so ich hab meine settings gestern auch no überarbeitet, 3,3 GHz ist echt der rest mehr will einfach net ob ich PL anheb oder die volt settings mehr funkt stabil net...
ich hab den multi mehr runter dreht um mehr FSB raus zu quetschen, die ram performance ist derbe dadurch gestiegen, 1:1 ist einfach schön
settings :
Ai Tweaker
Ai Overclock Tuner [Manual]
CPU Ratio Setting [07.0]
FSB Frequency [472]
PCIE Frequency [100]
FSB Strap to North Bridge [Auto]
DRAM Frequency [DDR2-944]
DRAM Timing Control [Manual]
CAS# Latency [5 DRAM Clocks]
DRAM RAS# to CAS# Delay [5 DRAM Clocks]
DRAM RAS# Precharge [5 DRAM Clocks]
DRAM RAS# Activate to Precha [12 DRAM Clocks]
DRAM Static Read Control [Disabled]
DRAM Read Training [Disabled]
MEM. OC Charger [Enabled]
Ai Clock Twister [Moderate]
Ai Transaction Booster [Manual]
C/P : A1 A2 A3 A4 | B1 B2 B3 B4
LVL : 10 10 10 10 | 10 10 10 10
Common Performance Level [10]
Pull-In of CHA PH1 [Disabled]
Pull-In of CHA PH2 [Disabled]
Pull-In of CHA PH3 [Disabled]
Pull-In of CHA PH4 [Disabled]
Pull-In of CHB PH1 [Disabled]
Pull-In of CHB PH2 [Disabled]
Pull-In of CHB PH3 [Disabled]
Pull-In of CHB PH4 [Disabled]
******** Please key in numbers directly! ********
CPU Voltage [1.36250]
CPU GTL Reference [0.63x]
CPU PLL Voltage [1.50]
FSB Termination Voltage [1.28]
DRAM Voltage [1.98]
NB Voltage [1.26]
SB Voltage [1.10]
PCIE SATA Voltage [1.50]
Load-Line Calibration [Enabled]
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled]
CPU Clock Skew [Auto]
NB Clock Skew [Auto]
CPU Margin Enhancement [Optimized]
Advanced > CPU Configuration
C1E Suppport [Disabled]
Max CPUID Value Limit [Disabled]
Intel(R) Virtualization Tech [Disabled]
CPU TM Function [Enabled]
Execute Disable Bit [Enabled]
