So manche Sachen wusste ich hier nich so gut weil ich das Board nicht habe,da muss dann halt ein anderer hiernoch was zu sagen,aber im großen und ganßen kannst du es so mal ausprobieren,und dann mit Prime testen..:AI Tweaker:.
AI Overclock Tuner [Manual]
CPU Ratio Setting [Auto] 9
FSB Frequency [Auto] 400
PCI-E Frequency [Auto]100
FSB Strap to North Bridge [Auto]333
DRAM Frequency [Auto] 1:1 sprich erstmal den kleinsten Wert
DRAM CLK Skew on Channel A1 [Auto]
DRAM CLK Skew on Channel A2 [Auto]
DRAM CLK Skew on Channel B1 [Auto]
DRAM CLK Skew on Channel B2 [Auto]
DRAM Timing Control [Auto]
1st Information : X-X-X-XX-X-XX-X-X
CAS# Latency [Auto]5
DRAM RAS# to CAS# Delay [Auto]5
DRAM RAS# Precharge [Auto]5
DRAM RAS# Activate to Precharge [Auto]18
RAS# to RAS# Delay [Auto]
Row Refresh Cycle Time [Auto]
Write Recovery Time [Auto]
Read to Precharge Time [Auto]
2nd Information : X-X-X-X-X-X-X
READ to WRITE Delay (S/D) [Auto]
Write to Read Delay (S) [Auto]
WRITE to READ Delay (D) [Auto]
READ to READ Delay (S) [Auto]
READ to READ Delay (D) [Auto]
WRITE to WRITE Delay (S) [Auto]
WRITE to WRITE Delay (D) [Auto]
3rd Information : XX-X-X-X-X
WRITE to PRE Delay [Auto]
READ to PRE Delay [Auto]
PRE to PRE Delay [Auto]
ALL PRE to ACT Delay [Auto]
ALL PRE to REF Delay [Auto]
DRAM Static Read Control [Auto]
DRAM Read Training [Auto]
MEM. OC Charger [Auto]
AI Clock Twister [Auto] Auf das niedigste erstmal,kann man später hochdrenen
AI Transaction Booster [Auto]
Common Performance Level []10
Pull-In of CHA PH1 [Disabled]
Pull-In of CHA PH2 [Disabled]
Pull-In of CHA PH3 [Disabled]
Pull-In of CHA PH4 [Disabled]
Pull-In of CHB PH1 [Disabled]
Pull-In of CHB PH2 [Disabled]
Pull-In of CHB PH3 [Disabled]
Pull-In of CHB PH4 [Disabled]
******** Please key in numbers directly! ********
CPU Voltage [Auto]Musst du testen 1.3v sollten für den Anfang ausreichen
CPU GTL Voltage Reference (0/2) [Auto]
CPU GTL Voltage Reference (1/3) [Auto]
CPU PLL Voltage [Auto]1.52v
FSB Termination Voltage [Auto] 1.20v
DRAM Voltage [Auto]2.0v
NB Voltage [Auto]1.20v
NB GTL Reference [Auto]
SBridge Voltage [Auto]
PCIE SATA Voltage [Auto]
Load Line Calibration [Auto]Disabled
CPU Spread Spectrum [Auto]
PCIE Spread Spectrum [Auto]
CPU Clock Skew [Auto]
NB Clock Skew [Auto]
CPU Margin Enhancement [Auto]
.:Advanced - CPU Configuration:.
C1E Suppport [Enabled]
Max CPUID Value Limit [Disabled]
Intel (R) Virtualization Tech [Enabled]
CPU TM Function [Enabled]
Execute Disable Bit [Enabled]
Intel (R) SpeedStep (TM) Tech [Enabled]
Intel (R) C-STATE Tech [Enabled]
Die 600Mhz FSB hab ich nicht geprimelt, aber 45min gebencht, lief solang bombenstabilxXRadioaktivXx
Was für Spannungen brauchst du für 600 FSB?
Haste die schonmal durch large durchbekommen?
Stell mal einen Screenshot von dem Bluescreen hier rein.
@ Obihoernchen
Was bedeutet das "m" bei "Bios: 1901m"?
Das Ket Mod Bios reizt mich auch, nur habe ich die nächsten Tage keine Zeit zum testenkann man damit noch mehr FSB fahren, als ohnehin schon möglich?
Stichwort RAM-Teiler: Bei gleichem FSB kannst Du mit dem 400er Strap den Speicher per Teiler noch höher takten als mit dem 333er Strap.![]()
http://www.hardwareluxx.de/community/showpost.php?p=11346022&postcount=12
Das kannste dir auch mal ankucken ganß informativ,die Spannung passt,ist die derzeit auf "Auto"?
Man muss echt zugeben dieser Thread ist echt gut gemacht,jetzt wo ich ein wenig bescheid weiß merk ich das erst![]()
Das wird soviel wie "modifiziert" heißen. Er benutzt das BIOS von Ket.
Danke.
ObihoernchenDE
Schaust du nochmal über die Settings die ich ihn gegeben hab,für sein Gewissen damit das auch beruigt is![]()
Jepp und zwar im BIOSjap warat sehr nett :P
achja was ich noch fragen wollte ..
da ich meine lüfter über ne master ace steuer und somit den cpu lüfter nich am board hab kommt vorm boot screen immer ne meldung :
cpu fan error oder so
press f1 to continue
kann man die irgendwie ausschalten?![]()
@ SoliderofWastelanD
nun Orxses hat Dir ja nun die Anfangslektüre bereitgestellt - viel Spaß damit, wenn Du es kapiert hast ist dein Eintrittskarte auch abgeknipst wie auf Schalke oder so ;-)
Wenn Du gerade nen neues Board hast kannst Du mir sicherlich mal verraten welch eine revision von dem Bord (Boardversio) du besitzt. Das steht neber der Bezeichnung auf dem Board REV. 1.xxx
Und an den rest welche Revisionen gibt es denn vom p5q-E wenn überhaupt.
@ Christine
Du kannst mal versuchen das alles mit nur einem Ram Baustein zu machen in Everest ist auch ein netter Ram test. Stimmt im Bios immer deine Uhrzeit? ansonsten kann die Batterie hin sein und beim Starten schaut das Bord was alles da ist denn das Gedächtnis ist ja leer und wie bei uns dauert es beim einen schneller und beim anderen langsamer ;-)
Welche Revision hat denn dein Board?
Danke ObihoernchenDE
Sagt mal wenn man sich nun ein neues P5Q-E Kauft sind da keine Aufkleber mit dabei und ist das nicht mehr in dieser Anthrazit schimmernden Folie Verpackt?
oder hat mir da KM in Frankfurt ein gebrauchtes als neu verkauft?1?
Ich frage nur mal so weil den Verkäufer habe ich gefragt und der sagte es sei neu und OVP ansonsten würde man sich strafbar machen und man Vertraut ja seinem Händler des Vertrauens.
