[Sammelthread] ASUS P8Z77-V / -PRO / -Deluxe / -Premium (Intel Z77)
- Sockel: LGA1155 - Chipsatz: Intel Z77 Sammelthread -
P8Z77 | Geizhals.at Deutschland
INHALTSVERZEICHNIS
1.Spezifikationen 1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77V
- Zusammenfassung Spezifikationen / Features -
Prozessor / Sockel:
Intel® Socket 1155 for 3rd/2nd Generation Processors
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z77
Memory:
4 x DIMM, Max. 32GB, DDR3 2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB/DisplayPort ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology *1
Supports AMD Quad-GPU CrossFireX™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *2
Expansion Slots:
2 x PCIe 3.0/2.0 x16 (x16 or dual x8) *3
1 x PCIe 2.0 x16 (x4 mode, black)
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
Intel® Z77 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *5
ASMedia® PCIe SATA controller : *6
2 x SATA 6Gb/s port(s), navy blue
LAN:
Intel® 82579V, 1 x Gigabit LAN Controller(s)
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Wireless Data Network:
Wi-Fi 802.11 b/g/n
Supports single band frequency 2.4GHz
Audio:
Realtek® ALC892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller : *7
2 x USB 3.0 port(s) (2 at back panel, blue)
Intel® Z77 chipset : *7
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
10 x USB 2.0 port(s) (2 at back panel, black, 8 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
- Smart DIGI+ Key- quickly delivers higher VRM frequency, voltage and current for superior CPU/iGPU/DRAM overclocking performance with one switch.
- Smart CPU Power Level (Intel® VRD 12.5 Future Power Design)- provides the best digital power saving conditions.
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 12 Phase Power Design
(8 -phase for CPU, 4 -phase for iGPU)
- Industry leading Digital 2 Phase DRAM Power Design
- CPU Power Utility
- DRAM Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *8
- Wi-Fi GO! Remote for portable Smartphone/Tablet, supporting iOS & Android systems
- Wi-Fi Engine for network sharing and connection: Client Mode, AP Mode
ASUS Exclusive Features :
- USB BIOS Flashback
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
1 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x WLAN connector(s) for ASUS wireless module
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin)
4 x USB 2.0 connector(s) support(s) additional 8 USB 2.0 port(s)
1 x TPM connector(s)
1 x COM port(s) connector(s)
4 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
1 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x Optional Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Clear CMOS jumper(s)
1 x USB BIOS Flashback button(s)
Accessories:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
2 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ASUS Wi-Fi GO! card(s)
1 x Wi-Fi Ring Moving Antenna(s)
BIOS:
64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen, F3 Shortcut Function and ASUS DRAM SPD (Serial Presence Detect) memory information
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, PXE, WOR by PME
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: With 2 PCIex16 graphics card.
*2: LucidLogix Virtu MVP supports Windows 7 operating systems.
*3: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*4: The PCIe x1_2 shares bandwidth with SATA6G_E12. SATA6G_E12 is enabled by default for system resource optimization.
*5: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*6: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*7-1: Supports ASUS USB 3.0 Boost UASP Mode.
*7-2: The USB 3.0 ports only support Windows® 7 or later versions.
*8: Available with V1.01.00 or later.
*9: Due to Intel® chipset limitation, P8Z77, P8H77 and P8B75 series motherboards do not support Windows® Vista operating system.
CPUs für P8Z77-V:
ASUS - Mainboards- ASUS P8Z77-V
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V PRO
Prozessor / Sockel:
Chipset:
Intel® Z77
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
LAN:
Wi-Fi 802.11 b/g/n
Audio:
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB Ports:
Special Features:
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
Internal I/O Ports:
2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin)
4 x Chassis Fan connector(s)
1 x System panel(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
CPUs für P8Z77-V Pro:
ASUS - Mainboards- ASUS P8Z77-V Pro
Tests (deutsch):
http://www.awardfabrik.de/mainboards/asus-p8z77-v-pro.html
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Deluxe
Prozessor / Sockel:
Unterstützt Intel® 22 nm-Prozessoren
Unterstützt die Intel® Turbo Boost-Technologie 2
* Die Unterstützung der Intel® Turbo Boost-Technologie 2.0 ist vom Prozessor-Typ abhängig.
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 MHz Non-ECC, Un-buffered Memory
Dual Channel-Speicherarchitektur
Unterstützt Intel® Extreme Memory Profile (XMP)
* Die Hyper DIMM-Unterstützung ist von den Merkmalen des jeweiligen Prozessors abhängig.
* Eine Liste freigegebener Speichermodule finden Sie auf der Webseite ASUS oder im Benutzerhandbuch.
Grafik:
Integrierter Grafikprozessor
Multi-VGA Ausgaben Unterstützung : HDMI/DisplayPort Schnittstellen
- Unterstützt HDMI mit einer max. Auflösung von 1920 x 1200 @ 60 Hz
- Unterstützt DisplayPort mit einer max. Auflösung von 2560 x 1600 @ 60 Hz
Multi-GPU-Unterstützung:
Unterstützt die AMD® Quad-GPU CrossFireX™-Technologie
Erweiterungsschächte:
1 x PCIe 2.0 x16 (x4 Modus, schwarz)
4 x PCIe 2.0 x1 *4
Speichersystem:
2 x SATA 6Gb/s-Schnittstellen, grau
4 x SATA 3Gb/s-Schnittstellen, blau
Unterstützen RAID 0, 1, 5, 10
Marvell® PCIe 9128 controller :
2 x SATA 6Gb/s-Schnittstellen, navy blue
2 x eSATA 6Gb/s-Schnittstellen, red
LAN:
Realtek® 8111F, 1 x Gigabit LAN Controller(s)
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Kanal High Definition Audio CODEC
- Unterstützt : Anschlusserkennung, und Multistreaming, Technologien sowie automatische Geräteerkennung an der Gehäusevorderseite
Audio Feature :
- Blu-ray audio layer Content Protection
- optischer S/PDIF-Ausgang an der Gehäuserückseite
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
4 x USB 3.0 Schnittstellen (4 an der Gehäuserückseite, blau)
4 x USB 3.0 Schnittstellen (2 an der Gehäuserückseite, blau, 2 intern)
8 x USB 2.0 Schnittstellen (4 an der Gehäuserückseite, schwarz, 4 intern)
Übertaktung:
Sicherheit beim Übertakten :
Besondere Features:
ASUS Dual Intelligent Processors Technologie 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU-Taste
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 20 Phase Power Design
(16 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS (EZ-Modus) inkl. benutzerfreundlicher, grafischer Oberfläche
- ASUS SSD Caching
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Anschlüsse (Rückseite):
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) Schnittstelle
6 x USB 3.0
4 x USB 2.0
1 x S/PDIF-Ausgang (optisch)
6 x Audio-Anschlüsse
1 x Bluetooth V4.0 connector(s) for ASUS Wi-Fi GO! card
1 x USB BIOS Flashback Button(s)
interne Anschlüsse:
1 x USB 3.0-Anschluss unterstützt zusätzlich 2 USB 3.0-Schnittstellen (19-pin)
2 x USB 2.0-Anschlüsse unterstützen zusätzlich 4 USB 2.0-Schnittstellen
4 x SATA 6Gb/s-Schnittstellen
1 x Prozessorlüfteranschluss
4 x Gehäuselüfteranschlüsse
1 x S/PDIF-Ausgang
1 x 24-Pin EATX Netzanschluss
1 x 8-Pin ATX 12V Netzanschluss
1 x Audio-Anschluss an der Gehäusevorderseite (AAFP)
1 x MemOK!-Taste
1 x System panel(s)
1 x TPU-Taste
1 x EPU-Taste
1 x Clear BIOS-Taste
1 x Power-on button(s)
1 x Reset button(s)
Zubehör:
User's manual
ASUS Q-Shield
2 x SATA 3Gb/s-Kabel
4 x SATA 6Gb/s-Kabel
1 x SLI bridge(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS :
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
12 " x 9.6 " ( 30.5 cm x 24.4 cm )
Anmerkung:
- CPU-Liste -
Grundsätzlich sind alle LGA1155 Sandy-Bridge CPUs kompatibel zum ASUS P8Z77-V Deluxe. Wer jedoch seinen Prozzi möglichst weit übertakten möchte,
der kommt an einem Modell mit dem Zusatz "K" im Namen nicht vorbei. Denn auschliesslich diese lassen einen höheren "Turbomulti" zu. Modelle ohne "K"
besitzen einen festen maximalen "Turbomulti" und sind daher für OC ungeeignet, da der Referenztakt nur von 100MHz auf maximal 105-110MHz
erhöht werden kann (kommt sonst zu Instabilitäten!).
CPUs für P8Z77-V Deluxe:
ASUS - Mainboards- ASUS P8Z77-V DELUXE
Tests (deutsch):
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=733&sel_lang=german
http://www.hartware.net/review_1463.html
Bios History:
0801
0906
1015
1206
1401
1502
1504
1617
1709
1805
1908
2003
2104
1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Premium
CPU:
Intel® Socket 1155 for 3[SUP]rd[/SUP]/2[SUP]nd[/SUP] Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.ChipsetIntel® Z77
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Thunderbold:
ThunderboltVGA output support
Data transfer rate up to 10 Gbps
Daisy-chain up to 6 Thunderbolt devices
Grafik:
Multi-VGA output support : HDMI/DisplayPort/Thunderbolt ports
- Supports Thunderbolt with max. resolution 2560 x 1600 @ 60 Hz
Maximum shared memory of 1696 MB
Supports NVIDIA® 4-Way SLI™ Technology
Supports AMD 4-Way CrossFireX Technology
Supports LucidLogix® Virtu™ MVP Technology *[SUP]1[/SUP]
4 x PCIe 3.0/2.0 x16 (dual x16 or x16, x8, x8 or quad x8) *[SUP]2[/SUP]
2 x PCIe 2.0 x1
Speichersystem:
Intel® Z77 chipset : 2 x SATA 6Gb/s port(s), gray
3 x SATA 3Gb/s port(s), blue
1 x mini-SATA 3Gb/s port(s) with onboard 32GB SSD, black
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *[SUP]3[/SUP]
Marvell® PCIe 9230 controller :
4 x SATA 6Gb/s port(s), navy blue
Support Raid 0, 1, 10
ASMedia® PCIe SATA controller : *[SUP]4[/SUP]2 x eSATA 6Gb/s port(s), red
LAN:
Intel® 82583, 1 x Gigabit LAN Controller(s)
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Channel High Definition Audio CODEC
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
Intel® Z77 chipset : *[SUP]5[/SUP]4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
Intel® Z77 chipset :6 x USB 2.0 port(s) (2 at back panel, black, 4 at mid-board)
Übertaktung:
Besondere Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- CPU Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *[SUP]6[/SUP]
ASUS Exclusive Features :- USB BIOS Flashback
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS SSD Caching II
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY : - ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
1 x Thunderbolt port(s)
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
interne Anschlüsse:
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
3 x SATA 3Gb/s connector(s)
1 x mSATA connector(s) with 32GB SSD onboard
1 x CPU Fan connector(s) (4 -pin)
1 x CPU OPT Fan connector(s) (4 -pin)
1 x System panel(s) (Q-Connector)
1 x TPU switch(es)
1 x EPU switch(es)
1 x CPU/DRAM overvoltage jumper(s)
1 x Reset button(s)
1 x Clear CMOS button(s)
Zubehör:
User's manual
ASUS Q-Shield
4 x SATA 6Gb/s cable(s)
1 x 3-Way SLI bridge(s)
1 x 4-Way SLI bridge(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
Anmerkung:
*1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*3: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*4: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*5: The USB 3.0 ports run at USB 3.0 speed rate under Windows® 7 or later versions.
*6: Available with V1.01.00 or later.
3.UEFI-Einblicke (ehemals Bios) 3.UEFI-Einblicke (ehemals Bios)
4.Downloads 4.Downloads
allgemein:
Hinweis:
Nach dem Download nicht vergessen die zip.-Datei zu entpacken.
UEFI-Update möglichst mit EZ-Flash durchführen. Näheres dazu siehe Handbuch.
Flash erfolgt grundsätzlich auf eigenes Risiko!
6.kompatible CPU-Kühler 6.kompatible CPU-Kühler
Alle Sockel 1156-Kühler könnten auf dem Z77 passen, da die Lochabstände 1156/1155 identisch sind! Vorausgesetzt sie kollidieren nicht mit Anbauten/Heatpipes
(fast) problemlos passende Luftkühler: :)
Be quiet! Dark Pro Advanced
EKL Brocken
Intel Boxed Kühler
Noctua NH-C12P SE14
Noctua NH-D14
Prolimatech Genesis (es kann möglicherweise zu Problemen mit dem Pcie x1 anschluß kommen, kleiner abstand zum kühler)
Thermalright HR-02 Macho (SE / Rev. A) - keine Probleme (neuere Revisionen mit Innenbefestigungsklammern)
Zalman CNPS11X Performa (auch bei Vollbestückung knapp passend)
Mit Einschränkungen !!! :
be quiet! Dark Rock Pro 2 (es sollten low Profile Ram verwendet werden)
Noctua NH-U14S (oberster PCIe Slot nur eingeschränkt nutzbar)
Scythe Mine 2 unter verwendung FSMB 4 Backplate und weiteren einschränkungen
Scythe Mugen II Revision B mit dem 1156er Kit Ram Bänke A1 und B1 nur noch mit low profil Ram bestückbar
Scythe Mugen 3 B
wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright Archon SB-E u. Thermalright Archon - blockiert teilweise obersten Slot (PCIe x1), sonst keine Probleme
Thermalright HR-02 Macho wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright HR-02 Macho 120 - keine Probleme bei Nutzung von Ram ohne hohe HS, andernfalls kann der erste Ramslot nicht genutzt werden
Thermalright Silver Arrow SBE SE -
Nur die 2 blauen RAM Slots lassen sich nutzen wenn der erste Lüfter normal sitzt, will man alle haben muss man ihn höher montieren, nur LP Ram Pci-e wird blockiert
Thermalright True Spirit 140 längere Pcie Karten auf Slot Pcie x1 sind nicht mehr verwendbar.
Wasserkühler und Flüssigkeitskühler
Antec H2o 620
Corsair H80
7.kompatibler RAM 7.kompatibler RAM
Corsair XMS3 PC3-16000U CL9
Corsair XMS3 Dominator Platinum DIMM Kit 8GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMD8GX3M2A2133C9) Achtung Ram hat Überhöhe !!
Corsair Dominator CMP16GX3M4X1866C9 4x4 Kit
Corsair XMS3 Dominator GT DIMM Kit 16GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMT16GX3M4X2133C9)
Corsair Vengeance Low Profile schwarz DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600)
Corsair Vengeance 2*8GB (CML16GX3M2A1600C10)
Corsair Vengeance Low Profile 16GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CML16GX3M4A1600C9)
Corsair Vengeance Low Profile 16GB (DDR3-1600) CML16GX3M4A1600C9
Corsair Vengeance Low Profile 4x8GB CL10-10-10-27 (DDR3-1600) (CML32GX3M4A1600C10B)
Crucial Ballistix Sport CL9 2 x 8GB Crucial BLS8G3D1609DS1S00
Crucial Ballistix Tactical LP (8GB Single) mit Einschränkungen siehe Post 1233
GeIL Evo Corsa GOC38GB1866C9DC
G.Skill Ares F3-1600C9D-8GAO
G.Skill F3-1866C10D-16GAB
G.Skill Ares DIMM Kit 16GB PC3-14900U CL9-10-9-28 (DDR3-1866) (F3-1866C9Q-16GAB)
G.Skill Ares F3-2133C9Q-16GAB - CL9-11-10
G.Skill RipJaws-X DIMM Kit 8GB PC3L-12800U CL9-9-9-24
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133) (F3-17000CL11D-8GBXL)
G.Skill RipJaws 4x 4GB 1600MHz CL 9-9-9-24 @ 1.5V ~ F3-12800CL9Q-16GBRL
G.Skill RipJaws 16GB DDR3 F3-12800CL9Q-16GBRL
Hynix RAM DDR3-1333 | 2x 2048 MB | Typ: HTM325U6CFR8C
Kingston KHX1333C9D3B1K2/8G 2x4 GB (DDR-3-1333)
Kingston HyperX blu. DIMM XMP Kit 8GB PC3-12800U CL9-9-9-27 (DDR3-1600) (KHX1600C9D3B1K2/8GX)
Kingston HyperX Plug n Play DIMM Kit 8GB PC3-12800U CL9 (DDR3-1600) (KHX1600C9D3P1K2/8G)
Kingston HyperX DDR3-1600 16 GB Kit (Typ: KHX1600C9D3K4/16GX)
Patriot (PXD316G1866C9K, Viper Xtreme DIVISION2) DIMM 16 GB DDR3-1866 Kit
Muskin Stileto DDR3-1333
Samsung Green Series DIMM Kit 8GB PC3L-12800U CL11 LP (MV-3V4G3D)
TeamGroup Elite 4x4GB PC3-10667U CL9-9-9-24
Danke an alle die dazu Beitragen das die Liste der Kompatibilität länger wird ...:hail:
sonstige Links
Da immer wieder die Fragen nach den unterschieden der Boards untereinander aufkommen, habe ich mal ein PDF Tabelle online gestellt, wo ich mich bemüht habe die meisten Unterschiede zu markieren.
Viel Spass damit:
http://netload.in/dateiHl4LsFD9cy/Vergleichsliste Asus P8Z77 Boards.pdf.htm
Update: 13.08.2012 (Changelog siehe Spoiler)
Threadupdate-History:
- 27.04.2015: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 08.01.2013: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 13.08.2012: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 05.07.2012: Bios History deluxe hinzugefügt
- 07.06.2012: Vergleichsliste gebaut und auf netload hochgeladen
- 04.06.2012: Tests hinzugefügt
- 03.06.2012: ein paar änderungen und P8Z77 Premium hinzugefügt
- 02.06.2012: Thread übernahme und aktualisierung der kompatiblen CPU Kühler sowie Arbeitsspeicher
- 19.04.2012: Sammelthread gestartet
:) Bei Gefallen des Threads darf der "Danke-Button" gerne gedrückt werden. :)
Ja, das 14er BIOS erst mal nicht benutzen.
Ich werde es bei mir erstmal drauf lassen und auf einen Fix warten.
Wobei ich bei mir aber keine Fehler bisher festgestellt habe.
Falls jemand weiß, was genau das Problem sein soll immer raus damit. ;)
Gesendet von meinem Galaxy Nexus mit der Hardwareluxx App
Da ich das Deluxe nicht unbedingt brauche, wollte ich das P8Z77-V bei Amazon bestellen. Sehe aber gerade, dass das Pro nur 10 Euro mehr kostet. Lohnt sich der kleine Aufpreis?
Weil?
Edit: Kann man WLAN im UEFI eigentlich deaktivieren?
Ja, kann man. Und Bluetooth, falls vorhanden, kann man auch deaktivieren.
Hallo Leute,
habe gerade einen Rechner mit einem Asus P8Z77-V Pro aufgesetzt und nun komme ich nicht mehr ins BIOS rein. Hatte es vorhin schon mal geschafft, aber jetzt.... Wann muss ich denn nun welche Tastenkombination drücken ? Habe den Rechner schon x-mal über ctrl-alt-del neu gestartet aber es nicht geschaft: Sei es mit ESC oder mit ENT.
Habt Ihr eine Idee ?
Danke schon mal für einen Tipp !
fortie
Entf drücken wenn du dazu aufgefordert wirst beim ersten Screen. Einmal drücken reicht.
Man muss schon fix sein, das Zeitfenster ist kurz...
Gesendet von meinem HTC Desire S mit der Hardwareluxx App
Da das P8Z77-V Pro ja keine eSATA-Anschlüsse hat, hab ich meine externen SATA-HDDs über je ein eSATA-Slotblech angeschlossen, welches wiederum an den internen Intel-SATA-Anschlüssen vom MB hängt.
Momentan muß ich die Platten vorm Booten einschalten, damit sie in Windows erkannt werden.
Was muß ich denn einstellen/installieren, damit die Platten beim Einschalten im laufenden Windows-Betrieb erkannt werden?
Hotplug im UEFI aktivieren.
Du kannst im UEFI (ich weiß jetz grad nich, wie genau der Punkt heißt) einzeln für jeden SATA-Port des Z77 Hotplug aktivieren bzw. deaktivieren.
ich hab's mehrmals versucht: Ich komme nicht in das BIOS über DEL rein.
Gibt es sonst noch irgenwelche Tricks ?
Danke für Eure Hilfe
fortie
fortie
Hast du die Tastatur an einem der für Eingabegeräte vorgesehenen Ports angesteckt? Diese sind auf der Blende markiert.
@fortie:
Ich würde Maus und Tastatur immer an den USB2.0-Ports anschließen.
Oder mal eine alte Tastatur mit PS/2-Anschluß testen. Damit sollts auf jeden Fall funktionieren.
Haben die eSATA-Anschlüsse Port Multiplier Funktion?
ich wollte mal fragen ob die beiden eSATA-Anschlüsse auf der Rückseite beim ...-Deluxe eine Port-Muliplier Funktion haben?
So dass man bei einigen externen Festplatten-Gehäusen zB. 2 oder 3 einzelne Platten sehen kann, über eine einzige eSATA Verbindung.
So, System ist aufgesetzt: Asus P8Z77-V mit Intel i5 3750k. Speicher sind noch meine alten Kingston HyperX 1333er DDR3. Als Systemplatte verwende ich jetzt eine Samsung 830 SSD mit 128GB.
Alles soweit installiert und läuft bisher top.
Eine Frage hab ich schonmal: Im Gerätemanager habe ich noch den "PCI-Kommunikationscontroller (einfach)" mit Ausrufezeichen versehen.. Treiber findet er autom. keine. Was muss ich hier machen und wozu ist der gut?
Danke!
An die Frage schließ ich mich an: Den hab ich auch und ich weiß nicht was es ist. Board: P8Z77-M Pro
Danke!
Was genau sin das jetzt? Kann mir unter "Management-Engine" grade nix denken.
Mein P8Z77-V DELUXE hat Alzheimer :(
da mir der Support von Asus bisher nicht weiterhelfen konnte wende ich mich an euch, vielleicht habt ihr noch eine Idee.
Mein Board vergißt immer die Einstellungen. Das fängt damit an das ich nach jedem Neustart mein eigenes Lüfterprofil in FaxXpert2 neu laden muss.
Das BIOS ist auch immer im ecoMode so dass ich sogar CPU Failure Warnung bekommen hatte (kommt zum Glück nicht mehr).
Ich wähle den normalen Modus und er befindet sich wieder im ECO beim Neustart.
CLR_CMOS bei entfernter Batterie und 5 Min warten war bei mir auch erfolglos.
Was kann ich noch tun? Hoffe nicht das mein Board defekt ist.
Hier meine Daten:
*Product Type : Motherboard
*Product Model : P8Z77-V DELUXE
[Motherboard Specification]
*Motherboard Revision : Rev. 1.xx
*Motherboard BIOS Revision : 1206
[VGA Card Specification]
*VGA Card Vendor : Asus
*VGA Card Model : GTX670-DC2-2GD5
*VGA Card Chipset : GTX670-DC2-2GD5
*VGA Card Driver : GTX670-DC2-2GD5
[CPU Specification]
*CPU Vendor : Intel
*CPU Type : IVY
*CPU Speed : I3770k
[Memory Specification]
*Memory Vendor : Corsair
*Memory Model : DD3
*Memory Capacity : 8132 MB 2Module
Bernhard
Die aktuelle Version installieren, da haben die Lüfterprofile Bestand.
Vielleicht noch für die Kompatbilitätsliste:
passt mit dem 1156er Kit ohne Probleme, allerdings sind die RAM-Bänke A1 und B1 durch den CPU-Fan verdeckt, sodass nur low profile RAMs in die ersten beiden Slots passen.
2x 4GB DDR3 1333er Riegel von Kingston, laufen @ stock settings ohne Probleme, auch wenn sie nicht in der Kompatibilitätsliste von Asus aufgeführt sind.
Von mir auch was für die Kompatibilitätsliste:
4x4GB TeamGroup Elite PC3-10667U CL9-9-9-24, laufen problemlos und wurden direkt erkannt
be quiet! Dark Rock Pro 2, passt, man sollte jedoch Low Profile RAM verwenden.
Was ist mit Punkt 3 gemeint?
"Fixed Nvidia GTX 680 hang when runing with UEFI driver."?
Benutze die Kombination und mir ist derartiges noch nicht aufgefallen.
