[Sammelthread] Asrock X58 Extreme (Intel X58)
Hier ensteht ein Sammelthread zum bis her günstigsten X58 Mainboard
im gegensatz zu anderen X58 Billig Mainboard bietet dieses hier eine Lizenz für SLI.
ab 133€
http://preisvergleich.hardwareluxx.de/deutschland/a442028.html
habe es mir bestellt testen kann ich vorausichtlich erst nächste Woche.
■Intel® Socket 1366 Core™ i7 Processor Extreme Edition / Core™ i7 Processor Supports Intel® Dynamic Speed Technology
■System Bus up to 6400 MT/s; Intel® QuickPath Interconnect
■ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
■Intel® X58 + ICH10R Chipsets
■Advanced V8 Power Phase Design
■Supports Triple Channel DDR3 2000(OC)/1866(OC)/1600(OC)/1333(OC)/1066 (6 x DIMM slots) non-ECC, un-buffered memory, Max. capacity up to 24GB
◦Supports DDR3 ECC, un-buffered memory with Intel® Workstation 1S Xeon® processors 3500 series
◦Supports Intel® Extreme Memory Profile (XMP)
◦3 x PCI Express 2.0 x16 slots (blue @ x16 mode, orange @ x4 mode) (Double-wide slot spacing between each PCI-E slot)
◦Supports ATI™ CrossFireX™, 3-Way CrossFireX™ and Quad CrossFireX™
◦Supports NVIDIA® SLI™ and Quad SLI™
◦PCIE Gigabit LAN 10/100/1000 Mb/s
◦6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, 1, RAID10, RAID 5 and Intel® Matrix Storage), NCQ, AHCI and Hot Plug functions
◦1 x Powered eSATAII/USB Connector
◦Supports 2 x IEEE1394 ports (one port on back panel, one header on board)
◦EuP Ready
◦Smart Switch
◦Dr. Debug
◦Supports ASRock Instant Boot, Instant Flash
◦Supports Smart BIOS, ASRock OC Tuner, Intelligent Energy Saver
◦7.1 CH Windows® Vista™ Premium Level HD Audio with Content Protection, supports DAC with 110dB dynamic range (ALC890 Audio Codec)
◦Windows® Vista™ Premium 2008 Logo Ready
◦Free Bundle: 1 x ASRock SLI_Bridge_2S Card
◦I/O Panel : 1 x Coaxial SPDIF Out Port, 1 x Optical SPDIF Out Port, 7 x Ready-to-Use USB 2.0 Ports, 1 x Powered eSATAII/USB Connector, 1 x RJ-45 LAN Port with LED, 1 x IEEE 1394 Port, 1 x Clear CMOS Switch
Product Specifications
General
CPU - Intel® Socket 1366 Core™ i7 Processor Extreme Edition / Core™ i7 Processor Supports Intel® Dynamic Speed Technology
- System Bus up to 6400 MT/s; Intel® QuickPath Interconnect
- Advanced V8 Power Phase Design
- Supports Hyper-Threading Technology
- Supports Untied Overclocking Technology
- Supports EM64T CPU
Chipset - Northbridge: Intel® X58
- Southbridge: Intel® ICH10R
Memory - Triple Channel DDR3 memory technology
- 6 x DDR3 DIMM slots
- Supports DDR3 2000(OC)/1866(OC)/1600(OC)/1333(OC)/1066 non-ECC, un-buffered memory
- Supports DDR3 ECC, un-buffered memory with Intel® Workstation 1S Xeon® processors 3500 series
- Max. capacity of system memory: 24GB*
- Supports Intel® Extreme Memory Profile (XMP)**
*Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® XP and Windows® Vista™. For Windows® XP 64-bit and Windows® Vista™ 64-bit with 64-bit CPU, there is no such limitation.
**Due to Intel® CPU spec definition, XMP DIMMs and DDR3 2000/1866/1600 are supported for one DIMM per channel only.
BIOS - 8Mb AMI BIOS
- AMI Legal BIOS
- Supports "Plug and Play"
- ACPI 1.1 Compliance Wake Up Events
- Supports jumperfree
- SMBIOS 2.3.1 Support
- CPU, DRAM, NB, SB, VTT Voltage Multi-adjustment
- Supports I. O. T. (Intelligent Overclocking Technology)
- Supports Smart BIOS
Audio, Video and Networking
Graphics - n/a
Audio - 7.1 CH Windows® Vista™ Premium Level HD Audio with Content Protection
- DAC with 110dB dynamic range (ALC890 Audio Codec)
LAN - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
- Realtek RTL8111DL
- Supports Wake-On-LAN
Expansion / Connectivity
Slots - 3 x PCI Express 2.0 x16 slots (blue @ x16 mode, orange @ x4 mode) (Double-wide slot spacing between each PCI-E slot)
- 2 x PCI Express x1 slots
- 2 x PCI slots
- Supports ATI™ CrossFireX™, 3-Way CrossFireX™ and Quad CrossFireX™
- Supports NVIDIA® SLI™ and Quad SLI™
Connector - 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Matrix Storage), NCQ, AHCI and Hot Plug functions
- 1 x ATA133 IDE connector (supports 2 x IDE devices)
- 1 x Floppy connector
- 1 x IR header
- 1 x COM port header
- 1 x HDMI_SPDIF header
- 1 x IEEE 1394 header
- 1 x TPM header
- CPU/Chassis/NB/Power FAN connector
- 24 pin ATX power connector
- 8 pin 12V power connector
- CD in header
- Front panel audio connector
- 2 x USB 2.0 headers (support 4 USB 2.0 ports)
Rear Panel I/O I/O Panel
- 1 x PS/2 Mouse Port
- 1 x PS/2 Keyboard Port
- 1 x Coaxial SPDIF Out Port
- 1 x Optical SPDIF Out Port
- 7 x Ready-to-Use USB 2.0 Ports
- 1 x Powered eSATAII/USB Connector
- 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
- 1 x IEEE 1394 Port
- 1 x Clear CMOS Switch
- HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone
Other Features / Miscellaneous
Unique Feature - ASRock OC Tuner
- Intelligent Energy Saver
- Instant Boot
- ASRock Instant Flash
- Hybrid Booster:
- CPU Frequency Stepless Control
- ASRock U-COP
- Boot Failure Guard (B.F.G.)
Smart Switch - 1 x Power Switch
- 1 x Reset Switch
Support CD - Drivers, Utilities, AntiVirus Software (Trial Version)
Accessories - 1 x ASRock SLI_Bridge_2S Card
- Quick Installation Guide, Support CD, I/O Shield
- Floppy/ATA 133 Cables
- 4 x SATA Data Cables (optional)
- 2 x SATA 1 to 1 Power Cables (optional)
Hardware Monitor - CPU Temperature Sensing
- Chassis Temperature Sensing
- CPU/Chassis/NB/Power Fan Tachometer
- CPU Quiet Fan
- Voltage Monitoring: +12V, +5V, +3.3V, CPU Vcore
Form Factor - ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
- All Solid Capacitor design (100% Japan-made high-quality Conductive Polymer Capacitors)
OS - Microsoft® Windows® XP / XP 64-bit / Vista™ / Vista™ 64-bit compliant
Certifications - FCC, CE, WHQL
- EuP Ready (EuP ready power supply is required)
Reviews:
http://www.futurelooks.com/asrock-x58-extreme-motherboard-review/
http://www.tomshardware.com/reviews/cheap-x58-motherboard,2368.html
http://www.motherboards.org/reviews/motherboards/1923_1.html
http://www.ocworkbench.com/2009/asrock/X58-Extreme/g1.htm
http://www.anandtech.com/mb/showdoc.aspx?i=3593
Weitere Infos folgen!
Edit 19.01.2010:
Review www.tomshardware.com/de
http://www.tomshardware.com/de/x58-Mainboards,testberichte-240378-18.html
Das die NB und Spawas sehr heiss werden habe ich auch gemerkt.
Habe auf die NB und die Spawas je einen 120mm Scythe Kaza mit 1900 U/min blasen lassen.
Mein Board war ja nicht gestorben, erkannte halt nur den E5506 nicht mehr.
Der W3570 und der Gulftown wurden einwandfrei erkannt.
Gestern das Board eingebaut und es geht nachher wieder zurück.
Wolte den Max Blck des Boardes finden und es ist beim ersten versuch gestorben! Beim versuch 200x12 rest alles auf Auto mit einen core i7 920. Prime lief 20min und danach gigng das board einfach aus und gibt kein piep mehr vonsich.
@killerdeluxe
...mir ist gerade haargenau das gleiche passiert. Habe das Board wochenlang mit einem i7 920 alle möglichen Benchmarks @ 21x222 BCLK - 4.66 GHz - (1.52 VCore) laufen lassen (-> HWBOT) - heute wollte ich eigentlich nur die optimalen Spannungen ausloten. Das Board ist mir bei 1.362V VCore und gemächlichen 4.20 GHz (200x21) nach ca. 10 min Prime abgeraucht und lässt sich nicht mehr starten :fire:
@killerdeluxe
Hmm, das ist echt merkwürdig. Hast Du denn außer Spannung und Bclk auch irgendwas an der Kühlung geändert? Hattest Du denn vorher die Mosfets irgendwie gekühlt?
Schönen Gruß
E.
Schönen Gruß
E.
Das System lief in einer offenen Testplattform mit der ich momentan meine ganzen Grafikkarten für HWBot benche. Habe mehrere Lüfter direkt auf alle zu kühlenden Teile des Mainboards gerichtet (unter anderem die Spannungswandler) - Umgebungstemperatur war ca. 15°. Das Mainboard lief davor wie gesagt problemlos mit bis zu 21x223 und 1.52 VCore...
- zum Zeitpunkt des Ablebens waren es "nur" 1.362V
Hi Jungs,
iwie habe ich das problem, dass das Board nicht starten will.
Man muss dann quasi dreimal den Power.Button drücken, bis was passiert!
Verbaut ist ein i7 920 D0, als NT werkelt ein Cougar CM 550W, Graka eine ATI 4890 (beide Stromanschlüsse sind dran^^) und 3* 2Gb G.Skill Speicher 1600er.
Manuell gefixt habe ich den QPI-Takt auf 6,4GT/s, Uncore Takt auf 3200MHz, RAM auf 1600MHz.
Ausserdem kommt als die Fehlermeldung. dass die OC-Settings fehlerhaft waren bzw. einige Restarts da waren und man doch bitte F2 drücken soll!
Und wo zum Henker finde ich im Biios die Option mit dem Turbomodus?
Axo...Bios ist aktuell -> 1.60!
Ich versuche es seit Stunden, kann mir jemand einen Tipp geben.
Gibt es irgendeine Bios Einstellung um die SATA Festplatte als DIE anzusprechen?
Die Einstellung SATAII als IDE zu verwenden brachte nicht.
Ich will meine Festplatte partitionieren und meine Boot CD´s finden leider keine Platten.
Das board scheint schon lange ein Bug zu haben, sobald man anstatt SATA im Bios IDE Modus "Kompatible" einstellt, hilft nur noch ein Bios Reset.
So langsam bereue ich den Kauf von dem Board, ich möchte seit ein paar Tagen Partitionen verändern/Erstellen und bekomme kenne einzige Boot CD zum laufen (weder Acronis noch Linux). Irgendwie hat das Board ein komische IDE Modus, ich habe das schon xx mal mit anderen Rechner gemacht im IDE Modus Partitionieren und wieder auf SATA modus umstellen..
Mein Board lebt immernoch. Aber ich habs auch nicht mit Volts auf CPU und NB gequält. Maximal atm 3,2 Ghz mit HT und 1,104V seit 60 min Primstable.
Die hier benutzen Settings erinnern mich eher an den Rampage II Extremethread.
moin,
ich habe zwar das deluxe und nicht das extreme, aber mein problem sollte sich ja übertragen lassen.
wenn ich den multi auf 21 stelle, dann geht der unter last auf 20 zurück, kennt jemand das problem?
Was hast in dem Biosmenü eingestellt?
Turbo muss ich bei meinen noch vorhandenen abstellen, und bei CPU Ratio einfach 21 auswählen dann sollte der Multi auf 21 fix bleiben unter Last.
habe ihn auf 21 gefixt, bei auto springt er ja nicht auf 21 unter last. bootet dann auch mit 200*21, aber so sobald ich last erzeuge, springt er auf 20 zurück. bin auch schon von bios 2.20 auf 2.10 zurück, brachte keine veränderung. außerdem fehlt mir auch die option zum vdrop, bis zu welcher bios-version war die noch drin?
edit: habe übrigens auch nicht die option für den turbo-mode
Hmm, je nach bclk musst Du vielleicht auch Thermal Throttling ausschalten. Dann solltest Du aber _selbst_ drauf achten dass das Teil unter Last nicht zu heiss wird, sonst stirbt die CPU (das throttling ist ja nicht zweckfrei).
E.
das board ist echt schrott, mittlerweile kann ich nichtmal mehr den 21er multi wählen... :(
bei älteren Bios ging das auch nicht und du hast selkbst gesagt das ein älteres drauftust weiter oben....
nagut, werd ich mich wohl nach nem neuen board umschauen... kann jemand ne empfehlung aussprechen? all zu tuer sollte es natürlich nicht sein!
edit: meine probleme rührten vom netzteil... :)
meins ist gestern abgeraucht mit relativ normaler Spannung Vcore 1,26
habe das Problem im OC 1366 Fred beschrieben.
Benötige auch noch ne Board empfehlung.
Ziel 3,6 GHz unter Luft primestabel (eigentlich kein großer Anspruch)
Brauche schnelle Hilfe, Noooby!
ich soll für einen Freund einen PC zusammenbauen, hat bisher auch alles geklappt, aber mit den Button für Reset und Power komme ich nicht klar. Kann man diese Button abziehen, um die Frontanschlüsse dranzustecken?
...und eine zweite Frage: Gibt es hier kein Anschluss auf dem MB für Power- und HD-LED?
Danke für Eure Hilfe.
Hier steht auf Seite 12 im Handbuch die Stecker sind rechts von den Rambänken !
Jop, hatte das Board auch schon...einfach mal im Handbuch schaun, wo die Front-Anschlüsse hinsollen und nein diese Buttons kannst du nicht abziehen :p
Danke, nun habe ich es gefunden, aber die Anschlüsse sind aber auch an einer Stelle, an der man sie nie suchen würde.
Ja, meistens sind diese ja unten rechts am Board....bei dem ASRock aber nicht. Fand das auch nicht schlimm, da man die Anschlüsse da oben auch sehr gut anschließen konnte...
Ich habe mir das Board gekauft aber erst jetzt hier gelesen. Ist es für OC nicht so gut geeignet ? habe eine i7 920 dazu bestellt und möchte von 2.66 auf 3.2 oder 3.4ghz übertakten mehr nicht.
Merci
The-Spacehiker
wenn du dir mal die ersten seiten durchliest ...hmm ,aber man bekommt hier eh nicht sonderlich feedback-.-
