. @arkos In der Beschreibung steht nur etwas von DVI-D...[/QUOTE schrieb:
Das ist nicht normal.
Die Festplatten wurden bei mir schon immer angezeigt - egal ob IDE oder AHCI Modus und mit welcher Biosversion bzw. Treiberversion.
Ob bei DVI-D die 2560er Auslösung unterstützt wird, steht nirgends.
> Hast Du wirklich auch den Rechner abgeschaltet? Hast Du Vista? Wenn Du da auf den Button mit dem Stopsignal gehst, wird er nur in den Standbye versetzt.
Zum richtigen Abschalten muss man auf > klicken und "Herunterfahren" wählen.
> Ansonsten kann es schon sein, dass Du im Bios PowerUp über Keyboard enabled hast. > AnyKey oder PowerKey oder so.
Es gab früher auch auf den Boards nen Jumper, mit dem man diese Funktion erst aktivieren musste, also könnte man dies audch wieder deaktivieren.
Es würde dann nen Jumper geben, der USV+5 Volt oder so angeschrieben wäre, bzw. die Funktion.
Aber ich denke, wenn es nicht an Vista und der Herunterfahrmethode liegt, dann eher im Bios. Die PowerUp Funktion.
Den besagten Jumper haben nicht mehr alle Boardsm, weil's bei denen Standardmässig nur aktiviert ist.
@ Arkos
Habe vista ultimat 64 bin in der kennen lern Phase hatte bis letzter Woche noch XP home.
Abschalten mache ich auch nur über Herunterfahren oder den Ausschaltknopf über die Tastatur.
Im bios ist so eingestellt das ich nicht über die Tastatur staten kann. Habe da schon einige Einstellungen ausprobiert.
Nach den besagten Jumper(USV+5 Volt) muss ich mal kucken ob ich hin finde.
Ich habe gestern das Board bestellt und habe zwei Fragen:
1.Welchen Treiber nutze ich den für den Chipsatz?
Die AMD Seite ist völlig blöd aufgebaut.
Ich hatte bis jetzt noch keine AMD Chipsatz.
Für meine HD4850 und HD3870 finde ich ja auch die Grafikkarten-Treiber - stell ich mich wirklich so blöd an?
Bitte mit Link zum Treiber 9.2
2. Ram
Ich habe mir diesen Ram bestellt ---> klick
Ich hatte bis jetzt nur DDR1 Ram.
Wie sieht es mit der CommandRate aus - ich habe gefunden die Rams laufen mit 1T - ich dachte immer DDR2 läuft mit 2T - geht das mit dem Board?
:) WinXP 32bit
ist die Full Catalyst Software Suite bei ATI Radeon™ Video Card Drivers und Motherboard/Integrated Video Drivers die gleiche?
Die Größe und Bezeichnung stimmt.
Also brauche ich nur diese für Chipsatz und Radeon HD4850?
Oder brauche ich noch zusätzlich Individual Drivers (Motherboard/Chipset)
in der Full Suite müsste alles drin sein und die unterscheidet sich soweit ich weiß nicht, sprich is beides das selbe.
Die Catalyst-Suite mit allen Treibern bzw. auch Southbridgetreiber gibt es auf englisch.
(Catalyst Control Center auf englisch)
http://game.amd.com/us-en/drivers_catalyst.aspx?driver=VideoCard/xp32-suite
Den Grafiktreiber selbst gibt es auch auf deutsch (Catalyst Control Center).
http://support.amd.com/us/gpudownlo...spx?type=2.4.1&product=2.4.1.3.36&lang=German
Dann gibt es noch die Southbridgetreiber separat:
http://game.amd.com/us-en/drivers_catalyst.aspx?driver=Integrated/xp32-chipset
Und dann gibt es noch das sog. Performance-Tool für Mainboards mit Chipsätzen der 7er-Reihe.
http://game.amd.com/us-en/drivers_chipset.aspx
Hier wird aber nur die Festplatten-Option "Erhöhte Leistung aktivieren" eingeschaltet.
Sollte man auch selbst im Gerätemanager machen können -> Festplatte -> Eigenschaften -> Richtlinien
Habe aber Vista und kann es für Windows XP nicht definitv sagen.
Unter Vista ist die Option meist schon in der Standardkonfiguration aktiviert, für XP muss man dies explizit unter der gleichen Stelle aktivieren.
Dann ist dieses Tool wohl hauptsächlich für XP gedacht.
Läßt sich der Asrock Boot Screen (Bild) ausschalten - finde es nicht im BIOS V1.40.
Ich hatte gelesen das sich die Lüfter mit Speedfan steuern lassen aber ich bekomme es nicht hin - kann mir jemand einen Tipp geben.
Ich habe meine Festplatten im AHCI Modus laufen.Was passiert wenn ich einen SATA DVD Brenner anschließe läuft der dann im IDE Kompatibilitätsmodus?
Wird der Brenner erkannt wenn ich versuche Windows XP zu installieren?
Was macht die Einstellung L3 Cache Allocation?
