[Sammelthread] ASUS P8Z77-V / -PRO / -Deluxe / -Premium (Intel Z77)
- Sockel: LGA1155 - Chipsatz: Intel Z77 Sammelthread -
P8Z77 | Geizhals.at Deutschland
INHALTSVERZEICHNIS
1.Spezifikationen 1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77V
- Zusammenfassung Spezifikationen / Features -
Prozessor / Sockel:
Intel® Socket 1155 for 3rd/2nd Generation Processors
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z77
Memory:
4 x DIMM, Max. 32GB, DDR3 2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB/DisplayPort ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology *1
Supports AMD Quad-GPU CrossFireX™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *2
Expansion Slots:
2 x PCIe 3.0/2.0 x16 (x16 or dual x8) *3
1 x PCIe 2.0 x16 (x4 mode, black)
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
Intel® Z77 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *5
ASMedia® PCIe SATA controller : *6
2 x SATA 6Gb/s port(s), navy blue
LAN:
Intel® 82579V, 1 x Gigabit LAN Controller(s)
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Wireless Data Network:
Wi-Fi 802.11 b/g/n
Supports single band frequency 2.4GHz
Audio:
Realtek® ALC892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller : *7
2 x USB 3.0 port(s) (2 at back panel, blue)
Intel® Z77 chipset : *7
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
10 x USB 2.0 port(s) (2 at back panel, black, 8 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
- Smart DIGI+ Key- quickly delivers higher VRM frequency, voltage and current for superior CPU/iGPU/DRAM overclocking performance with one switch.
- Smart CPU Power Level (Intel® VRD 12.5 Future Power Design)- provides the best digital power saving conditions.
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 12 Phase Power Design
(8 -phase for CPU, 4 -phase for iGPU)
- Industry leading Digital 2 Phase DRAM Power Design
- CPU Power Utility
- DRAM Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *8
- Wi-Fi GO! Remote for portable Smartphone/Tablet, supporting iOS & Android systems
- Wi-Fi Engine for network sharing and connection: Client Mode, AP Mode
ASUS Exclusive Features :
- USB BIOS Flashback
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
1 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x WLAN connector(s) for ASUS wireless module
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin)
4 x USB 2.0 connector(s) support(s) additional 8 USB 2.0 port(s)
1 x TPM connector(s)
1 x COM port(s) connector(s)
4 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
1 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x Optional Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Clear CMOS jumper(s)
1 x USB BIOS Flashback button(s)
Accessories:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
2 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ASUS Wi-Fi GO! card(s)
1 x Wi-Fi Ring Moving Antenna(s)
BIOS:
64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen, F3 Shortcut Function and ASUS DRAM SPD (Serial Presence Detect) memory information
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, PXE, WOR by PME
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: With 2 PCIex16 graphics card.
*2: LucidLogix Virtu MVP supports Windows 7 operating systems.
*3: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*4: The PCIe x1_2 shares bandwidth with SATA6G_E12. SATA6G_E12 is enabled by default for system resource optimization.
*5: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*6: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*7-1: Supports ASUS USB 3.0 Boost UASP Mode.
*7-2: The USB 3.0 ports only support Windows® 7 or later versions.
*8: Available with V1.01.00 or later.
*9: Due to Intel® chipset limitation, P8Z77, P8H77 and P8B75 series motherboards do not support Windows® Vista operating system.
CPUs für P8Z77-V:
ASUS - Mainboards- ASUS P8Z77-V
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V PRO
Prozessor / Sockel:
Chipset:
Intel® Z77
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
LAN:
Wi-Fi 802.11 b/g/n
Audio:
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB Ports:
Special Features:
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
Internal I/O Ports:
2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin)
4 x Chassis Fan connector(s)
1 x System panel(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
CPUs für P8Z77-V Pro:
ASUS - Mainboards- ASUS P8Z77-V Pro
Tests (deutsch):
http://www.awardfabrik.de/mainboards/asus-p8z77-v-pro.html
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Deluxe
Prozessor / Sockel:
Unterstützt Intel® 22 nm-Prozessoren
Unterstützt die Intel® Turbo Boost-Technologie 2
* Die Unterstützung der Intel® Turbo Boost-Technologie 2.0 ist vom Prozessor-Typ abhängig.
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 MHz Non-ECC, Un-buffered Memory
Dual Channel-Speicherarchitektur
Unterstützt Intel® Extreme Memory Profile (XMP)
* Die Hyper DIMM-Unterstützung ist von den Merkmalen des jeweiligen Prozessors abhängig.
* Eine Liste freigegebener Speichermodule finden Sie auf der Webseite ASUS oder im Benutzerhandbuch.
Grafik:
Integrierter Grafikprozessor
Multi-VGA Ausgaben Unterstützung : HDMI/DisplayPort Schnittstellen
- Unterstützt HDMI mit einer max. Auflösung von 1920 x 1200 @ 60 Hz
- Unterstützt DisplayPort mit einer max. Auflösung von 2560 x 1600 @ 60 Hz
Multi-GPU-Unterstützung:
Unterstützt die AMD® Quad-GPU CrossFireX™-Technologie
Erweiterungsschächte:
1 x PCIe 2.0 x16 (x4 Modus, schwarz)
4 x PCIe 2.0 x1 *4
Speichersystem:
2 x SATA 6Gb/s-Schnittstellen, grau
4 x SATA 3Gb/s-Schnittstellen, blau
Unterstützen RAID 0, 1, 5, 10
Marvell® PCIe 9128 controller :
2 x SATA 6Gb/s-Schnittstellen, navy blue
2 x eSATA 6Gb/s-Schnittstellen, red
LAN:
Realtek® 8111F, 1 x Gigabit LAN Controller(s)
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Kanal High Definition Audio CODEC
- Unterstützt : Anschlusserkennung, und Multistreaming, Technologien sowie automatische Geräteerkennung an der Gehäusevorderseite
Audio Feature :
- Blu-ray audio layer Content Protection
- optischer S/PDIF-Ausgang an der Gehäuserückseite
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
4 x USB 3.0 Schnittstellen (4 an der Gehäuserückseite, blau)
4 x USB 3.0 Schnittstellen (2 an der Gehäuserückseite, blau, 2 intern)
8 x USB 2.0 Schnittstellen (4 an der Gehäuserückseite, schwarz, 4 intern)
Übertaktung:
Sicherheit beim Übertakten :
Besondere Features:
ASUS Dual Intelligent Processors Technologie 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU-Taste
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 20 Phase Power Design
(16 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS (EZ-Modus) inkl. benutzerfreundlicher, grafischer Oberfläche
- ASUS SSD Caching
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Anschlüsse (Rückseite):
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) Schnittstelle
6 x USB 3.0
4 x USB 2.0
1 x S/PDIF-Ausgang (optisch)
6 x Audio-Anschlüsse
1 x Bluetooth V4.0 connector(s) for ASUS Wi-Fi GO! card
1 x USB BIOS Flashback Button(s)
interne Anschlüsse:
1 x USB 3.0-Anschluss unterstützt zusätzlich 2 USB 3.0-Schnittstellen (19-pin)
2 x USB 2.0-Anschlüsse unterstützen zusätzlich 4 USB 2.0-Schnittstellen
4 x SATA 6Gb/s-Schnittstellen
1 x Prozessorlüfteranschluss
4 x Gehäuselüfteranschlüsse
1 x S/PDIF-Ausgang
1 x 24-Pin EATX Netzanschluss
1 x 8-Pin ATX 12V Netzanschluss
1 x Audio-Anschluss an der Gehäusevorderseite (AAFP)
1 x MemOK!-Taste
1 x System panel(s)
1 x TPU-Taste
1 x EPU-Taste
1 x Clear BIOS-Taste
1 x Power-on button(s)
1 x Reset button(s)
Zubehör:
User's manual
ASUS Q-Shield
2 x SATA 3Gb/s-Kabel
4 x SATA 6Gb/s-Kabel
1 x SLI bridge(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS :
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
12 " x 9.6 " ( 30.5 cm x 24.4 cm )
Anmerkung:
- CPU-Liste -
Grundsätzlich sind alle LGA1155 Sandy-Bridge CPUs kompatibel zum ASUS P8Z77-V Deluxe. Wer jedoch seinen Prozzi möglichst weit übertakten möchte,
der kommt an einem Modell mit dem Zusatz "K" im Namen nicht vorbei. Denn auschliesslich diese lassen einen höheren "Turbomulti" zu. Modelle ohne "K"
besitzen einen festen maximalen "Turbomulti" und sind daher für OC ungeeignet, da der Referenztakt nur von 100MHz auf maximal 105-110MHz
erhöht werden kann (kommt sonst zu Instabilitäten!).
CPUs für P8Z77-V Deluxe:
ASUS - Mainboards- ASUS P8Z77-V DELUXE
Tests (deutsch):
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=733&sel_lang=german
http://www.hartware.net/review_1463.html
Bios History:
0801
0906
1015
1206
1401
1502
1504
1617
1709
1805
1908
2003
2104
1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Premium
CPU:
Intel® Socket 1155 for 3[SUP]rd[/SUP]/2[SUP]nd[/SUP] Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.ChipsetIntel® Z77
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Thunderbold:
ThunderboltVGA output support
Data transfer rate up to 10 Gbps
Daisy-chain up to 6 Thunderbolt devices
Grafik:
Multi-VGA output support : HDMI/DisplayPort/Thunderbolt ports
- Supports Thunderbolt with max. resolution 2560 x 1600 @ 60 Hz
Maximum shared memory of 1696 MB
Supports NVIDIA® 4-Way SLI™ Technology
Supports AMD 4-Way CrossFireX Technology
Supports LucidLogix® Virtu™ MVP Technology *[SUP]1[/SUP]
4 x PCIe 3.0/2.0 x16 (dual x16 or x16, x8, x8 or quad x8) *[SUP]2[/SUP]
2 x PCIe 2.0 x1
Speichersystem:
Intel® Z77 chipset : 2 x SATA 6Gb/s port(s), gray
3 x SATA 3Gb/s port(s), blue
1 x mini-SATA 3Gb/s port(s) with onboard 32GB SSD, black
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *[SUP]3[/SUP]
Marvell® PCIe 9230 controller :
4 x SATA 6Gb/s port(s), navy blue
Support Raid 0, 1, 10
ASMedia® PCIe SATA controller : *[SUP]4[/SUP]2 x eSATA 6Gb/s port(s), red
LAN:
Intel® 82583, 1 x Gigabit LAN Controller(s)
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Channel High Definition Audio CODEC
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
Intel® Z77 chipset : *[SUP]5[/SUP]4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
Intel® Z77 chipset :6 x USB 2.0 port(s) (2 at back panel, black, 4 at mid-board)
Übertaktung:
Besondere Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- CPU Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *[SUP]6[/SUP]
ASUS Exclusive Features :- USB BIOS Flashback
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS SSD Caching II
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY : - ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
1 x Thunderbolt port(s)
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
interne Anschlüsse:
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
3 x SATA 3Gb/s connector(s)
1 x mSATA connector(s) with 32GB SSD onboard
1 x CPU Fan connector(s) (4 -pin)
1 x CPU OPT Fan connector(s) (4 -pin)
1 x System panel(s) (Q-Connector)
1 x TPU switch(es)
1 x EPU switch(es)
1 x CPU/DRAM overvoltage jumper(s)
1 x Reset button(s)
1 x Clear CMOS button(s)
Zubehör:
User's manual
ASUS Q-Shield
4 x SATA 6Gb/s cable(s)
1 x 3-Way SLI bridge(s)
1 x 4-Way SLI bridge(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
Anmerkung:
*1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*3: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*4: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*5: The USB 3.0 ports run at USB 3.0 speed rate under Windows® 7 or later versions.
*6: Available with V1.01.00 or later.
3.UEFI-Einblicke (ehemals Bios) 3.UEFI-Einblicke (ehemals Bios)
4.Downloads 4.Downloads
allgemein:
Hinweis:
Nach dem Download nicht vergessen die zip.-Datei zu entpacken.
UEFI-Update möglichst mit EZ-Flash durchführen. Näheres dazu siehe Handbuch.
Flash erfolgt grundsätzlich auf eigenes Risiko!
6.kompatible CPU-Kühler 6.kompatible CPU-Kühler
Alle Sockel 1156-Kühler könnten auf dem Z77 passen, da die Lochabstände 1156/1155 identisch sind! Vorausgesetzt sie kollidieren nicht mit Anbauten/Heatpipes
(fast) problemlos passende Luftkühler: :)
Be quiet! Dark Pro Advanced
EKL Brocken
Intel Boxed Kühler
Noctua NH-C12P SE14
Noctua NH-D14
Prolimatech Genesis (es kann möglicherweise zu Problemen mit dem Pcie x1 anschluß kommen, kleiner abstand zum kühler)
Thermalright HR-02 Macho (SE / Rev. A) - keine Probleme (neuere Revisionen mit Innenbefestigungsklammern)
Zalman CNPS11X Performa (auch bei Vollbestückung knapp passend)
Mit Einschränkungen !!! :
be quiet! Dark Rock Pro 2 (es sollten low Profile Ram verwendet werden)
Noctua NH-U14S (oberster PCIe Slot nur eingeschränkt nutzbar)
Scythe Mine 2 unter verwendung FSMB 4 Backplate und weiteren einschränkungen
Scythe Mugen II Revision B mit dem 1156er Kit Ram Bänke A1 und B1 nur noch mit low profil Ram bestückbar
Scythe Mugen 3 B
wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright Archon SB-E u. Thermalright Archon - blockiert teilweise obersten Slot (PCIe x1), sonst keine Probleme
Thermalright HR-02 Macho wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright HR-02 Macho 120 - keine Probleme bei Nutzung von Ram ohne hohe HS, andernfalls kann der erste Ramslot nicht genutzt werden
Thermalright Silver Arrow SBE SE -
Nur die 2 blauen RAM Slots lassen sich nutzen wenn der erste Lüfter normal sitzt, will man alle haben muss man ihn höher montieren, nur LP Ram Pci-e wird blockiert
Thermalright True Spirit 140 längere Pcie Karten auf Slot Pcie x1 sind nicht mehr verwendbar.
Wasserkühler und Flüssigkeitskühler
Antec H2o 620
Corsair H80
7.kompatibler RAM 7.kompatibler RAM
Corsair XMS3 PC3-16000U CL9
Corsair XMS3 Dominator Platinum DIMM Kit 8GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMD8GX3M2A2133C9) Achtung Ram hat Überhöhe !!
Corsair Dominator CMP16GX3M4X1866C9 4x4 Kit
Corsair XMS3 Dominator GT DIMM Kit 16GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMT16GX3M4X2133C9)
Corsair Vengeance Low Profile schwarz DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600)
Corsair Vengeance 2*8GB (CML16GX3M2A1600C10)
Corsair Vengeance Low Profile 16GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CML16GX3M4A1600C9)
Corsair Vengeance Low Profile 16GB (DDR3-1600) CML16GX3M4A1600C9
Corsair Vengeance Low Profile 4x8GB CL10-10-10-27 (DDR3-1600) (CML32GX3M4A1600C10B)
Crucial Ballistix Sport CL9 2 x 8GB Crucial BLS8G3D1609DS1S00
Crucial Ballistix Tactical LP (8GB Single) mit Einschränkungen siehe Post 1233
GeIL Evo Corsa GOC38GB1866C9DC
G.Skill Ares F3-1600C9D-8GAO
G.Skill F3-1866C10D-16GAB
G.Skill Ares DIMM Kit 16GB PC3-14900U CL9-10-9-28 (DDR3-1866) (F3-1866C9Q-16GAB)
G.Skill Ares F3-2133C9Q-16GAB - CL9-11-10
G.Skill RipJaws-X DIMM Kit 8GB PC3L-12800U CL9-9-9-24
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133) (F3-17000CL11D-8GBXL)
G.Skill RipJaws 4x 4GB 1600MHz CL 9-9-9-24 @ 1.5V ~ F3-12800CL9Q-16GBRL
G.Skill RipJaws 16GB DDR3 F3-12800CL9Q-16GBRL
Hynix RAM DDR3-1333 | 2x 2048 MB | Typ: HTM325U6CFR8C
Kingston KHX1333C9D3B1K2/8G 2x4 GB (DDR-3-1333)
Kingston HyperX blu. DIMM XMP Kit 8GB PC3-12800U CL9-9-9-27 (DDR3-1600) (KHX1600C9D3B1K2/8GX)
Kingston HyperX Plug n Play DIMM Kit 8GB PC3-12800U CL9 (DDR3-1600) (KHX1600C9D3P1K2/8G)
Kingston HyperX DDR3-1600 16 GB Kit (Typ: KHX1600C9D3K4/16GX)
Patriot (PXD316G1866C9K, Viper Xtreme DIVISION2) DIMM 16 GB DDR3-1866 Kit
Muskin Stileto DDR3-1333
Samsung Green Series DIMM Kit 8GB PC3L-12800U CL11 LP (MV-3V4G3D)
TeamGroup Elite 4x4GB PC3-10667U CL9-9-9-24
Danke an alle die dazu Beitragen das die Liste der Kompatibilität länger wird ...:hail:
sonstige Links
Da immer wieder die Fragen nach den unterschieden der Boards untereinander aufkommen, habe ich mal ein PDF Tabelle online gestellt, wo ich mich bemüht habe die meisten Unterschiede zu markieren.
Viel Spass damit:
http://netload.in/dateiHl4LsFD9cy/Vergleichsliste Asus P8Z77 Boards.pdf.htm
Update: 13.08.2012 (Changelog siehe Spoiler)
Threadupdate-History:
- 27.04.2015: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 08.01.2013: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 13.08.2012: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 05.07.2012: Bios History deluxe hinzugefügt
- 07.06.2012: Vergleichsliste gebaut und auf netload hochgeladen
- 04.06.2012: Tests hinzugefügt
- 03.06.2012: ein paar änderungen und P8Z77 Premium hinzugefügt
- 02.06.2012: Thread übernahme und aktualisierung der kompatiblen CPU Kühler sowie Arbeitsspeicher
- 19.04.2012: Sammelthread gestartet
:) Bei Gefallen des Threads darf der "Danke-Button" gerne gedrückt werden. :)
Hallo zusammen,
habe gestern ein Asus P8 Z77 V Pro bekommen, habe den Sockel-Schutz entfernt und dann ist mir aufgefallen, dass 2 Pins verbogen sind.
Schonmal meine erste Frage: Kann das beim Abziehen des Schutzes passiert sein? Glaub ich persönlich eigentlich nämlich eher nicht.
Hier mal ein Bild von den Pins: http://imageshack.us/a/img204/8403/20121023124751.jpg
Habe dann anschließend trotzdem mal einen i3 2100 verbaut +Ram etc.
Bekam aber immer kein Bild. Am Anfang leuchtete immer ganz kurz die Cpu-Leuchte rot(denk ich normal), dann die RamLeuchte über diesen Zustand kam er nicht hinaus.
Mit und ohne Graka getestet. Muss dazu sagen, dass ich leider weder bei Ram, Cpu noch bei Nt sicher weis, ob sie funktionieren.
Werde Morgen mal mit Teilen testen die auf jedenfall funktionieren.
Jetzt meine eigentliche Frage: Meint ihr ich kann das Board ohne Sorge verwenden und es funktioniert, oder soll ich die Pins zurück biegen?
Danke für eure Antworten
Grüße loruz
Geb das Board zurück und sag, dass die Pins verbogen waren!
Bei meinem ersten Sockel 1155-Board waren auch Pins verbogen, als ich die CPU trotzdem montiert hatte gab es keine Kullanz von Asus, ich hätte das Board wegwerfen können wenn mir der Chipsatzbug von Intel nicht in die Karten gespielt hätte.
hi, ich bin gerade am spielen mit dem P8Z77-V. und werde nicht ganz schlau wie ich nun meinen 3770k übertakten soll Über die Turbo-Ratio (funktioniert) oder über die CPU-Ratio (da kann ich eingeben was ich will, passiert nix.) Bitte um kurzen Tip, finde wiedersprüchliche Angaben im Netz :(
könnte mir bitte jemand meine Frage kurz beantworten? Habe seit ca. 5 Jahren nichts mehr übertaktet und möchte nichts kaputt machen.
Das Problem gabs auch mal bei den p8p67, die Lösung war das Deaktivieren von PLL Overvoltage, stand glaub ich default auf "auto".
Ich war schon fast euphorisch, als der Computer, nachdem ich ihn mehrmals kurz komplett vom Netz getrennt hatte, immer auf Anhieb richtig startete. Als ich ihn aber wieder eine Weile ausgeschaltet gelassen habe, wiederholte sich aber das Problem... :( Trotzdem danke!
Ich untersuche dann mal, inwieweit es am Netzteil liegen könnte - das wäre mir doch lieber als ein defektes Board.
Hallo
Ich habe das P877 Premium. Ich habe 2 Platten am Marvell Kontroller. Die Bootzeit mit dem Marvell Kontroller dauert ganz schön lange. Kann man den Marvell Kontroller beim Booten Deaktivieren?.
ich weiß, dass der Windows 7 Leistungsindex nichts aussagt, möchte aber dennoch gerne wissen, warum bei mir die Wertung des Arbeitsspeichers um 0.1 (von 7.9 auf 7.8) gesunken ist. Kann es sein, dass ein Windows Update diesen Test "anspruchsvoller" macht? Bzw. könnt ihr mir sagen, was euch der Test anzeigt? Ich habe das Asus P8Z77-V Pro und die Corsair Vengeance LP 8GB DDR3-1600.
Habe den selben Speicher und bei mir war der Wert schon immer auf 7.8 Punkte. Der Test für den Leistungsindex wird von Microsoft nicht abgeändert, weil sonst die Vergleichbarkeit flöten gehen würde.
Hast du vielleicht im UEFI was verstellt? Andere Speichertimings, Taktfrequenz oder sonstiges?
danke, dann scheint ja doch alles klar zu sein. Verstellt bzw. etwas geändert habe ich ebenfalls nicht.
hat irgendwer zufällig die Karte von Euch?
GBT Forum
GV-R797OC-3GD Win8Pro IE10,PowerDVD 12,TMT5 stürzt ab unter WIN7 nur die Programme - AMD und Nvidia VGA Karten - GIGABYTE Forum
ich habe Probleme bei Blu-ray mit Power DVD 12 oder Arcsoft TMT 5? Arcsoft hängt ab und an bei der Wiedergabe Bild und Ton läuft aber dann weiter und Power DVD stürzt ab mit Fehlermeldung.
Das ganze hab ich unter Win7 x64 und Win8 x64 RTM. Die Treiber, Bios und Software auf aktuellem Stand.
Unter Win8Pro stürzt IE10 laufend ab in Win7 IE9 ist aber unauffällig.
Prime und Memtest zeigen NULL Auffälligkeiten auch nach 48 Stunden Run 0 Fehler.
Ich raffe es einfach nicht mehr. Ich habe Komponenten ersetzt (bis auf den RAM), abgeklemmt usw. ohne Erfolg.
KEIN OC SYSTEM läuft @Stock
i7 3770k
Asus P8Z77-V Deluxe Bios: 1617
G.Skill TridentX DIMM Kit 8GB PC3-19200U CL10-12-12-31 (DDR3-2400) (F3-2400C10D-8GTX)
Gigabyte GV-R797OC-3GD Bios: F2 Rev:1.0
Samsung 830 128GB,Intel Postville SSD G2 120GB,10x HDD
Pioneer BDR-207M
Liteon iHAS524B
Corsair HX 850 Watt
Asrock Sata 6 PCIe 1x
Digitus Sata 3 PCIe 4x ( DS-30104 )
Logitech G15
Logitech G700
EIZO Foris 2332 TFT
Beschreibung
Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\Internet Explorer\iexplore.exe
Problemsignatur
Problemereignisame: BEX
Anwendungsname: IEXPLORE.EXE
Anwendungsversion: 10.0.9200.16384
Anwendungszeitstempel: 50107ee0
Fehlermodulname: atiuxpag.dll
Fehlermodulversion: 8.14.1.6290
Fehlermodulzeitstempel: 50860026
Ausnahmeoffset: 0000d72d
Ausnahmecode: c0000409
Ausnahmedaten: 00000005
Betriebsystemversion: 6.2.9200.2.0.0.256.103
Gebietsschema-ID: 1031
Zusatzinformation 1: 3daa
Zusatzinformation 2: 3daa1970f7148b27ee8f6a812f28eb1c
Zusatzinformation 3: ec28
Zusatzinformation 4: ec287b9e135326a3094c394bb666d361
Weitere Informationen über das Problem
Bucket-ID: 74a83e6b407d24f7c8cea2ff18a21543 (-938747860)
Ich hatte lange die der Ram von G.Skill unter verdacht doch das stellt sich nun anders dar. Man hätte mal in das Wartungscenter schauen sollen.
Das Problem tritt mit ALLEN erschienen Treibern auf die diese Karte unterstützen
Auch diese von der mitgelieferten CD. z.Z. habe ich den AMD_Catalyst_12.11_Beta4_dotNET4 drauf aber auch alle Vorgänger Versionen ob Hotfix,Beta,whql.
Ich habe heute nachdem ich die Treiber runtergeschmissen und die Karte ausgebaut habe 0 Abstürze verzeichnen können. Auch die Videosoftware läuft tadellos mit der Intel GPU des 3770k. Ist die Karte nun hinüber oder Bios Problem? F2 ist drauf und auf der Home kein neues.
Auf dem GA-Z77-UD5H wifi verhält sich die Karte genauso also können wir inkompatibel zum Asus ausschließen.
cu Bohne02
hatte von euch jemand mit dem P8Z77-V schon das Problem, dass das System, nachdem es komplett vom Netz getrennt oder einfach einige Zeit im Standby war, nicht auf Anhieb richtig startet? Ich habe eine detailliertere Beschreibung bereits bei CB gepostet (Kein "Kaltstart" möglich - ComputerBase Forum).
Ja, mein Asus bootet in seltenen Fällen 4-5x bis es endlich ins Windows kommt. Danach läuft es aber problemlos.
@Bohne
Muss diese übertrieben große Schrift sein? Dramatik hin oder her... du schreibst du hast alle Komponenten bis auf den RAM ersetzt, ohne die AMD Grafikkarte nur mit der IGP sollte ja kaum noch ein atiuxpag-Fehler aufgetreten sein?!
Falls doch, dann stimmt was mit deiner Softwareinstallation nicht.
@cerubis
Jein,habs geändert.:eek: Ich hab den Beitrag aus dem GBT Forum kopiert da muss einiges Groß geschrieben werden um unnötig alles 3Mal zu erklären. Weil OC usw. ist ja immer erst mal Schuld ob es vorhanden ist oder nicht.;) Also tritt auf wenn die AMD Treiber drauf kommen. Der WDM Treiber verursacht dieses IE Problem nicht.
Ich hab aber auch neuere Erkenntnisse mit der Gigabyte GV-R797OC-3GD
Bios Schalter auf 1 = Boot und diese Probleme
Bios Schalter auf 2 = No Boot Board piept sich Doof ( VGA Led = ON ) und wird der Schalter wieder auf 1 gestellt und Board neu gestartet erscheint die Meldung " VGA no kompatible UEFI Treiber" Es muss erst ein Bios Reset ausgeführt werden.
Also denk ich die Karte ist hinüber weil Schalter BIOS 1 oder 2 doch Bockwurst sein sollte. So war es jedenfalls bei meinen 6970ern.
Hat eigentlich schon einer für die Boardserie einen funktionierenden Intel ME Driver gefunden für Win 8? Der von der Asus Seite für das Pro geht nicht zum installieren, der für Windows 7 läuft anscheinend auch nicht richtig.
Für das Deluxe/Win8 habe ich die ME-Software 8.1.10.1300 installiert, der installierte ME-Treiber hat dann die Version 8.1.10.1275. Allerdings habe ich vorher (mit Win7) die ME-Firmware auf 8.1.10.1286 geflasht. Ging alles ohne Probleme.
Den Treiber habe ich von Standard-Driver, das FW-Tool ist von Asus (der Link dafür wurde hier angeboten).
Falls du die ME Firmware meinst die ich auch hier nochmal hochgeladen habe, hab ich die schon.
Ansonsten, hast du einen Directlink zu dem Treiber, wäre nett. Die Seite Standard Driver gibt es nämlich irgendwie nicht...
Edit: Achso noch eine Frage, hast du auch die Intel Netzwerktreiber installiert, die aktuellsten haben mir nämlich (nett aussehende) Bluescreens gegeben...
Super, danke dir. Schau ich mir später gleich mal an und berichte auch ob die NW Treiber gehen.
Edit: Also, die Me Treiber gehen. Andere Sache übrigens ich konnte mit meinem Pro Board Win 8 so lange nicht runter fahren bis ich den Schnellstart deaktiviert hatte. Hat immer wieder neu gestartet. Kann das jemand bestätigen, dann könnte man Asus Bescheid geben, da ist dann wohl ein neues BIOS fällig.
Heute morgen habe ich versucht, Virtu MVP auf mein sauber installiertes Win8 installiert.
Die Folge war: der Rechner startete anschließend nicht mehr.
Nach mehreren (vergeblichen) Startversuchen hat dann die Win8-Reparaturversion angesprochen und Win8 wieder hergestellt. Allerdings waren die zuletzt installierten Programme nicht mehr vorhanden, auch hat der Virenscanner dann gesponnen.
Gott sei Dank habe ich für meine beiden SSDs (System und Progs) jeweils ein Image angelegt. Die habe ich dann mit einer Acronis-Boot-CD neu aufgespielt, dann war wieder alles bestens und mein "Fehltritt" war beseitigt.
Das hat mir wieder gezeigt wie wichtig FP-Images sind. Ich habe eine kostenlose Acronis 2011-Version, die kanns auch mit Win8.
Seit dem BIOS 1617 auf dem Deluxe ist bei mir das Gerät mit der Hardware ID USB\VID_0B05&PID_17B5 aufgetaucht. Das Gerät selber heißt "BCM20702A0". Dabei handelt es sich nach Google um das Bluetooth Modul. Allerdings habe ich dieses bereits zwei Mal im BIOS abgeschaltet. Das Gerät hatte ich noch nie im Gerätemanager. Beim ersten Neustart nach dem BIOS-Update sollte ich einen Treiber installieren. Wie kriege ich die Komponente deaktiviert?
Schon dieses probiert: Defaults im BIOS laden, speichern, Reset, dann BT abschalten. Kompletter CMOS-Reset? Hat sich eventuell verhakt.
---------- Post added at 08:12 ---------- Previous post was at 08:10 ----------
Das Installationsmenü meldet sich bei mir so:
So wie es aussieht, ist die Treiber-SW für den Atom-Proz.
Habe jetzt gesehen, obwohl textlich die neuere Version dort sein soll, verlinkt der Verweis dann aber auf eine ältere Datei. Habe nun aber auch die richtige .1007 geladen und dennoch wird nicht ein Treiber installiert. Scheinbar hat sich nichts geändert.
Hallo zusammen,
ich habe den EKL Brocken auf dem Board und somit kann der in die Kompatibilitästliste aufgenommen werden.
Grüße
Da hätte ich auch noch ein paar:
Corsair H80 - keine Probleme
Thermalright Archon SB-E - siehe Archon
Auch damit habe ich kein Glück. Der Installer meldet, dass er für dieses System ungeeignet sei. W7 Ult x64 SP1 mit allen Updates.
Es war letztlich nötig einen elevated command prompt zu öffnen und mit "setup -overall" zu starten. Dann lief es, danke!
@DrNo123,
ich habe jetzt den Intel-Inf-Treiber 9.3.0.1025 installiert, passt besser zu den Z77-Boards.
Siehe hier:
www.station-drivers.com • Afficher le sujet - Driver: Intel chipset Device Software Version 9.3.0.1025
Dieser Treiber hat bei mir den 9.3.0.1024 installiert.
Für Win 7 + 8 gibt es einen neuen Intel-Grafiktreiber (9.17.10.2875):
Intel Grafiktreiber Download - ComputerBase ...
Der automatische Updatedienst von Microsoft bietet mir für mein Win7 x64 auch ein Update an: "Intel Corporation - Graphics Adapter WDDM1.1, Graphics Adapter WDDM1.2 - Intel(R) HD Graphics 4000".
Hat jemand Ahnung welche Version das ist? WDDM1.1 und 1.2 sagen mir nichts.
Ich hatte ja erst vor 14 Tagen diesen Grafik-Treiber für HD4000 direkt von der Intel-Page installiert: 15.26.12.64.2761 (8.15.10.2761).
Was passiert wenn ich jetzt das Microsoft Update mache?
Oder sollte ich das von Rudi_Taube erwähnte ganz neue verwenden? Was wurde da geändert/verbessert?
Nachtrag: Nachdem ich den Changelog des neuen Intel-Treibers gelesen hatte, konnte ich doch nicht wiederstehen und hab ebenfalls, wie Rudi, die Version: 9.17.10.2875 (15.28.8.64.2875) installiert. Bisher sieht alles gut aus.
WDDM 1.2 ist für Windows 8 erforderlich.
Treiber gibts mittlerweile auch bei Computerbase zum Downloaden. Installation klappt bei mir auch nicht.
Hallo :)
Ist mein erster Post hier im Forum und ich hoffe mal das ich richtig bin ^^
Ich lese Hardwareluxx schon seit mittlerweile 2 jahren (printed) und i net Seite. Bisher konnte ich auch immer eine Lösung finden falls ich irgendwo mal nen Problem hatte aber jetzt muss ich mich direkt mal hier zu Wort melden.
Zu meinem Problem:
Ich habe mir einen neuen Rechner zusammengestellt und soweit funktioniert auch alles gut, nur ich sehe nur die obere linke hälfte im UEFI. Es Sieht so aus
wie wenn nur eine geringere Auflösung oder sowas an meinen Monitor gesendet wird. ka wie ich das hier so richtig beschreiben soll. Ich kann die Maus bewegen
und per Tastatur agieren nur sehe ich halt nicht alles. Habe es über den Grafikausgang am Mainboard und über die Grafikkarte versucht immer das selbe :<
Ich habe noch einen guten alten 19 Zoll Röhrenmonitor ^^
Würde gern noch gern nen UEFI update versuchen nur weiß ich nicht wie ich es machen soll ohne das ich im UEFI was sehe, zumal ich sowas noch nie gemacht hab.
Z.z. ist 0801 vom Werk her installiert.
Hoffe das mir hier jemand weiterhelfen kann :)
System
Asus P8Z77-V LX Intel Z77 So.1155
Corsair Vengeance LP Black DDR3-1600 DIMM CL9-9-9-24 Dual Kit 8GB (2x 4096MB)
Intel Core i5 3450 4x 3.10GHz
EVGA GeForce GTX 660 Ti FTW Signature2
OS win7 64Bit
