[Sammelthread] ASUS P8Z77-V / -PRO / -Deluxe / -Premium (Intel Z77)
- Sockel: LGA1155 - Chipsatz: Intel Z77 Sammelthread -
P8Z77 | Geizhals.at Deutschland
INHALTSVERZEICHNIS
1.Spezifikationen 1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77V
- Zusammenfassung Spezifikationen / Features -
Prozessor / Sockel:
Intel® Socket 1155 for 3rd/2nd Generation Processors
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z77
Memory:
4 x DIMM, Max. 32GB, DDR3 2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB/DisplayPort ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology *1
Supports AMD Quad-GPU CrossFireX™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *2
Expansion Slots:
2 x PCIe 3.0/2.0 x16 (x16 or dual x8) *3
1 x PCIe 2.0 x16 (x4 mode, black)
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
Intel® Z77 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *5
ASMedia® PCIe SATA controller : *6
2 x SATA 6Gb/s port(s), navy blue
LAN:
Intel® 82579V, 1 x Gigabit LAN Controller(s)
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Wireless Data Network:
Wi-Fi 802.11 b/g/n
Supports single band frequency 2.4GHz
Audio:
Realtek® ALC892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller : *7
2 x USB 3.0 port(s) (2 at back panel, blue)
Intel® Z77 chipset : *7
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
10 x USB 2.0 port(s) (2 at back panel, black, 8 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
- Smart DIGI+ Key- quickly delivers higher VRM frequency, voltage and current for superior CPU/iGPU/DRAM overclocking performance with one switch.
- Smart CPU Power Level (Intel® VRD 12.5 Future Power Design)- provides the best digital power saving conditions.
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 12 Phase Power Design
(8 -phase for CPU, 4 -phase for iGPU)
- Industry leading Digital 2 Phase DRAM Power Design
- CPU Power Utility
- DRAM Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *8
- Wi-Fi GO! Remote for portable Smartphone/Tablet, supporting iOS & Android systems
- Wi-Fi Engine for network sharing and connection: Client Mode, AP Mode
ASUS Exclusive Features :
- USB BIOS Flashback
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
1 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x WLAN connector(s) for ASUS wireless module
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin)
4 x USB 2.0 connector(s) support(s) additional 8 USB 2.0 port(s)
1 x TPM connector(s)
1 x COM port(s) connector(s)
4 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
1 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x Optional Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Clear CMOS jumper(s)
1 x USB BIOS Flashback button(s)
Accessories:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
2 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ASUS Wi-Fi GO! card(s)
1 x Wi-Fi Ring Moving Antenna(s)
BIOS:
64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen, F3 Shortcut Function and ASUS DRAM SPD (Serial Presence Detect) memory information
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, PXE, WOR by PME
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: With 2 PCIex16 graphics card.
*2: LucidLogix Virtu MVP supports Windows 7 operating systems.
*3: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*4: The PCIe x1_2 shares bandwidth with SATA6G_E12. SATA6G_E12 is enabled by default for system resource optimization.
*5: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*6: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*7-1: Supports ASUS USB 3.0 Boost UASP Mode.
*7-2: The USB 3.0 ports only support Windows® 7 or later versions.
*8: Available with V1.01.00 or later.
*9: Due to Intel® chipset limitation, P8Z77, P8H77 and P8B75 series motherboards do not support Windows® Vista operating system.
CPUs für P8Z77-V:
ASUS - Mainboards- ASUS P8Z77-V
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V PRO
Prozessor / Sockel:
Chipset:
Intel® Z77
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
LAN:
Wi-Fi 802.11 b/g/n
Audio:
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB Ports:
Special Features:
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
Internal I/O Ports:
2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin)
4 x Chassis Fan connector(s)
1 x System panel(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
CPUs für P8Z77-V Pro:
ASUS - Mainboards- ASUS P8Z77-V Pro
Tests (deutsch):
http://www.awardfabrik.de/mainboards/asus-p8z77-v-pro.html
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Deluxe
Prozessor / Sockel:
Unterstützt Intel® 22 nm-Prozessoren
Unterstützt die Intel® Turbo Boost-Technologie 2
* Die Unterstützung der Intel® Turbo Boost-Technologie 2.0 ist vom Prozessor-Typ abhängig.
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 MHz Non-ECC, Un-buffered Memory
Dual Channel-Speicherarchitektur
Unterstützt Intel® Extreme Memory Profile (XMP)
* Die Hyper DIMM-Unterstützung ist von den Merkmalen des jeweiligen Prozessors abhängig.
* Eine Liste freigegebener Speichermodule finden Sie auf der Webseite ASUS oder im Benutzerhandbuch.
Grafik:
Integrierter Grafikprozessor
Multi-VGA Ausgaben Unterstützung : HDMI/DisplayPort Schnittstellen
- Unterstützt HDMI mit einer max. Auflösung von 1920 x 1200 @ 60 Hz
- Unterstützt DisplayPort mit einer max. Auflösung von 2560 x 1600 @ 60 Hz
Multi-GPU-Unterstützung:
Unterstützt die AMD® Quad-GPU CrossFireX™-Technologie
Erweiterungsschächte:
1 x PCIe 2.0 x16 (x4 Modus, schwarz)
4 x PCIe 2.0 x1 *4
Speichersystem:
2 x SATA 6Gb/s-Schnittstellen, grau
4 x SATA 3Gb/s-Schnittstellen, blau
Unterstützen RAID 0, 1, 5, 10
Marvell® PCIe 9128 controller :
2 x SATA 6Gb/s-Schnittstellen, navy blue
2 x eSATA 6Gb/s-Schnittstellen, red
LAN:
Realtek® 8111F, 1 x Gigabit LAN Controller(s)
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Kanal High Definition Audio CODEC
- Unterstützt : Anschlusserkennung, und Multistreaming, Technologien sowie automatische Geräteerkennung an der Gehäusevorderseite
Audio Feature :
- Blu-ray audio layer Content Protection
- optischer S/PDIF-Ausgang an der Gehäuserückseite
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
4 x USB 3.0 Schnittstellen (4 an der Gehäuserückseite, blau)
4 x USB 3.0 Schnittstellen (2 an der Gehäuserückseite, blau, 2 intern)
8 x USB 2.0 Schnittstellen (4 an der Gehäuserückseite, schwarz, 4 intern)
Übertaktung:
Sicherheit beim Übertakten :
Besondere Features:
ASUS Dual Intelligent Processors Technologie 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU-Taste
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 20 Phase Power Design
(16 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS (EZ-Modus) inkl. benutzerfreundlicher, grafischer Oberfläche
- ASUS SSD Caching
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Anschlüsse (Rückseite):
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) Schnittstelle
6 x USB 3.0
4 x USB 2.0
1 x S/PDIF-Ausgang (optisch)
6 x Audio-Anschlüsse
1 x Bluetooth V4.0 connector(s) for ASUS Wi-Fi GO! card
1 x USB BIOS Flashback Button(s)
interne Anschlüsse:
1 x USB 3.0-Anschluss unterstützt zusätzlich 2 USB 3.0-Schnittstellen (19-pin)
2 x USB 2.0-Anschlüsse unterstützen zusätzlich 4 USB 2.0-Schnittstellen
4 x SATA 6Gb/s-Schnittstellen
1 x Prozessorlüfteranschluss
4 x Gehäuselüfteranschlüsse
1 x S/PDIF-Ausgang
1 x 24-Pin EATX Netzanschluss
1 x 8-Pin ATX 12V Netzanschluss
1 x Audio-Anschluss an der Gehäusevorderseite (AAFP)
1 x MemOK!-Taste
1 x System panel(s)
1 x TPU-Taste
1 x EPU-Taste
1 x Clear BIOS-Taste
1 x Power-on button(s)
1 x Reset button(s)
Zubehör:
User's manual
ASUS Q-Shield
2 x SATA 3Gb/s-Kabel
4 x SATA 6Gb/s-Kabel
1 x SLI bridge(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS :
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
12 " x 9.6 " ( 30.5 cm x 24.4 cm )
Anmerkung:
- CPU-Liste -
Grundsätzlich sind alle LGA1155 Sandy-Bridge CPUs kompatibel zum ASUS P8Z77-V Deluxe. Wer jedoch seinen Prozzi möglichst weit übertakten möchte,
der kommt an einem Modell mit dem Zusatz "K" im Namen nicht vorbei. Denn auschliesslich diese lassen einen höheren "Turbomulti" zu. Modelle ohne "K"
besitzen einen festen maximalen "Turbomulti" und sind daher für OC ungeeignet, da der Referenztakt nur von 100MHz auf maximal 105-110MHz
erhöht werden kann (kommt sonst zu Instabilitäten!).
CPUs für P8Z77-V Deluxe:
ASUS - Mainboards- ASUS P8Z77-V DELUXE
Tests (deutsch):
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=733&sel_lang=german
http://www.hartware.net/review_1463.html
Bios History:
0801
0906
1015
1206
1401
1502
1504
1617
1709
1805
1908
2003
2104
1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Premium
CPU:
Intel® Socket 1155 for 3[SUP]rd[/SUP]/2[SUP]nd[/SUP] Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.ChipsetIntel® Z77
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Thunderbold:
ThunderboltVGA output support
Data transfer rate up to 10 Gbps
Daisy-chain up to 6 Thunderbolt devices
Grafik:
Multi-VGA output support : HDMI/DisplayPort/Thunderbolt ports
- Supports Thunderbolt with max. resolution 2560 x 1600 @ 60 Hz
Maximum shared memory of 1696 MB
Supports NVIDIA® 4-Way SLI™ Technology
Supports AMD 4-Way CrossFireX Technology
Supports LucidLogix® Virtu™ MVP Technology *[SUP]1[/SUP]
4 x PCIe 3.0/2.0 x16 (dual x16 or x16, x8, x8 or quad x8) *[SUP]2[/SUP]
2 x PCIe 2.0 x1
Speichersystem:
Intel® Z77 chipset : 2 x SATA 6Gb/s port(s), gray
3 x SATA 3Gb/s port(s), blue
1 x mini-SATA 3Gb/s port(s) with onboard 32GB SSD, black
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *[SUP]3[/SUP]
Marvell® PCIe 9230 controller :
4 x SATA 6Gb/s port(s), navy blue
Support Raid 0, 1, 10
ASMedia® PCIe SATA controller : *[SUP]4[/SUP]2 x eSATA 6Gb/s port(s), red
LAN:
Intel® 82583, 1 x Gigabit LAN Controller(s)
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Channel High Definition Audio CODEC
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
Intel® Z77 chipset : *[SUP]5[/SUP]4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
Intel® Z77 chipset :6 x USB 2.0 port(s) (2 at back panel, black, 4 at mid-board)
Übertaktung:
Besondere Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- CPU Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *[SUP]6[/SUP]
ASUS Exclusive Features :- USB BIOS Flashback
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS SSD Caching II
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY : - ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
1 x Thunderbolt port(s)
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
interne Anschlüsse:
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
3 x SATA 3Gb/s connector(s)
1 x mSATA connector(s) with 32GB SSD onboard
1 x CPU Fan connector(s) (4 -pin)
1 x CPU OPT Fan connector(s) (4 -pin)
1 x System panel(s) (Q-Connector)
1 x TPU switch(es)
1 x EPU switch(es)
1 x CPU/DRAM overvoltage jumper(s)
1 x Reset button(s)
1 x Clear CMOS button(s)
Zubehör:
User's manual
ASUS Q-Shield
4 x SATA 6Gb/s cable(s)
1 x 3-Way SLI bridge(s)
1 x 4-Way SLI bridge(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
Anmerkung:
*1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*3: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*4: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*5: The USB 3.0 ports run at USB 3.0 speed rate under Windows® 7 or later versions.
*6: Available with V1.01.00 or later.
3.UEFI-Einblicke (ehemals Bios) 3.UEFI-Einblicke (ehemals Bios)
4.Downloads 4.Downloads
allgemein:
Hinweis:
Nach dem Download nicht vergessen die zip.-Datei zu entpacken.
UEFI-Update möglichst mit EZ-Flash durchführen. Näheres dazu siehe Handbuch.
Flash erfolgt grundsätzlich auf eigenes Risiko!
6.kompatible CPU-Kühler 6.kompatible CPU-Kühler
Alle Sockel 1156-Kühler könnten auf dem Z77 passen, da die Lochabstände 1156/1155 identisch sind! Vorausgesetzt sie kollidieren nicht mit Anbauten/Heatpipes
(fast) problemlos passende Luftkühler: :)
Be quiet! Dark Pro Advanced
EKL Brocken
Intel Boxed Kühler
Noctua NH-C12P SE14
Noctua NH-D14
Prolimatech Genesis (es kann möglicherweise zu Problemen mit dem Pcie x1 anschluß kommen, kleiner abstand zum kühler)
Thermalright HR-02 Macho (SE / Rev. A) - keine Probleme (neuere Revisionen mit Innenbefestigungsklammern)
Zalman CNPS11X Performa (auch bei Vollbestückung knapp passend)
Mit Einschränkungen !!! :
be quiet! Dark Rock Pro 2 (es sollten low Profile Ram verwendet werden)
Noctua NH-U14S (oberster PCIe Slot nur eingeschränkt nutzbar)
Scythe Mine 2 unter verwendung FSMB 4 Backplate und weiteren einschränkungen
Scythe Mugen II Revision B mit dem 1156er Kit Ram Bänke A1 und B1 nur noch mit low profil Ram bestückbar
Scythe Mugen 3 B
wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright Archon SB-E u. Thermalright Archon - blockiert teilweise obersten Slot (PCIe x1), sonst keine Probleme
Thermalright HR-02 Macho wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright HR-02 Macho 120 - keine Probleme bei Nutzung von Ram ohne hohe HS, andernfalls kann der erste Ramslot nicht genutzt werden
Thermalright Silver Arrow SBE SE -
Nur die 2 blauen RAM Slots lassen sich nutzen wenn der erste Lüfter normal sitzt, will man alle haben muss man ihn höher montieren, nur LP Ram Pci-e wird blockiert
Thermalright True Spirit 140 längere Pcie Karten auf Slot Pcie x1 sind nicht mehr verwendbar.
Wasserkühler und Flüssigkeitskühler
Antec H2o 620
Corsair H80
7.kompatibler RAM 7.kompatibler RAM
Corsair XMS3 PC3-16000U CL9
Corsair XMS3 Dominator Platinum DIMM Kit 8GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMD8GX3M2A2133C9) Achtung Ram hat Überhöhe !!
Corsair Dominator CMP16GX3M4X1866C9 4x4 Kit
Corsair XMS3 Dominator GT DIMM Kit 16GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMT16GX3M4X2133C9)
Corsair Vengeance Low Profile schwarz DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600)
Corsair Vengeance 2*8GB (CML16GX3M2A1600C10)
Corsair Vengeance Low Profile 16GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CML16GX3M4A1600C9)
Corsair Vengeance Low Profile 16GB (DDR3-1600) CML16GX3M4A1600C9
Corsair Vengeance Low Profile 4x8GB CL10-10-10-27 (DDR3-1600) (CML32GX3M4A1600C10B)
Crucial Ballistix Sport CL9 2 x 8GB Crucial BLS8G3D1609DS1S00
Crucial Ballistix Tactical LP (8GB Single) mit Einschränkungen siehe Post 1233
GeIL Evo Corsa GOC38GB1866C9DC
G.Skill Ares F3-1600C9D-8GAO
G.Skill F3-1866C10D-16GAB
G.Skill Ares DIMM Kit 16GB PC3-14900U CL9-10-9-28 (DDR3-1866) (F3-1866C9Q-16GAB)
G.Skill Ares F3-2133C9Q-16GAB - CL9-11-10
G.Skill RipJaws-X DIMM Kit 8GB PC3L-12800U CL9-9-9-24
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133) (F3-17000CL11D-8GBXL)
G.Skill RipJaws 4x 4GB 1600MHz CL 9-9-9-24 @ 1.5V ~ F3-12800CL9Q-16GBRL
G.Skill RipJaws 16GB DDR3 F3-12800CL9Q-16GBRL
Hynix RAM DDR3-1333 | 2x 2048 MB | Typ: HTM325U6CFR8C
Kingston KHX1333C9D3B1K2/8G 2x4 GB (DDR-3-1333)
Kingston HyperX blu. DIMM XMP Kit 8GB PC3-12800U CL9-9-9-27 (DDR3-1600) (KHX1600C9D3B1K2/8GX)
Kingston HyperX Plug n Play DIMM Kit 8GB PC3-12800U CL9 (DDR3-1600) (KHX1600C9D3P1K2/8G)
Kingston HyperX DDR3-1600 16 GB Kit (Typ: KHX1600C9D3K4/16GX)
Patriot (PXD316G1866C9K, Viper Xtreme DIVISION2) DIMM 16 GB DDR3-1866 Kit
Muskin Stileto DDR3-1333
Samsung Green Series DIMM Kit 8GB PC3L-12800U CL11 LP (MV-3V4G3D)
TeamGroup Elite 4x4GB PC3-10667U CL9-9-9-24
Danke an alle die dazu Beitragen das die Liste der Kompatibilität länger wird ...:hail:
sonstige Links
Da immer wieder die Fragen nach den unterschieden der Boards untereinander aufkommen, habe ich mal ein PDF Tabelle online gestellt, wo ich mich bemüht habe die meisten Unterschiede zu markieren.
Viel Spass damit:
http://netload.in/dateiHl4LsFD9cy/Vergleichsliste Asus P8Z77 Boards.pdf.htm
Update: 13.08.2012 (Changelog siehe Spoiler)
Threadupdate-History:
- 27.04.2015: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 08.01.2013: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 13.08.2012: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 05.07.2012: Bios History deluxe hinzugefügt
- 07.06.2012: Vergleichsliste gebaut und auf netload hochgeladen
- 04.06.2012: Tests hinzugefügt
- 03.06.2012: ein paar änderungen und P8Z77 Premium hinzugefügt
- 02.06.2012: Thread übernahme und aktualisierung der kompatiblen CPU Kühler sowie Arbeitsspeicher
- 19.04.2012: Sammelthread gestartet
:) Bei Gefallen des Threads darf der "Danke-Button" gerne gedrückt werden. :)
Erkennt Windows das Board und die neue CPU ohne Probleme , oder muß ich Win neu installieren?
Normalerweise geht sowas nach 1-2 reboots (Neu erkennung CPU, North und Southbridge etc.) dann wieder ganz normal.
Aber wie shorty schon sagt, ich würde auch neu Installieren bzw. ich installiere bei sowas auch immer neu.
Dem kann ich nur zustimmen. Ich habe bei MoBo-, FP- oder SSD-Wechsel zunächst die installierten Win geklont bzw. übernommen.
Irgendwie hat es funktioniert aber im nachhinein hab ich Win dann doch neu installiert, eine frische Win-Version ist immer die beste Lösung.
Letzte Woche habe ich z. B. eine SSD M4 gegen eine Samsung 840 Pro getauscht. Win 8 habe ich geklont, hat soweit gut geklappt, jedoch haben andere Proggis gemeckert. Fazit: alles neu installiert und und gut ist es.
Moin, ich habe Samstag mein P8Z77-V Pro erhalten :love:
CPU Kühler mit Einschränkungen: Thermalright Silver Arrow SBE SE
  • Nur die 2 blauen RAM Slots lassen sich nutzen wenn der erste Lüfter normal sitzt, will man alle haben muss man ihn höher montieren.
  • Nur LP RAM! (evtl geht normaler RAM ohne HS aber ich würde sagen eher nicht)
  • PCIe x1 wird blockiert (Vielleicht passt eine sehr kurze Karte, die darf dan aber nicht länger sein als das Ende des Steckplatzes)
RAM: Crucial Ballistix Tactical LP (8GB Single)
  • System startet nur mit einem Riegel im 1. blauen Slot, nachdem XMP aktiviert und die Spannung auf 1.35v gesetzt ist läuft es aber auch mit 2 Riegel.
Außerdem kann man, sofern man eine große Karte im schwarzen PCIe x16 verwendet den USB3 Header dort sehr schlecht bis garnicht nutzen.
Ich habe da meine X-Fi Titanium Fatal1ty Pro drin. Damit ist der Header bei mir komplett blockiert.
Zur Lüftersteuerung.
Die ist richtig Klasse :) Sie Regelt sowohl die 4Pin CPU- als auch die 3Pin Gehäuselüfter auf ein angenehmes Geräuschniveau.
Ich poste im laufe der Wochen mal ein paar Bilder.
Grüße
Edit:
Ich bin umgezogen von einem P5Q Premium mit einem Core2Quad Q9300.
Windows 7 war auf einer Samsung 830 (128GB).
Der Umzug sah wie folgt aus:
  1. SSD aus altem Rechner raus
  2. in neuen Rechner rein ;)
Hat tadellos geklappt und ich kann mir jetzt Zeit lassen mit dem neu Aufsetzen :)
Prolimatech Megahalems passt problemlos auf ein P8Z77-M Pro
---------- Post added at 21:33 ---------- Previous post was at 20:01 ----------
Kann jemand meine OC Einstellungen verifizieren und falls nötig notwendige Änderungen angeben:
Ai Overclock Tuner Manual
BCLK 100
MultiCore Enhancement Enabled
Turbo Ratio Manual
1-4 Core Ratio Limit 42
Internal PLL Overvoltage Disabled
CPU bus speed : DRAM speed ratio mode Auto
Memory Frequency DDR3-1600
EPU Power Saving Mode Disabled
CPU Voltage Offset Mode
Offset Mode Sign -
CPU Offset Voltage 0.020
DRAM Voltage 1.500
PCH Voltage 1.050
VCCSA Voltage Auto
CPU PLL Voltage Auto
CPU Spread Spectrum Auto
CPU Ratio 42
Enha. Intel SpeedStep Enabled
CPU Load-Line Calibration High
CPU Voltage Frequency Manual
CPU Fixed Frequency 350
CPU Power Phase Control Extreme
CPU Power Duty Control T.Probe
CPU Current Capability 120%
Intel Adaptive Thermal Moni Enabled
Active Processor Cores All
Limit CPUID Maximum Disabled
Executive Disable Bit Enabled
Hardware Prefetcher Enabled
Adjacent Cache Line Prefetch Enabled
CPU C1E Enabled
CPU C3 Report Enabled
CPU C6 Report Enabled
Package C State Support Disabled
CPU PLL Voltage wollte ich eigentlich auf 1.8V fix einstellen. Ich kann aber im UEFI des P8Z77-M Pro nur [Auto] oder [+0.1V] wählen.
Bitte um Kommentare.
Vielleicht die VCCSA Voltage fixen auf max. 0,95V, auf "Auto" sollte man solche Spannungen nicht lassen. Die Asus Boards stellen da oft exorbitante Werte ein.
Kann ich leider nicht. Beim UEFI des P8Z77-M Pro kann ich nur zwischen [Auto] und [+0.1V] wählen. Habs daher auf Auto gelassen. Gilt auch für CPU PLL Voltage.
erstmal noch mal danke an Katsche und Xsus76 wegen meiner letzten Frage.
und nun zu meiner neuen hab im web nichts gefunden. Ich hab die AI Suite II installiert nun möchte ich aber nicht das sie beim Windows Start mit starten tut.
Unter msconfig und dann unter Systemstart steht leider nichts von der AI Suite II drin. Wo kann ich das abstellen oder geht das nicht?
bin neu hier im Forum und im Besitz des P8Z77-Pro...
Als erstes kann ich schon mal sagen, der Alpenfön Himalaya paßt prima aufs Board, alle Speicherslots sind verfügbar.
Allerdings habe ich auch diverse Probleme mit dem Board, zum einen scheint es Treiber Probleme zu geben (alle aktuell), da ich teilweise (sporadisch) mit unerklärlichen Fehlermeldungen beim Start zugeschüttet werde, angefangen von Parameterfehler über alles mögliche - Rechner muß dann noch mal neu gestartet werden und läuft danach gut... Speicher ist in Ordnung, Memtest konnte nichts finden!
Zweite Problem, je nach Belegung der USB Ports, hängt der Rechner am Bios und läuft nicht hoch - teilweise ist es mir schon passiert, das dass USB Gerät sich nicht mehr einschalten ließ und komplett vom Strom getrennt werden mußte - hier scheint es Probleme mit den Spannungen zu geben.
Mein größtes Problem ist aber Wifi-Go! Der Rechner bootet, wenn er normal ausgeschaltet wurde, nach ca. 3-10 Minuten selber - eingrenzen konnte ich dies auf den Mediaplayer von Windows, wird dieser deaktiviert, ist das Problem weg, allerdings läuft die Remote Geschichte von Asus auch nicht mehr - wird der MediaPlayer wieder aktiviert, geht Remote immer noch nicht, die Asus Tools müssen erst neu installiert werden - Remote läuft danach wieder, allerdings bootet der Rechner wieder neu, wenn er ausgeschaltet wurde (3-10 Minuten Zeitraum) - dies passiert nicht, wenn der Netzschalter einmal umgelegt wurde und das Board Stromlos war!
Das Ereignis Protokoll gibt leider nichts aus, dem Mediaplayer habe ich alle Berechtigungen, unter der Aufgabenplanung (2 Stück), zum booten des Rechners entzogen.
Momentan bin ich echt ratlos und könnte da wirklich ein paar gute Tipps von euch brauchen
EDIT: Im Bios sind alle Optionen zum Booten deaktiviert (PCI etc...)
Hab mal nachgeschaut. Bei mir sind mehere Einträge in der MSCONFIG drin.
Mein neues System startet nicht, es leuchtet die Dram-LED.
Der verbautete Arbeitsspeicher: Corsair Vengeance Low Profile schwarz DIMM Kit 16GB PC3-12800U CL10-10-10-27 (DDR3-1600) (CML16GX3M2A1600C10)
steht zwar hier auf Seite 1 als kompatibel, aber mit/ab welchem Bios? Auf der Asus-Liste taucht er nicht auf!
Nach den Feiertagen teste ich mal kompatiblen Speicher von der Asus-Liste.
Oder gibt es noch irgendwelche Tricks, das Board zum Start zu überzeugen, ohne vorher am Bios was verändern zu können?
Seht auch den direkten Thread von mir dazu: http://www.hardwareluxx.de/community/f12/p8z77-v-pro-startet-nicht-933032.html
shyce, dann sollte das Kit aus den kompatiblen RAM auf Seite 1 entfernt werden. Wer hat das Kit "erfolgreich" verbaut?
Also ich hab das 8GB Kit mit CL9-9-9-24 um genau zu sein dieses hier.
Anfangs ging es bei mir auch so gar nicht. Die Dram-LED leuchtete die ganze Zeit und auch nach mehrmaligem drücken der Mem-Ok-Taste ging es nicht. Hatte dann von meinem Bruder Speicher drin, der in der Kompatibilitätsliste drin war. Damit ging es dann, ich glaube, beim zweiten Versuch. Danach hatte ich wieder auf meinem gewechselt und nach ein oder zweimal mit drücken der Mem-Ok-Taste ging es dann. Einmal in der ersten Woche startete der Rechner wegen dem Ram wieder nicht, aber dann wieder die Taste gedrückt und schon fuhr er hoch. Seit dem dann keine Probleme mehr gehabt.
Genau das denke ich auch bei meinem PC. Ich habe mal 8GB (2x4) von der Kompatibilitätsliste bestellt (hier in meinem Umfeld gibt es für mich sowas nicht zu borgen, andersrum klappt besser :rofl:).
Es gibt scheinbar noch weitere User die Probleme mit diesen Riegeln haben:
http://www.hardwareluxx.de/community/f201/anhaltende-probleme-mit-cml16gx3m2a1600c10-16-gb-corsair-kit-896837.html
---------- Post added at 05:43 ---------- Previous post was at 05:30 ----------
@michi2005,
wenn AI Suite II die Lüfter regeln soll, muss es auch mit Windows gestartet werden. Programmteile, die nicht benötigt werden, kann man im AI Suite-Menü (unter Einstellungen) deaktivieren.
Bei mir macht das 16GB Kit ebenfalls Probleme. Es ist das zweite Kit das ich bereits einschicke, da sich nach kurzer Zeit bei den verwendeten Speicher ein Modul als defekt heraustellt. Selbst mein Ersatzspeicher den ich hier im Einsatz war, hat gestern bei BF3 ständig gemuckt.
Da dieser Topic von mir war, kann ich was dazu sagen. Diese Speicher haben mich etwa 2-3 Wochen fertig gemacht bis ich überhaupt wusste das es der Speicher war, da selbst Memtest und andere Programme noch stundenlangen Durchläufen nichts gefunden haben.
Wie am Ende zu lesen ist, hab ich Ersatz bekommen und dieses Kit scheint zu laufen. Anscheinend ist es wirklich nicht 100% mit dem Board kompatibel oder die Speicher sind billig produziert und haben hohe Ausfallraten!
ich besitze das Asus P8Z77-V Pro mit der aktuellsten UEFI Version 1708. Sobald ich den PC ca. ~7x neustarte, ohne den PC dazwischen einmal heruntergefahren zu haben, werden keine Einstellungen mehr im UEFI übernommen, egal was man einstellt. Es sind also quasi die ganze Zeit die "Optimalen Standard Einstellungen" geladen, obwohl im UEFI ganz andere Einstellungen eingestellt worden sind. Dagegen hilft kein Kaltstart des PCs und auch kein CMOS-Reset, nur das neu flashen des UEFIs hilft, um dieses Problem wieder zu beseitigen. Nachdem man anschließend aber wieder ca. ~7x neustartet, ohne den PC dazwischen einmal heruntergefahren zu haben, tritt das Problem wieder auf.
Ist es ein Bug des UEFIs, wobei das UEFI beschädigt wird oder ist das so gewollt?
In folgendem Forum klagen Leute über das gleiche Problem (post #906, post #907 und post #909):
Asus Z77 Series Information Thread (drivers, BIOSes, overclocking, reviews) **UPDATED 12/20**
Mit freundlichen Grüßen,
onemoretime
onemoretime
Versuche doch mal im Asus-Forum dein Problem darzustellen:
ASUS
Hallo!
Hat es schon jemand geschafft, irgendein von den tollen ASUS DLNA Features erfolgreich zu nutzen?
Bisher habe ich nur ein Samsung S3 zum testen. Und ein Windows 7 Ultimate PC.
Habe die Wifi-Engine aktiviert. Als AP konfiguriert.
Das Konfigurationstool ist schonmal der letzte Schrott.
Welche Verschlüsselung läuft? Wo kann man den IP-Kreis bestimmen? Welcher Kanal? Wo kann man den DHCP-Server aktivieren?
Naja, letztendlich habe ich es zusammengeflickt und meinem S3 eine feste IP vergeben.
WLAN am PC läuft als AP und das Smartphone verbindet sich einwandfrei.
Dann habe ich auf dem S3 das Wifi Go Remote Tool installiert und gestartet.
Irgendwann tauchte der PC samt IP-Adresse zur Auswahl, auf mit dem ich mich dann verbunden habe.
Der Auswahlbildschirm von Wifi Go erscheint.
Ich tippe auf Remotedesktop und starte diesen.
Am PC flackert mehrmals der Bildschirm, das wars dann.
Auf dem S3 steht nur noch:
Waiting for Connection at: 192.168.137.2...20
Warum wartet das Smartphone denn auf die Verbindung???! Will doch den PC Remote steuern!!!
Sja, woran liegt's?!
Firewall und Avast hatte ich auch schon deaktiviert.
hab ein problme mit meinem Front USB 3 (Gehäuse ist ein Cooler Master 690 II mit Frontpanel 2x USB3 2xUSB2) also wenn ich meine externe Festplatte von WD oder meine USB-Stick von Transcend an die beide USB3-Ports stecke geht alles,sobald ich aber denn USB-Stick von Super Talent SuperCrypt USB 3.0 benutzen will wir er nicht erkannt. Schließe ich ihn aber an die Hinteren USB3Ports an läuft er 1a.
An denn USB2 Ports an der Front läut der Super Talent SuperCrypt auch 1a.
Habt ihr vielleicht eine Idee woran es liegen kann?
Kann ich irgendwie die Einstellungen
von dem CPU Lüftern so einstellen, dass der am
2. CPU Lüfterslot nur auf 5 oder 7 Volt läuft?
Die 2 Orginal Lüfter laufen auf etwa 500 RPM
und der Noiseblocker bringt das ganze Case zum schwingen mit seinen 1200 RPM
am CPUK. Entkoppeln kann ich ihn dort ja auch nicht.
Hallo Leute. Muss ich im bios den xhci Modus auf smart Auto oder auf Aktiviren stellen
Hallo Leute!
Ich liebäugel mit dem P8Z77 in der einfachsten Ausstattung für einen 3570K.
Daher bin ich auf den Thread gestoßen und möchte mich vor allem für die gute Einleitung und die einführende pdf bedanken!
Trotzdem sind noch ein paar Fragen offen, die ihr mir vllt. beantworten könnt, sodass ich nicht alle 50 Seiten lesen muss:
Ich möchte die CPU später moderat übertakten, d.h. LuKü und dann ohne oder minimaler V-Core Erhöhung. Mir schweben 4 Ghz vor, die, AFAIK, nicht ganz unrealistisch sein sollten. Reicht dafür vermutlich die 12 Phasen Spannungsvesorung des V oder sind die Unterschiede zur 16 bzw. 20 Phasenversorung eklatant?
Bin bisher mit einem C2D mit 2.2 Ghz unterwegs, den ich mit meinem alten Abit IP35 Pro auf 3 Ghz bekommen habe, trotz starkem VDrop. Daher bin ich eigentlich zuversichtlich, dass ich nicht die teurere Version brauche.
Die übrigens Extras der besseren Versionen sind zwar nett zu haben, aber für mich kein Argument, 50 Euro oder mehr zusätzlich auszugeben.
Außerdem wäre meine Frage, welche (kostengünstigen) aber zuverlässigen Alternativen es zum Asus gibt. Viele schwören ja auf ASROCK, aber damit hab ich einmal sehr schlechte Erfahrungen gemacht und scheue daher das Feuer ;)
Vielen Dank so weit für Eure Meinungen!
EDIT:
Eine wichtige Sache noch: Ich hoffe die Kompatibilitäsliste für RAM im 1. Post ist nicht mehr ganz aktuell, ansonsten müsste das Board ja relativ wählerisch sein, oder? Suche jedenfalls ein günstiges und zuverlässiges Kit. Allerdings bin ich mir unsicher, wie groß die Mehrleistung bei z.B. 2133 Mhz schnellem Ram wäre... denn durch den freien Multi dürfte es sich doch nicht wirklich lohnen, groß am FSB zu schrauben, oder ist das nicht mehr aktuell? Wenn sich der Mehrpreis für schnelleren RAM rechnen würde, wäre es mir das wert - für 2-3% jedoch greife ich lieber zu langsamerem, günstigerem RAM. Tendiere derzeit für ein 8 GB Kit, wenns relativ günstig ist auch 16 GB... Auch hier vielen Dank für Eure Vorschläge!
Ich habe das P8Z77-V und auch einen 3570K darauf. Im Moment lasse ich ihn auf 4Ghz sogar mit etwas Undervolting laufen und bis 4,7 Ghz habe ich schonmal getestet. Also kann ich sagen, dass sich die mehr Phasen nicht lohnen. Für 4 Ghz dürften sogar auch weit günstigere Mainboards ausreichen.
Na, wenn auch 4,5 drin sein könnten, sag ich natürlich nicht nein...
Hat jemand den alten, aber immer noch sehr guten Thermalright Ultra-120 eXtreme auf dem Board? Es gibt wohl nen Adapter für den 1156er Sockel, ich weiß nur nicht, ob der Kühler irgendwelchen Bauteilen in den Weg kommt. Muss der Ram ggf. ne niedrigere Bauhöhe haben?
Hab jetzt einfach mal den Rechner zusammengestellt, mit diesem RAM: 16GB-Kit Corsair Vengeance blau PC3-12800U CL10-10-10-27
Ist hier im Topic, wenn ich das richtig gesehen habe, eher gut als schlecht weggekommen. Wahl ok?
Hmm... denke nicht, dass der Kühler irgendwelchen Bauteilen im Weg ist. Könnte natürlich sein, dass hoher Speicher nicht passt, zumindest nicht in allen Slots.
Wenn ich es richtig in Erinnerung habe, dann hatte vor ein paar Posts jemand mit genau diesem RAM Probleme.
Also ich hab mal die letzten 10 Seiten gelesen, da war es jedenfalls nicht ;)
Hab nun einfach mal 16GB Corsair Vengeance LP Black DDR3-1600 DIMM CL10 Dual Kit bestellt und schaue was passiert. Als Reserve kommt dann noch Corsair CMV16GX3M2A1600C11 ValueSelect Arbeitspeicher 16GB (1600MHz, CL11, 2x 8GB) DDR3-RAM Kit von Amazon, leider im Moment noch sehr lange Lieferzeit, ich hoffe, den werde ich gar nicht erst brauchen.
Außerdem ist eine 2TB Platte, eine EVGA 660 GTX Ti sowie ein optisches LW und natürlich das Asus P8Z77-V LX bestellt... nun hoffe ich, dass wirklich alles wie angegeben vorrätig war und die Sachen zügig kommen. Ist mein erster neuer Rechner seit 5 Jahren *g*
Edit:
Gestern kam alles an, scheine auch alles richtig zusammengebaut zu haben... nur der RAM zickt. Das Board stellt ihn auf nur 1333 Mhz ein. Lade ich das XMP-Profil, bleibt der Bildschirm schwarz. Hat da jemand nen guten Tipp?
Edit:
Das mit PC1333 hat mein Board zu beginn auch gemacht und mußte auch manuell das XMP-Profil laden. Hast du mal ein Bios-Update gemacht?
Gesendet von meinem GT-I9001 mit der Hardwareluxx App
habe das P8Z77-V & aktuellstes Bios drauf. Hatte vorher Win7, wollte Win8 draufhauen. Dazu meine 2 SSDs im RAID0. Im Bios auf RAID von AHCI umgestellt, aber bei der Tastenkombination CTRL+I passiert beim Postscreen nichts, er bootet weiter. Direkt nach dem PS des Bios kommt auch kein RAID Setup Screen wie von älteren Mainboards gewohnt. Dort musste man ja im Normalfall erst per Tastenkombi reinspringen. Wo ist der Fehler?
Bios auch bereits auf Standartwerte zurückgesetzt, brauchte nichts.
Habe nun auf eine SSD mal Win8 drauf installiert. Die 2te SSD erkennt er immer, meine HDD allerdings nicht immer. Wenn ich neu starte ist sie nicht in Windows verfügbar, nur wenn ich vorher im Bios war (dort listet er die HDD natürlich nach wie vor) findet sie Win8 oder beim Anschalten ist die Chance 50/50 habe ich das Gefühl. Datenträgerverwaltung "neu einlesen" bringt hier keine Verbesserung.
So ein Mist :(
