[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
Bau erstmal alles zusammen und teste es. Auch wenn Asus sagt es läuft einwandfrei kann es sein das sie etwas gemacht haben (Bios Update, ... ).
BIOS war immer up to Date, ich dachte halt der Fehler liegt daran das Wasser aufs Board kam und nun nix mehr ging. Asus sagt Board geht
Hast du es jetzt mal zusammengebaut und getestet?
Wollt ich heut machen nur mir fehlt wlp. Zefix kein laden hat was. Muss morgen früh mal gugen
Wie ist der Stand?
heut abend weiss ich mehr wenns zamgebaut ist, unglaublich das kein grosser laden mehr wlp hat, musst zu nem kleinen und hatte no spätschicht deswegen erst heut abend zam bauen kann.
jetzt leuchtet die VGA led permanent rot, ich konnte ram, graka und cpu gegentauschen gegen komplett neue teile, inkl. NT. Immer noch das gleiche, ich raffs nicht wo etz der Fehler liegt, alles angeschlossen und borad wurde von Asus zweimal gegengetestet. Ich glaub ich probiers heut abend nochmal ansonsten schmeiss ichs raus und wechsel zu msi, ich hab echt keine nerven mehr mich mit asus rumzuärgern vor allem ist schon das zweite board.
Dann weiß ich im Moment auch nicht weiter. Man müsste das Board vor sich liegen haben :d.
jetzt gehts auch wieder keine ahnung woran es lag
Habe mal eine Frage:
1. Ist es normal das auf den USB Ports immer Strom ist auch wenn der Pc ausgeschaltet ist? Weil die Beleuchtung meiner Peripherie immer leuchtet.
habe ich auch..
daher nutze ich eine Steckdosenleiste,
die den Strom komplett cutted...
mfG
Achim
bei mir nicht.
tastaturbeleuchtung und die leds der maus sind nach abschalten des pc aus. der pc wird nur ganz normal herunter gefahren. keine steckdosnleiste oder ähnliches.
Ja , war dumm , meine Einlassung...(daher immer erst denken , dann posten - kommt ab sofort, auf meine ToDo-Liste)
.....den USB-Hub (aktiv) vergessen gehabt...
der wird ja auch noch vom Netzteil gespeist
aber vielleicht hat "ro0ki" auch noch einen aktiven Hub...
dann wäre das Verhalten "normal"
mfG
Achim
Das mit dem Dauerstrom auf den USB Ports kann man im Bios einschalten bzw. ausschalten
weil hier immer cap dateien gepostet wurden wie bekomm ich das zu ner rom datei zum updaten weil cap frisst das ja nicht?
Das normale Formula hat ROM Dateien und das Formula-Z hat CAP Dateien ;)
aso ok und fürs normale gibt es da ein aktuelles bios oder ist das letzte echt von 012?
Letzte Bios ist von 2012. Solltest du aber noch Bugs finden wird das Asus sicherlich fixen.
Zufälligerweise bin ich auf diesem Sammelthread gestolpert, falls dieser Posting hier nicht rein gehört, dann Sorry!
Ich habe im Internet erfahren, das dass ASUS Crosshair V Formula-Z die neuen AMD CPUs der FX-9xxx Serie unterstützen, jedoch muss das UEFI BIOS auf die Version 1403 aktualisiert werden.
Aber kann man wirklich eine FX-9590 auf dem Crosshair V Formula-Z einsetzen? Denn laut Datenblatt können Prozessoren mit max. 140 TDP eingebaut werden und die FX-9590 haben 220 TDP oder verstehe ich da was falsch?
Klar können die 9590 und 9370 auf dem Board eingestezt werden. Mach dir da keine Sorgen ;).
moin
kann mir einer sagen was ich machen muss damit mein PC auch so schnell startet?
http://www.youtube.com/embed/L1VrW_...This=true&TB_iframe=true&height=325&width=560
denn Knopf fast boot auf dem Board habe ich auf ON aber meine kiste startet nicht so wie im Video Link
CPU........................AMD FX-8350 8x 4,0 GHz @ 8x 4,5GHz
Motherboard .......... Asus Crosshair V Formula-Z
RAM.......................16GB Corsair Vengeance LP Black
Grafikkarte..............Asus Radeon R9 290X Matrix Platinum
Jo win 8.1
Gesendet von meinem GT-I9505 mit der Hardwareluxx App
Mal im Taskmanager den Reiter Autostart durchforsten, ob man das alles braucht , was da gestartet wird...
Alternativ wäre das Programm "Autoruns" das es im Programmpaket der "SysinternalsSuite" (von MS) gibt,
gut zu gebrauchen..
AUch schauen , was an Dienste alles geladen werden..
ob man die alle braucht...(eventuell mal hier lesen Windows-Dienste optimal konfigurieren - Windows-Tricks - Windows - PC-WELT)
denn alles was erst geladen werden muß , braucht auch Zeit
EDIT
In Windows 8/8.1 gibt doch auch "MSconfig" ...
damit lassen sich alle Startprogramme/Dienste gut einstellen
Hier wäre die offizielle Microsoft Seite , zum Nachschlagen zu empfehlen http://windows.microsoft.com/de-de/windows/using-system-configuration#1TC=windows-8
mfG
Achim
Scheint sich auch nichts mehr zu zucken, zwecks BIOS für das Formula-Z...22.05.2014.
Ich könnte kotzen: ein Board für über 200€ und so eine eingeschränkte Lüfterregelung (Temperatur bzw Drehzahlbereich).
Die CPU-Lüfter sind eigentlich ausreichend flexibel einstellebar (aber warum nicht 0% PWM???? Also aus)
Die optionalen Lüfteranschlüsse sind jedoch die Härte.
Auf Minimalstufe immer noch zu viel Spannung...warum nicht auch 0 Volt und fertig?!?!?!
Ein Sensor ist auf Min 40°C und Max 70°C eingestellt...
Die Sensortemp liegt bei 37°C
Die Lüfter drehen aber dennoch mit 800U/min (Maximaldrehzahl sind 1200U/min)
Fan Xpert unterstützt auch nicht die optionalen Lüfter.
das geht im Bootmenue
unter Boot
"Secure Boot Parameters"
und
"Secure Boot Mode"
mfG
Achim
