[Sammelthread] Asus Maximus V Formula (Z77)
WIP
Willkommen im Asus Maximus V Formula Sammelthread
Asus Maximus V Formula bei Geizhals.at
Bilder
Spezifikationen
Specifications
CPU Intel® Socket 1155 for 3rd/2nd Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors*
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0*
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
* Refer to ASUS for CPU support list
Chipset Intel® Z77
Memory 4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2666(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.*
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic Integrated Graphics Processor*
Multi-VGA output support : HDMI/DisplayPort ports*
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support Supports NVIDIA® SLI™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots 3 x PCIe 3.0/2.0 x16 (x16 or dual x8 or x8/x4/x4) *2
1 x PCIe 2.0 x4*
3 x PCIe 2.0 x1*
1 x mini-PCIe 2.0 x1 *3
Storage Intel® Z77 chipset :*
2 x SATA 6Gb/s port(s), red
2 x SATA 3Gb/s port(s), black
1 x eSATA 3Gb/s port(s), red
1 x mini-SATA 3Gb/s port(s) , black
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *4
ASMedia® PCIe SATA controller : *5
4 x SATA 6Gb/s port(s), red
LAN Intel®, 1 x Gigabit LAN Controller(s)
Wireless Data Network Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth Bluetooth V4.0
Bluetooth V3.0+HS
Audio SupremeFX IV built-in 7.1-Channel High Definition Audio CODEC*
- Output Signal-to-Noise Ratio (A-Weighted): 110 dB
- Output THD+N at 1kHz: 95 dB
- TI 6120A2 high fidelity headphone amplifier
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- ELNA premium audio capacitors
- 1500 uF Audio Power Capacitor
- Blu-ray audio layer Content Protection*
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports Intel® Z77 chipset :*
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
8 x USB 2.0 port(s) (4 at back panel, black+white, 4 at mid-board)
ASMedia® USB 3.0 controller :*
2 x USB 3.0 port(s) (2 at back panel, blue)
Overclocking Features mPCIe Combo™ (mPCIe/mSATA combo card)
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Slow Mode
- LN2 Mode
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
GameFirst II
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS TurboV EVO :
- CPU Level Up
ASUS EPU :
- EPU*
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send*
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3*
- ASUS EZ Flash 2*
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM*
- ASUS Q-Connector
Back I/O Ports 1 x DisplayPort
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0*
4 x USB 2.0*
1 x Optical S/PDIF out
1 x Optical S/PDIF in
5 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
Internal I/O Ports 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)*
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
3 x Chassis Fan connector(s) (4 -pin)
3 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)*
1 x Slow Mode switch(es)
8 x ProbeIt Measurement Points
3 x Thermal sensor connector(s)
1 x LN2 Mode header(s)
1 x EZ Plug connector(s) (4-pin Molex power connector)
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x mPCIe Combo header(s)
Accessories User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)*
1 x ROG Connect cable(s)
1 x 12 in 1 ROG Cable Label(s)
1 x mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
1 x 2-in-1 RF Cable(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS 64Mb UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
Manageability WfM2.0, DMI2.0, WOL by PME, PXE
Support Disc Drivers
Kaspersky® Anti-Virus
DAEMON Tools Pro Standard
GameFirst II
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form Factor Extended ATX Form Factor*
12 inch x 10.1 inch ( 30.5 cm x 25.7 cm )
Note *1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2-1: PCIe 3.0 speed is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*2-2: x8/x4/x4 mode is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*3-1: The mPCIe 2.0 x1 slot is located on mPCIe Combo™ expansion card.
*3-2: The mini-PCIe slot is pre-installed with an Wi-Fi/Bluetooth module.
*4: Supports on Intel® Core™ processor family with Windows® 7 operating systems.
*5: These SATA ports are for data hard drives only.
Downloads
BIOS, Drivers, ETC.
passende CPU Kühler
Luftkühler:
teilt mir eure Konfigs mit...
Wasserkühler:
Heatkiller 3.0 LC/LT, Copper, Black Nickel/Chrome
XSPC Raystorm
Passender Schlauch:
Primochill Schlauch PrimoFlex Pro 16/10 (3/8"ID) Clear
RAM
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133)
Patriot Viper 3 PC3-17000 2133 Mhz (2x4 Gb)
G.Skill Ripjaw Z F3 -17000CL9Q-16GBZH (4x4 Gb)
G.Skill Ripjaw X F3- 17000CL9Q-4GBXMD (2x4GB, 2 Kits in Vollbetückung laufen auch !)
More to come...
16GB vollkommen ausreichend :)
und mit 1,40 V SUPER ZUfrieden mit 2133 CL10 :)
sind die neuen Corsair Dominator Platinum gute Wahl?
Am Anfang wollte ich noch das M5E aber das M5F reicht für mich locker und die 100€ kann für was anderes ausgeben.
Gut sein sollen sie, laufen halt ab 2400 mit 1,65v vdimm und kosten recht viel.Aer zufrieden sind die Leute damit wohl laut Thread :)
Die Samsung sind Preiswerter unn auch Klasse.
O.k. Hab jetzt mal geschaut, also lt. einer Caseking Bewertung sollen die 2133Cl9er platinum 2400 mit 1,5 v vdimm machen ( 8GB Verison), ich glaub die MUß ich mal TESTEN :d
die scheinen schon richtig Gut zu sein...
guggst du hier 8GB Corsair Dominator Platinum 2133MHz@2400MHz 1,5volt
Einen Blick wert könnten auch die GeIL Veloce/Leggera sein. Die 2133er Kits gehen mit 1,5 V auch sehr weit, mein Testkit der Veloce sogar bis 2666 mit 1,5 V.
Wenn ich mich im www so umschaue nicht das einzige Kit der Reihen mit gutem OC.
Es kommt aber auch aufs Board drauf an(was ich davor nicht glauben konnte) , Ich hatte vor 2 Wochen noch das Asrock extreme 6 z77 da habe ich die Riegel nicht über 2000MHz bekommen ..... Seid dem ich das Asus Maiximus V Formula habe kein Problem
kann auch sein das das Asrock die Riegel nicht leiden mochte , getestet hatte ich Corsair Dominator und Geil Evo Corsa 2133MHz keine chance ..........
ASRock ist dafür bekannt, dass die Speicherzicken sind. Ein Grund, warum ich nicht zum Formula OC gegriffen habe als Ramtester :d
@Polarcat
deswegen habe ich es auch wieder verkauft und bin zum alt bewehrten zurück ...... das OC formula sieht schon klasse aus aber aussehen ist nicht alles , und der support ist auch gleichnull bei asrock die habe die schuld alles anderem gegeben, das beste war da schickt mir der support bilder das es bei ihnen funktioniert hat den speicher mit 2133MHz zu betreiben mit kingston riegel ich aber hatte Geil und Corsair Riegel da konnte ich nur noch mit dem kopf schütteln , anscheinend kennt ASROCK nur kingston Ram :d
Bin gerade aufgestanden und noch müde....*Gähn* ....war die Xmp option (für Ram) nicht ai overclock ?
oder haben die sammý´s kein Xmp ?
ich finde das ned...-.-
Lies doch mal das SPD im Bios aus, da siehst du doch, ob ein XMP Profil hinterlegt wurde.
Kann gut sein, dass bei 1600er RAM keins angelegt wurde, ist ja auch nicht notwendig, da reicht JEDEC vollkommen aus.
jo, hab das beim ersten mal auch recht schwer gefunden deshalb nicht das ich es einfach Übersehe -.-
is quasi 06:45 in der Früh für mich o_0
Aha nö kein Xmp, ok danke Dir erstmal bis baldi :)
Man is das ein Gefrickel Ram ( 8GB Avexir) auf 2666mhz zu bekommen...
no boot über 2200mhz...
ich glaub das war mein Erster und Letzter Avexir...weder mit xmp noch mit 2400mhz zu booten :(
2666 auf einem Sandy und vor allem unter OC ? Das nenn ich mutig. Bei 4,6 bekomm ich nicht mal auf meinem Ivy 2400 MHz hin..
nene, hab wieder ein 3770K drin, sorry aber es läuft nun, teste gleich nochmal mit 4,4 gig dann lad ich n Screen hoch ;)
Also biste unter 4,5 GHz aktuell ?
Da läuft es auch bei mir wieder ;)
Bloss jenseits der 4,5 brauch ich bei meinem Ivy nicht probieren den Ram über 2200 zu bringen, macht er nicht mit.
AHA das hört sich interessant an, werde mich melden wenn ich noch 300 mhz drauf legen will...
Wenn du Glück hast, hast du eine Ivy mit gutem IMC erwischt, dann geht auch mehr. Soll ja auch Ivys geben, die 3000er Speichertakt mitmachen, bei meiner ist bei knapp über 2800 Schluss, egal was ich anstelle :/
Für 4,4 frisst deine aber schon ganz gut VCore, wie sind da deine Werte unter 4,7 ? Da muss ja deine Temp auch durch die Decke steigen..
Das is ne recht neue Cpu da muß ich mal schauen aber die soll recht Kühl bleiben, ca 74° hatte ich mal als ich kurz getested hatte mit 1.35 v vcore
Unter Luft ? Okay, das ist nicht schlecht, bei dem VCore bekomm ich das gerade so mit meiner Wakü hin.. Ist aber auch ein ES der ersten Gen..
richtig, mußte nun leider wieder die Sammy´s einbauen, da das Sys nicht startete mit 2666mhz...nach ausgeschaltetem Zustand das is ECHT Armseelig....da wirbt man mit was weiß ich für OC eigenschaften und wenn dann was benutzt wird, kommt nur 20 und 23...oh mann
naja vielleicht klappt es ja mit 2400 corsair´s werde mir da was ordern ;)
mal schauen
Nun geworben wird immer mit viel , ich denke das die diversen Hersteller davon ausgehen , das diejenigen die OC´n tun wissen das OC von diversen Faktoren abhängt ,
zum Leid der unwissenden .
da ich mich nun auch für dieses board entschieden habe (werde die thunder fx ausführung nehmen) brauche ich noch ram
am liebsten würde ich 2 x 8 und noch besser direkt 4 x 8 gb verbauen
kann sein dass ich jetzt müll von mir gebe, aber keine ahnung von übertakten:
bisher hatte ich mit overclocking noch nichts zu tun und würde das wenn überhaupt am liebsten nur über voreingestellte profile mehr oder weniger auf knopfdruck machen, geht das mit diesem board, wenn nicht auch nicht schlimm dann werde ich wohl einfach nicht übertakten
dahingehend aber die frage nach geeignetem ram ... muß ich wenn ich übertakten will auch direkt besseren ram nehmen? also anstatt 1600 z.b. 1866 ? und wenn ich dann auf 1866 übertakten will dann könnte ich direkt 1866ram einbauen und müßte den gar nicht übertakten sondern nur die cpu ?
und meint ihr der hier sollte laufen (würde mir optisch gefallen): 32GB G.Skill SNIPER DDR3-1866 DIMM CL10 Quad Kit - Hardware, Notebooks
Das Board hat gewisse Profile vorgespeichert, die deinen CPU in 3-4 Stufen übertaktet. Ob die Profile für deinen CPU hinreichend sind ist jedoch nicht garantiert. Musst du dann einfach probieren.
Schnelleren Ram braucht es dafür nicht unbedingt. Mit dem 1866 dürftest du nicht schlecht fahren.
Mir stellen sich allerdings 2 Fragen:
1. Warum dieses Board, wenn OC für dich keine Rolle spielt ? Austattungsmäßig gibt es günstigere Boards, die genau das Gleiche/mehr bieten.
2. Warum 32 GB ? Machst du viel Videoschnitt/Fotobearbeitung oder einfach Haben-wollen ?
Es gibt voreingestellte OC-Profile bis 4,6 GHz und speziellen RAM brauchst du auch nicht dafür. Wenn du schnellen RAM möchtest würde ICH empfehlen, direkt diesen RAM zu kaufen, also wenn du 2133 willst dann nimm auch 2133er RAM. Das sehen andere aber anders.
die cpu wird ne core i7 3770k ... erkennt das board dann bzgl. der profile was möglich ist? oder muß ich da selber dann rumfummeln? geht jetzt eher um sicherheit beim overclocken um nix kaputt machen zu können
zu euren fragen bzw. anmerkungen
die wahl des gskill sniper ist ne kombination aus 1866, preis und optik
das board ist ne kombination aus optik u. ausstattung
32 gb direkt weil kein bock in 3 jahren aufrüstmarathon mit speichersuche und evtl. dann 16 gb rausschmeissen zu müssen weil was auch immer ... direkt 32 gb und ruhe ... aber auch viel multitasking + 2 virtuelle maschinen + 10 browserfenster und jedes mit 10 tabs ... und natürlich haben wollen ... kombination aus allem halt ... (ich werde auch 2 x 830er 256gb samsungs verbauen + 2 x 2tb caviar black ... das hat schon alles seine gründe auch wenn andere es für übertrieben halten) ... ok, vielleicht würden 16gb ram auch ausreichen aber der aufpreis für direkt 32 und meine gedanken dazu rechtfertigen das für mich
hauptsächlich gehts auch um die richtige wahl und nicht die gesamtkapazität
ob ich am ende übertakte ist ne andere frage, wahrscheinlich eher nicht, die leistung wird erstmal auch ohne übertakten ausreichen ... hinsichtlich stromverbrauch bin ich sogar gegens übertakten bzw. werde dies aus diesem grund dann eher nicht machen weil ich die mehrleistung im alltäglichen betrieb nicht benötige und die normale leistung erstmal reichen sollte
aber nur mal theoretisch, was wäre denn die erste übertaktungsstufe, wie hoch?
---------- Post added at 12:39 ---------- Previous post was at 11:54 ----------
ich merk grad ich hab noch ein problem
specs:
nunhab ich
4 x caviar green
2 x caviar black
2 x ssd
wie krieg ich denn jetzt hier noch ein cd/dvd laufwerk angeschlossen? gar nicht oder?
bzw. nur über ne zusätzliche sata karte und da dann z.b. die caviar greens drüber laufen lassen ... oder? und wenn ja dann welche karte?
http://www.mindfactory.de/product_info.php/info/p152030_Adaptec-1430SA-SATA-Single-PCIe.html ???
Da würde ich mir fast eher überlegen das Laufwerk in ein externes Case zu verpacken.
So oft braucht man heutzutage die optischen Medien nicht mehr.
Ordentliche Controller kosten gutes Geld, wenn du nicht willst, dass deine Platten mit wenig Speed durch die Gegend gondeln. Und zum Farbkonzept dürften noch weniger Controller passen. Die Karte die du zeigst wäre geeignet, widerspricht aber dem, was du bisher als deine eigenen Ansprüche deklarierst.
Alternativ für das Laufwerk sowas hier verwenden:
http://www.addonics.com/products/adsau3.php
Würde ich auch empfehlen, ich hab mir ein externes Slim-Laufwerk besorgt das bei Bedarf einfach an USB angeschlossen wird. Gebraucht hab ich es bis jetzt nur einmal.
der nutzen würde hier das optische überwiegen und extern nervt mich nur noch ...
alles wird in ein case labs m8 verbaut, d.h. platz sollte eigentlich ausreichend vorhanden sein, die platten werden zudem über einen sata power switch "verwaltet", also bei bedarf an/aus ...
zudem ist das gehäuse noch erweiterbar (unterbau mit platz für festplatten, und im deckel (6,5cm höhe) lassen sich auch festplatten unterbringen ... d.h. platz ist ausreichend vorhanden um 8 platten bzw. 7 + dvd und dann noch theoretisch 4 weitere zu verbauen, in meinem fall direkt mal 8 platten + dvd
und ein NAS wird auch erst bei 4 platten für mich interessant, kostet dann ohne platten 200+ euro (weil wenn dann kauft man ja auch direkt was besseres und nicht das erstbeste einsteiger-NAS), braucht auch zusätzlich strom und wenn es läuft laufen alle 4 platten, wieder zusätzlich strom
