[Sammelthread] Asus Maximus II Formula R.o.G. (Intel P45)
devic
Semiprofi
Übersicht
1. Allgemeines
  • 1.1 Layout
  • 1.2 Features
  • 1.3 Technische Daten
  • 1.4 BIOS Screens
  • 1.5 Lieferumfang
  • 1.6 Bilder
2. Nützliches
  • 2.1 Informationen
  • 2.2 FAQ
  • 2.3 Reviews / Previews
  • 2.4 Kompatibilitätsliste
3. Downloads
  • 3.1 BIOS
  • 3.2 Handbuch
  • 3.3 Treiber
  • 3.4 Software
_____________________________________
Allgemeines
1.1 Layout
1.2 Features
  • Intel® P45 Chipset
  • LGA775 Intel® Core™2 Extreme/Core™2 Quad/Core™2 Duo Processor Ready
  • PCIe 2.0
  • Dual-Channel DDR2
  • ATI CrossFireX Technology
  • CPU Level Up
  • Speeding HDD
  • Extreme Engine
  • Pin Fin Thermal Module
  • BIOS Flashback
  • Extreme Tweaker
  • Voltiminder LED
  • iROG
  • ASUS EPU-6 Engine
  • COP EX
  • Loadline Calibration
  • SupremeFX X-Fi
  • LCD Poster
  • Onboard Switch
  • ASUS Q-Connector
  • Fan Xpert
  • AI NOS™
  • ASUS O.C. Profile
  • C.P.R.(CPU Parameter Recall)
  • Noise Filter
  • EZ Flash 2
  • MyLogo3
  • Stack Cool 2
  • Q-Shield
  • Dual Gigabit LAN
  • IEEE 1394a interface
  • SATA on the Go
  • High Definition Audio
  • S/PDIF-out on Back I/O Port
  • Extreme Engine
    - 16-phase power design for CPU
    - 3-phase power design for north bridge
    - 2-phase power design for memory
CPU
Intel Socket 775 Processors for Intel® Core™2 Extreme / Core™2 Quad / Core™2 Duo / Pentium® dual-core/Celeron® dual-core /Celeron® Processors
Support Intel® next generation 45nm Multi-Core CPU
Compatible with Intel® 06/05B/05A processors
Chipset
Intel P45 / ICH10R with Intel® Fast Memory Access Technology
Front Side Bus
1600/1333/1066/800 MHz
Memory
4 x240-pin DIMM, Max. 16 GB, DDR2 1200/1066/800/667 Non-ECC,Un-buffered Memory
*Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lidts).
**When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Expansion Slots
2 x PCIe 2.0 x16 (single max @16,dual @ x8 speed)
3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
2 x PCI 2.2
CrossFire
Support ATI CrossFireX™ technology, up to Quad CrossFireX
Storage
Southbridge
6 xSATA 3 Gb/s ports Intel Matrix Storage Technology supports Support RAID 0,1,5,10 Marvell® 88SE6121 controller
1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
Silicon Image Sil5723
2 x SATA 3.0 Gb/s ports
Supports RAID 0, 1
LAN
Dual Gigabit LAN, both featuring AI NET2
Support Teaming Technology
Audio
SupremeFX X-Fi Audio Card
- ADI® AD2000B 8-channel High Definition Audio CODEC
- Creative X-Fi capability
- X-Fi interface
Coaxial/Optical S/PDIF out ports
IEEE 1394
2 x 1394a ports (1 port at back I/O, 1 port onboard)
USB
12 USB 2.0 ports (6 ports at mid-board, 6 ports at back panel)
Back Panel I/O Ports
1 x PS/2 Keyboard port(purple)
1 x eSATA port
2 x LAN (RJ45) ports
6 x USB 2.0/1.1 ports
1 x IEEE1394a port
1 x Clr CMOS switch
Internal I/O Connectors
3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
1 x Floppy disk drive connector
1 x IDE connector for two devices
6 x SATA connectors (Blue)
2 x Speeding HDD connectors (Black)
8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
3 x thermal sensor connectors
1 x IEEE1394a connector
1 x Chassis Intrusion connector
24-pin ATX Power connector
8-pin ATX 12V Power connector
1 x En/Dis-able Clr CMOS
1 x LCD Poster connector
1 x ROG connector
1 x Power-on switch
1 x Reset switch
System panel connector
BIOS
16 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.4
ACPI 2.0a
Multi-language BIOS
1.4 BIOS Screens
1.5 Lieferumfang
  • SupremeFX X-Fi Audio Card
  • LCD Poster
  • ASUS Optional Fan
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • Floppy disk drive cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • Q-Shield
  • Cable Ties
  • User's manual
1.6 Bilder
Nützliches
2.1 Informationen
Preis:
Produkthomepage:
OC-Ergebnisse:
2.3 FAQ
Messpunkte:
Quelle: Awardfabrik.de (@arne)
_______________________________________________________
Die GTL-Einstellung:
Die GTL ist ein Teiler. Sie ergibt mit der VTT multipliziert einen Wert in mV. Bei den meisten Board benutzt man den Teiler um auf einen höheren/niedrigeren (eben für die CPU perfekte) Endvoltage zu kommen. Beim Maximus II Formula wird dieser Teiler jedoch gefixt und dafür vom Endwert in mV abgezogen. Das hat den Vorteil, dass sich der Endwert bei gleicheingestellter GTL nicht durch die variable VTT ändert.
Beispiel mit Asus P5Q Deluxe und vielen anderen Boards:
VTT x GTL = mV
1,1V x 0,63V = 693mV
Beispiel mit Asus Maximus II Formula:
VTT x fixed GTL = mV - mV
1,1V x 0,677 = 744,7mV - 50mV
Beide Beispiele kommen auf etwa das gleiche raus ;)
Dickgedruckt = Jeweils im BIOS einstellbare Werte
Northbridge Temperaturproblem beheben:
Um die zu hohen Temperaturen der Northbridge zu senken, muss der Anpressdruck des Kühlsystems verstärkt werden. Dazu muss das Board ausgebaut und umgedreht werden. Daraufhin werden unter die Schrauben, die die Heatpipekühlung auf der Northbridge halten einfach zwei Unterlegscheiben (0,5 - 1mm) gelegt. Das erhöht den Anpressdruck und senkt gleichzeitig die Temperaturen der Northbridge.
Habt ihr hier nicht aufgelistete Hardware in Betrieb? Dann schreibt mir bitte eine . Danke!
Kühler schrieb:
  • Alpenfön Groß Clock'ner (nur mit leichtem Verbiegen der Lamellen!)
  • Arctic Freezer 7 Pro
  • Asus Silent Night 1+2
  • Asus Triton 79
  • Coolermaster Hyper 212
  • Noctua NH-U-12P
  • Scythe Mugen / Infinity
  • Thermalright IFX-14
  • Thermalright Ultra 120 eXtreme / True Black
  • Xigmatek HDT-S1283 / Red Scorpion
  • ZHEROtherm Nirvana NV 120
Arbeitsspeicher schrieb:
  • 2x 1GB A-DATA Vitesta Extreme DDR2-800
  • 2x 1GB Corsair XMS2 DHX DDR2-800
  • 2x 1GB Aeneon XTune DDR2-1066
  • 2x 1GB CompuStocx Diablo DDR2-1200
  • 4x 1GB Crucial Ballistix DDR2-1066
  • 4x 1GB Corsair Dominator DDR2-1066
  • 2x 2GB OCZ XTC Platinum DDR2-1000
  • 2x 2GB Apogee GT DDR2-1066
  • 2x 2GB Transcend aXeram DDR2-1066
  • 2x 2GB Corsair Dominator DDR2-1066
  • 2x 2GB G.Skill F2 4GBPK DDR2-1066
  • 2x 2GB G.Skill F2 4GBPI DDR2-1066
  • 2x 2GB G.Skill F2-4GBPI DDR2-1100
  • 2x 2GB Mushkin XP2 DDR2-1100
  • 2x 2GB OCZ Flex II DDR2-1150
  • 2x 2GB Chaintech Apogee GT DDR2-1150
Downloads
3.1 BIOS
3.2 Handbuch
3.3 Treiber
3.4 Software
Habt ihr Verbesserungsvorschläge -> --------Seid ihr zufrieden ->
Danke an e.v.o für die Unterstützung im Download-Part!
Jop. Habe ich auch schon gefunden. Danke!
Muss nochmal ordentlich zwischen Features und technischen Daten unterscheiden, dann kanns losgehn!
Ich verbinde Features und technische Daten einfach!
Bin auf den Test von AF gespannt, der im XS hat das Board ja auf keine 500 Mhz FSB gebracht, aber mal gucken was die neuen BIOS Versionen so bringen....:d
Echt, hast nen Link ?
Hab den Thread nur überflogen, dachte der testet den FSB :fresse:
Ich arbeite jetzt einfach mal an dem Sammelthread weiter... Wenn er Stress macht, kann er ja die Daten einfach übernehmen. Halte mich beim Layout ja auch stark an das vom P5Q Deluxe Sammelthread, weils mir einfach gefällt!
1.000 Post :d
Ich denke grad an die Sig von einem User hier:
"And dont forget kids, the more posts you have, the bigger your penis is!"
Sieht ja schon mal was von dermassen geil hier aus der Thread :hail:
Vielen Dank!
Bei +Flori+ könnt ihr euch für das Layout bedanken, das habe ich größten Teils aus seinem Asus P5Q Deluxe Sammelthread übernommen.
Die fehlenden Daten werden natürlich noch ergänzt!
Ich werde noch versuchen aus einem guten Foto der Maximus II Formula Verpackung einen ordentlichen Header (wird das so geschrieben?) zu machen.
Edit:
Vielleicht mache ich mir nachher mal die Mühe die ganzen englischen Angaben auf deutsch zu übersetzten.
Sagt mal was Weiße da in der Tüte beim Zubehör ? das schaut aus wie wakü adapter aber wozu sollte die solche beipacken :hmm:
Ist mir auch schon aufgefallen. Ist von einer Review-Seite des Maximus II Formula. Dann haben die wohl einen Fehler gemacht...
Danke für den Hinweis! Ich nehme auch Rechtschreibfehler gerne entgegen!
Edit:
Asus hat auf einmal das Maximus II Formula von der Seite genommen...
Da wird niemand nen Fehler gemacht haben, aber Asus verschickt Samples auch gerne
in Kartons von älteren Mainboards ;)
Oder das ;)
Finde ATM kein Bild von dem Maximus II Formula Zubehör. Weil es aber höchstwahrscheinlich dem des Maximus Formula sehr ähnlich sein wird, lasse ich das Bild mit einem kleinen Hinweis erstmal drin.
Edit#1:
Jetzt ist das Maximus II Formula wieder auf der Asus Seite zu finden...:hmm:
Edit#2:
Die Links zu den BIOSen kann ich erst morgen hinzufügen, wenn ich an meinen Computer kann. Die Asus-Support-Seite ist gescriptet, weswegen man nicht direkt verlinken kann. Werde die BIOSe dann einfach auf meine Page laden udn von dort aus verlinken.
Edit#3:
Besser habe ich es mit GIMP erstmal nciht hinbekommen. Wenn morgen mein Mainboard kommt, geh ich das nochmal richtig an!
Vielen Dank!
Edit:
@mentum_20: Die Bilder gefallen mir nicht richtig, weil nicht das ganze Zubehör zu sehen ist...
Super Thread! Hoffe das bald viele das board haben und ordentlich testen und poste!
Danke devic!!
Gratuliere zum 1000sten!
Das gefällt mir richtig gut, danke!
Danke für die ganzen Bildervorschläge! Werde morgen mal genauer durchschauen!
Eben war ich aber komplett durcheinander :d
Post gelöscht
Hab totalen Müll geschrieben. Habe gedacht ich befinde mich im Asus P5Q Deluxe Sammelthread :d
Jetz genug OT ;) Sonst gibts noch Stress...
