[Sammelthread] Asus Rampage Extreme R.o.G. (Intel X48) [2]
[blockquote]
InhaltInhalt des Sammelthreads
Spezifikationen Spezifikationen
CPU
  • LGA 775 socket for:
    - Intel® Core™2 Extreme/Core™2 Quad/ Core™2
  • Supports Intel Enhanced Memory 64 Technology (EMT64T)
  • Supports Enhanced Intel SpeedStep Technology (EIST)
  • Supports Intel Hyper-Threading Technology
  • Supports 1600/1333/1066/800MHz FSB
Intel® chipset
  • Northbridge:
    - Intel® X48 Express chipset
    - Intel® Fast Memory Access technology
  • Southbridge:
    - Intel® ICH9R
Memory
  • 4 x DIMM, Max. 8 GB, DDR3 2000(O.C.)/1800(O.C.)/1600/1333/1066/800
  • ECC,Non-ECC,Un-buffered Memory
  • Dual Channel memory architecture
    *Overclock speed
    - Supports Intel® Extreme Memory Profile (XMP)
    - For the X.M.P. support, CPUs with FSB 1333 or above are recommended
Expansion Slots
  • 2 x PCIe 2.0 x16 , support at full x16, x16 speed
  • 3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 2 x PCI 2.2
BIOS
  • AMI BIOS
  • 16 Mb Flash ROM
  • DMI 2.0
  • PnP
  • WfM 2.0
  • SM BIOS 2.4
  • ACPI 2.0a
  • Multi-language BIOS
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8-channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2
  • Support Teaming Technology
IDE
  • Marvell® 88SE6121 controller
    - 1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
Serial ATA with RAID
  • Southbridge:
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • Silicon Image Sil5723 controller:
    - 2 x SATA 3.0 Gb/s port
    - Supports RAID 0, 1
Rear Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector for two devices
  • 6 x SATA connectors (Blue)
  • 2 x Speeding HDD SATA connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 3 x thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x LCD Poster connector
  • 1 x EL I/O Shield connector
  • 1 x Chassis Intrusion connector
  • 24-pin ATX Power connector
  • 8-pin ATX 12V Power connector
  • 1 x En/Dis-able Clr CMOS slide switch
  • System panel connector
Accessories
  • Fusion Block System Accessory
  • Optional Thermal Kit for NB and MOS
  • DIY Pedestal
  • ASUS Optional Fan
  • External LCD Poster
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • Floppy disk drive cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
Overclocking Features
  • Fusion Block System with optional thermal kit on MOS and NB
  • Extreme Tweaker
  • TweakIt
  • Extreme Engine
    - 16-phase CPU power design
    - 3-phase NB power design
    - 2-phase DDR3 power design
    - ML Caps on CPU, memory and NB respectively
  • Speeding HDD
  • iROG
  • BIOS Flashback
  • Loadline Calibration
  • Intelligent overclocking tools:
    - CPU Level Up
    - Memory Level Up
    - AI Gear 3 + ™
    - ASUS AI Booster Utility
    - O.C Profile
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Special Features
  • Onboard Switches: TweakIt / Power / Reset / Cls CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Form Factor
  • ATX Form Factor
  • 30.5cm x 24.5cm
BilderBilder
Verpackung & Accessoires
Layout
Zusatzkühler für den Betrieb mit Lukü montiert
Bauteile im Detail
Das BiosDas Bios
OC VerhaltenOC Verhalten
Vom Board bereitgestellte Spannungen im Bios:
  • CPU Spannung: 0.85v ~ 2.50v in 0.00625 Volt Schritten
  • CPU PLL Spannung: 1.50v ~ 3.00v in 0.013 Volt Schritten; Standard 1.50 Volt
  • FSB Termination Spannung: 1.10v ~ 2.00v in 0.013 Volt Schritten; Standard 65nm = 1.20 Volt / 45nm = 1.10 Volt
  • DRAM Spannung: 1.50v ~ 2.80v in 0.013 Volt Schritten; Standard 1.50 Volt
  • Northbridge Spannung: 1.25v ~ 2.05v in 0.013 Volt Schritten; Standard 1.25 Volt
  • Southbridge 1.05v Spannung: 1.05v ~ 1.96v in 0.013 Volt Schritten; Standard 1.05 Volt
  • Southbridge 1.50v Spannung: 1.05v ~ 2.05v in 0.013 Volt Schritten; Standard 1.50 Volt
  • NB DDRVref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
  • DDR3 Channel A/B Vref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
Biostemplate für das Extreme Tweaker Menü:
Code:
Ai Overclock Tuner:
OC From CPU Level UP:
OC From Memory Level UP:
FSB Frequency:
CPU Ratio Control:
- CPU Configuration:
- CPU Clock Skew:
- NB Clock Skew:
FSB Strap to North Bridge:
PCI-E Frequency:
DRAM Frequency:
DRAM Command Rate:
DRAM Timing Control:
- CAS# Latency:
- RAS# to CAS# Delay:
- RAS# PRE Time:
- RAS# ACT Time:
- RAS# to RAS# Delay:
- REF Cycle Time:
- Write Recovery Time:
- Read to PRE Time:
- Read to Write Delay(S/D):
- Write to Read Delay(S):
- Write to Read Delay(D):
- Read To Read Delay(S):
- Read To Read Delay(D):
- Write To Write Delay(S):
- Write To Write Delay(D):
- Write to PRE Delay:
- Read to PRE Delay:
DRAM Static Read Control:
DRAM Dynamic Write Control:
DRAM Skew Control:
- DRAM CMD Skew on Channel A/B:
- DRAM CLK Skew on DIMM A1/A2/B1/B2:
- DRAM CTL Skew on DIMM A1/A2/B1/B2:
Ai Clock Twister:
- Ai Clock Skew for Channel A:
- Ai Clock Skew for Channel B:
Ai Transaction Booster:
- Common Performance Level:
- Pull-In of CHA PH1:
- Pull-In of CHA PH2:
- Pull-In of CHA PH3:
- Pull-In of CHA PH4:
- Pull-In of CHA PH5:
- Pull-In of CHB PH1:
- Pull-In of CHB PH2:
- Pull-In of CHB PH3:
- Pull-In of CHB PH4:
- Pull-In of CHB PH5:
EPU II Phase Control:
CPU Voltage:
Load-Line Calibration:
CPU PLL Voltage:
FSB Termination Voltage:
- CPU GTLVref (0):
- CPU GTLVref (1):
- CPU GTLVref (2):
- CPU GTLVref (3):
North Bridge Voltage:
DRAM Voltage:
- NB DDRVref:
- DDR3 ChannelA Vref:
- DDR3 ChannelB Vref:
South Bridge 1.5 Voltage:
South Bridge 1.05 Voltage:
CPU Spread Spectrum:
PCIE Spread Spectrum:
Ein paar OC Ergebnisse von OnePageBook (OCX)
500FSB Everest & Orthos:
600FSB Everest & Orthos:
Speicher KompatibilitätslisteSpeicher Kompatibilitätsliste
2x1024MB Kits
  • 2x1GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x1GB Kit OCZ Intel Extreme PC3-12800
  • 2x1GB Kit Patriot Viper PC3-12800
  • 2x1GB Kit Patriot Viper PC3-14400
  • 2x1GB Kit Patriot Viper PC3-15000 (Micron D9GTR)
  • 2x1GB Kit TeamGroup Xtreem PC3-12800 (Micron D9GTR)
2x2048MB Kits
  • 2x2GB Kit Adata XSeries PC3-12800
  • 2x2GB Kit Chaintech APOGEE GT Blazer PC3-14400
  • 2x2GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x2GB Kit OCZ Intel Extreme PC3-12800
Passende Kühler (Lukü)Passende CPU Kühler (Lukü)
Luftkühler:
  • Zalman CNPS 9500 AT
FAQFAQ
F: Wie funktionieren die GTL Einstellungen?
A: Beim Rampage Extreme funktioniert dies über einen festen GTL Multi und einer justierbaren Spannung (-155mV bis +155mV).
Die festen Multis sehen wie folgt aus:
  • CPU 0 = 0.635
  • CPU 1 = 0.67
  • CPU 2 = 0.635
  • CPU 3 = 0.67
Die GTL Voltage wird so eingestellt / berechnet:
  • VTT (FSB Spannung) x GTL Multi +/- xxx mV = GTL Spannung
  • 1.16v (VTT) x 0.635 (Multi) - 25mV (Spannung) = 0.7116v
F: Ist mein altes Backplate noch ohne weiteres nutzbar?
A: Aufgrund des zusätzlichen Fujitsu Chips auf der Rückseite des Sockels kann man nicht ohne weiteres jedes Backplate
nutzen oder man muss es bearbeiten. Für diejenigen die sich lieber ein passendes Kaufen weil sie nicht die möglichkeit
haben es zu bearbeiten hat der User "Navigator1" ein passendes rausgesucht, hier der Link zu dem passenden Post
DownloadsDownloads
Bios Downloads (Flashen auf eigene Gefahr!)
Treiber & restliche Downloads
[/blockquote]
@fu2z3l
besten dank
wenn mir noch jemand zum OCen nöch ein paar tips geben könnte dann würde ich mich echt freuen
Was willste übertakten und wie weit? Wobei ich eigentlich für 24/7 der falsche Ansprechpartner bin, eher so in die Richtung Benchen 600Mhz+ FSB...;)
Christian
Also ich würde gern mit meinem cpu die 3,6 ghz erreichen
ich brauche eigentlich nur ein paar tips wo mann was einstellt weil dieses bios ist ganz anders als die die bis jetzt kenne
Ai Overclock Tuner Manual
OC From CPU Level Up Auto
OC From Memory Level Up Auto
FSB Frequency 400
CPU Ratio 9
CPU Clock Skew Delay Auto
NB Clock Skew Delay Auto
FSB Strap to North Bridge 400Mhz
PCIE Frequency 100
DRAM Frequency DDR3-1600
DRAM Command Rate 1N
DRAM Timing Control Manual
CAS# Latency 8 DRAM Clocks
RAS# to CAS# Delay 8 DRAM Clocks
RAS# PRE Time 8 DRAM Clocks
RAS# ACT Time 24 DRAM Clocks
RAS# to RAS Delay Auto
REF Cycle Time Auto
WRITE Recovery Time Auto
READ to PRE Time Auto
2nd Information Auto
3rd Information Auto
DRAM Static Read Control Auto
DRAM Dynamic Write Control Auto
CPU Voltage 1.40000 (ausprobieren)
Load-Line Calibration enabled
CPU PLL Voltage 1.51106
FSB Termination Voltage 1.28
CPU GTLVref (0) Auto
CPU GTLVref (1) Auto
CPU GTLVref (2) Auto
CPU GTLVref (3) Auto
NB GTLVref Auto
North Bridge Voltage 1.3
DRAM Voltage 1,85
NB DDRVref Auto
DDR3 ChannelA Vref Auto
DDR3 ChannelB Vref Auto
South Bridge 1.5 Voltage 1,5
South Bridge 1.05 Voltage 1,05
CPU Spread Spectrum Disabled
PCIE Spread Spectrum Disabled
Das soll nur ein grober Richtwert sein.
Im Endeffekt musst du selber ausprobieren.
FSB Frequency 425
CPU Ratio 8
PCIE Frequency 100
CAS# Latency 9 DRAM Clocks
RAS# to CAS# Delay 9 DRAM Clocks
RAS# PRE Time 9 DRAM Clocks
REF Cycle Time Auto
CPU Voltage 1.42
NB GTLVref Auto
DRAM Voltage 1,85
NB DDRVref Auto
so sind momentan meine einstellungen
Q6600 2,4@3,40 GHZ
FSB:dRAM 1:2 850 MHZ
prime 95 läuft schon seit 4.40 cpu zeit und die temps sind so um die 54°C
Ist doch schon mal ein Anfang. ;)
so jetzt bin ich fertig mit OCen bin mit 425fsb 3,40 zu frieden
cpu vlt ist auf 1,39 und die temps bei vollast auf max 53°C
Besten dank für die tipps
man ist nie "fertig" mit OCen :-)
OLANO will das defekte Board jetzt zur erneuten Untersuchung wiederhaben... hätten sie sich auch früher überlegen können...
Naja ich habe es gründlich fotografiert...nicht, dass noch andere Schäden "auftreten"
Na, wenigstens hast es versucht!
Das ist die Hauptsache!!
web
@brodtwage
sagen wir mal fürs erste
mein nächster cpu wird ein Xeon 3360 oder 3370
Hab leider keine Zeit das Maximus Extreme einzubauen. :heul:
Das defekte Maximus 2 Formula ist heute vom Händler zu ASUS geschickt worden. :d
heute ist mir was seltsames passiert
beim starten des systems wolte der rechner nicht mehr starten und auf dem lcd display stant "det ram" was ist das
mußte im bios rein und speichern danach ging alles wieder
hi,
denke mal detecting RAM, ram probs
das ist "das standardproblem" des boards wenn irgendwas nicht stabil läuft kommt das häufiger mal vor. Solltest nochmal ausgiebig deine settings testen...
hab augerade mal im internet rumgestöbert und da steht was von der kompatibletät des rams usw.
kann es sein das die zu wenig strom bekommen eigentlich nicht weil die laufen momentan bei 1,85 und dürfen nur 1,8 haben laut hersteller
1,9volt kann auch net schaden, meine laufen auch mit 1,9v
wie geasgt, es ist de facto eine Meldung die bei diversen unstabilitäten auftritt...nicht NUR bei RAM Problemen.
@brodtwaage
Das glaube ich auch weil wenn ich jetzt prime 95 laufen lasse dann schaltet sich der erste kern schon nach 3 min ab.
Irgendwas mache ich falsch oder ist doch mein CPU eine gurke?
DAs sind meine einstellungen
FSB Frequency 425
CPU Ratio 8
PCIE Frequency 100
REF Cycle Time Auto
CPU Voltage 1.42
NB GTLVref Auto
DRAM Voltage 1,85
NB DDRVref Auto
Haste einen Quad? Wenn ja, dann erhöhe mal ein bissel die vNB. Die scheint mir ein bissel niedrig...;) Vielleicht hilft es was.
Christian
ja hab einen Q6600
momentan lasse ich ihn bei 425*8 laufen
wie hoch darf ich denn gehen
probier doch ob er die 4Ghz schafft.
wie soll das denn gehen
ich meine da müßt ihr mir ein aar tips geben um den CPU zu OCen
bei 1.4 NB spanung geht der erste kern nach 3min aus
wieso gurke?? ist halt nen 65nm Quad...ich hatte vor meinem jetzigen Prozessor ebenfalls einen Q6600 der lief maximal 3300 MHz...also ist 3400 schon nicht sooo schlecht.
Die sind generell nicht solche Brenner...
Wäre interessant zu wissen welchen Prime test du gemacht hast und bei welchem Test er genau abbricht?
Hast du Small oder Blend oder Large getestet?
ist halt abhängig was für ein Stepping der Q6600 hat... die erste Reihe ging nicht so gut... das G0-Stepping geht aber doch ganz gut... ich hatte meinen auf 4GHz und das sogar auf dem P5N32-E SLI ( was ja angeblich soooo schlecht zu takten geht ;) ).
