Processor:
- AMD Athlon64 (3500+, 3800+, Fx-53, future 4000+ and Fx-55) on Socket 939
- Supports dual-Channel on 4 slots RAM (DDR400/DDR333/DDR266 ECC/non-ECC, unbuffered)
- Bus Hypertransport 1000MHz, 16bit (4Go/s bidirectional or 2000MT/s)
- AMD Cool & Quiet (goes down to 1000MHz @ 1.1V, max 22W, at rest)
Chipset:
- Nvidia NForce 4 Ultra (Ck8-04)
- Single-Chip
- passive and not very bulky chipset heatsink
Expansion
-1x PCI-Express 16x (2.5GHz, 4Go/s bidirectional)
-3x PCI-Express 1x (2.5GHz, 250MB/s bidirectional)
-3x NCV 32bit (33MHz, 132Mo/s)
Storage
-4x SATA 2 (3Gbit/s, 300Mo/s potentially) supporting NVRaid (0,1, RAID 0+1, JBOD), NCQ, ATAPI and Hotplug (native NF4)
-4x SATA 1 (1,5Gbit/s, limited to 132Mo/s - > NCV) supporting the Raid (0,1, 0+1, JBOD, RAID 5 software) (chip Silicon Sil3114CT Image, via bus NCV)
-2x IDE 33/66/100/133 supporting 4 peripherals and NVRaid even between IDE and SATA (native NF4)
-1x Floppy (chip ITE IT8711F, via bus NCV ?)
Network
-1x Gigabit Ethernet via PHY, hardware Firewall integrated into the NF4, low CPU usage (chip Marvell 88E8053, via bus NCV-E or PHY )
-1x Gigabit Ethernet via the Marvell 88E8001, via bus NCV or PHY
-1x Wifi Controller , standard "G" 54MBit/s (72Mbit/s according to the Marvell site) (chip Marvell 88W8310 + 88W8000G, via bus NCV)
* External Ports *
-10x USB 2.0 (480MBit/s) 6 via bracket (native NF4)
-2x Firewire 400 (400MBit/s) including 1 via square (chip Texas Instruments TSB4ÁA22, via PHY)
-1x parallel Port (native NF4
-2x Port series (native NF4)
-1x Midi Port (chip ITE IT8711F, via bus NCV ?)
* Audio *
- codec Realtek xxx? 7.1? (?)
- miniplug, coaxial, optical Exit
* I/O *
1x PS/2 Mouse
1x PS/2 Keyboard
1x Parallel
4x USB 2.0
1x Firewire 400 (IEEE139â)
1x RJ45 Gigabit
1x Wifi Antenna
1x 5.1 audio channels miniplug (+ 1x Mic, + 1x Line-in)
1x Coaxial Audio
1x Optical audio
* Internal Connectors *
1x 24-pin Connector E-atx (Extended ATX) or EPS
1x 4-pin Connector ATX 12V
3x USB supporting 6 port USB
1x (2x??) Firewire 400
1x Audio CD-in
