[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
Jupp , so it's
frohe Ostern...
mfG
Achim
Die frohen Ostern wünsche ich natürlich auch.
Sorry, aberden Punkt Secure Boot Parameters haben wir leider nicht gefunden. Ich kann es leider nicht sehen.. die Blindheit eben und bin auf fremde Augen angewiesen. Bestimmt ist es irgendwo versteckt. Wenn wir auf boot gehen, sagte der Sehende ist da weder was mit security oder Sicherheit.
Das Board ist das ASUS Crosshair V Formula ohne Z.
Ohh Sorry..bin von "Z" ausgegangen...
Das Ohne "Z" kenn ich jetzt nicht ..
vor allem dessen BIOS nicht
mfG
Achim
- - - Updated - - -
um grundlegendes zu klären...
Ohne Neuinstallation ist ein Windows nicht von BIOS Boot auf UEFI umzustellen...
wenn ein Windows von BIOS bootet, dann wird von "winload.exe" gebootet und die Festplatte wird über "MBR" (Master Boot Record") verwaltet...
unter "UEFI" wird "winload.efi" verwendet und die Festplatte über "GPD" (GUID-Partitionstabelle) verwaltet...
Dafür ist wie gesagt ein UEFI Betriebssystem notwendig (ab Windows8) - es soll sich zwar auch Windows7 (64bit) im UEFI installieren lassen , soll aber nicht so einfach sein
man sieht einem Windows auch nicht so einfach an, ob es in UEFI installiert ist ...
EIn You Tube Video zu Crosshair 5 und UEFI
http://www.youtube.com/watch?v=9ZDSCrW_Ruw
Ein You Tube Video zum installieren von Win7 unter UEFI
https://www.youtube.com/watch?v=WbyGTwa3UXY
mfG
Achim
Für die Konfiguration danach hätte ich schon einen Guide da.. ;-) Aber glaube mittlerweile, dass das V uefi noch nicht supportet.
laut Spezifikation ist es ein UEFI Board
Mainboards | CROSSHAIR V FORMULA
mfG
Achim
Edit
URL korrigiert
nochmal Edit
irgendwie verändert sich die url immer nach ein Paar mal aufrufen
und verweist dann auf den ASUS Shop...shit eben
Nabend Leute!
Ich war heute fleissig TW3 am zoggen, als mir ein übler Gestank in die Nase ging!
Der Rechner war übel am Qualmen und ich sprang an die Steckerleiste.
Na toll dachte ich erst jetzt hasts das Netzteil zerhauen , aber dem war nicht so.
Nach genauerer Überprüfung sah ich dann das übel!
Die Spannungsversorgung vom Mainboard hats gegrillt.
IMG_20160117_213913.jpg IMG_20160117_214005.jpg IMG_20160117_214316.jpgIMG_20160117_214328.jpg IMG_20160117_222017.jpg IMG_20160117_222154.jpgIMG_20160117_222550.jpg IMG_20160117_222615.jpg IMG_20160117_222650.jpg
Mit dem System wie es in der Info steht ausser das aktuell ein 8370E 5016Mhz@1,476V verbaut war, diente hauptsächlich zum Benchen und Spielen.
Der Rechner ging erst mit dem Netzschalter aus.:fresse::hmm:
Habe die restliche Hardware gestestet und läuft noch zuverlässig(inkl Netzteil).
Das Board hat extrem viel mitgemacht.Ich denke da hats nach den Jahren des Testens das Board einfach weichgekocht!
Da werde ich mir bis Zen kommt, wohl ein Übergangsboard besorgen müssen.:wall:
Gruss Hasestab
das sieht echt böse aus
Woha da hat es aber ganz schön gebrutzelt :fire:. Schade um das schöne Board aber immerhin funktioniert die restliche Hardware noch.
Ja alleine 6FX ,1Thuban,3Phenoms hat das Board für GHz-Club gebencht. Und das ganze ausloten usw.
Und dann beim Gamen gehts in A....! 2Jahre 10Monate ist es alt.
Allerdings frag ich mich warum des so lange gebruzzelt hat und sich nicht schon früher verabschiedet hat.
Ging wie gesagt erst mit der Steckerleiste aus. Aber vielleicht ist deswegen noch alles ganz. Das hat gefunkt und geblitzt.
Und vorher keine Anzeichen. Von jetzt auf gleich.
Singlerailpower halt!!!!!
Danke für den Tip vom Board!
Gruss Hase
Edit: Ist noch garnicht so alt ! Noch 1 Monat Garantie! Ich versuch mal mein Glück
Gesendet von meinem Samsung Galaxy S5 mit der Hardwareluxx App
bei meinem Crosshair (ohne -Z) war es ähnlich, nur dass es die Garantiezeit komplett und problemlos überstanden hat. Von heute auf morgen hat es mir dann einfach den Mittelfinger gezeigt und, wie erwähnt, Garantie 2 Monate rum :shot:.
Das Crosshair-Z hatte ich im Nov vom Alternate-Outlet und das hat sich erst garnicht starten lassen, weder mit meinem P2-955 noch mit dem FX-8350 :mad:
mit dem Board habe ich auch schon geliebäugelt, da es eigentlich das aktuellste ist und ich auch kein wirklicher Freund von ASRock bin. Im Grunde ist es damit für mich konkurrenzlos und ich glaube nicht dass ich nochmal ein Crosshair-Z hole, da mir die (sinnlose) Bastelei auf den Keks geht, zumal ich ne Wakü benutze
Da aber AMD wohl jetzt komplett auf den AM4 Sockel setzt brauchen wir vielleicht nicht mehr so lange auf neue Boards warten, auch wenn ZEN noch ein Wenig auf sich warten lässt
@Hasestab so wie ich das sehe gab es keine Rückmeldung von Asus? Schickst du es trotzdem auf gut Glück ein?
Mein Board vom Hauptsystem ist auch schon gute 3.5 Jahre alt. Zu Zen wird es aber mal wieder aufgerüstet :)
Ja ,Ticket hab ich schon. Nur gerade noch keine Zeit gehabt.
@Hasestab,
Oh Mist das tut mir leid und das bei dem qualitäts Brett, wieviel Sachen hattes du bis zum crash drauf :-[
Sorry steht ja alles oben :(
Übergansboard bis ZEN Tip:
GIGABYTE - Mainboard - Socket AM3+ - GA-990FX-Gaming (rev. 1.0)
Das GB ist an und für sich echt interessant. Nur schade das bei den Spawas keine Einigkeit besteht.
Bei GB steht nichts darüber. Hat es also 8+2 oder nicht?
Wenn nicht, macht das Board kein Sinn.
Wir sprechen hier über ein Ersatzboard eines Boards wo diese abgeraucht sind und an und für sich mehr als super sind... ;)
Hab ja das V auch noch in Benutzung. Und ein IV im Karton liegen. Was an und für sich läuft... aber Lan Port ist defekt, 2. Ram Bank ist defekt, NB muss auf 0.900v gesetzt werden damit es nicht überhitzt. Läuft aber damit stabil :fresse: weswegen das 970er GB im zweit Rechner ist und angeschafft wurde.
Nach dem was das Board aber mit gemacht hat darf es das auch :fresse:
Das GB hat aber auch eine Macke trotz inoffiziellen Beta Bios direkt vom GB Support der das beheben soll... nämlich den mistigen Start Bug. Abhilfe schafft hier nur leichtes OC am FSB :fresse:
Ich stell hier einfach mal ne Frage :drool:
Hat hier jemand noch ein defektes crosshair v formula-z ?? Ich könnte das als Teilespender brauchen!! Genau genommen gehts um den Kühler für die SpaWas !!!
Also wenn jemand so ein Schätzchen liegen hat... :cool:
macom
mit nem normalen Formula (nicht '-Z') könnte ich Dir weiterhelfen, aber ich glaube die passen nicht untereinander
Also der Kühler des Crosshair v Formular ohne Z passt doch auf das Formular Z !!!
Danke an Neo52, du hast mir sehr geholfen!! :wink::wink::wink::wink:
Mfg
macom
...jetzt lebt mein Crosshair V Formula (ohne 'r') in Deinem -Z weiter :teufel: :teufel: :haha::haha::haha::haha::haha::haha:
moin
ich hab das problem das sich meine cpu nicht mehr übertakten lässt im bios ist immer eingestellt alles wie vorher speicher ab und beim neustart zeigt er mir das an siehe bild, cmos reset bringt nix....
anderes neues Problem, seit dem bios reset geht mein pc aus wenn ich nichts an dem mache, der fährt einfach runter bildschirm aus zack weg, wenn ein spiel läuft oder so bleibt der an. Hab im Windows alle energiesparmodis aus. Was hat sich da verstellt?
Keiner?
Mir geht das Problem echt aufn Keks das der Rechner in ruhemodus geht wenn ich nichts dran mache obwohl ich alles deaktivieret habe...
hmm. Vielleicht eine Option im Bios übersehen? Oder erneutes Bios Reset?
Hey Leute,
ich habe mal aus langer Weile im BIOS mal die CPU auf 5GHZ getaktet und wenn ich Cinebench durchlaufen lass, friert der Rechenr ein. Da hab ich mir mal die Beschreibung des Boards zur Brust genommen und bin auf zwei Sachen aufmerksam geworden. Zum einen auf Seite 43 die Anschlüsse B (EATX12V_1) und C (EATXPWR) werden von meinem Netzteil mit Energie versorgt. Die Anschlüsse A (EZ_PLUG) und D (EATX12V_2) sind mir ein Rätsel. D ist für mehrere Grafikkarten, meinen die damit SLI-Verbunde und nur dann, wenn der Fakt erfüllt ist? Die werden doch per Stromkabel direkt vom Netztteil versorgt. Und was soll der Anschluss A? ist das zusätzlich oder Netzteilspezifisch bedingt? Müsste ich den eventuell nutzen, damit meine CPU noch mehr Energie bekommt und ggf. stabil 5GHZ leisten kann?
VG,
House
