[Sammelthread] Asus Maximus V Formula (Z77)
WIP
Willkommen im Asus Maximus V Formula Sammelthread
Asus Maximus V Formula bei Geizhals.at
Bilder
Spezifikationen
Specifications
CPU Intel® Socket 1155 for 3rd/2nd Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors*
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0*
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
* Refer to ASUS for CPU support list
Chipset Intel® Z77
Memory 4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2666(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.*
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic Integrated Graphics Processor*
Multi-VGA output support : HDMI/DisplayPort ports*
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support Supports NVIDIA® SLI™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots 3 x PCIe 3.0/2.0 x16 (x16 or dual x8 or x8/x4/x4) *2
1 x PCIe 2.0 x4*
3 x PCIe 2.0 x1*
1 x mini-PCIe 2.0 x1 *3
Storage Intel® Z77 chipset :*
2 x SATA 6Gb/s port(s), red
2 x SATA 3Gb/s port(s), black
1 x eSATA 3Gb/s port(s), red
1 x mini-SATA 3Gb/s port(s) , black
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *4
ASMedia® PCIe SATA controller : *5
4 x SATA 6Gb/s port(s), red
LAN Intel®, 1 x Gigabit LAN Controller(s)
Wireless Data Network Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth Bluetooth V4.0
Bluetooth V3.0+HS
Audio SupremeFX IV built-in 7.1-Channel High Definition Audio CODEC*
- Output Signal-to-Noise Ratio (A-Weighted): 110 dB
- Output THD+N at 1kHz: 95 dB
- TI 6120A2 high fidelity headphone amplifier
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- ELNA premium audio capacitors
- 1500 uF Audio Power Capacitor
- Blu-ray audio layer Content Protection*
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports Intel® Z77 chipset :*
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
8 x USB 2.0 port(s) (4 at back panel, black+white, 4 at mid-board)
ASMedia® USB 3.0 controller :*
2 x USB 3.0 port(s) (2 at back panel, blue)
Overclocking Features mPCIe Combo™ (mPCIe/mSATA combo card)
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Slow Mode
- LN2 Mode
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
GameFirst II
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS TurboV EVO :
- CPU Level Up
ASUS EPU :
- EPU*
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send*
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3*
- ASUS EZ Flash 2*
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM*
- ASUS Q-Connector
Back I/O Ports 1 x DisplayPort
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0*
4 x USB 2.0*
1 x Optical S/PDIF out
1 x Optical S/PDIF in
5 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
Internal I/O Ports 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)*
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
3 x Chassis Fan connector(s) (4 -pin)
3 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)*
1 x Slow Mode switch(es)
8 x ProbeIt Measurement Points
3 x Thermal sensor connector(s)
1 x LN2 Mode header(s)
1 x EZ Plug connector(s) (4-pin Molex power connector)
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x mPCIe Combo header(s)
Accessories User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)*
1 x ROG Connect cable(s)
1 x 12 in 1 ROG Cable Label(s)
1 x mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
1 x 2-in-1 RF Cable(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS 64Mb UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
Manageability WfM2.0, DMI2.0, WOL by PME, PXE
Support Disc Drivers
Kaspersky® Anti-Virus
DAEMON Tools Pro Standard
GameFirst II
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form Factor Extended ATX Form Factor*
12 inch x 10.1 inch ( 30.5 cm x 25.7 cm )
Note *1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2-1: PCIe 3.0 speed is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*2-2: x8/x4/x4 mode is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*3-1: The mPCIe 2.0 x1 slot is located on mPCIe Combo™ expansion card.
*3-2: The mini-PCIe slot is pre-installed with an Wi-Fi/Bluetooth module.
*4: Supports on Intel® Core™ processor family with Windows® 7 operating systems.
*5: These SATA ports are for data hard drives only.
Downloads
BIOS, Drivers, ETC.
passende CPU Kühler
Luftkühler:
teilt mir eure Konfigs mit...
Wasserkühler:
Heatkiller 3.0 LC/LT, Copper, Black Nickel/Chrome
XSPC Raystorm
Passender Schlauch:
Primochill Schlauch PrimoFlex Pro 16/10 (3/8"ID) Clear
RAM
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133)
Patriot Viper 3 PC3-17000 2133 Mhz (2x4 Gb)
G.Skill Ripjaw Z F3 -17000CL9Q-16GBZH (4x4 Gb)
G.Skill Ripjaw X F3- 17000CL9Q-4GBXMD (2x4GB, 2 Kits in Vollbetückung laufen auch !)
More to come...
Also board geupdatet.
Werde das gleich mal testen mit der Karte für WLAN.
Also bis jetzt finde ich das board erste Sahne!
Muss mich nur mal durch das BIOS kämpfen wofür die ganzen Einstellungen sind die ich nicht kenne fürs übertakten ,^^
Gesendet von meinem GT-I9300 mit der Hardwareluxx App
@Polarcat:
Das Nichterkennen bzw. feherhafte Funktionalität ist in den meisten Fällen auf die alten BIOS zurückzuführen, da die Karte nur bedingt oder garnicht erkannt wurde, besonders wenn Settings verändert wurden.
Im ROG Forum wurden bei den meisten welche Probleme mit der Karte hatten, diese mit dem neuen BIOS beseitigt.
Also bestimmt mal aufs neue BIOS flashen und wenn das nicht hilft kann man die Kontakte checken.
Wir reden von unterschiedlichen Problemen.
Ich beziehe mich auf sein Problem, dass er hat wenn er die Karte einbaut, nämlich das der Rechner gar nicht mehr zuckt. Das hat nichts mit fehlerhafter Erkennung zu tun, weil das Board nicht mal dazu kommt das Bios zu laden ( drum bekommt er auch keinen Post-Code ). Ich hatte das gleiche Problem, ich weiß wie das aussieht.
Was du meinst sind die anderen Problemen, die aber zumindest einen Start bis zum Post ermöglichen.
Die WLAN Karte ist für mich sowieso eine Enttäuschung, wenn auch die einzige, größere Enttäuschung bei dem Board.
Für mich um so unverständlicher, da es beim "kleinen" Bruder P8Z77-Deluxe ohne Probleme klappt ( gut nicht der gleiche Funktionsumfang, aber vom Prinzip ähnlich. )
Naja der Mini PCIe Add-On Anschluss wurde bei den ROG Boards ja direkt mit dem Intel Controller eingeschlossen, daher auch 3GBit/s
Bei den anderen ASUS boards läuft dieser lediglich über den Secondary Controller, ich denke Marvel oder JMB.
Deswegen war die BIOS Codierung dafür auch viel kompizierter und es gibt mehr Probleme, da eben peripher geschalten werden muss.
Mit dem neuen BIOS wurde aber fast alle Interferenzen beseitigt, nur wenn einige bestimmte BIOS Settings verändert werden gibts noch Probleme.
Ein physisches Problem welches von Anfang an von Schmutz auf den Kontakten ausgeht ist natürlich auch möglich.
Ich persönlich finds cool booten zu können ohne jegliche Laufwerke angesteckt zu haben:)
Moin :)
Mein Formula ist jetzt auch endlich da und läuft super!
Konnte es ohne Probleme in betrieb nehmen, nur der ram wurde zu anfang nicht auf 1866 erkannt, war aber schnell umgestellt.
Welches bios gerade läuft hab ich noch garnicht geprüft. Beim start dauert es ein klein wenig bis die internet verbindung steht, schaft da das aktuelle bios abhilfe? Benutze ganz normal die kabel lösung übers board.
Bin ansonsten top zufrieden, der Sprung zu meinem alten System ist enorm, soviel mehr hätte ich dann auch nicht erwartet :fresse:
Bei all deinen Problemen die du hattest hast du mein Mitgefühl. Nach anfänglichen Problemen bei mir, der gleichen Art, half in der Tat nur ein Hardcore reset und das anschließen einer billigtastatur da meine alte G15 selbst heute noch nicht zuverlässig erkannt wird. In den USB 3.0 Buchsen schon gar nicht da die echt noch Zicken und auch zb mein corsair headset mit USB Anschluss zum Kratzen bringen. Auf USB 2.0 ist die erkennungsrate jetzt recht hoch, aber auch nur wenn ich das headset oder Game Controller nicht angeschlossen habe.
Support von asus sagt das die USB 2.0 Buchsen nach Standard aufgebaut sind und es daher mit größeren beleuchteten Tastaturen zu Stress kommen kann.
Was für ein Schwachsinn. Hab die Tastatur mittlerweile 6 Jahre und zig boards gehabt, und jedes kam mit der Tastatur zurecht. JEDES
Das hört sich gar nicht gut an,
ich hab am Crosshair G7, G500, G15 (die ganz alte) und das 360 Pad angeschlossen, läuft ohne Probleme, dazu kommen noch 2 WD HDD, iPod und das Handy, die werden aber nur bei gebrauch angeschlossen, genau gleich möchte ich das Maximus verwenden...
Hi Leute, kann ich in nen pci e 2 Slot auch meine alte Pci soundkarte stecken?
Um Himmels Willen nein!
PCI-Express und der alte PCI Standard sind elektrisch und mechanisch nicht kompatibel.
PCI-Express und der alte PCI Standard sind elektrisch und mechanisch nicht kompitabel ( wobei man zweiteres sicher mit Gewalt überwinden kann, natürlich mit Schäden an Karte und Board )
Shit dann kann ich meine pci soundkarte wohl in der Bucht verhöckern. Braucht man für nen 2.1 system ne extra soundkarte oder reicht der onboard sound. Was lässt sich da sonst an soundkarten empfehlen? Hatte bis jetzt ne soundblaster extrem music.
Ist das nicht ne pci express karte?
Da ich mal davon ausgehe, dass du ein PC-Komplett-2.1-System der niederen Preisklasse meinst, brauchst du keine Soundkarte.
Das macht erst Sinn, wenn du teureres Equipment anschließt.
Naja hab nen z2300 logitech. Hat mal 130 euro gekostet. Also doch ne sound karte. Würde wieder ne creative nehmen. Was lässt sich empfehlen?
Ne, 130 € + Logitech ist noch niederes Segment, da braucht es keine Soundkarte, zumal der Onboardsound des Formula schon kein schlechter ist.
Ne hat mal mehr gekostet so um 170 ist ja auch egal. Die wahl ist auf ne soundblaster z bulk für 75 gefallen. Werd mir irgendwann mal nen edifier 2.1 holen dann werd ich froh sein die z zu haben. Danke für den hinweis pci und pci e.
Der Chip auf dem Board hält locker mit der Soundblaster z mit.
Asus hat da nen guten Job gemacht durch hervorragende Abschirmung und mit der gebotenen Software.
Hehehe na die z ist schon noch nen bissle besser als der supreme fx. Isbesondere was raumklang kit headphones angeht. Aber ich werde den supreme fx testen.
Das Problem ist, dass du den Unterschied mit deinem System nicht hören wirst. Die fressen dir so viel von der Quali weg, dass du den Unterschied nicht hören wirst. 2:1 Verhältnis zwischen Wiedergabe und Quelle ist nicht wirklich gut, erst recht nicht bei so einer Kombi. Ist Geldverschwendung auf Seiten der Quelle.
Der Supreme FX sollte voll ausreichen, die Karte ist voll overpowered. Selbst für ein 730D wäre das zu viel des Guten...
Wer von euch benützt denn eigentlich Surround Boxen + Sub?
Also mit nem guten Headset welches brauchbares Noise Cancelling hat, ist der Supreme FX mehr als genug.
In Verbindung mit dem ThunderFX ist das Signal sogar noch cleaner und es gibt so gut wie keine Audiointerferenzen.
Was sich wirklich bemerkbar gemacht hat, ist diese SuperCap welche extra Spannung für rapid ansteigende Audiofrequenzen sammelt.
Jede Explosion, Kanonenschuss etc. hört sich so voll und satt an, wirklich toll.
Hi Leuts, so mein Sys ist eingebaut. Vorab, bei 2133 ddr3 bekomm ich bei prime direkt nen bluescreen. auf ddr3 2000 läufts erstmal. Das ist auch nen bissle Kundennepp. Mit cpuz habe ich doe timings für ddr3 2133 ausgelesen. die angegebenen 10-11-10-31 2T funzen nur bis 2000 mhz. Bei voller geschwindigkeit 2133 mhz muss man 10-12-12-32 2T einstellen...was solls....wollt ich nur mal posten.
wie warm wird eurer 3570 unter vollast? meine 4 kerne zeigen im peak 49-max 61° an.im idle 26-31°. ist das mit wakü ok oder sollte ich den kühler bischen stramer draufschreuben? hab die federn wie von watercool angegeben auf 19,5 mm länge angezogen, der kühler sitzt meiner meinung nach fest. habe auch bei der cpu wie bei der southbridge großzügig wärmeleitpaste drauf.
wo kann ich die interne grafikeinheit deaktivieren?
Lol die Soundblaster Z habe ich soeben im webshop um die ecke bestellt....supreme fx hin oder her ;-)
ich hab das Board seit einigen tagen. Läuft fast alles Top.
Eine Sache gibt mir bloß zu Denken:
Mein Arbeitsspeicher ( TridentX F3-2400C10D-16GTX ) erreicht nicht die erwartet Geschwindigkeit.
READ 196000 Write 20400 Copy 20500 Latency 31,6ns
er sollte ja im Aida64 so um die 24000-25000 erreichen. (Laut einigen Testberichten)
Hat jemand eine Idee? Hab ich was falsch gemacht im Bios evtl?
Bei der CPU, wo der Kühler sehr dicht anliegt, ist eher weniger, sehr dünn verstrichene WLP von von Vorteil bzgl. Performance im Gegensatz zu mehr.
Deine Temps sind normal würd ich sagen, 61C Load ist gut.
Hinsichtlich des RAMs, einfach weiter ausprobieren und:)
Gehe nur sicher, dass das XMP ein ist und du die gerateten Timings falls notwendig richtig per Hand eingibst.
Die Scores hören sich eh normal an, es ist möglich, dass der IMC ein bischen throttelt, denn 2400 sind schon ne Menge.
Sonst kannst du ja noch mit der VTT Voltage etwas spielen.
schau mal ins bios wie die timings und die spannung sind. maßgeblich sind erstmal die verpackungsangaben. ich musste meine timings auch schlechter stellen @ stock. werd aber auf 2000 mhz runtertakten um cl 10 machen zu können.
---------- Post added at 10:07 ---------- Previous post was at 09:59 ----------
wieviel vcore hast du eingestellt? bei mir ist noch auto drinnen und des jagt sich bei last auf 1,288 hoch. will max 1,250 einstellen. wo kann ich einstellen dass die cpu unter last im turbo nur 1,250 vcore bekommt? vg
naja evt zuviele wärmeleitpaste drückt sich bei erwärmung langfristig sicher eh zur seite..
also wenn ich bei power limit control 1,250 einstelle fährt er erst garnet hoch...ich kapiers net...dann lieber 1,128 bei 4,0 ghz fest - bin eh mehr in battlefield als idle ^^
unter volllast prime 95 satte temp max 49-55° Yeah so hab ich mir das vorgestellt...
@Ronin: Wenn du im Idle einen angepasst niedrigeren Vcore willst als unter Last, dann musst du dich mit Offset außeinander setzen.
Dabei wird ein dynamischer Vcore für den jeweiligen Takt der unter Idle oder Last von Turbo bzw. EIST geschalten wird eingestellt.
Du kannst dabei Untergrenzen und Obergrenzen setzen.
Da du hier sehr viel herumspielen und testen wirst, bis du die optimale Offset gefunden hast, rate ich dir, dies mit der AI Suite im OS zu tun.
Mit der Digi Control gehts um einiges leichter, da man sofort die Spannungen auslesen und entsprechend testen bzw. beobachten kann.
Falls du das ganze nicht willst, dann einfach in den CPU Power Management Options, EIST und Turbo ausschalten.
Und dann suchst du einfach den niedrigsten VCore für einen konstant gleichbleibenden Takt:)
hi thx, mit 1,128 im idle kann man sehr gut leben oder? :-) übrigends vom cash back und vom assasins creed 3 hab ich schon seid 2 wochen nix gesehen...die wollten nur dass ich meine rechnung nochmal zumaile obwohl ich sie hochgeladen habe...bin mal gespannt ob das noch was wird.
Ja das ist OK, jedoch ist dann auch dein Takt etwas eingeschränkt.
Und es könnte sein, dass die Graka etwas gebottleneckt wird, falls du anspruchsvolle Grafikapplikationen betreibst.
Bei mir läuft der 3770K mit 0.664 V im Idle und geht bis 1,048 unter Volllast (4GHz, Offset). Das läuft absolut stabil, darf aber auch kein Stück im Idle weniger sein sonst kriegt der Kernel Panik... :-)
Frohes Fest!
Meine läuft bei -0.05V.
Offset mit der AI Suite tüfteln macht wirklich Spaß:)
In Sachen Stromsparen hab ich jetzt fast schon 20% weniger Watt Gesamtverbrauch, seitdem ich die perfekte Offset gefunden habe.
Hab aber den Turbo ausgeschalten, da rapiden Anstiege und darauffolgenden Voltage Resets auf Langzeit unvorteilhaft für die Regler und die Induktoren sein sollen.
Hab dann noch ein OC BIOS Profil mit manueller Spannung, ohne Turbo und ohne EIST.
Bzw. ein Gaming Profil mit iGPU Settings, und OC.
was heisst denn das? nutze nur meine 580 gtx. hab die cpu grafik in die bucht gejagt ^^ sind 56 temp max (mit deaktiviertem bluetooth, wifi und interner gpu) unter wakü auch ok?
seltsam cpuz zeigt core voltage 1,120 an und core temp ne vid von 1,306. sind das andere werte?
Wenn der CPU Takt zu niedrig ist, kann es sein, dass die Grafikleistung beeinträchtigt bzw. zurückgehalten wird.
Software zum auslesen des Vcores ist meistens inakkurat, falls dus genau wissen willst brauchst du ein Voltmeter, sonst eher dem BIOS für den nächst besten Wert vertrauen.
hi thx....naja die cpu taktet doch bei 4 ghz dass ist doch net zu niedrig?
Naja Tests zufolge wirds mit 4GHZ keinen großen Unterschied mehr machen, jedoch wären 4.2GHZ schon empfehlenswert bei ner 580 für volle Leistungsbereitschaft.
Du hast ja nicht ohne Grund eine unlocked CPU:)
Die GTX 580 ist eine sehr leistungsfähige Karte, gib ihr bischen mehr Luft zum atmen.
Du kannst es ja mal ausprobieren.
Mach mal ne 3DMark11 Loop mit 4GHZ und einmal mit 4.2GHZ.
Bin mir sicher, dass man da noch was rausholen kann.
