[Sammelthread] ASUS Maximus V Extreme R.O.G (Z77)
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- ASUS Republic of Gamers Microsite ---
--- ASUS Maximus V Extreme R.O.G @ hwbot ---
--- ASUS Australia - Hands On Preview (+ OC-Primer) ---
---> mehr Bilder im User Review
Specifications
CPUIntel Socket 1155 Core i7/i5/i3/Pentium/Celeron processors
Sandy Bridge (32nm) & Ivy Bridge (22nm)
Intel Turbo Boost Technology 2.0
ChipsetIntel Z77
PLX PEX8747
PLX PEX8608
Expansion Slots5x PCIe 2.0/3.0 x16 (at 16, 8+8, 8+8+8 or 8+8+8+8 Lanes)
1x PCIe 2.0 x4
1x Mini-PCIe
Anbindung:
Graphics1) Intel HD Graphics
Multi VGA Output
- HDMI (1920x1200 @ 60Hz)
- DisplayPort (2560x1600 @ 60Hz)
- Thunderbolt (2560x1600 @ 60Hz)
2) Multi Graphics Technology
4-Way NVIDIA SLI technology
4-Way ATI CrossFireX technology
Memory4x DDR3-1066 / 1333 / 1600 / 1866-2000-2133-2200-2400-2600-2666-2800 (OC) Non-ECC U-DIMM
Dual Channel Memory Architecture
Support for Extreme Memory Profile (XMP v1.3) memory modules
ThunderboltIntel DSL3310
Single Channel
6 daisy chainable devies
VGA enabled
AudioRealtek ALC898 HD-Audio Codec
2 / 4 / 5.1 / 7.1 Channel
Support for S/PDIF In/Out
Networking1x Intel 82579V Gigabit-Ethernet (10/100/1000 Mbit)
AzureWave AW-NB111H (802.11a/b/g/n Dual Band WiFi)
Bluetooth V4.0 & V3.0+HS
Storage InterfaceSouth Bridge: 2x SATA 6Gb/s, 4x SATA 3GB/s, RAID 0/1/5/10
ASMedia ASM1064: 4x SATA 6Gb/s
USBChipset: 4x USB 3.0 (2x back, 2x internal)
Chipset: 8x USB 2.0 (4x back, 4x internal)
ASMedia ASM1042: 4x USB 3.0 (2x back, 2x mid)
Internal I/O Connectors2x USB 3.0
2x USB 2.0
6x SATA 6Gb/s
3x SATA 3Gb/s
S/PDIF-Out
Frontpanel Audio (AAFP)
OC Key
2x Subzero Sense
2x VGA Hotwire(s)
Slow Mode
15x ProbeIt measure points
7x ProbeIt cable
3x Thermal Sensor
Power-on button
Reset button
ROG Connect switch
LN2 Mode switch
Go Button
BIOS Switch button
mPCIe Combo header
Fan:
2x CPU (4pin)
3x Chassis (4pin)
3x Optional (4pin)
Power Connector:
24-pin EATX
8-pin ATX 12V
4-pin ATX 12V
6-pin EZ_PLUG
4-pin EZ_PLUG
Back Panel ConnectorsPS/2 keyboard/mouse combo
Thunderbolt
DisplayPort
HDMI
LAN (RJ45)
4x USB 3.0
4x USB 2.0
1x Optical S/PDIF out
1x Optical S/PDIF in
5x Audio
Clear CMOS button(s)
ROG Connect On/ Off
I/O ControllerNuvoton NCT6779D
H/W MonitoringCPU/System fan fail warning
CPU/System fan speed detection
CPU/System fan speed control
CPU overheating warning
System voltage detection
CPU/System temperature detection
BIOS2x 64Mb UEFI AMI BIOS (Cfon EN25F64)
PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a
Multi-Language
Unique FeaturesmPCIe Combo™ (mPCIe/mSATA combo card)
ROG OC Key
- OSD TweakIt
- OSD Monitor
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Subzero Sense
- VGA Hotwire
- Slow Mode
- LN2 Mode
- PCIe x16 Lane Switch
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
ASUS TurboV EVO :
- TurboV
ASUS EPU :
- EPU
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Bundle SoftwareKaspersky Anti-Virus
DAEMON Tools Pro Standard
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form FactorE-ATX Form Factor; 30.5cm x 27.2cm
Lieferumfang
  • Mainboard
  • User's manual
  • I/O Shield
  • 2x SATA 3Gb/s cable(s)
  • 6x SATA 6Gb/s cable(s)
  • 3-Way SLI bridge(s)
  • 4-Way SLI bridge(s)
  • SLI bridge(s)
  • CrossFire cable(s)
  • Q-connector(s) (2 in 1)
  • 2-port USB 2.0 and eSATA module(s)
  • ROG Connect cable(s)
  • ProbeIt cable set(s)
  • 12 in 1 ROG Cable Label(s)
  • mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
  • 2-in-1 RF Cable(s)
  • 2x Wi-Fi Ring Moving Antenna(s)
  • OC Key(s)
  • OC Key cable(s)
Schema
BIOS
1) Bilder
2) Spannungen
CPU VCore Offset-0.635 bis +0.635V, in 0.005V Schritten
iGPU Voltage Offset-0.635 bis +0.635V, in 0.005V Schritten
VCCSA Voltage0.800 bis 1.700V, in 0.00625V Schritten
VCCIO Voltage0.900 bis 1.550V, in 0.00625V Schritten
2nd VCCIO Voltage0.400 bis 1.700V, in 0.00625V Schritten
CPU PLL Voltage1.250 bis 2.500V, in 0.00625V Schritten
Skew Driving Voltage0.275 bis 1.600V, in 0.00625V Schritten
PCH 1.05V Voltage0.800 bis 1.600V, in 0.00625V Schritten
VTTDDR Voltage0.625 bis 1.100V, in 0.00625V Schritten
DDR3 Voltage1.200 bis 1.920V, in 0.005V Schritten
Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
3) BIOS Downloads: (ME-Updater v8.1)
4. Unofficial BIOS Downloads (Nutzung auf eigene Gefahr!)
5. Unofficial ME Updates (Nutzung auf eigene Gefahr!)
News & Reviews
Hardwareluxx News: Asus stellt Maximus V Extreme vor
Hardwareluxx News: ASUS gibt Preis und Verfügbarkeit des Maximus V Extreme bekannt
International Reviews
00) Hardwareluxx Review: Test: ASUS Maximus V Extreme
01) Guru3d
02) Overclock3D
03) t-break
04) Hardware.Info (UK)
05) Hartware.net
06) ocaholic
07) Gamezoom
08) McZonk - User Review @ PCGHX
09) Bjorn3d
10) Techpowerup
11) --> bitte weitere Review Links im Thread posten!
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
  • Hersteller | Modell | Preisvergleich | kompatibel | Einschränkungen / Anmerkungen
  • Hersteller | Modell | Preisvergleich | inkompatibel | Grund
  • GeIL | EVO Leggera GEL316GB1866C9DL | 2x8GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-1600C9Q-32GXM | 4x8GB | DDR3-1600 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-17600CL9D-4GBXLD | 2x4GB | DDR3-2200 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • G.Skill | Sniper F3-1866C10Q-32GSR | 4x8GB | DDR3-1866 CL10 | Preisvergleich | kompatibel
  • G.Skill | TridentX F3-2400C10D-8GTX | 2x4GB | DDR3-2400 CL10 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator GT CMT12GX3M3A2000C9 | 3x4GB | DDR3-2000 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator CMD8GX3M2A1600C8 | 2x4GB | DDR3-1600 CL8 | Preisvergleich | kompatibel
  • Corsair | Dominator CMP16GX3M4X1866C9 | 4x4GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • Corsair | Vengeance CMZ32GX3M4X1600C10 | 4x8GB | DDR3-1600 CL10 | Preisvergleich | kompatibel
  • Mushkin | Blackline Ridgeback 998826 | 3x2GB | DDR3-1600 CL6 | Preisvergleich | kompatibel (User: emissary42)
  • Mushkin | Blackline Frostbyte 996829 | 2x2GB | DDR3-2000 CL7 | Preisvergleich | kompatibel (User: emissary42)
  • Kingston | HyperX Genesis KHX2133C11D3K4/16GX | 4x4GB | DDR3-2133 CL11 | Preisvergleich | kompatibel (Review: GameZoom)
  • Kingston | HyperX LoVo KHX1600C9D3LK2-8GX | 2x4GB | DDR3-1600 CL9 1.35v | Preisvergleich | kompatibel (User: emissary42)
  • Samsung | Green MV-3V4G3D | 2x4GB | DDR3L-1600 CL11 | Preisvergleich | kompatibel (User: emissary42)
3) Mainboard
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.
Nützliche Links (im Forum & im WWW)
INCOMING... Mini-Review?
Zum User Review: Mangels Interesses hier im Thread, habe ich das Vorhaben kurz nach den Aufnahmen und Tests verworfen. Deshalb wird es von mir nicht mehr fertig gestellt.
Vintage Gallery
Mein Testsetup
CPUIntel Core i5-3570K
MainboardASUS Maximus V Extreme R.O.G (BIOS 704)
Memory2x2GB G.Skill RipajwsX F3-17600CL9D-4GBXLD (PSC X)
2x4GB G.Skill F3-14900CL8D-8GBXM (Samsung HCH9)
2x4GB Samsung Green 30nm MV-3V4G3D (Samsung HYK0)
2x2GB Kingston HyperX T1 DDR3-2000 CL8 (KHX2000C8D3T1K2/4GX, Elpida Hyper)
2x2GB GeIL Ultra DDR3-2133 CL9 (GUP34GB2133C9DC, Epida BBSE)
CoolingThermaltake FRIO CL-P0564 (CPU)
230mm Cooler Master (Mainboard-Rückseite)
140mm Corsair AF (Chipsatz)
Power SupplySuper Flower Golden Green 400W (SF-400P14XE)
HDDWestern Digital Raptor 74GB
PeripheryAvocent Switchview DVI
Razer Diamondback
Microsoft Natural Keyboard 4000
SoftwareMicrosoft Windows 7 Pro SP1, aktuelle Treiber
Vergleichswerte
1) AMD FM1 Plattform: AMD A8-3870K, Gigabyte A75-UD4H, 4GB G.Skill RipjawsX @ DDR3-1866 (OC:2200)
2) Intel LGA1366 Plattform: Intel Core i7-980X, Gigabyte X58A-OC, 6GB Kingston HyperX @ DDR3-1333 (OC: 1600)
3) Intel LGA1155 Plattform: Intel Core i5-3570K, ASUS Maximus V Extreme (Z77), 4GB RipjawsX @ DDR3-1600 CL9
4) Intel Pentium G2120 (simuliert): Intel Core i5-3570K @ 3.1Ghz (2c2t), sonst siehe 3)
Benchmarks - synthetisch
Bonus - Memory Overclocking
1) G.Skill RipjawsX F3-17600CL9D-4GBXLD (2x2GB DDR3-2200 CL9-11-9-28, PSC)
DDR3-2500 | CL9-11-9-28-1T | 1.65v | 2x2GB | Screen
2) G.Skill RipjawsX F3-14900CL8D-8GBXM (2x4GB DDR3-1866 CL8-9-9-27, Samsung HCH9)
DDR3-2000 | CL8-9-9-21-1T | 1.575v | 2x4GB | Screen
3) G.Skill ECO F3-12800CL7D-4GBECO (2x2GB DDR3-1600 CL7-8-7-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.637v | 2x2GB | Screen
4) G.Skill Sniper F3-14900CL9D-8GBSR (2x4GB DDR3-1866 CL9-10-9-29, Hynix CFR)
DDR3-2500 | CL11-12-11-26-1T | 1.60v | 2x4GB | Screen
5) Samsung Green MV-3V4G3D (2x4GB DDR3-1600 CL11-11-11-31, HYK0)
DDR3-2400 | CL9-11-11-26-1T | 1.625v | 1x4GB | Screen
6) Mushkin Blackline Ridgeback 998826 (3x2GB DDR3-1600 CL6-8-6-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.650v | 2x2GB | Screen
7) G.Skill TridentX F3-2400C10D-8GTX (2x4GB DDR3-2400 CL10-12-12-31)
DDR3-2200 | 9-10-10-26-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2400 | 10-11-11-26-1T | 1.563v | 2x4GB | emissary42 | Screen
DDR3-2500 | 10-12-12-28-1T | 1.563v | 2x4GB | emissary42 | Screen
8) Kingston HyperX LoVo KHX1600C9D3LK2-8GX (2x4GB DDR3-1600 CL9-9-9-24 1.35v)
DDR3-2133 | 10-12-11-28-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2200 | 10-12-11-28-1T | 1.538v | 2x4GB | emissary42 | Screen
DDR3-2400 | 11-13-12-31-1T | 1.525v | 2x4GB | emissary42 | Screen
9) Mushkin Blackline Frostbyte 996829 (2x2GB DDR3-2000 CL7-10-8-27 1.65v, PSC)
DDR3-2060 | 6-9-6-24 1T | 1.650v | 2x2GB | emissary42 | Screen
DDR3-2284 | 7-10-7-26 1T | 1.650v| 2x2GB | emissary42 | Screen
DDR3-2400 | 8-11-8-28 2T | 1.700v| 2x2GB | emissary42 | Screen
10) Corsair Dominator GT CMT12GX3M3A2000C9 (3x4GB DDR3-2000 CL9-10-9-28 1.65v, Hynix CFR)
DDR3-2600 | 11-13-12-29 1T | 1.650v | 3x4Gb | emissary42 | Screen
DDR3-2666 | 11-13-13-31 1T | 1.650v| 2x4GB | emissary42 | Screen
WORK IN PROGRESS!​
Kurze Frage... im Bios steht da unter der Bios Version und dem Datum eine EC Version und eine EC2 Version. Was bedeuten beide versionen?
Trotzdem, ein großes Danke an dich. Man muss ja auch nicht alles selbst können, wenn man die entsprechenden Kontakte hat? :bigok:
jetzt habe ich mein system soweit fertig und möchte noch ein bisschen feintuning machen.es gibt ja die möglichkeit mit dem fast boot (USB initialisierung) das system etwas schneller zu starten, wenn man die option unter fast boot den USB Support auf disabled stellt. siehe auch hier bei 0:38 Technologie Asus Fast Boot : activation via l'UEFI - YouTube
Natürlich komme ich mit der einstellung so ohne weiteres nicht mehr ins Bios, weil Tasta und Maus per USB angeschlossen ist.
Kennt jemand ne Möglichkeit wie es dennoch geht und das bios zu resetten?
Auf der Asusseite gibt es eine Software um von Windows direkt ins BIOS zu booten.
Asus Bootsettings
Einfach in der Downloadsektion vom Board suchen.
und wenn ich im bios bin kann ich maus unt tastatur auch verwenden? :-) hat das jemand mal getestet?
Hallo, ich bin neu hier.
Ich habe leider auch gleich eine Frage, genauer gesagt 4: :o
ich vermute das emissary42 der richtige Ansprechpartner ist, da seine Bemerkungen zwecks Thunderbolt mich erst dazu brachten, folgendes Detail überhaupt's erst einmal zu recherchieren:
ich plane einen Videobearbeitungs-PC zu erstehen oder ihn ev. auch selbst zusammenzubauen. Thunderbolt (und DP) möchte ich als Option dabei haben, auch wenn ich diese Variante noch nicht nutze.
Asus bietet Thunderbolt für 3 boards an, die ich mir daher auch genauer anschaue (und ich möchte nach Möglichkeit nicht von Asus weg, da ich mit denen bisher sehr zufrieden bin):
Maximus V Extreme
P8Z77-V Premium (schon komplett)
P8Z77-V Pro/Thunderbolt (=kein DP, dafür DVI und ein seltsamer Hinweis auf 'RGB' => VGA?)
1. Wieso brauchst Du/Sie speziell die Maximus im Zusammenhang mit Thunderbolt?
Ich habe zwar schon einen Hinweis bei den beiden 'V'-Versionen gefunden, zwecks geteilter Bandbreite... aber zumindest bei der Pro/Thunderbolt steht schon in der Produktübersicht auf der Asus Website, das man das auf volle Nutzung umstellen kann.
Falls das der Grund ist, geht das bei der Premium nicht (da sie ja anscheinend auch keine Alternative ist?)?
Oder übersehe ich da was?
2. kann es sein, das nur die Premium echte 2x 16 anbietet? Bleibt es dabei die PCIe 3.0 Variante?
Die Maximus scheint 3-fach und 4-fach als x16 zu haben, aber ich sehe nichts mit 'normalem' SLI-Verbund.
Die Tabelle mit den 'shared'-Einträgen kapiereich nur insoweit, das da was shared ist, aber nicht, inwieweit sich das dann ev. verändernd/einschränkend auswirkt.
In der weiter entfernten Vergangenheit habe ich eigentlich immer selbst herumgeschraubt, allerdings waren das immer simplere Computer und nichts war mit der aktuellen Entwicklung vergleichbar. Ich kenne leider auch die heutigen (oder damaligen) Begriffe eher nicht, da ich das Meiste durch herumprobieren und andere Computer zerlegen / vergleichen gelernt hatte => bitte nicht wundern, wenn ich nix kapiere.
3. Taugt der Marvel-Controller auf der Premium genug, um damit halbwegs vernünftig mehrere SSDs zu verwalten? Soweit ich mich da hieingelesen habe, brauche ich vermutlich 1 Set als 'Raid' und vermutlich 3 nicht als Raid verknüpfte Platten (ev. Windows und Windows Temp sep. plus Datenspeicherung). Bei der Maximus bräuchte ich - zumindest glaube ich das so verstanden zu haben - eine extra Controller-Karte zwecks der 'nicht so dolle' on-board Variante für Adobe CS Zwecke?
Hmmm, ich traue mich noch, eine 4. Frage zu stellen:
für Adobe CS6 inkl. AE / PP / PS.... eher die Maximus (die mir auch ob der erweiterten Menge a PCIe's gefällt), oder eher die Premium nehmen? Die Pro ist mir ein wenig zu wenig erweiterungsfähig (dual-slot GPU), hat kein DP...
vielen Dank fürs Lesen!
Wir benutzen das TB-Interface hier in der Firma hauptsächlich für Backups von virtuellen Maschinen und für die Software-Zertifizierung / Produkttests. Ursprünglich hatten wir dafür ein anderes Modell, dass sich jedoch als nicht sehr haltbar herausgestellt hat, weshalb ich mein privates Spielzeug (M5E) dann vorübergehend dafür hergegeben habe. Privat habe ich etwas mit TB und PCIe-Boxen in Windows 7 experimentiert und TB-Storage steht hier auch irgendwo herum.
Kann es sein, das nur die Premium echte 2x 16 anbietet? Bleibt es dabei die PCIe 3.0 Variante?
Wenn du volle zwei PEG nach PCIe 3.0 Standard mit nativer Anbindung willst, dann musst du dich von LGA1155 verabschieden und mit LGA2011 liebäugeln. Dann fällt allerdings Thunderbolt flach. Es würde für dich dann also auf einen Kompromiss hinauslaufen. Bei allen Z77 Modellen, die mit mehreren x16 Slots beworben werden, wird dies durch Verwendung eines PLX PCIe Switches realisiert, weil die Prozessoren selbst nur 16 PCIe 3.0 Lanes besitzen (Core i5 und Core i7, bzw Xeon).
Beim M5E wurden für unterschiedliche Setups verschiedene Anbindungs-Alternativen implementiert. Für ein 2 Way SLI sind, wie in der Grafik zu sehen, die beiden nativ angebundenen Slots mit jeweils 8 PCIe 3.0 Lanes vorgesehen. Diese bieten in der Regel eine bessere Performance als zwei per PLX auf 16 Lanes geswitchte PEG. Zwar sollten diese eigentlich einen Performancevorteil durch die zusätzliche Bandbreite haben, jedoch wird dieser in der Praxis durch die, bei Verwendung eines solchen Switches zusätzliche Latenz, teilweise wieder aufgefressen. Der PLX hat trotzdem seine Daseinsberechtigung, weil er für 3 Way und vor allem für 4 Way Setups gebraucht wird (dann mit 8 PCIe 3.0 Lanes pro Karte).
Siehe dazu auch die Grafik im ersten Beitrag oder hier.
Wenn du ein SSD-RAID bilden willst, würde ich dafür unabhängig vom Typ des Add-On Controllers immer die Intel Ports bevorzugen. Die einzige Ausnahme dafür wäre ein Onboard LSI, wie er auf ein oder zwei X79 Modellen zu finden ist. Man kann an einem ASMedia oder Marvell SATA Controller sicherlich auch SSDs betreiben und/oder einen RAID Verbund erzeugen, die Performance kann aber mitunter etwas gegenüber den integrierten 6Gb/s Anschlüssen zurückbleiben. Wenn man sich dessen bewusst ist, spricht aber nichts dagegen die Anschlüsse trotzdem zu verwenden. Man sollte eben nur wissen, was man erwarten kann und was nicht ;)
Mit dem Premium selbst hatte ich bisher nicht viel zu tun und ein RAID Setup mit dem Add-On controller habe ich nie getestet. Daher kann ich zu deiner Frage selbst nichts sagen.
Das Mainboard spielt für CS6 im Prinzip keine größere Rolle, hier kommt es vor allem auf CPU-Leistung an. Eine leistungsfähige Grafikkarte kann aber natürlich helfen, je nach Anwendungsgebiet mal mehr und mal weniger. Die Speicherbandbreite der beiden Modelle unterscheidet sich bei gleichen Einstellungen ebenfalls nur im Bereich der Messungenauigkeit. Das M5E bringt eine Menge Funktion mit, die sich vor allem an Overclocker richten. Auch wenn du diese nicht nutzt, hast du am Ende trotzdem dafür bezahlt. Deshalb würde ich mir noch mal überlegen, bei welchem der beiden Modelle du wirklich mehr für dein Geld / deinen Anwendungsbereich bekommst.
Wir benutzen das TB-Interface hier in der Firma hauptsächlich für Backups von virtuellen Maschinen und für die Software-Zertifizierung / Produkttests. Ursprünglich hatten wir dafür ein anderes Modell, dass sich jedoch als nicht sehr haltbar herausgestellt hat, weshalb ich mein privates Spielzeug (M5E) dann vorübergehend dafür hergegeben habe. Privat habe ich etwas mit TB und PCIe-Boxen in Windows 7 experimentiert und TB-Storage steht hier auch irgendwo herum..
Uuuups, da habe ich mich wohl 'mal wieder nicht eindeutig ausgedrückt:
warum muss es für die Thunderbolt-Nutzung speziell das Maximus sein, die Bemerkungen hier klangen - für mich - so, als ob es keine Alternative gäbe. => unterscheidet sich die Technik hinter dem Thunderbolt auf dem Maximus von der Technik hinter den P8Z77-V boards? Lt. den mal vorkommenden und mal eben nicht vorkommenden Bemerkungen bei Asus wäre das möglich.
Nachdem Premiere Pro im Gegensatz zu After Effects sowieso nur eine GPU verwendet, bin ich da sowieso noch am überlegen.... Habe mich auf die Ivy Bridge unter anderem zwecks Optimus - HD 4000... eingeschossen, ich mache auch Projekte, die kaum Rechenleistung ziehen (ähnlich Office). Energie sparen, Lärm,... ich bin auf der Suche nach dem 'besten' Kompromiss.
wieder was dazu gelernt (auch wenn ich wie immer in letzter Zeit google zur Übersetzung der 'neuen' Begriffe bzw Abkürzungen brauche. Komme aus der Zeit, als man statt 'at' noch Klammeraffe sagte - genau genommen aus der Zeit als es noch lange keine Computer für 'Normalos' gab) ;)
hihihi, ja, man sollte es wissen. Zum Teil weiss ich es sogar schon. Wie gesagt, für mich ist das ganze Thema RAID... Neuland.
Seit den xxxx-Einträgen im WWW die ich gelesen habe.... blick ich manchmal noch weniger durch wie vorher, manchmal aber auch mehr, so wie durch diesen Thread. Echt angenehm mal so alles übersichtlich aufgelistet zu sehen und die passenden Probleme, Lösungen,... an einem Ort zu finden - und diesesmal sogar auf deutsch.
Die meisten posts gaben mir den Eindruck, am Besten sei eine eigene Controller-Karte. on-board Intel... ja. Einzige Ausnahme irgendwo war eine laaaaange Siskusion über speziell den Marvell PCIe 9230 controller, angeblich soll der besser sein. Hatte auf muttersprachliche Bestätigung gehofft, mein - damals eher magerer - Englischunterricht liegt schon gute 30 Jahre zurück. ;) Inzwischen lese ich viel auf Englisch, aber ein neues technisches Thema, ungewohnte Fachbegriffe.... manchmal bin ich mir 'halt niht sicher. Kein gejaule, nur so als Erklärung.
Meine Frage zwecks dem Mainboard war mehr zwecks der Anschlüsse (DP, Thuderbolt, DVI, ....) - welches von der Ausstattung 'breiter' für zukünftige Überraschungen gewappnet sein könnte. Ich schneide vor allem für Jugendliche, die bringen jedes Jahr noch moderneres 'Zeug' daher, wenn dann die Fileart / Kompression.... zu ungünstig ist, streikt mein alter PC.
GPU - denke gerade über die Asus GTX 670 4GB (oder 2GB, da wüsste ich jemanden zum weitervererben, falls die irgenwann nicht mehr reicht)
After Effects nutzt alle GPUs => Maximus scheint ein wenig grösser zu sein, könnte bei der Hitze helfen.... auch ein Punkt der für mich wichtig ist.
Also um deine Ur-Frage noch zu beantworten: Ich hatte mir das M5E gekauft, weil es neben Thunderbolt und DisplayPort (brauche ich für meinen Desktop KVM), auch eine Plattform zum CPU und Speicher testen/benchen darstellt. Wenn das Interesse hier im Thread damals etwas größer gewesen wäre, hätte mich auch noch etwas ausführlicher mit anderen Aspekten des Mainboards beschäftigt und ein paar Sätze zu dem einen oder anderen Punkt verloren, in etwa in diesem Stil. Da meine Zeit aber begrenzt ist, habe ich mich dann lieber anderen Dingen gewidmet... Wie das Leben nun mal so spielt.
Wirklich falsch machst du mit beiden Mainboards, dem Premium und dem M5E, nichts - auch wenn sie unter den 1155er Modellen, bedingt durch ihre Ausstattung, nicht gerade die sparsamsten sind. Die Mainboard-Kühlung ist aber bei den Modellen absolut ausreichend, seit die Northbridge in die CPU "gewandert" ist, gibt es auf dem Boards selbst nicht mehr viel zu kühlen (SB, PLX, Wandler). Aber warte mit dem Kauf nicht zu lang. Die nächste Plattform kommt bestimmt und dann geht alles wieder von Vorne los.
Btw: Nvidia Optimus für den Desktop gibt es nicht
hat das asus m5e ein button um direkt in bios zu gelangen?
Im Handbuch steht für den Go button um irgendwelche OC Profile zu laden.
sorry irgendwie war da noch der text von dem letztn post drin. ich meine gibt es direkt ein knopf auf dem board. beim m5e?
Also um deine Ur-Frage noch zu beantworten: .....
Wirklich falsch machst du mit beiden Mainboards, dem Premium und dem M5E, nichts - ......
.... Aber warte mit dem Kauf nicht zu lang. Die nächste Plattform kommt bestimmt und dann geht alles wieder von Vorne los.
Danke für die Mühe. Ich bin schon einen guten Schritt weiter. Ich recherchiere ja erst seit en paar Wochen, dachte anfangs sogar über eine Workstation nach (bis ich das zwecks CS-Anwenderposts wiederfallen ließ) => da muss ich auch den Optimus Begriff aufgeschnappt haben.
Nächsten boards = vielleicht ist das der Grund, das die Premium fast nirgends zu finden sind? Mir scheinen Asus/Thunderbolt boards oft schon vergriffen zu sein. Im Sommer dann Haswell.... eigentlich brauche ich meine 'Kiste' früher....
.... life = kenn ich ;)
Wie auch immer, dieses Thread und die 'Info-Zentrale' am Anfang finde ich sehr gut = danke für die viele Mühe!
Der Knopf hat zwei Funktionen:
1) Beim Einschalten: Die Mem_OK Funktion auslösen.
2) Im Betrieb: Lädt deine OC-Einstellungen aus der Go Button Datei (nicht irgendein Profil).
Wenn es dir um Zweiteres geht, solltest du natürlich zuvor eine entsprechende Datei im UEFI anlegen (Tool Tab -> Go Button File).
was bringt eigentlich ein MEI Firmware Update bei dem Board
habe das neueste hierleigen weis aber nicht ob und warum ich flashen sollte
ich meine die mei Firmware nicht die treiber
8.1.30.1350
8.1.30.1350
LMSService is potentially vulnerable to unquoted service path
vulnerability. This issue was fixed in 8.1.30 MR.
Ich habe kürzlich eine neue 9er Firmware bekommen, dachte deshalb fragst du ;)
Station Drivers sollte Changelogs zu den 8er Versionen haben.
habs geflashed. was es bringt weiß ich nicht... konnte aber auch nichts negatives feststellen. Würde mich aber auch interresieren ;)
9er Firmware? :) ... bin ein update freak ;)
Habe gerade noch mal nachgefragt und darf sie leider nicht weiter geben :-[
