![e42asusglobalogo.png](http://mods.hardwareluxx.de/emissary42/asusm5e/e42asusglobalogo.png)
ASUS Maximus V Extreme R.O.G
![e42asusroglogowhite.png](http://mods.hardwareluxx.de/emissary42/asusm5e/e42asusroglogowhite.png)
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- ASUS Republic of Gamers Microsite ---
--- ASUS Maximus V Extreme R.O.G @ hwbot ---
--- ASUS Australia - Hands On Preview (+ OC-Primer) ---
![e42asusmaximus5extremerogz77top.jpg](http://mods.hardwareluxx.de/emissary42/asusm5e/e42asusmaximus5extremerogz77top.jpg)
![](http://www.kingpic.net/th/e42asusmaximus5extremerogz77top.jpg)
![](http://www.kingpic.net/th/e42asusmaximus5extreme_3d.jpg)
CPU Intel Socket 1155 Core i7/i5/i3/Pentium/Celeron processors
Sandy Bridge (32nm) & Ivy Bridge (22nm)
Intel Turbo Boost Technology 2.0Chipset Intel Z77
PLX PEX8747
PLX PEX8608Expansion Slots 5x PCIe 2.0/3.0 x16 (at 16, 8+8, 8+8+8 or 8+8+8+8 Lanes)
1x PCIe 2.0 x4
1x Mini-PCIe
Anbindung:
Graphics 1) Intel HD Graphics
Multi VGA Output
- HDMI (1920x1200 @ 60Hz)
- DisplayPort (2560x1600 @ 60Hz)
- Thunderbolt (2560x1600 @ 60Hz)
2) Multi Graphics Technology
4-Way NVIDIA SLI technology
4-Way ATI CrossFireX technologyMemory 4x DDR3-1066 / 1333 / 1600 / 1866-2000-2133-2200-2400-2600-2666-2800 (OC) Non-ECC U-DIMM
Dual Channel Memory Architecture
Support for Extreme Memory Profile (XMP v1.3) memory modulesThunderbolt Intel DSL3310
Single Channel
6 daisy chainable devies
VGA enabledAudio Realtek ALC898 HD-Audio Codec
2 / 4 / 5.1 / 7.1 Channel
Support for S/PDIF In/OutNetworking 1x Intel 82579V Gigabit-Ethernet (10/100/1000 Mbit)
AzureWave AW-NB111H (802.11a/b/g/n Dual Band WiFi)
Bluetooth V4.0 & V3.0+HSStorage Interface South Bridge: 2x SATA 6Gb/s, 4x SATA 3GB/s, RAID 0/1/5/10
ASMedia ASM1064: 4x SATA 6Gb/sUSB Chipset: 4x USB 3.0 (2x back, 2x internal)
Chipset: 8x USB 2.0 (4x back, 4x internal)
ASMedia ASM1042: 4x USB 3.0 (2x back, 2x mid)Internal I/O Connectors 2x USB 3.0
2x USB 2.0
6x SATA 6Gb/s
3x SATA 3Gb/s
S/PDIF-Out
Frontpanel Audio (AAFP)
OC Key
2x Subzero Sense
2x VGA Hotwire(s)
Slow Mode
15x ProbeIt measure points
7x ProbeIt cable
3x Thermal Sensor
Power-on button
Reset button
ROG Connect switch
LN2 Mode switch
Go Button
BIOS Switch button
mPCIe Combo header
Fan:
2x CPU (4pin)
3x Chassis (4pin)
3x Optional (4pin)
Power Connector:
24-pin EATX
8-pin ATX 12V
4-pin ATX 12V
6-pin EZ_PLUG
4-pin EZ_PLUG
Back Panel Connectors PS/2 keyboard/mouse combo
Thunderbolt
DisplayPort
HDMI
LAN (RJ45)
4x USB 3.0
4x USB 2.0
1x Optical S/PDIF out
1x Optical S/PDIF in
5x Audio
Clear CMOS button(s)
ROG Connect On/ OffI/O Controller Nuvoton NCT6779D H/W Monitoring CPU/System fan fail warning
CPU/System fan speed detection
CPU/System fan speed control
CPU overheating warning
System voltage detection
CPU/System temperature detectionBIOS 2x 64Mb UEFI AMI BIOS (Cfon EN25F64)
PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a
Multi-LanguageUnique Features mPCIe Combo™ (mPCIe/mSATA combo card)
ROG OC Key
- OSD TweakIt
- OSD Monitor
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Subzero Sense
- VGA Hotwire
- Slow Mode
- LN2 Mode
- PCIe x16 Lane Switch
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
ASUS TurboV EVO :
- TurboV
ASUS EPU :
- EPU
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-ConnectorBundle Software Kaspersky Anti-Virus
DAEMON Tools Pro Standard
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS UtilitiesForm Factor E-ATX Form Factor; 30.5cm x 27.2cm
Lieferumfang
- User's manual
- I/O Shield
- 2x SATA 3Gb/s cable(s)
- 6x SATA 6Gb/s cable(s)
- 3-Way SLI bridge(s)
- 4-Way SLI bridge(s)
- SLI bridge(s)
- CrossFire cable(s)
- Q-connector(s) (2 in 1)
- 2-port USB 2.0 and eSATA module(s)
- ROG Connect cable(s)
- ProbeIt cable set(s)
- 12 in 1 ROG Cable Label(s)
- mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
- 2-in-1 RF Cable(s)
- 2x Wi-Fi Ring Moving Antenna(s)
- OC Key(s)
- OC Key cable(s)
Schema
BIOS
1) Bilder
2) Spannungen
CPU VCore Offset -0.635 bis +0.635V, in 0.005V Schritten iGPU Voltage Offset -0.635 bis +0.635V, in 0.005V Schritten VCCSA Voltage 0.800 bis 1.700V, in 0.00625V Schritten VCCIO Voltage 0.900 bis 1.550V, in 0.00625V Schritten 2nd VCCIO Voltage 0.400 bis 1.700V, in 0.00625V Schritten CPU PLL Voltage 1.250 bis 2.500V, in 0.00625V Schritten Skew Driving Voltage 0.275 bis 1.600V, in 0.00625V Schritten PCH 1.05V Voltage 0.800 bis 1.600V, in 0.00625V Schritten VTTDDR Voltage 0.625 bis 1.100V, in 0.00625V Schritten DDR3 Voltage 1.200 bis 1.920V, in 0.005V Schritten
Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
3) BIOS Downloads: (ME-Updater v8.1)
- 0257 (Initial Release)
- 0604 (Updates: Windows 8 / Stability / USB / GTX680 / CPU-Microcode)
- 0704 (Updates: Windows 8 / Stability)
- 1309 (Updates: Stability / ROG Exchange)
- 1408 (Updates: Stability, CPU Microcode)
- 1501 (Updates: Stability)
- 1604 (Updates: Stability)
- 1707 (Updates: CPU Multi Bugfix, Power On By RTC, F8 & Fastboot, CPU Microcode)
- 1802 (Updates: Optimize BIOS configuration)
- 1903 (Updates: Stability)
4. Unofficial BIOS Downloads (Nutzung auf eigene Gefahr!)
- 0010 (iGPU Disable Option, OC-Key Pause Function)
- 0020 (Updated Performance Tables, iGPU Disable in SA, adds BCLK Recovery "ignore" Option)
- 0021 (Bugfix to 0020: OC-Key)
- 0022 (Fixes: )
- 1309 (bisher nicht bekannt, "Improve System Stability") --> ist jetzt offiziell!
- 1707MOD (RAID ROM v12.0.0.1783)
- 1707MOD2 (RAID ROM v12.5.0.1066)
5. Unofficial ME Updates (Nutzung auf eigene Gefahr!)
- v8.1.10.1286 (Quelle: Rimabo)
News & Reviews
Hardwareluxx News: Asus stellt Maximus V Extreme vor
Hardwareluxx News: ASUS gibt Preis und Verfügbarkeit des Maximus V Extreme bekannt
International Reviews
00) Hardwareluxx Review: Test: ASUS Maximus V Extreme
01) Guru3d
02) Overclock3D
03) t-break
04) Hardware.Info (UK)
05) Hartware.net
06) ocaholic
07) Gamezoom
08) McZonk - User Review @ PCGHX
09) Bjorn3d
10) Techpowerup
11) --> bitte weitere Review Links im Thread posten!
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
- Hersteller | Modell | Preisvergleich | kompatibel | Einschränkungen / Anmerkungen
- Hersteller | Modell | Preisvergleich | inkompatibel | Grund
- Alpenföhn | Himalaya | Preisvergleich | kompatibel (Review: GameZoom)
- be quiet! | Dark Rock Pro C1 | Preisvergleich | kompatibel (Review: Hardwareluxx)
- be quiet! | Dark Rock Pro C2 | Preisvergleich | kompatibel
- Intel | XTS 100H | Preisvergleich | kompatibel (Review: tbreak)
- Noctua | NH-D14 | Preisvergleich (2) | kompatibel | Anmerkungen | Anmerkungen2
- Thermalright | Archon (SB-E / Extreme) | Preisvergleich | eingeschränkt kompatibel | Verdeckt je nach Ausrichtung den ersten PEG (User: atomix)
- Thermalright | Silver Arrow | Preisvergleich | kompatibel (Review: Overclock3d)
- Thermaltake | FRIO CL-P0564 | Preisvergleich | kompatibel (User: emissary42)
- --> Bitte helft mit sammeln!
2) RAM
- GeIL | EVO Leggera GEL316GB1866C9DL | 2x8GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
- G.Skill | RipJawsX F3-1600C9Q-32GXM | 4x8GB | DDR3-1600 CL9 | Preisvergleich | kompatibel
- G.Skill | RipJawsX F3-17600CL9D-4GBXLD | 2x4GB | DDR3-2200 CL9 | Preisvergleich | kompatibel (User: emissary42)
- G.Skill | Sniper F3-1866C10Q-32GSR | 4x8GB | DDR3-1866 CL10 | Preisvergleich | kompatibel
- G.Skill | TridentX F3-2400C10D-8GTX | 2x4GB | DDR3-2400 CL10 | Preisvergleich | kompatibel (User: emissary42)
- Corsair | Dominator GT CMT12GX3M3A2000C9 | 3x4GB | DDR3-2000 CL9 | Preisvergleich | kompatibel (User: emissary42)
- Corsair | Dominator CMD8GX3M2A1600C8 | 2x4GB | DDR3-1600 CL8 | Preisvergleich | kompatibel
- Corsair | Dominator CMP16GX3M4X1866C9 | 4x4GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
- Corsair | Vengeance CMZ32GX3M4X1600C10 | 4x8GB | DDR3-1600 CL10 | Preisvergleich | kompatibel
- Mushkin | Blackline Ridgeback 998826 | 3x2GB | DDR3-1600 CL6 | Preisvergleich | kompatibel (User: emissary42)
- Mushkin | Blackline Frostbyte 996829 | 2x2GB | DDR3-2000 CL7 | Preisvergleich | kompatibel (User: emissary42)
- Kingston | HyperX Genesis KHX2133C11D3K4/16GX | 4x4GB | DDR3-2133 CL11 | Preisvergleich | kompatibel (Review: GameZoom)
- Kingston | HyperX LoVo KHX1600C9D3LK2-8GX | 2x4GB | DDR3-1600 CL9 1.35v | Preisvergleich | kompatibel (User: emissary42)
- Samsung | Green MV-3V4G3D | 2x4GB | DDR3L-1600 CL11 | Preisvergleich | kompatibel (User: emissary42)
3) Mainboard
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.
Nützliche Links (im Forum & im WWW)
1) Hardwareluxx
- http://www.hardwareluxx.de/communit...ockel-1155-ivy-bridge-laberthread-885830.html
- http://www.hardwareluxx.de/communit...ead-kein-frage-oder-quatschthread-776057.html
- Ivy Bridge im Test: Intel Core i7-3770K und alle i5-Modelle
- http://www.hardwareluxx.de/communit...e-sockel-1155-geruechte-faq-infos-861522.html
- Maximus V Extreme R.O.G @ ASUS Support Forum
2) WWW (international)
- Shamino's Lair @ Kingpin Cooling (OC-BIOS Downloads, Extreme Cooling)
- ASUS Maximus V Formula & Extreme - Official Support Thread @ XS
- ASUS M5E & Ivy @ 7GHz - From Russia with Love (XS)
- ASUS Maximus V Formula Overclocking Guide @ ASUS R.O.G (lässt sich in großen Teilen auf das M5E übertragen, für Einsteiger)
- Tutorial: Ivy Bridge Memory Overclocking @ Overclockers
- ASUS ROG: ROG Breaks i7-3770K Frequency World Record & More!
Zum User Review: Mangels Interesses hier im Thread, habe ich das Vorhaben kurz nach den Aufnahmen und Tests verworfen. Deshalb wird es von mir nicht mehr fertig gestellt.
Vintage Gallery ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Mein Testsetup
Vergleichswerte
1) AMD FM1 Plattform: AMD A8-3870K, Gigabyte A75-UD4H, 4GB G.Skill RipjawsX @ DDR3-1866 (OC:2200) 2) Intel LGA1366 Plattform: Intel Core i7-980X, Gigabyte X58A-OC, 6GB Kingston HyperX @ DDR3-1333 (OC: 1600) 3) Intel LGA1155 Plattform: Intel Core i5-3570K, ASUS Maximus V Extreme (Z77), 4GB RipjawsX @ DDR3-1600 CL9 4) Intel Pentium G2120 (simuliert): Intel Core i5-3570K @ 3.1Ghz (2c2t), sonst siehe 3) ![]() ![]() ![]() ![]() Benchmarks - synthetisch ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Bonus - Memory Overclocking 1) G.Skill RipjawsX F3-17600CL9D-4GBXLD (2x2GB DDR3-2200 CL9-11-9-28, PSC) DDR3-2500 | CL9-11-9-28-1T | 1.65v | 2x2GB | Screen 2) G.Skill RipjawsX F3-14900CL8D-8GBXM (2x4GB DDR3-1866 CL8-9-9-27, Samsung HCH9) DDR3-2000 | CL8-9-9-21-1T | 1.575v | 2x4GB | Screen 3) G.Skill ECO F3-12800CL7D-4GBECO (2x2GB DDR3-1600 CL7-8-7-24, PSC) DDR3-2300 | CL9-11-9-28-1T | 1.637v | 2x2GB | Screen 4) G.Skill Sniper F3-14900CL9D-8GBSR (2x4GB DDR3-1866 CL9-10-9-29, Hynix CFR) DDR3-2500 | CL11-12-11-26-1T | 1.60v | 2x4GB | Screen 5) Samsung Green MV-3V4G3D (2x4GB DDR3-1600 CL11-11-11-31, HYK0) DDR3-2400 | CL9-11-11-26-1T | 1.625v | 1x4GB | Screen 6) Mushkin Blackline Ridgeback 998826 (3x2GB DDR3-1600 CL6-8-6-24, PSC) DDR3-2300 | CL9-11-9-28-1T | 1.650v | 2x2GB | Screen 7) G.Skill TridentX F3-2400C10D-8GTX (2x4GB DDR3-2400 CL10-12-12-31) DDR3-2200 | 9-10-10-26-1T | 1.500v | 2x4GB | emissary42 | Screen DDR3-2400 | 10-11-11-26-1T | 1.563v | 2x4GB | emissary42 | Screen DDR3-2500 | 10-12-12-28-1T | 1.563v | 2x4GB | emissary42 | Screen 8) Kingston HyperX LoVo KHX1600C9D3LK2-8GX (2x4GB DDR3-1600 CL9-9-9-24 1.35v) DDR3-2133 | 10-12-11-28-1T | 1.500v | 2x4GB | emissary42 | Screen DDR3-2200 | 10-12-11-28-1T | 1.538v | 2x4GB | emissary42 | Screen DDR3-2400 | 11-13-12-31-1T | 1.525v | 2x4GB | emissary42 | Screen 9) Mushkin Blackline Frostbyte 996829 (2x2GB DDR3-2000 CL7-10-8-27 1.65v, PSC) DDR3-2060 | 6-9-6-24 1T | 1.650v | 2x2GB | emissary42 | Screen DDR3-2284 | 7-10-7-26 1T | 1.650v| 2x2GB | emissary42 | Screen DDR3-2400 | 8-11-8-28 2T | 1.700v| 2x2GB | emissary42 | Screen 10) Corsair Dominator GT CMT12GX3M3A2000C9 (3x4GB DDR3-2000 CL9-10-9-28 1.65v, Hynix CFR) DDR3-2600 | 11-13-12-29 1T | 1.650v | 3x4Gb | emissary42 | Screen DDR3-2666 | 11-13-13-31 1T | 1.650v| 2x4GB | emissary42 | Screen |
