[Sammelthread] Asus Maximus V Gene R.O.G (Intel Z77)
Willkommen im Sammelthread zum ...
Layout:
weitere Bilder:
Spezifikationen:
Chipset Intel® Z77
Memory 4 x DIMM, Max. 32GB, DDR3 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic Integrated Graphics Processor
Multi-VGA output support : HDMI/DisplayPort ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support Supports NVIDIA® SLI™ Technology
Supports AMD CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots 2 x PCIe 3.0/2.0 x16 (x16 or dual x8, red) *2
1 x PCIe 2.0 x4 (black)
1 x mini-PCIe 2.0 x1 *3
Storage Intel® Z77 chipset : *4
2 x SATA 6Gb/s port(s), red
2 x SATA 3Gb/s port(s), black
1 x eSATA 3Gb/s port(s), red
1 x mini-SATA 3Gb/s port(s), black
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *5
ASMedia® PCIe SATA controller : *6
LAN Intel®, 1 x Gigabit LAN Controller(s)
Audio SupremeFX III built-in 8-Channel High Definition Audio CODEC
- Output Signal-to-Noise Ratio (A-Weighted): 110 dB
- Output THD+N at 1kHz: 95 dB
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- 1500 uF Audio Power Capacitor
- Gold-plated jacks
- X-Fi® Xtreme Fidelity™
- EAX® Advanced™ HD 5.0
- THX® TruStudio PRO™
- Creative ALchemy
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
USB Ports Intel® Z77 chipset :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
8 x USB 2.0 port(s) (4 at back panel, black+white, 4 at mid-board)
ASMedia® USB 3.0 controller :
2 x USB 3.0 port(s) (2 at back panel, blue)
Overclocking Features mPCIe Combo™ (mPCIe/mSATA combo card)
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase QPI/DRAM power design
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
GameFirst
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Backpanel:
1 x DisplayPort
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0
4 x USB 2.0 (one port can be switched to ROG Connect)
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
OnBoard-Anschlüsse:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
4 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
8 x ProbeIt Measurement Points
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x mPCIe Combo header(s)
Lieferumfang:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ROG Connect cable(s)
1 x 12 in 1 ROG Cable Label(s)
1 x ROG Door Hanger(s)
UEFI SCREENS:
Links:
Preisvergleich
Produktseite / Info beim Hersteller
Downloads: Bios, Treiber, Handbuch,...
Downloads: Bios, Treiber, Handbuch... Direktlinks
+ Handbuch MAXIMUS V GENE User's Manual (English)
+ Maximus V GENE Bios 0402 - [First Release Bios]
+ Maximus V GENE Bios 0503 - [1.Improve system stability. 2.Enhance compatibility with some USB devices.]
+ Maximus V GENE Bios 0602 - [Official Beta Bios Asus FTP]
+ Maximus V GENE Bios 0650 - [Beta Bios Shamino]
+ Maximus V GENE Bios 0701 - [Beta Bios Shamino]
+ Maximus V GENE Bios 0805 - [Added DRAM Tuning Improved Performance Default enable thunder bolt support IRST Update]
+ Maximus V GENE Bios 0880 - [Updates system compatibility Improves performance Improves DRAM Overclocking]
+ Maximus V GENE Bios 0881 - [fixed data vref bug ]
+ Treiber Chipsatz: Intel Chipset Software Installation Utility V9.3.0.1019 XpVistaWin7
+ Treiber Chipsatz: Intel Chipset Software Installation Utility V9.3.0.1020 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V8.0.0.1262 XpVistaWin7
+ Treiber Chipsatz: Intel Management Interface Engine V8.0.4.1441 Win7 32bit & 64bit
+ Treiber Chipsatz: Intel Management Interface Engine V8.0.10.1464 Win7 32bit & 64bit Windows XP HE MCE Pro 32bit & 64 Bit
+ Treiber SATA: Intel® Rapid Storage Technology V11.0.0.1032 Windows XP/7 32bit & 64bit (WHQL)
+ Treiber SATA: Intel® Rapid Storage Technology V11.1.0.1006 Windows XP/7 32bit & 64bit.(WHQL)
+ Treiber SATA: Intel® Rapid Start Technology Software V1.0.0.1022 for Windows 7 32bit & 64bit
+ Treiber SATA: Asmedia SATA Controller V1.3.4.0 Windows XP 32bit & XP 64bit & Win7 32bit & Win7 64bit (WHQL)
+ Treiber USB: Intel USB 3.0 Driver V1.0.1.209 Win7 32bit & Win7 64bit (WHQL)
+ Treiber USB: Intel USB 3.0 Driver V1.0.4.220 Win7 32bit & Win7 64bit (WHQL)
+ Treiber USB: Asmedia USB 3.0 V1.14.3.0 Windows XP 32bit & XP 64bit & Win7 32bit & Win7 64bit (WHQL)
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.6.0.0 WHQL XpWin7
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.8.1 Win7 32-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V16.8.1 Win7 64-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V17.0.0 Win7 32-Bit
+ Treiber LAN: Intel Gigabit Ethernet Driver V17.0.0 Win7 64-Bit
+ Treiber Video: Intel Graphics Accelerator V8.15.10.2598 Windows Win7 32bit & Win7 64bit (WHQL)
+ Treiber Video: Intel® HD Graphics Driver V8.15.10.2712 Win7 32-Bit
+ Treiber Video: Intel® HD Graphics Driver V8.15.10.2712 Win7 64-Bit
+ Treiber Video: Intel® HD Graphics Driver 15.26.8.2696 Win7 32-Bit
+ Treiber Video: Intel® HD Graphics Driver 15.26.8.64.2696 Win7 64-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.112.20176 Win7 32-Bit
+ Treiber Video: Lucidlogix VIRTU Version 1.2.112.20176 Win7 64-Bit
+ Treiber Video: Lucidlogix VIRTU V2111120856 Win7
+ Utility Video: LucidLogix Virtu MVP Wizard V1.00.08 for Windows Win7 32bit & Win7 64bit
+ Utility Video: Lucid Virtu Universal MVP Software V2.1.110.19997
+ Treiber Audio: Realtek Audio Driver Version 5.10.0.6570 & 6.0.1.6570 WHQL XpVistaWin7
+ Treiber Audio: Realtek Audio Driver Version 5.10.0.6602 & 6.0.1.6602 WHQL XpVistaWin7
+ Utility Audio: Sound Blaster X-Fi 2 Utility Package V1.0 (R11) Windows 7
+ ASUS AI Suite II 1.0.2.27 Windows XP Win7
+ ASUS AI Suite II 1.0.2.29 Windows XP Win7
+ ROG GameFirst V1.0.1.09
+ ROG ConnectPlus V1.0.0.14
+ ROG Connect V1.0.6.03
+ ROG CPU-Z V1.59.2
+ ROG Theme V1.0.0.12
+ DAEMON Tools Pro V44003120221 XP Win7
Besonderheiten:
Reviews:
[url=http://www.overclockers.com/asus-maximus-v-gene-motherboard-review/]ASUS Maximus V GENE Motherboard Review | Overclockers.com
ASUS Maximus V GENE (Intel Z77) Motherboard Review | TweakTown USA Edition
ASUS Maximus V GENE Motherboard review | guru3d.com
ASUS Maximus V Gene Overclocking Review And Benchmarks | motherboards.org
Asus Maximus Gene V Preview | lanoc.org
ASUS Maximus V GENE Review | votez.net
Asus Maximus V Gene (Z77) Motherboard Sandy Bridge Review | eTeknix.com
Intel Z77 Chipset Launch Roundup - ASUS Maximus V Gene | hardwareheaven.com
ASUS Maximus V Gene| AwardFabrik.de
Au-Ja! - ASUS Maximus V Gene | au-ja.de
Weitere Infos und nützliche Links:
- Maximus IV GENE-Z BIOS Guide - Overclocking
Kompatibilität Arbeitsspeicher:
QVL - QUALIFIED VENDOR LIST - DOWNLOAD
User Berichte:
Kompatibilität CPU Kühler:
+ Corsair H60 (Preisvergleich)(Foto von Emiras)
+ Corsair H70 (Preisvergleich)
+ EKL Alpenföhn K2 (Preisvergleich)
+ Noctua NH-C14 (Preisvergleich)
+ Noctua NH-D14 (Preisvergleich)
+ Prolimatech Genesis (Preisvergleich)
+ Prolimatech Megahalems (Preisvergleich)
+ Prolimatech Black Series Megahalems (Preisvergleich)
+ Thermalright Venomous-x (Preisvergleich)
+ Thermalright HR-02 Macho (Preisvergleich)
+ Thermalright Silver Arrow (Preisvergleich)
Overclocking Ergebnis:
Hallo
Ich hab mein Maximus jetzt seid gestern eingebaut (gebraucht hier aus dem Forum) und hab momentan noch probleme mit der Stabilität.
Der Rechner geht immer nach etwa 45 minuten Aus bzw. startet neu. Danach läuft er wieder eine Zeit bis er wieder einfach aus geht.
Ich hab nur das Mainboard ausgetauscht vorher war ein P8P67 Deluxe verbaut.
Die Temps sind ok. Hab jetzt auch mal zum testen die Lüfterdrehzahl hochgeschraubt auf Vollgas und hab jetzt 30° auf der CPU. Zu OC versuche bin ich noch nicht gekommen.
Was mir aufgefallen ist, das der Chipsatz extrem heiß/warm wird. Also man kann gerade noch mit dem finger hinfassen. Das war ich von dem P67 nicht gewohnt.
Ich muss dazu sagen das ich noch kein Gehäuse hab und das Mainboard einfach so auf dem dem Tisch steht. Ich hab jetzt mal noch einen Lüfter über den Chipsatz montiert. Er ist jetzt deutlichz kühler aber die Abstürze haben nicht aufgehört.
Ist das bei dem Board normal das der so heiß wird? ist unter dem Kühler noch was anderes drunter als nur der Z77?
Hab grad mal bei meinem Rechner geschaut, der Chipsatz wird nur handwarm, und die Kiste läuft seit mehreren Tagen nonstop.
Mach mal einen CMOS-Reset und schau nochmal. Vielleicht hat Dein Vorgänger extrem übertaktet.
Führe mal einen CMOS Reset aus und lade anschließend die optimized defaults > Save & Exit Eventuell bekommt der PCH zuviel Spannung ...
Empfiehlt sich im grunde IMMER vor der ersten Inbetriebnahme einen CMOS Reset durch zu führen vor allem wenn von Privat gekauft wurde.
Macht ein Board ja immer Automatisch sobald eine CPU verbaut wird. Hats mir auch am Anfang angezeigt.
Habs jetzt aber gerade nochmal wiederholt. Außerdem hab ich mal noch die Festplatte an die Ports vom Intel Kontroller gehängt. Vielleicht heizt ja auch irgentwie der Marvell.
Wie ist das mit der EPU und DIGi+? Auf was habt ihr die stehen?
hab jetzt alles auf Default.
BIOS Version ist 1302.
Findet kein CMOS Reset und auch kein Laden der optimized Defaults statt ...
Damit z.B. alle OC Settings weg sind sollte man - auch wenns umbequem ist - so vorgehen.
Das Bios 1302 ist auch eher suboptimal ... also entweder auf Version 1101 flashen oder auf eine Version >= 1604.
Und danach steht wie gehabt ein CMOS Reset an. ;)
Hab ich ja jetzt gemacht.
CMOS Reset und opimized Defaults.
Aber jetzt muss ich erstmal abwarten. Ob er nochmal abstützt oder obs jetzt stabil bleibt.
Wegen BIOS flashen muss ich erstmal mit dem Verkäufer in Kontakt treten.
Das wäre grober Unfug da es seither einige Bugfixes gab. Wie geschrieben ... das 1302 halt ich für suboptimal ... das hat bei einigen Usern Probleme verursacht.
Läuft jetzt Stabil.
Weiß aber nicht obs am BIOS Update auf 1802 oder daran liegt das ich die EPU auf Höchstleistung gestellt hab.
Als ich das Board verbaut hat hab ich die mal auf Automatisch gestellt.
Die hohen Temperaturen des CHipsatzes sind aber immernoch da.
Der Board-Sensor zeigt zwar nur 30° an aber das sind mit Lüfter locker 40° wenn nicht mehr.
Besorg mir auf morgen mal ein Infrarot Thermometer und messe mal.
Wer auf Windows 8.1 updaten möchte sollte damit Leben das Asmedia_USB3 Port nicht mehr Funktioniert. Wo kann man den aktuelle Asmedia_USB3 Treiber runter laden. Musste wirklich ganze System neu installieren :mad:
hatte neulich einen bluescreen, seit dem sind die front usb hinüber.
editle
öhm ja....was soll ich sagen, nach nem jahr kein b-update mehr gemacht :d
mit dem 1802 läufts wieder.
@braindead2004
Dark Rock Pro2 empfiehlt sich nicht für das Board mit diesem Speicher.
Lüfterklemmen sehr nah am PCB einer Graka im ersten Slot und die Dimms sollten maximal 4.3cm hoch sein.
Die Dominator Platinum sind aber 5.5cm hoch.
Mein Board hatte vor c.a 3 Wochen einen Defekt, also hab ich's zurück zu Caseking geschickt. Die wiederum haben das gute Board an Asus geschickt....
Kennt sich jemand mit der RMA von Asus/Rog aus? :/
Öffne am besten im Support Unterforum von Asus einen Thread und erkundige Dich nach dem Status Deiner RMA.
http://www.hardwareluxx.de/community/f248/
Die Seriennummer des Mainboards hast Du notiert ?
Wäre auch nicht das erste Board, das erst nach 2-3 Wochen vom Händler an den Hersteller retourniert wurde. :fresse:
Danke für deine Antwort :)
Werd' ich gleich mal machen, hab nur leider vergessen die SN zu notieren. Ich Döddel :wall:
Brauch ich die SN denn für den Thread bzw. braucht Asus die SN?
Hoffe, dass Caseking das Board schon weitergeleitet; sie haben mir ja auch geschrieben, dass es bereits beim Händler sei...
Grüße :)
Auch Caseking ist im Support Unterforum präsent. Schildere Dein Anliegen auch dort ... das könnte den Ablauf beschleunigen.
http://www.hardwareluxx.de/community/f243/
@braindead2004
Prolimatech Red Megahalems Kühlkörper Preisvergleich | Deutschland - Hardwareluxx - Preisvergleich
Prolimatech Black Megahalems Kühlkörper Preisvergleich | Deutschland - Hardwareluxx - Preisvergleich
Dazu als Lüfter - vor allem wenn man Speicher mit hohem Kühler hat:
Prolimatech Ultra Sleek Vortex 14 Preisvergleich | Deutschland - Hardwareluxx - Preisvergleich
Für den Sleek Vortex werden allerdings noch Lüfterklemmen benötigt:
Prolimatech Lüfterklemmen Ultra Sleek Vortex für Megahelms Preisvergleich | Deutschland - Hardwareluxx - Preisvergleich
Für normale 120er Lüfter sind natürlich Klemmen enthalten ... dann würde ich Dir den hier empfehlen:
Noiseblocker NB-Multiframe M12-PS, 120x120x25mm, 600-1500rpm, 40-100m³/h, 7-23dB(A) Preisvergleich | Deutschland - Hardwareluxx - Preisvergleich
Ich habe die Kombo übrigens bei mir im Einsatz gehabt auf dem Gene - empfehle also nur etwas wovon ich mich überzeugen konnte, dass es was taugt. ^^
Bios 1802 ist das erste Bios, mit dem ich Hyperthreading aktivieren/deaktivieren oder den Multi verstellen konnte, ohne dass die Einstellungen nicht übernommen wurden.
Haben die das etwa tatsächlich mal hinbekommen.. :)
bios 1802
meine cpu braucht eindeutig mehr vc
für 4,6 ghz statt vorher 1,200 jetzt 1,290
mit 1,280 nach 2 Std freez beim spielen.
ich haue mir mein alt bewährtes wieder drauf.
Moin
Habe seit kurzem auch dieses board bislang bin ich sehr zufrieden
Allerdings gab es probleme mit meiner aquaero die wurde komischer weise nicht einfandfrei erkannt am internen usb 2.0
Sobald ich die usb treiber installierte
Allerdings schaffte ein firnware und os flash der aquaero abhilfe
Nun bin ich gluecklich
Habe leider nur nen i5 3470 drauf verbaut habt ihr erfahrungen wie weit der geheb koennte
Bin bislang bei 39x106 auf allen 4 cores musste aber die spannung ein wenig anheben...aber denke mit 50grad unter prime 18h ohne probleme
Gesendet von meinem C6603 mit der Hardwareluxx App
---------- Post added at 13:04 ---------- Previous post was at 12:57 ----------
Ach und noch eine frage
Welche speicher empfehlt ihr
Bislang war ich immer ein corsair dominator verfechter
Gibts da was vergleichbares
G.Skill läuft auch sehr gut auf dem Board .... oder auch Team Xtreem.
Dieses Kit kann man schon als Schnäppchen ansehen:
TeamGroup Xtreem LV DIMM Kit 8GB PC3-19200U CL10-12-12-31 (DDR3-2400) (TXD38G2400HC10QDC01) Preisvergleich | Geizhals Deutschland
Dieses Kit ist sicherlich auch in Ordnung:
G.Skill TridentX DIMM Kit 8GB PC3-19200U CL10-12-12-31 (DDR3-2400) (F3-2400C10D-8GTX) Preisvergleich | Geizhals Deutschland
Für ein vergleichbares Dominator Platinum Kit darfst dann schon mal flauschige 50€ mehr abdrücken.
Kann mir jemand auf die schnelle sagen, ob das Board die USB Ports auch im S5 mit Strom versorgt, wie es bei AsRock der Fall ist??
Das würde mir reichen, ich muss nur intern 5V im OFF zustand abgreifen können, ohne nen Kabel an den ATX Stecker zu löten.
Kannst du das ggf. bei dir nachprüfen?
Jap ... musst mir aber etwas Zeit geben ... also bis Abend ...
Kann sein dass Power On by Keyboard enabled sein muss damit es geht.
Bei mir ist das immer enabled.
Das wäre super, wenn du das überprüfen könntest, also am internen USB Port einmal messen ob am +5VSB strom ankommt, wenn der Rechner aus ist.
Mein DMM ist leider am Sack ... habe ich wohl verdrängt ... kann also nur ein Device anschließen und schauen obs Lämple angeht. ;)
