[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
Hy,
ich denke, dass mehr nicht drin sein wird, kühle ja mit Luft. Werde trotzdem mal die Tage etwas testen und Feedback geben.
Meiner achtens nach, hat das anheben des HT auf 2,6 GHz was gebracht, wobei einige schreiben, dass es nichts bringt?
VG,
Housemarke
Moinsen
Hätte da mal einpaar Fragen zum Crosshair V-z.
Wollte mir das Mainboard zulegen, und hätte da gerne noch das ein oder andere gewusst :>
Möchte 2 Grafikkarten anschliessen.
Und zwar diese hier:
ASUS R7260X-DC2OC-2GD5 (2 Stück)
Es geht nur um die "4 Roten PCI-Express x16 Slots" NICHT um die "2 Schwarzen PCI-Express x1 Slots"
Die zähle ich nicht mit wenn ich von 4 Slots rede, tun wir so als gäbe es die Schwarzen-Slots nicht.
01) Wenn ich die 2 Grafikkarten in den PCI-Express Slot 1 und 2 stecke, dann laufen die doch jeweils im 16x Modus oder ?
02) Dann ist doch der PCI-Express Slot 3 nicht mehr nutzbar bzw wird dann auf 0x gesetzt oder ?
03) Dann hat doch der PCI-Express Slot 4 aber noch ein 4x Modus oder ?
04) Welcher der 4 PCI-Express Slots ist dann für Erweiterungskarten bzw für Controller Karten ?
05) Kann ich die Controllerkarte "LSI SAS 9201-16i" in den PCI-Express Slot 4 betreiben ?
06) Der Controller ist eine PCI-Express 8x Karte, läuft die dann auch in einen 16x Slot der auf 4x gedrosselt ist ?
07) Hatte allerdings auch etwas gehört vonwegen, man müsse die 2 Grafikkarten in den Slot 1 und Slot 3 Stecken ?
08) Wenn ich das täte könnte ich aber wohl die Controller-Karte nicht in Slot 4 stecken, weil der Slot 4 dann von der Grafikkarte in Slot 3 verdeckt wäre oder ?
09) Würde es denn gehen, das ich trotzdem die 2 Grafikkarten in Slot 1 und Slot 2 stecke ?
10) Und wie wäre dann die Geschwindigkeit 1x16 und 1x ???, oder würde das gar nicht gehn ?
11) Kann ich diesen RAM verwenden: "Corsair Vengeance Pro rot 32GB, DDR3-1600, CL9-9-9-24" ?
12) Wenn ein Arbeitsspeicher nicht in der Kombilitäts-Liste steht funktioniert er dann auch nicht ?
13) Oder kann es dann im laufe der Zeit zu Problemen kommen ?
Gruss
Schönen Tag noch.
Wäre auch mal gespannt was daraus geworden ist
Gesendet von meinem GT-I9505 mit der Hardwareluxx App
Slot 2 ist mechanisch nur für x8 ausgelegt. Wenn dann musst du diese in Slot 1 und 3 stecken.
Slot1 - x16
Slot2 - x8
Slot3 - x16
Slot4 - x4
Du hast insgesamt 38 Lanes. Ob man die im Bios einstellen kann oder ob das automatisch verteilt wird weiß ich allerdings auch nicht.
siehe Frage 2
Mechanisch passt die Karte in jeden Slot. Sie würde auch mit x4 laufen.
Du kannst dich mal in Netz umschauen. Soweit ich in Erinnerung habe ist der Verlust von x8 zu x16 nur minimal. Wenn dir das nicht so wichtig ist kannst du diese in 1+2 machen.
Der Ram sollte ohne Probleme laufen. In den meisten Fällen laufen auch Rams welche nicht in der Liste stehen. Ich hatte bisher nur ein einziges mal Probleme allerdings im hohen Taktbereich.
Ich habe da auch mal eine Frage zum Asus Crosshair V-Z
Zur Config:
AMD FX-9590
ASUS Crosshair V Formula-Z
G.Skill TridentX DIMM Kit 16GB, DDR3-2666
EVGA SuperNOVA 1300 G2 1300W
Ich will das gesammte System bis ans Maximum overclocken und wollte deswegen mit FSB übertakten. Die CPU selber kann ich bis 5,2 GHz prügeln (ohne HS, liquid Silver,guter Wasserkühlung) mit prime stabil. Oft höre ich, dass welche den FSB bei um die 300 MHz haben .... ich komme egal wie nicht über 240 MHz.
Dabei habe ich Div. Spannungen angeholen ... Speicherteiler geändert usw....
Kann mir einer sagen welche setting ich genau wie einstellen muss, damit ich den FSB zwischen 250 - 300 betreiben kann ?
THX
HT und NB Teiler auch angepasst?
Hi Shadowpeople.
So wie es sich anhört läufts! Bisste schon beim Feintuning!:fresse2:
Sehr komisch dein Problem. Wenn du alles richtig angepasst hasst müsste der mindestens bis 270-280 Mhz gehen.
Bist du sicher das sich die Ramtimings und Subtimings beim runtersetzen des Multis nicht mit in den Scharfen Bereich verändert haben?
Was für Probleme hast du denn,bzw was passiert beim erhöhen des FSB. Startet nicht oder wie?
Gruss Hasestab
Moin :d
Ja die CPU rennt super aber der rest .. naja .. Wenn ich den FSB über 240 mache, kackt er bei mir genau beim Windows Login ab. Ich habe den Speicherteiler so entschärft, dass RAM, NB und HT dicke Luft nach oben haben.
Ich dachte mir, dass vielleicht die SB unter dem Übertakten leidet und habe die Spannung mal gut angehoben ... aber nichts da .... Habe allgemein mal fast alle Spannungen deutlich angehoben ... gleiches Ergebnis
Und wie siehts mit einem höheren FSB aus, bzw andere Teiler. Vielleicht kommt er mit einem anderen höheren FSB besser klar.
Friert der PC ein wird der Bildschirm schwarz oder Bluescreen?
Normalerweise muss du nur leicht die CPU-NB erhöhen in der Spannung für einen höheren FSB wenn überhaupt.
Wie siehts aus wenn du alles so lässt und nur den CPU multi 1/2 zurücknimmst also etwas weniger Takt?
Ich verdächtige denn Arbeitsspeicher (Subtimings.) 2666 Mhz Profil laden und alles von Hand(manuell) eingeben könnte helfen. Zudem Ref cycle Time auf 350 anstatt 300. wenn der natürlich nur auf 1600Mhz läuft ist es egal. Aber ich denke ja mal das du den wieder mit hochziehst durch verändern des FSb.
Gruss
So ich bin ein wenig weiter gekommen....
Es scheint als gäbe es ein Problem mit dem Speicher. Es ist unabhängig wie hoch ich den Speicher takte und trotzdem friert der PC beim Windowslogin ein. Wenn ich aber in Windows bin und erst dann hochtakte komme ich in die Region 270 Mhz FSB. Wenn ich bei Prime einen Fehler bekomme hilft NUR das anheben der RAM-Spannung, obwohl dieser deutlich unterhalb seiner Möglichkeiten läuft.
Kommt mein Board nicht mit dem Speicher klar oder ist es bekannt das 2 x 8 GB immer diese Probleme macht ?
Hm ich selbst habe auch 2x8GB und keine Probleme damit.
In welchen Slots hast du den Ram stecken. Eventuell postest du mal deine Einstellungen. Vielleicht siehen wir etwas was uns vorher nicht aufgefallen ist.
ich habe 0 und 2 / 1 und 3 und auch nur Single probiert ... Von den Settings habe ich von überall auto bis massig Spannung auf alles probiert ... immer das gleiche ...
Den Speicher habe ich sehr entschäft mit CL 13,14,14,38,42 und die AMD wichtige setting auf 350. DIE CPU habe ich auf 1,45 Vcore, da dieser damit bis 5 GHz ohne Fehler läuft.
Also bestimmte Settings kann ich garnicht durchgeben weil ich wohl fast alle Probiert habe.
Ich habe nun alle Komponenten getauscht bis auf das Mainboard und nach wie vor ist der FSB nicht stabil über 240 zu bekommen. Ich gehe davon aus, dass das Mainboard ein defekt hat oder einfach nur sehr schlecht ist. Nachdem ich das Mainboard von "brutus999" hier im Forum gekauft habe und dieser mir 10 Euro zurückerstatten wollte, weil er die Belde nicht beigelegt hatte aber bis heute antwortet er mir nicht mehr und das Geld habe ich auch nicht gesehen, gehe ich davon aus, dass er von dem schlechten Zustand wusste .... einfach nur schade, dass es solche User gibt .... habe mir jetzt ein neues beim Händler gekauft ... Das war wohl sparen am falschen Ende
Das Brutus nicht mehr antwortet hat wohl andere Gründe. Schau mal hier.
Heißt du hast auch schon eine andere CPU probiert? Hast du eigentlich Turbo, APM und die Energieoptionen an oder aus?
Ja die CPU habe ich auch getauscht gegen Amd Phenomen II x4. Die Settings habe ich von Hasetab der mir tatkräftig beim Köpfen der CPU und schicken der Settings geholfen hat. Deswegen ist Turbo natürlich aus und APM ist auch komplett aus.
Ich gebe mal bescheid, wenn das neue Mainboard angekommen ist und ich alles damit durchgetestet habe.
Nachtrag ... ist ja mal Interessant mit Brutus99 ... beim nächsten mal schaue ich vorher, ob die User hier Probleme machen. Aber hey ... 10 Euro ist zum glück nicht die Welt :d
da in absehbarer zeit der neukauf eines boardes ansteht, und ich das in die engere wahl gezogen habe, würde ich gerne wissen, ob es probleme mit meinem thermalrihgt truespirit 140 und den heatspreader mit den ripjaws geben kann, oder passt das problemlos.
danke
wenn die cpu led dauerhaft leuchtet und später die dram led dazu blinkt wo ist der fehler? das board hat eventuell wasser abbekommen aber finde nichts
@pedi: Ohne Garantie aber sollte passen je nachdem wie viele Rams du verwendest. Der erste Slot wird mit Sicherheit vom Lüfter verdeckt sein aber der Rest müsste frei sein.
@ole88: Was hast denn schon alles probiert? Mal komplett vom Netz getrennt? Bios Reset? Minimalkonfig?
Vom Netz über Nacht, battery raus, go Schalter gedrückt passiert nix nur das DRAM blinkt, mit
Einem Riegel gestartet Null. Ka was daran Putt ist. Beim starten bleibt Bildschirm schwarz und zeigt von Anfang an rote CPU LED an der bootet net mal durch, hab noch Garantie werd es wohl einschicken morgen. Hoffe das Wasser ist net schuld
Naja hab meins eingeschickt auf Garantie, ging gar nix mehr, kurz vor ende der Garantie zeit son fehler, scho komisch
Habe eben folgendes Situation auf meinem C5F-Z gehabt.
AI-Suite hat Overvolting-Warnungen unter Win 8.1 zwischen 1.6-1.67 V (ca. alle 10 Sekunden) angezeigt, obwohl ich nichts neu installiert oder im BIOS verändert habe. Beim reseten kam im POST ein "CPU Over Voltage Error" und im BIOS (1901) hat er auch direkt 1.64V bei Optimized Settings angezeigt . Ich hatte den PC zwei Wochen nicht im Betrieb gehabt, lief schon zwei Stunden. Erst nachdem ich den PC ausgeschaltet habe und 10 Sekunden gewartet habe ist der Fehler verschwunden. Komisch. Irgendeiner irgendeine Idee?
Hallo
Ich bin neu und mir geht es nicht anders.
Ich hab das bord jetzt ca. 3 Monate und bekomme immer Spannungs-Warnungen.
Am Anfang habe ich mir gedacht das mein Netzteil der Auslöser ist, weil mir schon 2 GK abgeraucht sind und die von EVGA mir sagten das das Anzeichen sind für mein Netzteil sei. Also Netzteil ist neu 750 W.
Hat einer auch schon solche Fehler gehabt?
[06.15.2014 at 07:14 am] DRAM 0,866 Abnormal
[06.15.2014 at 07:14 am] DRAM 1,640 Normal
[06.15.2014 at 07:17 am] DRAM 1,122 Abnormal
[06.15.2014 at 07:17 am] DRAM 1,634 Normal
[06.15.2014 at 07:18 am] DRAM 0,104 Abnormal
[06.15.2014 at 07:18 am] DRAM 1,634 Normal
[06.15.2014 at 07:24 am] DRAM 0,929 Abnormal
[06.15.2014 at 07:24 am] DRAM 1,634 Normal
[06.15.2014 at 07:41 am] CHA_FAN2 1317 Normal
[06.15.2014 at 07:54 am] OPT2 65,0 Abnormal
[06.15.2014 at 07:54 am] OPT2 64,0 Normal
[06.15.2014 at 07:55 am] OPT2 64,0 Normal
[06.15.2014 at 07:55 am] OPT2 65,0 Abnormal
[06.15.2014 at 07:59 am] OPT2 64,0 Normal
[06.15.2014 at 08:12 am] OPT2 65,0 Abnormal
[06.15.2014 at 08:47 am] NB 1,542 Abnormal
[06.15.2014 at 08:47 am] NB 1,118 Normal
[06.15.2014 at 08:59 am] NB 1,542 Abnormal
[06.15.2014 at 08:59 am] NB 1,111 Normal
[06.15.2014 at 09:02 am] NB 1,634 Abnormal
[06.15.2014 at 09:02 am] NB 1,111 Normal
[06.15.2014 at 09:40 am] HT 1,729 Abnormal
[06.15.2014 at 09:40 am] HT 1,217 Normal
[06.15.2014 at 09:57 am] DRAM 8,802 Abnormal
[06.15.2014 at 09:57 am] DRAM 1,634 Normal
[06.15.2014 at 10:06 am] CPU/NB 0,000 Abnormal
[06.15.2014 at 10:06 am] DRAM 0,000 Abnormal
[06.15.2014 at 10:06 am] HT 0,000 Abnormal
[06.15.2014 at 10:06 am] NB 0,000 Abnormal
[06.15.2014 at 10:06 am] SB 0,000 Abnormal
[06.15.2014 at 10:06 am] OPT2 0,0 Normal
[06.15.2014 at 02:07 pm] CPU/NB 0,000 Abnormal
[06.15.2014 at 02:07 pm] DRAM 35,162 Abnormal
[06.15.2014 at 02:07 pm] HT 0,000 Abnormal
[06.15.2014 at 02:07 pm] NB 0,000 Abnormal
[06.15.2014 at 02:07 pm] SB 0,259 Abnormal
[06.15.2014 at 02:07 pm] OPT3 -7,0 Abnormal
[06.15.2014 at 02:07 pm] Opt1 14336 Normal
[06.15.2014 at 02:07 pm] CPU/NB 1,164 Normal
[06.15.2014 at 02:07 pm] DRAM 1,634 Normal
[06.15.2014 at 02:07 pm] HT 1,217 Normal
[06.15.2014 at 02:07 pm] NB 1,111 Normal
[06.15.2014 at 02:07 pm] SB 1,105 Normal
[06.15.2014 at 02:07 pm] OPT3 38,0 Normal
[06.15.2014 at 02:07 pm] CHA_FAN1 1015 Normal
[06.15.2014 at 02:07 pm] CHA_FAN3 1046 Normal
[06.15.2014 at 02:12 pm] SB 0,000 Abnormal
[06.15.2014 at 02:12 pm] SB 1,105 Normal
[06.15.2014 at 02:12 pm] CHA_FAN1 1012 Normal
[06.15.2014 at 02:12 pm] CHA_FAN2 1015 Normal
[06.15.2014 at 02:12 pm] CHA_FAN3 1049 Normal
Sind nur einfache Auslesefehler. Das ist "normal" bei der AiSuite. Wenns nur um die Sensorenwerte geht nehmt andere Programme wie zb. Aida64 oder HWMonitor
Also bei mir dreht die AiSuite sofort am Rad wenn ich CPU-Z, oder HWMonitor, oder sonst ein Ausleseprogramm starte. Läuf sie alleine, macht sie was sie soll.
Ich lese bei mir ununterbrochen ,wegen meine G19, mit Aida aus.
Auf dem Display der Tastatur bleiben die Werte auch konstant.
Im Gegensatz zur AI Suite , die immer sehr schwankend anzeigt (auch im Idle)...
Hier gibt es oft Im Sekundentakt , Unterschiede von etlichen Grad...
Bei mir komischerweise auch , wenn ich die AI Suite allein laufen lasse
Das ist einer der Gründe , warum ich mir eine G19 angeschafft habe..
Ich kann zur jeder Zeit meine Temparaturen (und andere Daten) ablesen...(mit Aida)
Selbst bei Vollbildspielen , überdeckt garnichts mein LCD an der Tastatur...
Da ich meinen 8350 mit Luftkühlung (Noktua NDH14) übertakte,
ist mir wohler, wenn ich die Temps jederzeit sehen kann...
mfG
Achim
Ok die AiSuite Software ist schrott..... gleich mal deinstalliert. Bin jetzt auch bei Aida64.
Da ich ja jetzt so ein tolles Bord habe wollte ich auch was damit machen (Overclocking) :)
Also hab ich mit Prime95 geholt und wollte meine Daten auslesen was sie unter volllast machen. in der Regel kann ich ja davon ausgehen das mein Rechner stabil läuft.
Nur wenn prime ca. 15 -20 min läuft schmiert mein Rechner ab....... Jetzt frag ich mich wieso? Das einzige was ich verändert habe ist der Ram, denn hab ich auf das Profiel 2 laufen 1866..... Kingston HyperX KHX1866C9D3/4GX Alle 4 bänke sind belegt.
Alles andere ist wie ab Werk. Hat einer ein tipp wo ich anfangen kann zu suchen das er wenigstens im Stock stabil läuft unter prime95.... So läuft er ja unter diversen Office / Spiele - Programmen Stunden lang. Das einzige was mir sorgen macht ist die Ram Temp. die liegt im Leerlauf bei 51 Grad und unter prime95 bei 71 Grad.
Auch wenn es momentan etwas wärmer ist sind 51 Grad im Idle schon heftig. Ich selbst hab momentan 32 Grad auf der CPU und 22 Grad Kern Temperatur (die Kern Temperatur wird erst ab ca 40 Grad genau).
Was für eine Wasserkühlung hast du denn. Alles richtig montiert, laufen alle Lüfter?
Um den Ram auszuschliesen kannst du probeweise mal zwei Riegel entnehmen und nochmal testen. Ich würde mich aber erstmal um die Temperaturen kümmern.
Was wird denn bei der CPU und CPU-NB Spannung im Bios angezeigt?
kann mir jemand weiterhelfen? Mein MB kam heute von asus wieder, funktioniert laut asus einwandfrei, beim wegschicken leuchtete die cpu led rot und nichts ging mehr. Cpu tot? oder was kann es sein? hatte noch keine zeit zum einbauen
