[Sammelthread] ASUS M4A88TD-M Evo/USB3, 880G
Link Geizhals ab: 87€
Herstellerlink
Spezifikationen:
Code:
[b]CPU[/b]
AMD Supports 45nm CPU
AMD Cool 'n' Quiet™ Technology Socket AM3 ;Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
[b]Chipsatz[/b]
AMD 880G/SB850
System Bus	5200/Up to ; HyperTransport™ 3.0 MT/s
[b]Memory[/b]
4 x DIMM, 16 GB, DDR3 2000*/1600/1333/1066 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Due to CPU spec., AMD 100 and 200 series CPUs support up to DDR3 1066Mhz. With ASUS design, this motherboard can support up to DDR3 1333MHz.
**Due to OS limitation, when installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
***Refer to www.asus.com for the memory QVL (Qualified Vendors Lists).
[b]Expansion Slots[/b]
1 x PCIe 2.0 x16
2 x PCI e x1
1 x PCI
[b]VGA[/b]
Integrated ATI Radeon™ HD 4250 GPU
SidePort Memory - onboard 128MB DDR3 1333 memory
Dual independent displays support with HDMI/DVI and D-Sub
Supports HDMI with max. resolution 1920 x 1200 (1080P)
Supports DVI with max. resolution 2560x1600 @60Hz
Supports D-Sub with max. resolution 2560x1440 @75Hz
Supports Microsoft® DirectX 10.1, OpenGL 2.0, Shader Model 4.1
Hardware Decode Acceleration for H.264, VC-1, and MPEG-2
Max. shared memory of 1GB
Hybrid CrossFireX™ Support
[b]Storage[/b]
SB850 Chipset
1 x eSATA port (6Gb/s ready)
5 x SATA 6.0 Gb/s ports 0,1,5,10 Support RAID VIA VT6415 PATA controller
UltraDMA 133/100 for up to 2 PATA devices
1 x
[b]LAN[/b]
Realtek® 8111E Gigabit LAN controller featuring AI NET2
[b]Audio[/b]	Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports 192kHz/ 24bit BD Lossless Sound
- Supports Jack-Detection, Multi-Streaming, and Front Panel Jack-Retasking
- Optical S/PDIF Out port at back I/O
[b]IEEE 1394[/b]
2 VIA® VT6315N controller supports x 1394a ports (1 at mid-board, 1 at back panel)
[b]USB[/b]
2 x USB 3.0 ports (@PCIE USB3 card)
14 x USB 2.0/1.1 ports (8 ports at mid-board, 6 ports at back panel)
[b]ASUS AI Lifestyle Features[/b]
ASUS Xtreme Design
ASUS Hybrid Processor - TurboV EVO
- Turbo Unlocker, Auto Tuning, TurboV, CPU Level UP, and GPU Boost
ASUS Hybrid Switch
- Core Unlocker
- Turbo Key II
ASUS Hybrid OS -- Express Gate
ASUS Power Solutions
- 4+1 Phase Power Design
- ASUS Anti-Surge Protection
- ASUS EPU
ASUS Exclusive Features
- MemOK!
ASUS Quiet Thermal Solution
- ASUS Fanless Design: Heat sink solution
- ASUS FanXpert
ASUS EZ DIY
- ASUS Q-Shield
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
- Multi-language BIOS
[b]Overclocking Features[/b]
Precision Tweaker - vCore: Adjustable CPU voltage at 0.003125V increment
- vDIMM: 64-step DRAM voltage control
- vChipset (NB): 64-step Chipset voltage control
2
SFS (Stepless Frequency Selection)
- HT tuning from 100MHz up to 550MHz at 1MHz increment
- PCI Express frequency tuning from 100MHz 150MHz at 1MHz
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
[b]Back Panel I/O Ports[/b]
x DVI
1 x D-Sub
1 x PS/2 Keyboard/Mouse Combo port
1 2 x USB 3.0 ports (@PCIE USB3 card)
6 x USB 2.0/1.1 ports 1 x HDMI
x External SATA
1 (Optical)
x S/PDIF Out 1 x IEEE 1394a
1 x RJ45 port
1 8 Channel Audio I/O
[b]Internal I/O Connectors[/b]
x USB connectors support additional 8 USB 2.0/1.1 ports
4 5 x SATA 6Gb/s connectors
1 x CPU Fan connector
1 x Chassis Fan connector
1 x Power Fan connector
1 x IEEE1394a connector
1 x S/PDIF Out Header
1 x Core Unlocker Switch
1 x Turbo Key II Switch
1 x MemOK! Button
Front panel audio connector
1 x COM connector
1 x LPT connector
1 x Clear CMOS jumper
1 x 24-pin ATX Power connector
1 x 4-pin ATX 12V Power connector
System Panel
x IDE connector
1
[b]BIOS[/b]
16 Mb Flash ROM , AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a
[b]Manageability[/b]
WOR by Ring,WOL by PME,WOR by PME,WOR by PME
[b]Accessories	[/b]
1 x PCIE USB3 card
1 x Ultra DMA 133/100 cable
2 x Serial ATA 6.0Gb/s cables
1 x Q-Shield
1 x User's manual & Support DVD for M4A88TD-M EVO
1 x User's manual & Support DVD for PCIE USB3
[b]Support CD[/b]
Drivers
ASUS Utilities
Anti-virus software (OEM version)
ASUS Update
[b]Form Factor[/b]
uATX Form Factor
9.6 inch x 9.6 inch 24.4 cm x 24.4 cm )
Das Bios:
Impressionen:
Übertaktung:
wird nachgereicht
Kühler welche passen oder nicht:
Luftkühlung:
Wasserkühlung:
Bios:
Version 1602
Update LAN option ROM to 2.35.
Version 1502
Set C1E function to enable as default.
Version 1404
Improve Auto Tuning function.
Version 1301
Improve system preformance.
Version 1012
Initial release.
Downloads:
- Bios / Treiber / Handbuch
Ruhezustand
Tach zusammen,
Vielleicht könnt ihr mir ja helfen. Habe ein Problem mit dem Ruhezustand und schiebe es jetzt einfach mal auf das Board. Hier mal meine Konfiguration
Windows7 64 bit
AMD X2 240
4 GB Ram
BeQuiet Netzteil
Silverstone Milo ML03
Und besagtes Board M4A88TD
Ich kann den Rechner in den Ruhezustand fahren, powercfg -h on ist gesetzt. Ich habe nur ein Problem mit dem wieder aufwecken. Ich kann auf dem Milo ML03, oder auf der Tastatur (Funk Logitech MK320) drücken was ich will, der Rechner wacht einfach nicht mehr auf. Ich muss den Saft komplett abdrehen, d.h. ich lege den Netzschalter am Netzteil ein paar Sekunden um und danach wieder ein, erst dann kann fährt der Rechner wieder mit dem Power Knopf hoch. Windows wird auch ordnungsgemäß fortgesetzt, aber es ist halt nervig immer hinter dem HTPC den Netzschalter zu ertasten im Schrank. Mit dem APM habe ich auch schon ein wenig herumgespielt im Bios, aber kein Erfolg gehabt. Es ist das aktuelle Bios 1702 installiert.
Danke!
guten abend, ich habe ein asus M4A88TD-V EVO/usb3 in meinem kleinen verbaut, weiß jemand ob das mb am3+ fähig bzw hat schon wer versucht einen zambezi da reinzuhaun? der chipsatz ist ja ein 880g mit dem eine ganze menge an MBs als am3+ fähig ausgegeben werden, mfg
Kennt jemand die Leistungsaufnahmen des reinen Mainboards ohne jeglichem Zubehör?
Habe weder im Internet, noch im UserGuide etwas nützliches gefunden...immer nur so angaben wie "man rechnet immer mit 20-30Watt"...
