[Sammelthread] Asrock AOD790GX/128M (AMD 790GX)
ASRock AOD790GX/128M, 790GX
1. Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
2. Supports CPU up to 140W
3. ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
4. AMD 790GX + SB750 Chipsets
5. AM3 CPU Ready!
* FSB 2600 MHz (5.2 GT/s)
* Supports AMD OverDrive™ with ACC feature (Advanced Clock Calibration)
* Supports Hyper-Transport 3.0 (HT 3.0) Technology
* Supports Dual Channel DDR2 1066 with AM2+ CPU , and DDR2 800/667/533 with AM2 CPU, with 4 DIMM slots, maximum capacity up to 16GB
* Integrated AMD Radeon HD 3300 graphics, DX10 class iGPU, Pixel Shader 4.0, Max. shared memory 512MB
* Integrated 128MB side port memory for iGPU
* Supports ATI™ CrossFire™ and Hybrid CrossFireX™
* 2 x PCI Express 2.0 x16 slots (green @ x16 mode, blue @ x8 mode)
* 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 5, RAID 10 and JBOD), NCQ, AHCI and Hot Plug functions
* 1 x eSATAII 3.0 Gb/s connector
* 2 x IEEE1394 ports (one port on back panel, one header on board)
* PCIE Gigabit LAN 10/100/1000 Mb/s
* Three VGA Output options: D-Sub, DVI-D and HDMI with DVI-to-HDMI Converter
* Supports HDCP function
* Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
* 1 x USB/WiFi header
* Supports Smart BIOS, ASRock OC Tuner, Intelligent Energy Saver, Extra ESD Protection
* Free Bundle: 1 x ASRock XFire Switch Card, 1 x DVI-to-HDMI Converter
* 7.1 CH Windows® Vista™ Premium Level HD Audio, DAC with 110dB dynamic range (ALC890 Audio Codec)
* Windows® Vista™ Premium 2008 Logo Ready
* I/O Panel: 1 x VGA/D-Sub Port, 1 x VGA/DVI-D Port, 1 x eSATAII Port, 1 x IEEE 1394 Port, 1 x RJ-45 LAN Port with LED, 6 x USB 2.0 Ports
2. FAQ - Frequently Asked Questions
- "Lassen sich 3 Pin Lüfter steuern?"
Nein das geht nicht.
- "Ist der Sideportspeicher alleine nutzbar?."
Jawohl das ist möglich.
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
http://www.asrock.com/mb/download.asp?Model=AOD790GX/128M&s=AM2+
3.2 Reviews
http://www.pctreiber.net/thread.php?threadid=10224
http://www.cpu3d.com/review/5844-1/asrock-aod790gx-128m-motherboard/introduction.html
http://www.thinkcomputers.org/index.php?x=reviews&id=850
http://my.ocworkbench.com/2008/asrock/AOD790GX-128M/g1.htm
http://www.amdzone.com/index.php/reviews/66/10542-asrock-aod790gx128mb
3.3 Interessantes:
- Sideportspeicher ist alleine nutzbar
- Asrock OC Tuner unter Windows zum Übertakten
- Stromsparender als der Vorgänger 780G
- DVI auf HDMI Adapter im Lieferumfang enthalten
3.4. Overclocking
4. Preise
http://preisvergleich.hardwareluxx.de/deutschland/a365733.html
http://www.hardwareschotte.de/hardware/preise/proid_9775432/preis_ASROCK+AOD790GX128M
http://www.preistrend.de/suchen.php?q=AOD790GX&s=0&a=&z=&x=0&y=0
http://www.google.de/products?q=ASRock+AOD790GX&hl=de&scoring=p
5. Bekannte Probleme:
unter XP ist die 2D Performance bei allen 7er Chipsätzen nicht sehr hoch. Den Treiber aktualisieren bringt etwas. Ganz schlimm ist es mit Treibern unter dem 8.12er!
6. Fixes:
Lüfteregelung mit Speedfan:
http://www.hardwareluxx.de/community/showpost.php?p=13259216&postcount=587
7. Bios:
1.70er Version ist aktuell, doch gibt es hier Probleme mit der Core-Freischaltung
Die ersten mit CL5-5-5-15. Hab da jetzt nicht großartig dran optimiert, laufen aber bei mir mit 2,1V. Also "relativ" viel. Aber da sollte man sicherlich auch mit weniger auskommen. Funktionieren tun sie aber sonst völlig problemlos.
Hi Leute, mal ne dumme Frage.
Da kann man doch kein Crossfire von DualSlotKarten laufen lassen.
Die zwei PCI-E Slots für GPUs sind doch viel zu nahe beieinander.
CIh frag deshalb, weil ein Freund von mir zwei HD5770 darauf laufen lassen möchte.
Kann mir da einer eine konkrete Aussage geben. Danke.
Wieso sollte das nicht gehen ? Zwischen dein beides Slots ist quasi "ein pci-slot-abstand". Allerdings setze ich es selbst nicht ein, deshalb keine Garantie dafür.
Nein, Kühler auf meiner Graka nimmt mehr Platz als eine DS-Graka ein. ;-)
Ja hab gerade gelesen im Test von PC Treiber dass man max. 3 DS-Karten einsetzen kann.
Bist du zufieden? Hat das Board irgendwelche Besonderheiten auf die man achten sollte?
Danke
Ich finde den Northbridge-Kühlkörper ätzend. Der ist irgendwie an einer ungünstigen Stelle und ziemlich hoch. Könnte bei einigen voluminösen CPU-Kühlern zu Montageproblemen kommen. Sonst gibt's daran absolut nichts auszusetzen in meinen Augen. Den BIOS-Support finde ich bisher auch vorbildlich muss ich sagen. Phenom X6 Unterstützung kann man als gesichert ansehen, weil es ja zumindest schon ein Beta-BIOS gibt. ;-)
OK, das hört sich gut an.
Er plant sich den AMD Athlon 64 X2 5000+ EE, 2x 2.20GHz zu bestellen und hofft auf einen freischaltbaren Deneb Kern.
Als GPU hat er genauso wie ich eine HD5770.
Das ist aber noch die alte Architektur. Da ist nix mit freischaltbaren Kernen. Athlon II ist die neue Architektur. Den den du nennst is ein waschechter 2-Kerner, wo nix deaktiviert wurde und sich somit auch nichts freischalten lässt.
Warte, ich check das nochmal.
Wie sieht es denn mit den RAM Teilern aus?
-Er hat nur DDR2-800 RAM, kann man damit überhaupt hoch genug geehen mit dem Referenztakt?
SOrry für die Fragen, hatte seit 6 Jahren kein AMD System mehr.
Momentan Corei5-750.
Danke
Wieso Referenztakt usw? ;-) Das muss man nicht mehr beachten. Der Läuft auf DDR2-800 und fertig. Nix übertakten, nix einstellen usw. CPU und RAM müssen nicht mehr "synchron" laufen. Einfach RAM rein und benutzen. :)
Asynchron.
Also hat OC über den "FSB" nichts mehr mit dem RAM-Takt zu tun.
Nein, hat damit nichts mehr zu tun. Taktet alles unabhängig voneinander. Allerdings bin ich auch nicht ganz in der Materie drin, weil meine CPU nen offenen Multi hat. Unter Umständen ist es also doch RAM-abhängig. Aber vll ist es in dem Fall besser, mal ein Blick ins OC-Forum hier zu werfen oder aber mal im Forum von planet3dnow.de zu gucken, das ist ja die AMD-Hochburg schlechthin. :)
Ja, sind 4 identische Riegel. Habe da nicht zu 100% darauf geachtet, aber ich meine im POST-Screen steht das.
weiß einer ob die neuen Phenom II X6 auch auf das mainboard passen ?
Ja, n paar Beiträge weiter oben ist das Beta-Bios 1.81 verlinkt. Das bietet Phenom X6 Support.
Was ist die Max HTT möglich auf diese Board-In kein Review steht es!
Kann ich auf die neuste BIOS flashen wenn eine X6 drin steht und die passende BIOS nicht drauf ist?
Ich hab da mal eine Frage...
Ein Freund von mit hat das A790GXH/128M und kann nicht mehr als mit 2 Riegel einsetzen. Ich hab schon allesprobiert, was mir eingefallen ist.... schon beim einstecken des 3. Riegels bleibt der Bildschirm einfach aus....
RAM: G.E.I.L. DDRII-800 4.4.4.12 (1,8V-2,1V)
schon VRAM und VCore erhöht und die Speichergeschwindigkeit gesenkt...
die RAMs und die Slots können es nicht sein, denn wenn ich die beiden Riegel durchwechsle geht es ohne Probleme und wenn man die anderen beiden Sots vom MB benutzt geht es auch ohne Probleme es gehen eben nur nicht mehr als 2 Riegel geichzeitig.....-.-
Da musst Du mal die RamKompatibilitätsliste anschauen.
Hast Du die Ram bei den Versuchen auf Standard SPD eingestellt? Also nicht manuelle Timings, auch nicht EPP. Denn einige werden im EPP Modus falsch ausgelesen.
Als Kontrolle einfach EPP auf SPD umstellen. Dann ürden sie wohl mit gemässigten Settings laufen.
hab ich noch nicht gemacht, werds mal probieren und dann meld ich mich wieder :d
Scotty, beam me up, it's tea time! :d
für alle mit ramploblemen bei 1066er riegeln:
4 riegel (vollbesetzung) ist mit 1066Mhz nicht möglich bei phenoms.
benutzt dann lieber 800mhz und dreht die latenzzeiten runter.
hab selber das board.
mit dem betabios 1.81 ist mir ausserdem aufgefallen, dass die CPU keinen reset mehr macht, wenn sie zu heiß wird (Phenom2 x4 940)
hat bei allen vorherigen biosversionen beim wechsel von 61°C auf 62°C resettet...
bis 68°C hab ich mich getraut (3,4Ghz bei 1,3625V; 2,2Ghz NB bei 1,150V und 2,2Ghz HT) bei minimaler drehzahl , dann hab ich meinen zalman 9700 hochgedreht.
bin mir am überlegen ob ich nen 6kerner drauf machen soll. aber hat von euch noch keiner mit nem 6 kerner getestet ?
kann ich das mainboard eigentlich mit 4 x 2 Gb bestücken ? habe zurzeit 2 x 2 GB drin und würde gern auf 8 Gb aufrüsten
6 Kerne läuft super, habe den 1090T getestet ;)
Mit 8GB OCZ RAM 4X 2Gb auf 1066, geht auch mit dem X4 940.
Alles eine Frage der Einstellung^^
und wie soll das gehen ohne das ram auf 800Mhz zu begrenzen?
es läuft zwar auch mit 1066mhz, aber nicht sonderlich lange...
nach spätestens 24h is der erste absturz da.
