[Sammelthread] Asus Maximus III Extreme RoG (Intel P55)
Maximus III Extreme "Republic of Gamers"
Specifications
CPU Intel® Socket 1156 Core™ i7 Processor/Core™ i5 Processor/Core™ i3 Processor
Supports Intel® Turbo Boost Technology
* Refer to ASUSTeK Computer for Intel CPU support list
Chipset Intel® P55 Express Chipset
Memory 4 x DIMM, Max. 16 GB, DDR3 2200(O.C.)/2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Supports Intel® Extreme Memory Profile (XMP)
* Please refer to ASUSTeK Computer or user manual for the Memory QVL(Qualified Vendors List).
Expansion Slots 5 x PCIe 2.0 x16 Supports single at x16, dual at x16, triple at x 16 x16 x8, quad x8, or 5 x8
1 x PCI 2.2
Multi-GPU Support Supports NVIDIA® SLI™ Technology / ATI® CrossFireX™ Technology
Storage Intel® P55 Express Chipset built-in
6 xSATA 3.0 Gb/s ports (Gray)
Intel Matrix Storage Technology Support RAID 0,1,5,10
JMicron® 363 controllers:
- 1 x SATA 3.0 Gb/s port (Black)
- 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
Marvell® PCIe SATA 6Gb/s controller
- 2 x SATA 6.0 Gb/s ports (Red)
LAN Realtek® RTL8112L Gigabit LAN controller
Audio VIA® VT2020 10-Channel High Definition Audio CODEC
- Supports Blu-ray audio layer content protection
- Supports 1 Optical S/PDIF out port at back I/O
- Supports 1 S/PDIF out header
- Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
IEEE 1394 2 x 1394a port(s) (1 port onboard, 1 port at back I/O)
USB NEC® USB 3.0 controller
- 2 x USB 3.0/2.0 ports (at back I/O)
- 11 USB 2.0 ports (4 ports at mid-board, 7 ports at back I/O, 1 port at back I/O is also for ROG connect)
Overclocking Features ROG Connect
RC Bluetooth
Extreme Engine Digi+
- 8-phase CPU digital VRM power
- 3-phase VTT digital VRM power
- 3-phase Memory power
- ML Cap for CPU
ProbeIt
iROG
Extreme Tweaker
BIOS Flashback
Loadline Calibration
Intelligent overclocking tools:
- 8 O.C. Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features CPU Level Up
MemOK!
Onboard Button: Power / Reset / Clr CMOS (at back IO)
ASUS MyLogo3
ASUS Fan Xpert
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
ASUS Q-Slot
ASUS Q-DIMM
Back Panel I/O Ports 1 x External SATA
1 x IEEE 1394a
1 x LAN(RJ45) port
10 -Channel Audio I/O
1 x Clr CMOS switch
1 x PS/2 Keyboard port (purple)
7 x USB 2.0 ports (1 port also for ROG Connect)
1 x ROG Connect On/Off switch
S/PDIF Out (Optical)
Internal I/O Connectors 2 x USB connectors support additional 4 USB 2.0 ports
9 x SATA connectors: 2 x SATA 6.0Gb/s connectors (Red) / 6 x standard SATA connectors (Black) / 1 x SATA_E(Gray)
8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
5 x ProbeIt Measurement Points
3 x Thermal Sensor Connectors
1 x IEEE1394a Connector
1 x SPDIF_Out Connector
1 x 24-pin ATX Power Connector
1 x 8-pin ATX 12V Power Connector
1 x En/Dis-able Clr CMOS Switch
1 x LN2 Mode Header
1 x Power on Switch
1 x Reset Switch
2 x EZ Plug Connectors
1 x OC Station Header
1 x RC Bluetooth Header
1 x Go Button
1 x BIOS Button
System Panel Connector
BIOS 16 Mb Flash ROM AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
Manageability WOL by PME,WOR by PME,PXE
Accessories 1 x RC Bluetooth Card
1 x I/O Shield
1 x Optional Fan
1 x ROG Connect Cable
1 x SLI Cable
1 x 3-way SLI Cable
1 x 2-in-1 ASUS Q-Connector Kit
1 x 2-in-1 SATA 6.0Gb/s Cables
3 x 2-in-1 SATA 3.0Gb/s Signal Cables
1 x 2-port USB2.0 + ESATA Module
1 x Thermal Sensor Cables Pack
1 x Cable Ties Pack
1 x ROG Theme Label
1 x 12-in-1 ROG Cable Label
1 x User's Manual
Bluetooth Module Accessory Card
- Bluetooth V2.0/V2.1+EDR
- RC Bluetooth On/Off Switch
Support Disc ASUS PC Probe II
ASUS AI Suite
ASUS Update
Kaspersky® Anti-Virus
Support DVD:
- Drivers and Applications
Futuremark® 3DMark® Vantage Advanced Edition
ASUS TurboV EVO Utility
Form Factor ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Reviews
http://www.guru3d.com/article/asus-maximus-iii-extreme-review/
http://www.tweaktown.com/reviews/3193/asus_maximus_iii_extreme_p55_express_motherboard/index.html
http://www.bjorn3d.com/read.php?cID=1807
http://www.pureoverclock.com/review.php?id=942&page=1
OVP+Zubehör
Geizhals Link
ASUS Maximus III Extreme, P55 (dual PC3-10667U DDR3) (90-MIBBX0-G0EAY00Z) Preisvergleich bei Geizhals.at Deutschland
Treiber&Tools
ASUSTeK Computer Inc.-Support-
Bios Screenshots
Bios Downloadlink
ftp://ftp.asus.com.tw/pub/ASUS/mb/LGA1156/Maximus_III_Extreme/
Bios History
[ 0901 ]
1. Added additional memory settings for improved performance.
2. Enhanced overclocking.
3. Enhanced K series CPU support
[ 0805 ]
1.Fix system might hang when using Clarkdale i5 655 CPU and DIMM with 1600Mhz default SPD.
2.Fix BIOS setup might show incorrect Target DRAM Frequency when using DIMM with 1600Mhz default SPD.
[ 0705 ]
1. Improve memory compatibility
2. Improve system stability
3. Fix 2.2T HDD size is wrong if Quick Boot option is disabled
4. Improve compatibility with some USB3.0 devices
5. Support new CPUs. Please refer to our website at: ASUSTeK Computer Inc.-Support-
[ 0606 ]
3. Fix system will stay at POST screen too long when iPod 80GB is connected
4. Fix DEL and F8 keys doesn't work with Microsoft Reclusa Keyboard
5. Fix tRRD option can't be set to values lower than 4
[ 0503 ]
Fix TurboV and PC probeII may get incorrect value.
[ 0402 ]
[ 0309 ]
First Release Bios
CPU Support Liste
Core i3 530(2.93G,L2:4M, IGPU,rev.C2,73W) ALL 0218
Refer to below URL for more info: http://support.asus.com/faq
Core i3 540(3.06G,L2:4M,IGPU, rev.C2,73W) ALL 0218
Core i3 550(3.2G,L2:4M, IGPU,rev.K0) ALL 0705
Core i5 650(3.2G,L2:4M, IGPU,rev.C2,73W) ALL 0218
Core i5 655K(3.2G,L2:4M, IGPU,rev.K0,73W) ALL 0705
Core i5 660(3.33G,L2:4M, IGPU,rev.C2,73W) ALL 0218
Core i5 661(3.33G,L2:4M,IGPU, rev.C2,87W) ALL 0218
Core i5 670(3.46G,L2:4M, IGPU,rev.C2,73W) ALL 0218
Core i5 680(3.6G,L2:4M, IGPU,rev.K0,73W) ALL 0705
Core i5 750(2.66G,L3:8M, rev.B1,95W) ALL 0218
Core i5 750S(2.4G,L3:8M, rev.B1,82W) ALL 0218
Core i7 860(2.80G,L3:8M, rev.B1,95W) ALL 0218
Core i7 860S(2.53G,L3:8M, rev.B1,82W) ALL 0218
Core i7 870(2.93G,L3:8M, rev.B1,95W) ALL 0218
Core i7 875K(2.93G,L3:8M, rev.B1,) ALL 0705
Core i7 880(3.06G,L3:8M, rev.B1) ALL 0705
Pentium G6950(2.8G,L2:4M, IGPU,rev.C2,73W) ALL 0218
fragen zum board gehören in den sammelthread und nicht in eine PN. so ein vorgehen (PN wegen problemen oder allg. fragen) zeugt nur von egoismus. deshalb durchaus verständlich wenn es dann keine antwort gibt. ich hab auch keinen bock merfach das gleiche zu schrieben und antworte in so einem fall nicht oder mit verweis auf den ST. also: hier posten oder die füße stillhalten...
daher: posting entfernt
Wie ist das Board so? Ich überlege es mir auch zu holen. Gibts Probleme? Laßt es sich gut OC?
board ist top verabrbeitet
mit bios 0705 keine probleme
oc noch nicht getestet
Windows 7 ready ? welche Version von Kaspersky AntiVirus Programm ist auf der DVD ?
Bei M3F ist die version 7 dabei und ist nicht mit win7 kompatibel :)
wie verhält sich das board mit sli und dann usb3 bzw sata3 performance
bei den gigabyte wurde ja die leistung gemindert, wenn sli/cf aktiv war
habe min 10 reviews gelesen, aber nichts aussagekräftiges gefunden
du hast volle anbindung wenn du usb3 oder sata6 nutzt daher der plx chip
nicht so wie bei GB wo die lanes der graka einbrechen
Ich hab Bios 0503 u.hab mein i5 auf 4 Ghz gebracht, bei 1,36V, ist etwas zuviel, werde mal das neue Bios raufspielen und schauen ob er dann weniger braucht. BCLK bei 200, sobald ich mehr gebe muss ich die V-Core stark anheben, bekomme dann aber Bluescreens. Das Board ansich ist natürlich top, auch mit USB 3.0 für die Zukunft gerüstet, für den Preis kann man das aber auch erwarten...
Also nach paar Tagen rumprimen kann ich sagen (Bios 0705), dass das Board durchaus Potenzial hat. Allerdings braucht es, entweder weil ich mich zu glatt anstelle oder weil es das Board einfach braucht, deutlich mehr VTT als mein altes EVGA P55 FTW (BCLK 200MHz).
Ansonsten bin ich noch gut beschäftigt die vielen Einstellmögichkeiten auszuloten. Mal schauen was noch geht :)
nutzt einer sli von euch?
wenn ja mal die grakas in slot 1+2 drücken und schauen ob sie mit 16x angebunden sind
im asus forum schreibt mal das sie nur mit 8x laufen würden wenn die grakas in slot 1+2 wären
in slot +4 würden sie mit 16x laufen
kann das wer gegentesten??
weil sie müssen eigentlich in slot 1+2 mit 16x laufen
Bios Bug??
@Robär .. aus keinem Review, das ich bis jetzt gelesen habe, geht klar hervor, wie man 2 DualSlot Karten setzen kann, so dass beide mit voll 16 lanes angesprochen werden.
Da ich immer gut finde, wenn so 2 Hitzemonster einen möglichst weiten Abstand voneinander haben, würde ich wissen wollen, ob man sie in Slot 1 und 4 setzen kann.
Vielleicht kannst Du das mal testen .. danke
Erst einmal vornweg, das Board rennt wie Schmidt's Katze :d
BCLK 200 bei 1,14V VTT/IMC, das sind dann 0,03V weniger als auf dem EVGA P55 FTW. Langsam muss ich mich mal in Gefilde von BCLK 220+ machen :d
Bzgl. SLI/Crossfire und welche Slots man da zu benutzen hat kann ich leider im Moment keine Auskunft geben. Im Handbuch steht leider nichts drin, außer in dem Fall wenn 3 oder 4 Karten benutzt werden. Aber ich versuch mal noch irgendeine Grafikkarte zu organisieren.
kann mir einer sagen woran es liegen könnte warum das Netzwerk nach dem Boot solange sucht und erst nichts findet?
Dauert einige Zeit bis das gelbe Ausrufezeichen verschwindet!
Neueste Treiber ist installiert, aber mit dem Mitgelieferten ist es das gleiche.
Ansonsten ist das Board sehr gut.
Einwenig Probleme mit der Lüftersteuerung, komme da aber noch drauf.
noch keiner einen Tip woran es liegen könnte bzgl. der ewiglangen Netzwerksuche :-(
---------- Beitrag hinzugefügt um 14:42 ---------- Vorheriger Beitrag war um 11:15 ----------
Habe das Netztwerkproblem in den Griff bekommen, in dem ich im Gerätemanager alle NetzwerkTreiber(bis auf den letzten MS Treiber) deinstalliert habe. Immer jeweils Neu gestartet, dann Windows Update klicken und er schlägt Dir den neuesten RealtekTreiber vor.
Hoffe damit geholfen zu haben, bei mir hats wunderbar geklappt.
Gruß Sascha
Davon weiss ich leider nichts, funktioniert das etwa auch? Habe momentan ein EVGA FTW 200 und bin am überlegen mir das zu kaufen, frage wie laufen denn die G Skills Rip F3 16000 CL9D- 4GBRH damit?
Da ich bisher wenig Zeit hatte konnte ich die gewünschte Lane-Verteilung mit 2 Grafikkarten noch nicht testen. Desweiteren hat es meine G.Skill Perfect Storm dahin gerichtet. Muss euch deswegen leider erstmal die Antwort schuldig bleiben.
Eigene Erfahrungen habe ich nicht, aber sie stehen auf der QLV Liste von Asus.
ich bin der eine, der in dem Asusboard etwas zu crossfire geschrieben hat.
Wie gesagt, zwei Powercolor 5750 in Crossfire in Slot 1 und 2 gibt mir 8x/16x, tauschen bringt das gleiche.
Der Support wollte noch wissen, was ich habe, wenn nur Slot 1 besetzt ist, aber wollte dafür jetzt nicht meinen HTPC aus dem Rack rausfummeln.
Slot 2+4 kann ich auch nicht nutzen (weiß gar nicht, ob die crossfire Brücke da reicht...), weil im PCI eine TV-Karte steckt.
Bei Asus gabs jetzt den Hinweis, das wäre j normal, weil die 16 Lanes der CPU in zweimal 8 geteilt werden müßten, um mit 8 Lanes den NF200 anzusprechen.
Und das versteh ich nicht, weil ich 'nen Clarkdale habe, der doch die 16 Lanes gar nicht aufteilen kann, d.h. wenn ich nur eine Karte in Slot 1 habe, müßten es 16x sein, bei Karten in Slot 1 und 2 doch dann auch 16x/16x, oder?
Bye
Heißt also, dass du bei 2 Karten keine 16 Lanes für jede Karte bekommst?
Was passiert denn wenn du Slot 1 und 3 oder 1 und 4 benutzt?
Tja, hab's jetzt auch mal probiert.
In Slot 2+4 gibt's die vollen 16x/16x!
Und dazu kann ich dann aber nur noch sagen: wer zum Geier hat sich das Layout ausgedacht? Hinter dem ersten Slot ist 'ne Lücke, d.h. da wird jeder immer 'ne Grafikkarte einstecken wollen (und eine einzelne soll ja tatsächlich dort auch mit 16x laufen).
Aber jeder Enthusiast, der sich zwei Karten reinsetzen will, muss nun den 4er nehmen und verbaut sich damit den einzigen PCI-Slot.
Für 300 Tacken hätt ich da mehr erwartet...
bye
wieso, sei doch froh. So hast du zum CPU Kühler wenigstens etwas Platz. Bringt m.E. viel von den Tems her!
Wer braucht denn noch PCI wenn man 5x16 Slots zur Verfügung hat.
Also ich find das Teil klasse.
Hatte heute schon 4Ghz mit 1,35 vcore stabil unter Luft unter 70°C
gut ok wenn er etwas weiter unten angesiedelt wäre.
Also mit nem Noctua D14 ist der erste Slot nicht wirklich der Rede wert.
Aus diesem Grund habe ich mir das Board gekauft um später 2 Karten in nem guten Abstand zueinander laufen zu lassen
Hey Leute
habe jetzt auch mein Mobo bekommen, hoffe das ich die Woche noch die restlichen Teile bekomme, DHL hat bei mir wieder einmal schieße gebaut, Packet mit MoBo beim Nachbarn abgegeben, Tower nicht obwohl beide Packete im Fahrzeug wahren, keine Benachrichtigung erhalten und Festplatten und CPU Lüfter liegen seit 4.5. bei DHL in Bremen.
Hoffe ich bekomme die Woche nach alle Waren das ich endlich basteln kann.
1 x Intel Core i7-860, 4x 2.80GHz Erhalten
2 x G.Skill RipJaws DIMM Kit 4GB PC3-12800U CL9-9-9-24 Erhalten
1 x Asus Maximus III Extreme Erhalten
1 x Prolimatech Mega Shadow Kühlkörper Erhalten
2 x Scythe Slip Stream 120x120x25mm Erhalten
1 x Silverstone SST-FT02B Liegt bei der Post ggrr Scheiß DHLer
3 x Silverstone SST-CP05 Lieferung am 13.5
1 x Seasonic X-Series X-750 750W ATX 2.3 Erhalten
1 x Scythe Kaze Master Ace schwarz Erhalten
1 x Samsung SH-B083L bulk Erhalten
1 x Corsair Nova V64 Erhalten
2 x Samsung SpinPoint F1 1000GB Erhalten
1 x Gainward GeForce GTX 470, 1280MB GDDR5 Erhalten
1 x Microsoft: Windows 7 Professional 64Bit Erhalten
