[Sammelthread] ASUS Maximus V Extreme R.O.G (Z77)
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- ASUS Republic of Gamers Microsite ---
--- ASUS Maximus V Extreme R.O.G @ hwbot ---
--- ASUS Australia - Hands On Preview (+ OC-Primer) ---
---> mehr Bilder im User Review
Specifications
CPUIntel Socket 1155 Core i7/i5/i3/Pentium/Celeron processors
Sandy Bridge (32nm) & Ivy Bridge (22nm)
Intel Turbo Boost Technology 2.0
ChipsetIntel Z77
PLX PEX8747
PLX PEX8608
Expansion Slots5x PCIe 2.0/3.0 x16 (at 16, 8+8, 8+8+8 or 8+8+8+8 Lanes)
1x PCIe 2.0 x4
1x Mini-PCIe
Anbindung:
Graphics1) Intel HD Graphics
Multi VGA Output
- HDMI (1920x1200 @ 60Hz)
- DisplayPort (2560x1600 @ 60Hz)
- Thunderbolt (2560x1600 @ 60Hz)
2) Multi Graphics Technology
4-Way NVIDIA SLI technology
4-Way ATI CrossFireX technology
Memory4x DDR3-1066 / 1333 / 1600 / 1866-2000-2133-2200-2400-2600-2666-2800 (OC) Non-ECC U-DIMM
Dual Channel Memory Architecture
Support for Extreme Memory Profile (XMP v1.3) memory modules
ThunderboltIntel DSL3310
Single Channel
6 daisy chainable devies
VGA enabled
AudioRealtek ALC898 HD-Audio Codec
2 / 4 / 5.1 / 7.1 Channel
Support for S/PDIF In/Out
Networking1x Intel 82579V Gigabit-Ethernet (10/100/1000 Mbit)
AzureWave AW-NB111H (802.11a/b/g/n Dual Band WiFi)
Bluetooth V4.0 & V3.0+HS
Storage InterfaceSouth Bridge: 2x SATA 6Gb/s, 4x SATA 3GB/s, RAID 0/1/5/10
ASMedia ASM1064: 4x SATA 6Gb/s
USBChipset: 4x USB 3.0 (2x back, 2x internal)
Chipset: 8x USB 2.0 (4x back, 4x internal)
ASMedia ASM1042: 4x USB 3.0 (2x back, 2x mid)
Internal I/O Connectors2x USB 3.0
2x USB 2.0
6x SATA 6Gb/s
3x SATA 3Gb/s
S/PDIF-Out
Frontpanel Audio (AAFP)
OC Key
2x Subzero Sense
2x VGA Hotwire(s)
Slow Mode
15x ProbeIt measure points
7x ProbeIt cable
3x Thermal Sensor
Power-on button
Reset button
ROG Connect switch
LN2 Mode switch
Go Button
BIOS Switch button
mPCIe Combo header
Fan:
2x CPU (4pin)
3x Chassis (4pin)
3x Optional (4pin)
Power Connector:
24-pin EATX
8-pin ATX 12V
4-pin ATX 12V
6-pin EZ_PLUG
4-pin EZ_PLUG
Back Panel ConnectorsPS/2 keyboard/mouse combo
Thunderbolt
DisplayPort
HDMI
LAN (RJ45)
4x USB 3.0
4x USB 2.0
1x Optical S/PDIF out
1x Optical S/PDIF in
5x Audio
Clear CMOS button(s)
ROG Connect On/ Off
I/O ControllerNuvoton NCT6779D
H/W MonitoringCPU/System fan fail warning
CPU/System fan speed detection
CPU/System fan speed control
CPU overheating warning
System voltage detection
CPU/System temperature detection
BIOS2x 64Mb UEFI AMI BIOS (Cfon EN25F64)
PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a
Multi-Language
Unique FeaturesmPCIe Combo™ (mPCIe/mSATA combo card)
ROG OC Key
- OSD TweakIt
- OSD Monitor
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Subzero Sense
- VGA Hotwire
- Slow Mode
- LN2 Mode
- PCIe x16 Lane Switch
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
ASUS TurboV EVO :
- TurboV
ASUS EPU :
- EPU
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Bundle SoftwareKaspersky Anti-Virus
DAEMON Tools Pro Standard
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form FactorE-ATX Form Factor; 30.5cm x 27.2cm
Lieferumfang
  • Mainboard
  • User's manual
  • I/O Shield
  • 2x SATA 3Gb/s cable(s)
  • 6x SATA 6Gb/s cable(s)
  • 3-Way SLI bridge(s)
  • 4-Way SLI bridge(s)
  • SLI bridge(s)
  • CrossFire cable(s)
  • Q-connector(s) (2 in 1)
  • 2-port USB 2.0 and eSATA module(s)
  • ROG Connect cable(s)
  • ProbeIt cable set(s)
  • 12 in 1 ROG Cable Label(s)
  • mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
  • 2-in-1 RF Cable(s)
  • 2x Wi-Fi Ring Moving Antenna(s)
  • OC Key(s)
  • OC Key cable(s)
Schema
BIOS
1) Bilder
2) Spannungen
CPU VCore Offset-0.635 bis +0.635V, in 0.005V Schritten
iGPU Voltage Offset-0.635 bis +0.635V, in 0.005V Schritten
VCCSA Voltage0.800 bis 1.700V, in 0.00625V Schritten
VCCIO Voltage0.900 bis 1.550V, in 0.00625V Schritten
2nd VCCIO Voltage0.400 bis 1.700V, in 0.00625V Schritten
CPU PLL Voltage1.250 bis 2.500V, in 0.00625V Schritten
Skew Driving Voltage0.275 bis 1.600V, in 0.00625V Schritten
PCH 1.05V Voltage0.800 bis 1.600V, in 0.00625V Schritten
VTTDDR Voltage0.625 bis 1.100V, in 0.00625V Schritten
DDR3 Voltage1.200 bis 1.920V, in 0.005V Schritten
Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
3) BIOS Downloads: (ME-Updater v8.1)
4. Unofficial BIOS Downloads (Nutzung auf eigene Gefahr!)
5. Unofficial ME Updates (Nutzung auf eigene Gefahr!)
News & Reviews
Hardwareluxx News: Asus stellt Maximus V Extreme vor
Hardwareluxx News: ASUS gibt Preis und Verfügbarkeit des Maximus V Extreme bekannt
International Reviews
00) Hardwareluxx Review: Test: ASUS Maximus V Extreme
01) Guru3d
02) Overclock3D
03) t-break
04) Hardware.Info (UK)
05) Hartware.net
06) ocaholic
07) Gamezoom
08) McZonk - User Review @ PCGHX
09) Bjorn3d
10) Techpowerup
11) --> bitte weitere Review Links im Thread posten!
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
  • Hersteller | Modell | Preisvergleich | kompatibel | Einschränkungen / Anmerkungen
  • Hersteller | Modell | Preisvergleich | inkompatibel | Grund
  • GeIL | EVO Leggera GEL316GB1866C9DL | 2x8GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-1600C9Q-32GXM | 4x8GB | DDR3-1600 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-17600CL9D-4GBXLD | 2x4GB | DDR3-2200 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • G.Skill | Sniper F3-1866C10Q-32GSR | 4x8GB | DDR3-1866 CL10 | Preisvergleich | kompatibel
  • G.Skill | TridentX F3-2400C10D-8GTX | 2x4GB | DDR3-2400 CL10 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator GT CMT12GX3M3A2000C9 | 3x4GB | DDR3-2000 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator CMD8GX3M2A1600C8 | 2x4GB | DDR3-1600 CL8 | Preisvergleich | kompatibel
  • Corsair | Dominator CMP16GX3M4X1866C9 | 4x4GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • Corsair | Vengeance CMZ32GX3M4X1600C10 | 4x8GB | DDR3-1600 CL10 | Preisvergleich | kompatibel
  • Mushkin | Blackline Ridgeback 998826 | 3x2GB | DDR3-1600 CL6 | Preisvergleich | kompatibel (User: emissary42)
  • Mushkin | Blackline Frostbyte 996829 | 2x2GB | DDR3-2000 CL7 | Preisvergleich | kompatibel (User: emissary42)
  • Kingston | HyperX Genesis KHX2133C11D3K4/16GX | 4x4GB | DDR3-2133 CL11 | Preisvergleich | kompatibel (Review: GameZoom)
  • Kingston | HyperX LoVo KHX1600C9D3LK2-8GX | 2x4GB | DDR3-1600 CL9 1.35v | Preisvergleich | kompatibel (User: emissary42)
  • Samsung | Green MV-3V4G3D | 2x4GB | DDR3L-1600 CL11 | Preisvergleich | kompatibel (User: emissary42)
3) Mainboard
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.
Nützliche Links (im Forum & im WWW)
INCOMING... Mini-Review?
Zum User Review: Mangels Interesses hier im Thread, habe ich das Vorhaben kurz nach den Aufnahmen und Tests verworfen. Deshalb wird es von mir nicht mehr fertig gestellt.
Vintage Gallery
Mein Testsetup
CPUIntel Core i5-3570K
MainboardASUS Maximus V Extreme R.O.G (BIOS 704)
Memory2x2GB G.Skill RipajwsX F3-17600CL9D-4GBXLD (PSC X)
2x4GB G.Skill F3-14900CL8D-8GBXM (Samsung HCH9)
2x4GB Samsung Green 30nm MV-3V4G3D (Samsung HYK0)
2x2GB Kingston HyperX T1 DDR3-2000 CL8 (KHX2000C8D3T1K2/4GX, Elpida Hyper)
2x2GB GeIL Ultra DDR3-2133 CL9 (GUP34GB2133C9DC, Epida BBSE)
CoolingThermaltake FRIO CL-P0564 (CPU)
230mm Cooler Master (Mainboard-Rückseite)
140mm Corsair AF (Chipsatz)
Power SupplySuper Flower Golden Green 400W (SF-400P14XE)
HDDWestern Digital Raptor 74GB
PeripheryAvocent Switchview DVI
Razer Diamondback
Microsoft Natural Keyboard 4000
SoftwareMicrosoft Windows 7 Pro SP1, aktuelle Treiber
Vergleichswerte
1) AMD FM1 Plattform: AMD A8-3870K, Gigabyte A75-UD4H, 4GB G.Skill RipjawsX @ DDR3-1866 (OC:2200)
2) Intel LGA1366 Plattform: Intel Core i7-980X, Gigabyte X58A-OC, 6GB Kingston HyperX @ DDR3-1333 (OC: 1600)
3) Intel LGA1155 Plattform: Intel Core i5-3570K, ASUS Maximus V Extreme (Z77), 4GB RipjawsX @ DDR3-1600 CL9
4) Intel Pentium G2120 (simuliert): Intel Core i5-3570K @ 3.1Ghz (2c2t), sonst siehe 3)
Benchmarks - synthetisch
Bonus - Memory Overclocking
1) G.Skill RipjawsX F3-17600CL9D-4GBXLD (2x2GB DDR3-2200 CL9-11-9-28, PSC)
DDR3-2500 | CL9-11-9-28-1T | 1.65v | 2x2GB | Screen
2) G.Skill RipjawsX F3-14900CL8D-8GBXM (2x4GB DDR3-1866 CL8-9-9-27, Samsung HCH9)
DDR3-2000 | CL8-9-9-21-1T | 1.575v | 2x4GB | Screen
3) G.Skill ECO F3-12800CL7D-4GBECO (2x2GB DDR3-1600 CL7-8-7-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.637v | 2x2GB | Screen
4) G.Skill Sniper F3-14900CL9D-8GBSR (2x4GB DDR3-1866 CL9-10-9-29, Hynix CFR)
DDR3-2500 | CL11-12-11-26-1T | 1.60v | 2x4GB | Screen
5) Samsung Green MV-3V4G3D (2x4GB DDR3-1600 CL11-11-11-31, HYK0)
DDR3-2400 | CL9-11-11-26-1T | 1.625v | 1x4GB | Screen
6) Mushkin Blackline Ridgeback 998826 (3x2GB DDR3-1600 CL6-8-6-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.650v | 2x2GB | Screen
7) G.Skill TridentX F3-2400C10D-8GTX (2x4GB DDR3-2400 CL10-12-12-31)
DDR3-2200 | 9-10-10-26-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2400 | 10-11-11-26-1T | 1.563v | 2x4GB | emissary42 | Screen
DDR3-2500 | 10-12-12-28-1T | 1.563v | 2x4GB | emissary42 | Screen
8) Kingston HyperX LoVo KHX1600C9D3LK2-8GX (2x4GB DDR3-1600 CL9-9-9-24 1.35v)
DDR3-2133 | 10-12-11-28-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2200 | 10-12-11-28-1T | 1.538v | 2x4GB | emissary42 | Screen
DDR3-2400 | 11-13-12-31-1T | 1.525v | 2x4GB | emissary42 | Screen
9) Mushkin Blackline Frostbyte 996829 (2x2GB DDR3-2000 CL7-10-8-27 1.65v, PSC)
DDR3-2060 | 6-9-6-24 1T | 1.650v | 2x2GB | emissary42 | Screen
DDR3-2284 | 7-10-7-26 1T | 1.650v| 2x2GB | emissary42 | Screen
DDR3-2400 | 8-11-8-28 2T | 1.700v| 2x2GB | emissary42 | Screen
10) Corsair Dominator GT CMT12GX3M3A2000C9 (3x4GB DDR3-2000 CL9-10-9-28 1.65v, Hynix CFR)
DDR3-2600 | 11-13-12-29 1T | 1.650v | 3x4Gb | emissary42 | Screen
DDR3-2666 | 11-13-13-31 1T | 1.650v| 2x4GB | emissary42 | Screen
WORK IN PROGRESS!​
Wird unter DOS geflashed, also von einem bootbaren USB-Stick zum Beispiel ;)
Ich weis, hier wurde ein paar Mal erzählt, dass M5E tauge nicht dafür, aber lesen hier vielleicht trotzdem noch ein paar Overclocker mit?
Im Vergleich zu dem Einen oder Anderen hier, kann leider nicht so viel Zeit ins Übertakten investieren. Mag mir daher vielleicht jemand einen Tip geben, womit ich bei dem Takt und mit Vollbestückung am ehesten von 1M nach 32M (steigt im ersten Loop mit Rounding Error aus) komme? Außer mit dem massiven erhöhen aller relevanten Spannungen, also der Brute Force Methode, versteht sich. Denn das ist genau das, was ich dabei vermeiden möchte =))
Klar lese ich zum Beispiel hier mit. ;)
So Pi mal Daumen und Samsung Chips:
Versuche mal tRAS 35 oder 36
VCCSA ist zu niedrig, mindestens 0.948V, je nach IMC kann es auch leicht über 1.08V sein.
VTT-1 solltest du mal von 1.085V - 1.121V probieren.
Heinrich
Nachtrag:
VTT-1 = VCCIO
Hey, danke für den Schubs in die richtige Richtung :wink:
Werde das der Reihe nach testen. Bei den Timings habe ich noch etwas Luft, aber die VCCSA habe ich noch gar nicht angefasst. Das wäre also eine Möglichkeit. Eventuell dann zusammen mit einer leicht erhöhten VCCIO.
Exakt!
Wie du ja selber weißt, einfach die entsprechenden Spannung hochballern bringt es nicht, die richtige Abstimmung aufeinander macht es aus.
Heinrich
Einen Vorteil hat das Tweaken auf Intel ja, die 32M Durchläufe selbst sind nicht sehr zeitaufwändig... Da kann man in einer Stunde schon einige Einstellungen abklopfen.
Und mit meinem ersten 3570K habe ich dann wohl einfach Glück gehabt, alle danach waren ja leider eher Gurken.
Hast du Immer noch kein "Glück" gehabt, schade.
Ich musste mir vor kurzen mal einen 3570k zur Überbrückung kaufen, ich habe den 3770k von Werner(sen) "köpfen" lassen, kurzum, das hat sich von der Temperatur her gesehen mehr wie gelohnt und war auch nötig. Also, wieder "Blind" neu gekauft, die 3570k CPU bleibt sehr kühl, macht die 4.5GHZ bei 1.09V und die 5GHz bei 1.344V (primestable, FFT inplace), IMC 2600+ (nicht weiter getestet). Und ist ein Malaysia C Batch. Noch besser hat es Trust13 gemacht, der hat einen 3770k erwischt, der 4.5 GHz bei ca. 1.06V macht, ebenfalls ein Malaysia C Batch. Scheinen ein paar gute Chargen unterwegs zu sein, vielleicht greifst du nochmal zu? ;)
Heinrich
Naja, ich hab nun meinen ersten 3570K wieder und der reicht mir bis auf Weiteres. Der DDR3-2800 Teiler ist mir persönlich irgendwie wichtiger als der mögliche CPU-Takt, auch wenn 5GHz @ Luku schick waren, damals mit dem 2500K und 2600K.
Aber mit deinem Exemplar scheint du wieder einen guten Griff gemacht zu haben, dein 3770K war/ist ja auch ein Guter :)
Stimmt, ist zwar nicht die Perle an sich, dafür kann die beides gut (CPU + IMC Takt). ;)
5GHz @ Luft hat meine damalige Sandy Bridge CPU von der Temperatur her nicht gepackt, nur mit Wasserkühlung waren 5GHz plus möglich. Ja, das waren noch Zeiten wo man überlegt hat, ob man auf dem M4E im SLI Modus lieber die 2 x 8 Lanes Steckplätze benutzt oder die 2 x 16 Lanes, die über den Zusatzchip angebunden sind. Hier nur 8 Lanes direkt angebunden, dort 16 Lanes mit etwas größeren Lantenzzeiten bedingt durch den Multiplexer Chip. :d Nun ja, drei Grafikkarten habe ich nicht mehr, daher auch kein M5E. ;)
BtT.
Heinrich
Stimmt schon, für 3 Way Setups ist es natürlich der Spitzenkandidat. Aber man kann es sich eben auch aus anderen Gründen kaufen... Wenn man so bekloppt ist wie dieser Moderator :haha:
Willkommen, das war ja ein richtiger Schnäppchen :wink:
Stehen die Komponenten für das System schon fest?
Öh ja..... natürlich....
Wie schrieb ich schon im OCF Thread:
Einen an der Waffel haben wir alle hier. :d
Also mache hier mal keinen drauf als große Ausnahme von der Regel. ;)
Davon mal abgesehen, ein 08/15 Mainboard wäre auch nichts für mich, daher kann ich deine Entscheidung für das M5E schon nachvollziehen. Ist ja an sich ein gutes Board, nur liegen meine Prioritäten dabei etwas anders als deine.
Heinrich
Für mich ist es halt ein Memclocker-Board mit Thunderbolt. Dazu benötige ich den DisplayPort für meinen KVM... Ein Leben ohne kann ich mir gar nicht mehr vorstellen, so mit vier Mal Peripherie auf dem Tisch :fresse:
Edit: Wer hat eigentlich deine Dominator Platinum geerbt?
Wenn du es nich weiter sagst :d :
Nach der eBay Auktion hat mich dort jemand angeschrieben und mir ein akzeptables Angebot gemacht. Und der hat die nun. ;)
Ich muss aber zugeben, die TridentX laufen zumindest genau so gut wie die Domis, "oben herum* sogar etwas besser.
Thunderbolt ja, mal sehen inwieweit sich das durchsetzen kann. Vermisst habe ich die Schnittstelle bisher aber nicht.
Also jungs, ich habe meine System ejtzt einigermaßen stabil. jetzt wollte ich an den speicher gehen. wie würdet ihr da am besten vorgehen?
habe den speicher verbaut. G.Skill TridentX DIMM Kit 16GB PC3-19200U CL10-12-12-31 (DDR3-2400) (F3-2400C10D-16GTX) sind 2x 8GB Module.
habt ihr da ein paar tipps? Was ich Dazu Sagen kann. Diese Roten Headspreader musste ich abschrauben. ging nicht mehr unter den lüfter. aber ejtzt passt es. kann ich von dem speicher her überhaupt was erwarten?
Dann sind deine 2400er CL9 TridentX deutlich stärker als meine.
Die 8er Module, haben vermutlich etwas weniger Spielraum als die 4er, aber 2600 und 2666 kannst du ruhig mal versuchen. Ich würde die Timings erst mal so stehen lassen und nur wenn das nicht klappt, anfangen die Subtimings zu entschärfen. Wenn das immer nicht reicht, kannst du auch noch versuchen auf 11-12-12-31 oder gar 11-13-13-31 zu gehen. Aber die Performance wird dann nicht so viel besser als bei 2400 CL10 sein. Wenn du bei Postcode 23 stecken bleibst, sind kleinere Erhöhungen der Nebenspannungen (VCCIO und eventuell VCCSA) fällig. Ich würde dir empfehlen, vorher und bei jeder neu gefundenen stabilen Einstellungen ein Profil im UEFI zu erstellen, dann kannst du jederzeit zu diesen Einstellungen zurück kehren. Viel Spass beim herum probieren ;)
wie stresst du den speicher, mit welchem tool?
btw.: da fällt mir ein, dass es da 2 optionen im bios gibt. bin mir nicht sicher. wenn man die aktiviert bekomtm man einen höheren PI Score oder sowas. extra für benchmark ausgelegt... SPI Booster oder sowas. Dazu gibt es noch eine 2te option. Xtream Tweaking. was ist dass denn bitte? :-)
SPI Booster ist für SuperPi. Xtreme Tweaking ist für 3Dmark01. Kannst du beide ignorieren, wenn es dir nur um Stabilität geht.
Speicher testen: Schnelltest mit SPI32M und Stabilität dann mit Prime95 und/oder LinX.
Mal kurz ne Frage.
Sind die OC Key's kompatibel mit allen ROG Boards?
Könnte ich dieses für ein M5E nehmen, obwohl es laut Beschreibung nicht dafür geeignet ist?
Das ist eine sehr gute Frage, die ich dir leider nicht beantworten kann :/
Hast du selbst schon im WWW und insbesondere im ROG Forum nach einer Antwort gesucht?
Man findet leider gar nichts dazu :(
Wie funktioniert denn das Teil? Das muss am DVI von der Grafikkarte angeschlossen werden und das USB Kabel kommt von wo?
Edit:
Hab was gefunden, ist kompatibel! ( Unboxing the Maximus V Extreme - Republic of Gamers )
There’s OC Key at the bottom, along with the necessary adapter cable plugged in. The other end can be plugged into either the Maximus V Extreme or Rampage IV Extreme. The white USB cable is for ROG Connect and the two adapter cables are for hooking up a persistent multimeter setup to the ProbeIt in the top corner.
Dachte mir fast, dass irgendwann schon mal jemand im ROG Forum über die Frage gestolpert sein müsste... die haben ja teilweise halbe ROG Sammlungen dort :d
Ja, meine sind auch 2500er. Meine wollten zumindest weder 2600 c9 noch 2800 c10 machen, aber das ist natürlich meckern auf hohem Niveau :fresse:
Nun ja,
2800 C9 hat bei mir offiziell auch nur für eine CPU-Z Validation gereicht, der Screenshot dazu ist irgendwo im G.SKIll Thread. Ich hatte zwar auch einen Screenshot mit einem SuperPI 32M run, aber den hat mir der AFD versaut, da werden teilweise falsche Spannungswerte angezeigt. Der AFD verträgt sich nicht so ganz mit CPU-Z, manchmal passiert so was, wenn beide gleichzeitig laufen. :fresse: Aber zur Zeit steht Ram OC bei mir nicht an erster Stelle, ich bin anderweitig beschäftigt. :d
Heinrich
Habe ich auch schon gehört :shot:
Was und wo hast du etwas gehört? :fresse:
Ich habe aber nichts verlauten lassen davon, falls wir das gleiche meinen. ;)
So, ich habe den Screen mal gesucht und gefunden, wobei das mit dem wiederfinden immer so eine Sache bei mir ist. :d
CPU-Z Validator 3.1
Aber eigentlich sollte so was auch auf dem M5E möglich sein, wenn das Ram und die IMC mitspielt.
Heinrich
Dann meinte ich wohl etwas anderes (Hut ab, Spot an).
@2800C9: Das ist wohl nur eine Frage der Spannung... das waren ja vermutlich auch mehr als 1.65v bei dir?^^
