Dionysos808
Hi Clockwise,
ich hab Dir mal das BIOS-Template ausgefüllt und die zu verändernden Einstellungen rot markiert, damit Du Deinen schönen, neuen Rechner ohne allzuviel Kopfzerbrechen nutzen kannst.
Edit: @ Deathmo:
Jeden Tag eine gute Tat... auch wenn ich kein Pfadfinder bin.
Code:
[B][SIZE="3"]Ai Tweaker[/SIZE][/B]
Ai Overclock Tuner [Auto]
CPU Ratio Setting [Auto]
FSB Frequency [Auto]
PCIE Frequency [Auto]
FSB Strap to North Bridge [Auto]
[COLOR="Red"]DRAM Frequency [DDR2-1066MHz]
DRAM Timing Control [Manual][/COLOR]
[COLOR="SlateGray"]1st Information : 5-5-5-18-X-XX-X-X[/COLOR]
[COLOR="Red"] CAS# Latency [5 DRAM Clocks]
DRAM RAS# to CAS# Delay [5 DRAM Clocks]
DRAM RAS# Precharge [5 DRAM Clocks]
DRAM RAS# Activate to Precha [18 DRAM Clocks][/COLOR]
RAS# to RAS# Delay [X DRAM Clocks]
Row Refresh Cycle Time [XX DRAM Clocks]
Write Recovery Time [X DRAM Clocks]
Read to Precharge Time [X DRAM Clocks]
[COLOR="SlateGray"]2nd Information : X-X-X-X-X-X-X[/COLOR]
READ to WRITE Delay (S/D) [X DRAM Clocks]
Write to Read Delay (S) [X DRAM Clocks]
WRITE to READ Delay (D) [X DRAM Clocks]
READ to READ Delay (S) [X DRAM Clocks]
READ to READ Delay (D) [X DRAM Clocks]
WRITE to WRITE Delay (S) [X DRAM Clocks]
WRITE to WRITE Delay (D) [X DRAM Clocks]
[COLOR="SlateGray"]3rd Information : XX-X-X-X-X[/COLOR]
WRITE to PRE Delay [XX DRAM Clocks]
READ to PRE Delay [X DRAM Clocks]
PRE to PRE Delay [X DRAM Clocks]
ALL PRE to ACT Delay [X DRAM Clocks]
ALL PRE to REF Delay [X DRAM Clocks]
[COLOR="Red"]DRAM Static Read Control [Disabled]
DRAM Read Training [Disabled]
MEM. OC Charger [Enabled]
AI Clock Twister [Moderate]
AI Transaction Booster [Manual][/COLOR]
[COLOR="SlateGray"]C/P : A1 A2 A3 A4 | B1 B2 B3 B4[/COLOR]
[COLOR="SlateGray"]LVL : 10 10 10 10 | 10 10 10 10[/COLOR]
[COLOR="Red"]Common Performance Level [10][/COLOR]
Pull-In of CHA PH1 [Disabled]
Pull-In of CHA PH2 [Disabled]
Pull-In of CHA PH3 [Disabled]
Pull-In of CHA PH4 [Disabled]
Pull-In of CHB PH1 [Disabled]
Pull-In of CHB PH2 [Disabled]
Pull-In of CHB PH3 [Disabled]
Pull-In of CHB PH4 [Disabled]
******** Please key in numbers directly! ********
CPU Voltage [Auto]
CPU GTL Reference [Auto]
CPU PLL Voltage [Auto]
FSB Termination Voltage [Auto]
[COLOR="Red"]DRAM Voltage [Herstellervorgabe - 0,08][/COLOR]
NB Voltage [Auto]
SB Voltage [Auto]
PCIE SATA Voltage [Auto]
[COLOR="SlateGray"]*************************************************[/COLOR]
[COLOR="Red"]Load-Line Calibration [Disabled]
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled][/COLOR]
CPU Clock Skew [Auto]
NB Clock Skew [Auto]
CPU Margin Enhancement [Compatible]
[B][SIZE="3"]Advanced > CPU Configuration[/SIZE][/B]
C1E Suppport [Enabled]
Max CPUID Value Limit [Disabled]
Intel(R) Virtualization Tech [Enabled]
CPU TM Function [Enabled]
Execute Disable Bit [Enabled]
Intel(R) SpeedStep(TM) Tech [Enabled]
Intel(R) C-STATE Tech [Enabled]
Edit: @ Deathmo:
