mekki66
Semiprofi
CPU
- LGA 775 for Intel� Dual Core Pentium� D / Pentium� 4 / Celeron� D, supporting Core� 2 Duo Desktop (Conroe), Presler and Cedar Mill processors
- FSB 1066/800/533 MHz
- Supports Hyper-Threading Technology
- Supports Untied Overclocking Technology
- Supports EM64T CPU
Chipset
- Northbridge: Intel� 945P
- Southbridge: Intel� ICH7R
Hybrid Booster
- CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
Memory
- Dual Channel DDRII memory technology
- 4 x DDRII DIMM slots
- Supports DDRII 667/533
- Max. capacity: 4GB
Slots
- Supports ATI CrossFire�
- 3 x PCI slots
- 1 x PCI Express x 16 slot
- 1 x AGI Express slot (PCI Express x 4)
- 1 x PCI Express x 1 slot
Graphics
- n/a
Audio
- Realtek ALC888 7.1channel CODEC with High Definition Audio
LAN
- Gigabit LAN 10/100/1000 Mb/s
- PCIE x 1 Realtek RTL8111B
- Supports Wake-On-LAN
Connector
- 4 x Serial ATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel� Matrix Storage), NCQ, AHCI and "Hot Plug" functions
- 2 x eSerial ATAII 3.0 Gb/s connectors (shared with 2 SATAII ports), support "Hot Plug" function
- 1 x ATA100 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x Game header
- 1 x HDMI_SPDIF header
- 2 x IEEE 1394 headers
- CPU/Chassis FAN connectors
- 20 pin ATX power connector
- 4 pin 12V power connector
- SLI/XFire power connector
- CD in header
- Front panel audio connector
- 3 x USB 2.0 headers (support 6 USB 2.0 ports)
Rear Panel I/O
ASRock 8CH_eSATAII I/O
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x COM Port
- 1 x Parallel Port (ECP/EPP Support)
- 2 x Ready-to-Use USB 2.0 Ports
- 2 x eSATAII Ports
- 1 x RJ-45 LAN Port
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
BIOS Feature
- 4Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
Support CD
- Drivers, Utilities, AntiVirus Software (Trial Version)
Hardware Monitor
- CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU Overheat Shutdown to Protect CPU Life
- CPU Fan Tachometer
- Chassis Fan Tachometer
- CPU Quiet Fan
- Voltage Monitoring: +12V, +5V, +3.3V, CPU Vcore
Accessories
- Quick Installation Guide, Support CD, I/O Shield
- Floppy/ATA 100 cables
- 4 x SATA data cables (optional)
- 2 x SATA 1 to 1 power cables (optional)
- 1 x HDMI_SPDIF cable (optional)
- 1 x USB+1394 bracket
Form Factor
- ATX Form Factor: 12.0-in x 8.6-in, 30.5 cm x 21.8 cm
OS
- Microsoft� Windows� 2000/XP/XP 64-bit/Vista� compliant
Certifications
- FCC, CE, WHQL
zum Board: Leider musste ich feststellen das das Board bei 300MHz FSB dicht macht.V-core kann man auch nicht anheben Die DDR Voltage kann man von normal auf maximum stellen. Ansonsten ist es ein Top-Board, sehr gute ausstattung, läuft 100% stabil. aber denke es fliegt wieder raus wenn nicht ein bios update kommt um den fsb höher zu stellen.
Links:
Review zum Board: http://sg.vr-zone.com/?i=3779
BIOS und Treiber Updates: http://www.asrock.com/support/download.asp?Model=ConRoeXFire-eSATA2#bios
Falls es sonst noch jemand hat kann ja mal seine erfahrung posten.
Chipset
Hybrid Booster
- ASRock U-COP
Memory
Slots
- 3 x PCI slots
Graphics
- n/a
Audio
LAN
Connector
- 1 x IR header
- 1 x Game header
- CD in header
Rear Panel I/O
- 1 x COM Port
- 2 x eSATAII Ports
BIOS Feature
- 4Mb AMI BIOS
- AMI Legal BIOS
Support CD
Hardware Monitor
- CPU Quiet Fan
Accessories
Form Factor
OS
Certifications
- FCC, CE, WHQL
Links:
