[Sammelthread] Asus Rampage Extreme R.o.G. (Intel X48) [2]
[blockquote]
InhaltInhalt des Sammelthreads
Spezifikationen Spezifikationen
CPU
  • LGA 775 socket for:
    - Intel® Core™2 Extreme/Core™2 Quad/ Core™2
  • Supports Intel Enhanced Memory 64 Technology (EMT64T)
  • Supports Enhanced Intel SpeedStep Technology (EIST)
  • Supports Intel Hyper-Threading Technology
  • Supports 1600/1333/1066/800MHz FSB
Intel® chipset
  • Northbridge:
    - Intel® X48 Express chipset
    - Intel® Fast Memory Access technology
  • Southbridge:
    - Intel® ICH9R
Memory
  • 4 x DIMM, Max. 8 GB, DDR3 2000(O.C.)/1800(O.C.)/1600/1333/1066/800
  • ECC,Non-ECC,Un-buffered Memory
  • Dual Channel memory architecture
    *Overclock speed
    - Supports Intel® Extreme Memory Profile (XMP)
    - For the X.M.P. support, CPUs with FSB 1333 or above are recommended
Expansion Slots
  • 2 x PCIe 2.0 x16 , support at full x16, x16 speed
  • 3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 2 x PCI 2.2
BIOS
  • AMI BIOS
  • 16 Mb Flash ROM
  • DMI 2.0
  • PnP
  • WfM 2.0
  • SM BIOS 2.4
  • ACPI 2.0a
  • Multi-language BIOS
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8-channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2
  • Support Teaming Technology
IDE
  • Marvell® 88SE6121 controller
    - 1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
Serial ATA with RAID
  • Southbridge:
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • Silicon Image Sil5723 controller:
    - 2 x SATA 3.0 Gb/s port
    - Supports RAID 0, 1
Rear Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector for two devices
  • 6 x SATA connectors (Blue)
  • 2 x Speeding HDD SATA connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 3 x thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x LCD Poster connector
  • 1 x EL I/O Shield connector
  • 1 x Chassis Intrusion connector
  • 24-pin ATX Power connector
  • 8-pin ATX 12V Power connector
  • 1 x En/Dis-able Clr CMOS slide switch
  • System panel connector
Accessories
  • Fusion Block System Accessory
  • Optional Thermal Kit for NB and MOS
  • DIY Pedestal
  • ASUS Optional Fan
  • External LCD Poster
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • Floppy disk drive cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
Overclocking Features
  • Fusion Block System with optional thermal kit on MOS and NB
  • Extreme Tweaker
  • TweakIt
  • Extreme Engine
    - 16-phase CPU power design
    - 3-phase NB power design
    - 2-phase DDR3 power design
    - ML Caps on CPU, memory and NB respectively
  • Speeding HDD
  • iROG
  • BIOS Flashback
  • Loadline Calibration
  • Intelligent overclocking tools:
    - CPU Level Up
    - Memory Level Up
    - AI Gear 3 + ™
    - ASUS AI Booster Utility
    - O.C Profile
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Special Features
  • Onboard Switches: TweakIt / Power / Reset / Cls CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Form Factor
  • ATX Form Factor
  • 30.5cm x 24.5cm
BilderBilder
Verpackung & Accessoires
Layout
Zusatzkühler für den Betrieb mit Lukü montiert
Bauteile im Detail
Das BiosDas Bios
OC VerhaltenOC Verhalten
Vom Board bereitgestellte Spannungen im Bios:
  • CPU Spannung: 0.85v ~ 2.50v in 0.00625 Volt Schritten
  • CPU PLL Spannung: 1.50v ~ 3.00v in 0.013 Volt Schritten; Standard 1.50 Volt
  • FSB Termination Spannung: 1.10v ~ 2.00v in 0.013 Volt Schritten; Standard 65nm = 1.20 Volt / 45nm = 1.10 Volt
  • DRAM Spannung: 1.50v ~ 2.80v in 0.013 Volt Schritten; Standard 1.50 Volt
  • Northbridge Spannung: 1.25v ~ 2.05v in 0.013 Volt Schritten; Standard 1.25 Volt
  • Southbridge 1.05v Spannung: 1.05v ~ 1.96v in 0.013 Volt Schritten; Standard 1.05 Volt
  • Southbridge 1.50v Spannung: 1.05v ~ 2.05v in 0.013 Volt Schritten; Standard 1.50 Volt
  • NB DDRVref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
  • DDR3 Channel A/B Vref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
Biostemplate für das Extreme Tweaker Menü:
Code:
Ai Overclock Tuner:
OC From CPU Level UP:
OC From Memory Level UP:
FSB Frequency:
CPU Ratio Control:
- CPU Configuration:
- CPU Clock Skew:
- NB Clock Skew:
FSB Strap to North Bridge:
PCI-E Frequency:
DRAM Frequency:
DRAM Command Rate:
DRAM Timing Control:
- CAS# Latency:
- RAS# to CAS# Delay:
- RAS# PRE Time:
- RAS# ACT Time:
- RAS# to RAS# Delay:
- REF Cycle Time:
- Write Recovery Time:
- Read to PRE Time:
- Read to Write Delay(S/D):
- Write to Read Delay(S):
- Write to Read Delay(D):
- Read To Read Delay(S):
- Read To Read Delay(D):
- Write To Write Delay(S):
- Write To Write Delay(D):
- Write to PRE Delay:
- Read to PRE Delay:
DRAM Static Read Control:
DRAM Dynamic Write Control:
DRAM Skew Control:
- DRAM CMD Skew on Channel A/B:
- DRAM CLK Skew on DIMM A1/A2/B1/B2:
- DRAM CTL Skew on DIMM A1/A2/B1/B2:
Ai Clock Twister:
- Ai Clock Skew for Channel A:
- Ai Clock Skew for Channel B:
Ai Transaction Booster:
- Common Performance Level:
- Pull-In of CHA PH1:
- Pull-In of CHA PH2:
- Pull-In of CHA PH3:
- Pull-In of CHA PH4:
- Pull-In of CHA PH5:
- Pull-In of CHB PH1:
- Pull-In of CHB PH2:
- Pull-In of CHB PH3:
- Pull-In of CHB PH4:
- Pull-In of CHB PH5:
EPU II Phase Control:
CPU Voltage:
Load-Line Calibration:
CPU PLL Voltage:
FSB Termination Voltage:
- CPU GTLVref (0):
- CPU GTLVref (1):
- CPU GTLVref (2):
- CPU GTLVref (3):
North Bridge Voltage:
DRAM Voltage:
- NB DDRVref:
- DDR3 ChannelA Vref:
- DDR3 ChannelB Vref:
South Bridge 1.5 Voltage:
South Bridge 1.05 Voltage:
CPU Spread Spectrum:
PCIE Spread Spectrum:
Ein paar OC Ergebnisse von OnePageBook (OCX)
500FSB Everest & Orthos:
600FSB Everest & Orthos:
Speicher KompatibilitätslisteSpeicher Kompatibilitätsliste
2x1024MB Kits
  • 2x1GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x1GB Kit OCZ Intel Extreme PC3-12800
  • 2x1GB Kit Patriot Viper PC3-12800
  • 2x1GB Kit Patriot Viper PC3-14400
  • 2x1GB Kit Patriot Viper PC3-15000 (Micron D9GTR)
  • 2x1GB Kit TeamGroup Xtreem PC3-12800 (Micron D9GTR)
2x2048MB Kits
  • 2x2GB Kit Adata XSeries PC3-12800
  • 2x2GB Kit Chaintech APOGEE GT Blazer PC3-14400
  • 2x2GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x2GB Kit OCZ Intel Extreme PC3-12800
Passende Kühler (Lukü)Passende CPU Kühler (Lukü)
Luftkühler:
  • Zalman CNPS 9500 AT
FAQFAQ
F: Wie funktionieren die GTL Einstellungen?
A: Beim Rampage Extreme funktioniert dies über einen festen GTL Multi und einer justierbaren Spannung (-155mV bis +155mV).
Die festen Multis sehen wie folgt aus:
  • CPU 0 = 0.635
  • CPU 1 = 0.67
  • CPU 2 = 0.635
  • CPU 3 = 0.67
Die GTL Voltage wird so eingestellt / berechnet:
  • VTT (FSB Spannung) x GTL Multi +/- xxx mV = GTL Spannung
  • 1.16v (VTT) x 0.635 (Multi) - 25mV (Spannung) = 0.7116v
F: Ist mein altes Backplate noch ohne weiteres nutzbar?
A: Aufgrund des zusätzlichen Fujitsu Chips auf der Rückseite des Sockels kann man nicht ohne weiteres jedes Backplate
nutzen oder man muss es bearbeiten. Für diejenigen die sich lieber ein passendes Kaufen weil sie nicht die möglichkeit
haben es zu bearbeiten hat der User "Navigator1" ein passendes rausgesucht, hier der Link zu dem passenden Post
DownloadsDownloads
Bios Downloads (Flashen auf eigene Gefahr!)
Treiber & restliche Downloads
[/blockquote]
Also mein Q6600 ist ein G0 Stepping und den prime hatte ich bis gestern immer auf blend getestet
aber jetzt teste ich im small aber leider mit 400FSB *8 also 3,2 nur.Aber der läuft nur wenn ich den v core auf 1.40 setze bei 1,39 freest der ein so bald ich prime starte.
natürlich frage ich mich jetzt volgendes
1-soll ich mir ein neuen CPU holen(9650oder Xeon 3360)??
2-oder doch auf nehalem umsteigen da ich das board ja noch zurück geben kann es ist noch keine 10 tage alt
3-Oder mich zufrieden geben damit was ich habe da ich ehe gelegentlich zocke und ein bisßchen mit dem pc rumschlage
was meint ihr
---------- Beitrag hinzugefügt um 18:37 ---------- Vorheriger Beitrag war um 16:52 ----------
So hab ihn jetzt auf 3,31 mit 414FSB *8 bei 1.40v vCore
prime läuft stabil die temps sind bei 56°C
dram ist bei 828mhz cl9
tjo, dass musst Du selber wissen. :coolblue:
Also mein Q6600 war auch ein G0 und mehr als 3300 waren wirklich nicht drin. Aber ehrlich gesagt bis auf das Gute Gefühl und den OC Spaß habe ich bislang kaum Vorteile des deutlich schnelleren Q9550 bemerkt. Also der Umstig hat sich nicht unbedingt gelohnt. Würde ich dir nicht unbedingt empfehlen. Behalt deinen Quad und gut ist!
werde ich auch wohl machen
ich meine irgend wann muß mal auch schluß sein mit 414FSB *8 3.31GHZ bin ich auch zufrieden das reicht für den otto normalen verbraucher
hallo zusammen,
habe ein rampage extrem,e8600 und suche jetzt einen 2x2gb ram der auf dem board best möglich rent....was nicht gerade einfach ist muss ich sagen
also es kommt immer drauf an welche MHz du erreichen willst...
1333 ist für viele kein Problem, ab 1600 wirds schon schwerer, 2000 ist absolute Königsklasse.
die sollen das z.B. teilweise schaffen
es gibt aber auch noch andere gute.
Preis/Leistungsmäßig sind die hier interessant.
Wenn Geld keine Rolle spielt, kannst du auch zu den Dominator XMS3 greifen, aber 550 Tacken ist schon ne Hausnummer!
beim ersten link steht leider nichts,1800mhz wären schon nicht schlecht...wenn ich mir schon so ein board kaufe will ich einen ram der ab geht.....
was ist mit dem ram 2x2GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR),was können die auf dem board????
sorry aber das internet spint bei mir etwas,wollte nicht alles 2-3 mal schreiben...
einmal posten reicht auch wie ich finde...
die von dir angesprochenen Compustockx Diablo waren genau die, die ich im ersten Link gemeint hatte.
Der CompuStocx Diablo PC3-16000 soll einer der besten für das board sein ist das richtig???
Warum schreibst Alles 2-3mal?
wieso kann ich ab dem Beitrag von Pit Bull um 12:44 Uhr nichts mehr sehen?
Alle Beiträge danach kann ich nicht sehen bei mir! Weder im IE noch in Firefox!
EDIT: So das ist hinfällig! jetzt kann ich wieder alles sehn...
Also ja, die Diablos sollen gut sein, aber ausprobieren musst du es schon selbst...
tag luxxers
bei mir ist jetzt alles im grünen bereich
prime läuft stabil und die rams auf 826mhz
bin jetzt zu frieden mit 414fsb *8 bei 1.40 vcore
nochmals danke an alle ihr ward serh behilflich danke
mein Rampage scheint defekt zu sein
alle 3 tage läuft es in games instabil ( FEAR 2 und CoD4)
ich muß dann immer wieder das 2te bios laden und cos clear
kennt das jemand?
ich hab mir jetzt ein neues bestellt und werde es am We austauschen:verwirt:
kennt das jemand?
Nee, bis jetzt lüppt meins juut!! :coolblue:
Hat in dem Thread schon wer Dominator Ram auf dem Board laufen gehabt ??? Liebäugle nämlich damit um meinen 8600er ein wenig "anzutreiben" :d
greetz
Warum sollten die nicht laufen?!
Zumal eine genauere Angabe nicht schlecht wäre. :wink:
Da ich auf dem Striker II mit den Dominator (1066) totalen Stress hatte und generell auf Asus Boards die ich hatte die Dominator nie so liefen wie sie sollten hab ich mir gedacht ich frag mal...
Weiss nicht in wie weit sich da was getan hat, aber auf dem Striker II hat ich immer das DET DRAM Problem (mit anderen Ram hatte ich das nicht). ich weiss das DET DRAM muss nicht unbedingt was mit den RAM zu tun haben aber sobald ich andere rein getan habe hats gelüppt...
Meine derzeitigen Ram sind Dominator 1600 mit 1,65 V cl8
deswegen meine Frage...
und gleich die nächste:
Hat wer die Messpunkte für Vcore, VTT, PLL und VDIMM ???
Hi luxxers
hab ein neues problem
gerade habe ich vista ultimate 64 installiert und bekomme ständig ein blue screen mit der meldung (SYSTEM-SERVICE-EXEPTION)
was kann das denn sein
Nach dem Neustart gab Windoof mir dann folgende Meldung aus:
Problemsignatur:
Problemereignisname: BlueScreen
Betriebsystemversion: 6.0.6001.2.1.0.768.2
Gebietsschema-ID: 1031
Zusatzinformationen zum Problem:
BCCode: 1000007e
BCP1: FFFFFFFFC0000005
BCP2: FFFFFA60039855C6
BCP3: FFFFFA6005D3C788
BCP4: FFFFFA6005D3C160
OS Version: 6_0_6001
Service Pack: 1_0
Product: 768_1
Dateien, die bei der Beschreibung des Problems hilfreich sind:
C:\Windows\Minidump\Mini011909-01.dmp
C:\Users\Payniz\AppData\Local\Temp\WER-53461-0.sysdata.xml
C:\Users\Payniz\AppData\Local\Temp\WERD7C7.tmp.version.txt
So ich habe mir mal welche zur auswahl gesucht,ist nur die frage welcher ist der beste???
2x2GB Kit Mushkin XP3-12800 CL7 KIT BlackAscent
Danke euch für eure hilfe....
CSX Diablo
kennt das jemand?
Nein, das Problem kenne ich nicht. Aus aktuellem Anlass kann ich dir aber nur "viel Glück" bei der RMA wünschen.
Mach auf jedenfall viele Fotos vorher und lass dir alles schön quittieren.
Wie kommst du eigentlich darauf das dein Board defekt sein muss? Es gibt ja noch 1000 andere Möglichkeiten: RAM defekt, CPU defekt, einfach nur falsche Settings, Spannungen, etc.
@Pit Bull:
Ich würde gerne mal 2GB Riegel sehen, die D9GTR benutzen, die zeigste mir mal bitte...
@brodtwaage:
Ich behaupte jetzt einfach mal, steffel weiß, dass sein Board defekt ist, da es vorher absolut stabil lief und er (hoffentlich) nix geändert hat...;) Aber komisch ist es schon, das stimmt..;)
Christian
Auf den CSX Diablo sind D9GTS ;)
Aber nicht auf 2x2GB Riegeln, das kann ich mir nicht vorstellen und es wird auch nicht so sein...;) Auch wenn zB HPM schreibt, dass die da drauf sind.
Ich habe selber 2x1GB Riegel von Mushkin mit D9GTS Chips drauf und die Riegel sind doppelseitig, von daher..:)
Christian
