Du kannst mal diese Config benutzen:
AI Overclock Tuner [Manual]
CPU Ratio Setting [9.0]
FSB Frequency [400 MHz]
später dann erhöhen
PCI-E Frequency [100 MHz]
FSB Strap to North Bridge [333 MHz]
DRAM Frequency [800 MHz]
erhöht sich dann mit FSB Frequency
DRAM Timing Control [Manual]
CAS# Latency [5 DRAM Clocks]
DRAM RAS# to CAS# Delay [5 DRAM Clocks]
DRAM RAS# Precharge [5 DRAM Clocks]
DRAM RAS# Activate to Precharge [18 DRAM Clocks]
RAS# to RAS# Delay [Auto]
Row Refresh Cycle Time [Auto]
Write Recovery Time [Auto]
Read to Precharge Time [Auto]
READ to WRITE Delay (S/D) [Auto]
Write to Read Delay (S) [Auto]
WRITE to READ Delay (D) [Auto]
READ to READ Delay (S) [Auto]
READ to READ Delay (D) [Auto]
WRITE to WRITE Delay (S) [Auto]
WRITE to WRITE Delay (D) [Auto]
WRITE to PRE Delay [Auto]
READ to PRE Delay [Auto]
PRE to PRE Delay [Auto]
ALL PRE to ACT Delay [Auto]
ALL PRE to REF Delay [Auto]
DRAM Static Read Control [Disabled]
DRAM Read Training [Disabled]
MEM. OC Charger [Enabled]
AI Clock Twister [Moderate]
AI Transaction Booster [Manual]
Common Performance Level [13]
Pull-In of CHA PH1 [Disabled]
Pull-In of CHA PH2 [Disabled]
Pull-In of CHA PH3 [Disabled]
Pull-In of CHA PH4 [Disabled]
Pull-In of CHB PH1 [Disabled]
Pull-In of CHB PH2 [Disabled]
Pull-In of CHB PH3 [Disabled]
Pull-In of CHB PH4 [Disabled]
******** Please key in numbers directly! ********
CPU Voltage [1.30000]
In der Regel gilt=100MHz ~ +0,04v
CPU GTL Voltage Reference [Auto]
CPU PLL Voltage [1.52]
FSB Termination Voltage [1.18]
Probieren
DRAM Voltage [2.04]
NB Voltage [1.18]
Probieren
SBridge Voltage [1.10]
PCIE SATA Voltage [1.50]
Load Line Calibration [Disabled]
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled]
CPU Clock Skew [Auto]
NB Clock Skew [Auto]
CPU Margin Enhancement [Performance Mode]
Mach dir aber selber den gefallen und belege nicht alle 4 Speicher-Bänke.
Hau mal nur 2 Riegel rein und probier es mit der oben genannten Config.
Für 3,6 GHz sind die Werte wahrscheinlich ein bißchen zu hoch (vCore, vFSB und vNB), aber probier es mal so. Dann fährt dein PC auf jeden Fall mal hoch
Läuft es stabil (Prime small), kannst du gleich mal die vCore um 3Stufen runtersetzen und erneut small durchlaufen lassen.
So lange bis es nicht mehr stabil läuft.
Dann die vCore (um sicher zu gehen) 2 Stufen höher stellen.
Danach Large laufen lassen.
Hier kannst du vFSB und vNB 2 Stufenweise runterstellen und erneut probieren. So wie oben bei small.
Für den Anfang sollten jeweils ne Stunde Laufzeit reichen.
Später dann small und Large für min.3-4Std.
Mit deinem Q9650 sollten aber die 4GHz kein Problem sein, da es ein Multi von 9 hat.
Es kommt halt auf dich drauf an, auf was du aus bist.
