[Sammelthread] Asus Rampage Extreme R.o.G. (Intel X48) [2]
[blockquote]
InhaltInhalt des Sammelthreads
Spezifikationen Spezifikationen
CPU
  • LGA 775 socket for:
    - Intel® Core™2 Extreme/Core™2 Quad/ Core™2
  • Supports Intel Enhanced Memory 64 Technology (EMT64T)
  • Supports Enhanced Intel SpeedStep Technology (EIST)
  • Supports Intel Hyper-Threading Technology
  • Supports 1600/1333/1066/800MHz FSB
Intel® chipset
  • Northbridge:
    - Intel® X48 Express chipset
    - Intel® Fast Memory Access technology
  • Southbridge:
    - Intel® ICH9R
Memory
  • 4 x DIMM, Max. 8 GB, DDR3 2000(O.C.)/1800(O.C.)/1600/1333/1066/800
  • ECC,Non-ECC,Un-buffered Memory
  • Dual Channel memory architecture
    *Overclock speed
    - Supports Intel® Extreme Memory Profile (XMP)
    - For the X.M.P. support, CPUs with FSB 1333 or above are recommended
Expansion Slots
  • 2 x PCIe 2.0 x16 , support at full x16, x16 speed
  • 3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 2 x PCI 2.2
BIOS
  • AMI BIOS
  • 16 Mb Flash ROM
  • DMI 2.0
  • PnP
  • WfM 2.0
  • SM BIOS 2.4
  • ACPI 2.0a
  • Multi-language BIOS
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8-channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2
  • Support Teaming Technology
IDE
  • Marvell® 88SE6121 controller
    - 1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
Serial ATA with RAID
  • Southbridge:
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • Silicon Image Sil5723 controller:
    - 2 x SATA 3.0 Gb/s port
    - Supports RAID 0, 1
Rear Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector for two devices
  • 6 x SATA connectors (Blue)
  • 2 x Speeding HDD SATA connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 3 x thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x LCD Poster connector
  • 1 x EL I/O Shield connector
  • 1 x Chassis Intrusion connector
  • 24-pin ATX Power connector
  • 8-pin ATX 12V Power connector
  • 1 x En/Dis-able Clr CMOS slide switch
  • System panel connector
Accessories
  • Fusion Block System Accessory
  • Optional Thermal Kit for NB and MOS
  • DIY Pedestal
  • ASUS Optional Fan
  • External LCD Poster
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • Floppy disk drive cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
Overclocking Features
  • Fusion Block System with optional thermal kit on MOS and NB
  • Extreme Tweaker
  • TweakIt
  • Extreme Engine
    - 16-phase CPU power design
    - 3-phase NB power design
    - 2-phase DDR3 power design
    - ML Caps on CPU, memory and NB respectively
  • Speeding HDD
  • iROG
  • BIOS Flashback
  • Loadline Calibration
  • Intelligent overclocking tools:
    - CPU Level Up
    - Memory Level Up
    - AI Gear 3 + ™
    - ASUS AI Booster Utility
    - O.C Profile
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Special Features
  • Onboard Switches: TweakIt / Power / Reset / Cls CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Form Factor
  • ATX Form Factor
  • 30.5cm x 24.5cm
BilderBilder
Verpackung & Accessoires
Layout
Zusatzkühler für den Betrieb mit Lukü montiert
Bauteile im Detail
Das BiosDas Bios
OC VerhaltenOC Verhalten
Vom Board bereitgestellte Spannungen im Bios:
  • CPU Spannung: 0.85v ~ 2.50v in 0.00625 Volt Schritten
  • CPU PLL Spannung: 1.50v ~ 3.00v in 0.013 Volt Schritten; Standard 1.50 Volt
  • FSB Termination Spannung: 1.10v ~ 2.00v in 0.013 Volt Schritten; Standard 65nm = 1.20 Volt / 45nm = 1.10 Volt
  • DRAM Spannung: 1.50v ~ 2.80v in 0.013 Volt Schritten; Standard 1.50 Volt
  • Northbridge Spannung: 1.25v ~ 2.05v in 0.013 Volt Schritten; Standard 1.25 Volt
  • Southbridge 1.05v Spannung: 1.05v ~ 1.96v in 0.013 Volt Schritten; Standard 1.05 Volt
  • Southbridge 1.50v Spannung: 1.05v ~ 2.05v in 0.013 Volt Schritten; Standard 1.50 Volt
  • NB DDRVref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
  • DDR3 Channel A/B Vref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
Biostemplate für das Extreme Tweaker Menü:
Code:
Ai Overclock Tuner:
OC From CPU Level UP:
OC From Memory Level UP:
FSB Frequency:
CPU Ratio Control:
- CPU Configuration:
- CPU Clock Skew:
- NB Clock Skew:
FSB Strap to North Bridge:
PCI-E Frequency:
DRAM Frequency:
DRAM Command Rate:
DRAM Timing Control:
- CAS# Latency:
- RAS# to CAS# Delay:
- RAS# PRE Time:
- RAS# ACT Time:
- RAS# to RAS# Delay:
- REF Cycle Time:
- Write Recovery Time:
- Read to PRE Time:
- Read to Write Delay(S/D):
- Write to Read Delay(S):
- Write to Read Delay(D):
- Read To Read Delay(S):
- Read To Read Delay(D):
- Write To Write Delay(S):
- Write To Write Delay(D):
- Write to PRE Delay:
- Read to PRE Delay:
DRAM Static Read Control:
DRAM Dynamic Write Control:
DRAM Skew Control:
- DRAM CMD Skew on Channel A/B:
- DRAM CLK Skew on DIMM A1/A2/B1/B2:
- DRAM CTL Skew on DIMM A1/A2/B1/B2:
Ai Clock Twister:
- Ai Clock Skew for Channel A:
- Ai Clock Skew for Channel B:
Ai Transaction Booster:
- Common Performance Level:
- Pull-In of CHA PH1:
- Pull-In of CHA PH2:
- Pull-In of CHA PH3:
- Pull-In of CHA PH4:
- Pull-In of CHA PH5:
- Pull-In of CHB PH1:
- Pull-In of CHB PH2:
- Pull-In of CHB PH3:
- Pull-In of CHB PH4:
- Pull-In of CHB PH5:
EPU II Phase Control:
CPU Voltage:
Load-Line Calibration:
CPU PLL Voltage:
FSB Termination Voltage:
- CPU GTLVref (0):
- CPU GTLVref (1):
- CPU GTLVref (2):
- CPU GTLVref (3):
North Bridge Voltage:
DRAM Voltage:
- NB DDRVref:
- DDR3 ChannelA Vref:
- DDR3 ChannelB Vref:
South Bridge 1.5 Voltage:
South Bridge 1.05 Voltage:
CPU Spread Spectrum:
PCIE Spread Spectrum:
Ein paar OC Ergebnisse von OnePageBook (OCX)
500FSB Everest & Orthos:
600FSB Everest & Orthos:
Speicher KompatibilitätslisteSpeicher Kompatibilitätsliste
2x1024MB Kits
  • 2x1GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x1GB Kit OCZ Intel Extreme PC3-12800
  • 2x1GB Kit Patriot Viper PC3-12800
  • 2x1GB Kit Patriot Viper PC3-14400
  • 2x1GB Kit Patriot Viper PC3-15000 (Micron D9GTR)
  • 2x1GB Kit TeamGroup Xtreem PC3-12800 (Micron D9GTR)
2x2048MB Kits
  • 2x2GB Kit Adata XSeries PC3-12800
  • 2x2GB Kit Chaintech APOGEE GT Blazer PC3-14400
  • 2x2GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x2GB Kit OCZ Intel Extreme PC3-12800
Passende Kühler (Lukü)Passende CPU Kühler (Lukü)
Luftkühler:
  • Zalman CNPS 9500 AT
FAQFAQ
F: Wie funktionieren die GTL Einstellungen?
A: Beim Rampage Extreme funktioniert dies über einen festen GTL Multi und einer justierbaren Spannung (-155mV bis +155mV).
Die festen Multis sehen wie folgt aus:
  • CPU 0 = 0.635
  • CPU 1 = 0.67
  • CPU 2 = 0.635
  • CPU 3 = 0.67
Die GTL Voltage wird so eingestellt / berechnet:
  • VTT (FSB Spannung) x GTL Multi +/- xxx mV = GTL Spannung
  • 1.16v (VTT) x 0.635 (Multi) - 25mV (Spannung) = 0.7116v
F: Ist mein altes Backplate noch ohne weiteres nutzbar?
A: Aufgrund des zusätzlichen Fujitsu Chips auf der Rückseite des Sockels kann man nicht ohne weiteres jedes Backplate
nutzen oder man muss es bearbeiten. Für diejenigen die sich lieber ein passendes Kaufen weil sie nicht die möglichkeit
haben es zu bearbeiten hat der User "Navigator1" ein passendes rausgesucht, hier der Link zu dem passenden Post
DownloadsDownloads
Bios Downloads (Flashen auf eigene Gefahr!)
Treiber & restliche Downloads
[/blockquote]
Hi Ihr Alle!!
Melde mich mal wieder, mein Windoof Vista war total unbrauchbar konnte nicht mehr voll
booten. War ein Datenmissmatch.
Sämtliche Platten formatiert und system neu aufgespielt, jetzt lüppts wieder!!
Ist eine NB Temp von bis zu 48°C und eine SB Temp von bis zu 44°C im normal betrieb "NORMAL" ???
Gibt es alternativ NB Kühler die passen würden???
lg
lg
hi scorpi,
jo is normal aber nen alt nb cooler kenn ich keinen ähm...coole mit air.
cu webbie ;)
MoinMoin
hmm ok ich, wenn es noch "NORMAL" ist:)
Hast du eigentlich den gleich Speicher wie ich, siehe SIG?!?
lg
hallo, ein Kumpel hat das Board mit nem q9550 übertaktet und hatte vorher ne 4870 und alles lief einwandfrei, nun hat er 2 4890 im CF und nach ca 1 stunden zocken bleibt der rechner stehen, kein bluescreen und auch unter win kein fehlermeldung nach neustart...
ich habe mal einfach die NB vermutet, da die ja jetzt mit 2 karten arbeiten muss und eben der OC CPU
oder an was könnte es sonst liegen bzw hatte jemand ähnliches problem??
danke
BIOS Konfig
Hallo erstmal an euch ;)
Nach langem rumprobieren hab ich jetzt meinen Rechner stabil am laufen.
Ich würde euch bitten meine Einstellungen mal anzuschaun, weil ich mit den Termperaturen noch nicht so ganz zu frieden bin.
Ich denk mal die ein oder andere Spannung kann ich noch runtersetzen.
Danke schon mal für jeden Verbesserungsvorschlag
Kurze info über mein System:
Asus Rampage Extreme Bios 1202
Q9550
2*2GB OCZ ReeperX 1333 DDR3
Crossfire 4890 PCS+
Ai Overclock Tuner: Manual
OC From CPU Level Up: Auto
OC From Memory Level Up: Auto
FSB Frequency: 475
CPU Ratio Setting: 8.5
CPU Configuration
CPU Ratio Setting 8.5
C1E Support: Disabled
CPU TM Function: Disabled
Max CPUID Value Limit: Disabled
Vanderpool Technology: Enabled
Execute Disable Bit: Enabled
Core Multi-Processing: Enabled
CPU Clock Skew: Normal
NB Clock Skew: Normal
FSB Strap to North Bridge: 266
PCIE Frequency: 101
DRAM Frequency: 1429 Mhz
DRAM Command Rate: 1N
DRAM Timing Control: Manual
1st Information.
CAS# Latency: 6
RAS# to CAS# Delay: 6
RAS# Pre Time: 6
RAS# ACT Time: 20
RAS# To RAS# Delay: Auto
REF Cycle Time: Auto
WRITE Recovery Time: Auto
READ to Pre Time: Auto
2nd Information:
READ to WRITE Delay (S/D): Auto
WRITE to READ Delay (S): Auto
WRITE to READ Delay (D): Auto
READ to READ (S): Auto
READ to READ (D): Auto
WRITE to WRITE (S): Auto
WRITE to WRITE (D): Auto
3rd Information:
WRITE to PRE Delay: Auto
READ to PRE Delay: Auto
PRE to PRE Delay: Auto
ALL PRE to ACT Delay: Auto
ALL PRE to REF Delay: Auto
DRAM Static Read Control: Disabled
DRAM Dynamic Write Control: Disabled
DRAM Skew Control
DRAM CMD Skew on Channel A: Auto
DRAM CLK Skew on DIMM A1: Auto
DRAM CLK Skew on DIMM A2: Auto
DRAM CTL Skew on DIMM A1: Auto
DRAM CTL Skew on DIMM A2: Auto
DRAM CMD Skew on Channel B: Auto
DRAM CLK Skew on DIMM B1: Auto
DRAM CLK Skew on DIMM B2: Auto
DRAM CTL Skew on DIMM B1: Auto
DRAM CTL Skew on DIMM B2: Auto
Ai Clock Twister: Ligther
Ai Transaction Booster: Auto
EPU II Phase Control: Full Phase
CPU Voltage: 1.31875
Load-Line Calibration: Enabled
CPU PLL Voltage: 1.51106
FSB Termination Voltage: 1.31216
CPU GTLVerf (0): Auto
CPU GTLVerf (1): Auto
CPU GTLVerf (2): Auto
CPU GTLVerf (3): Auto
NB GTLVerf: +50mV
North Bridge Voltage: 1.60372
DRAM Voltage: 1.88206
NB DDRVref: +100mV
DDR3 ChannelA Vref: +50mV
DDR3 ChannelB Vref: +50mV
South Bridge 1.5 Voltage: 1.52431
South Bridge 1.05 Voltage: 1.07364
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
MoinMoin
lg
hi,
ich hab 2x2 gb ocx intel extreme pc3 1600 mhz und 2x2 gb xtune pc3 1866 mhz also vollbestückung.
bin damit sehr zufrieden laufen sogar mit mischmasch und 1800 mhz.
gruss
webbie
moin yunx.
ich wollt mir ma nen input abholen bei euch bzgl eures boards.
ich kann leider keinen oc beitrag finden der auf nem quadcore beruht. ich wollt nen q9550 drauf laufen lassen und ma hören wie das oc verhalten vom board so ist.
laufen diese rams drauf?
und passt der kühler drauf?
danke für eure antworten. falls es doch nen quad oc beitrag geibt immer her damit :d
Hello. Habe mir heute zum 3D Benchen dieses Board geholt. Nun meine Frage ob es ein paar wichtige Dinge gibt die man bei diesem Board unbedingt beachten sollte? Also spezielle Einstellungen die viel Sinn machen usw... Ich will damit nur benchen und ocen also muss nix primestable sein. Gekühlt wird mit Singlestage und zwar ein E8600. Ev habt ihr halt ein paar Tips die einem das Leben etwas leichter machen (welches Bios am schnellsten und besten ist usw....)
moin yunx.
Ich hatte bis ich das Board abgegeben habe einen Q9550 mit 471x8,5=4 GHz laufen. War absolut rockstable, NB braucht aber ziemlich Zunder. Ansonsten ist das Board echt zickig. Der RAM sollte eigentlich laufen (meine ich schon mal gelesen zu haben - bin mir aber nicht 1000% sicher!) aber 2000 MHz Ramtakt wirst du kaum erreichen. Ist sehr schwer. Wenn nicht unmöglich.
Ich habe knapp 1600 MHz Ramtakt gefahren mit 1600er Reapern und 1T - Ram Performance war OK, aber nicht überragend. Richtig gute Speicher könnten sich hier aber bezahlt machen.
Ansonsten stell ne spezielle Frage, dann kann ich dir vielleicht ne Antwort geben.
danke das schonmal hilfreich genug.
das der ram nich auf 2000mhz läuft war mir klar ... ich hab halt nen 2000er gekauft weil der gleiche ram mit meinem qx9650 auf nem S2E auf 1850mhz sync perfekt läuft. und 1880sync sollten ja auf dem rampage extreme auch gehen.
der noctua passt auch drauf. das weiss ich schonmal :d
falls ich sonst noch fragen hab meld ich mich dann ^^
Was habt ihr mit dem Board für Temps unter Wakü beim Chipsatz? Bitte nur Leute ohne zusätzliche Lüfter im Bereich der NB schreiben.
ich hatte immer so rund 60 Grad...die Heatpipe saß wohl aber auch nicht gut und ich habe nichts daran gemacht.
Geiles Phänomen heute gehabt. Habe 2 komplett verschiedene Einstellungen durchprobiert und lustige Ergebnisse erzielt. Kühlung ist SS
525Mhz 32M stable und 530Mhz nichtmal 1M stable
Ai Overclock Tuner: manual
OC From CPU Level UP: Auto
OC From Memory Level UP: Auto
FSB Frequency: 500
CPU Ratio Control: 10
- CPU Configuration
- CPU Clock Skew: 500ps
- NB Clock Skew: 200ps
FSB Strap to North Bridge: 400
PCI-E Frequency: 102
DRAM Frequency: 1333
DRAM Command Rate: auto
- CAS# Latency: 7
- RAS# to CAS# Delay: 7
- RAS# PRE Time: 7
- RAS# ACT Time: 24
Ai Transaction Booster: manual
- Common Performance Level: 11
- Pull-In of CHA PH1: disabled
- Pull-In of CHA PH2: disabled
- Pull-In of CHB PH1: disabled
- Pull-In of CHB PH2: disabled
EPU II Phase Control: full phase
CPU Voltage: 1,64375v
Load-Line Calibration: disabled
CPU PLL Voltage: 1,51106v
FSB Termination Voltage: 1,27241v
- CPU GTLVref (0): Auto
- CPU GTLVref (1): -50mV
- CPU GTLVref (2): Auto
- CPU GTLVref (3): -50mV
North Bridge Voltage: 1,44472v
DRAM Voltage: 2.06756v
- NB DDRVref: Auto
- DDR3 ChannelA Vref: Auto
- DDR3 ChannelB Vref: Auto
South Bridge 1.5 Voltage: 1,51106
South Bridge 1.05 Voltage: 1,06039
Rest alles auf Auto
Und die Zweiten Einstellungen waren bis 535Mhz SuperPi stable
FSB Frequency: 500
- CPU Configuration
- CPU Clock Skew: auto
- NB Clock Skew: auto
PCI-E Frequency: 100
DRAM Frequency: 1500
- CAS# Latency: 7
- RAS# PRE Time: 7
- RAS# ACT Time: 24
CPU Voltage: 1,6v
CPU PLL Voltage: 1,56406v
FSB Termination Voltage: 1,36516v
North Bridge Voltage: 1,60372v
DRAM Voltage: 2.00131v
- NB DDRVref: Auto
South Bridge 1.05 Voltage: 1,07364
Somit sollte mein Ziel sein mit den Spannungen der ersten Einstellung mein Ziel von 5,45Ghz Benchstable zu erreichen sein. Ich weiss dass diese CPU auf einem DFI P45 Board 5,6Ghz SuperPi und 5,4 GHZ 3D Benchstable macht. Somit hoffe ich doch dass ich sie hier auf die 5,4GHZ 3D stable bekomme. Ist ein E8600er und Super Talent Project X 1800er.
Da ich mit beiden Einstellungen annähernd am gleichen Wert hängen bleibe habt ihr vielleicht einen Tip für mich den ich dabei übersehen haben könnte.
Habe jetzt noch ausgetestet dass mit diesen Einstellungen und niedrigerem Multi auch mehr als 560Mhz FSB gehen aber sobald ich Multi 10 reinschmeisse steigt das Board bei 535MHz FSB aus.
ich habe da mal ne frage: weiß jemand, ob man die SupremeFX X-Fi Audio Card vom maximus 2 formula auf dem rampage formula verwenden kann? ich habe ja die SupremeFX 2 verbaut. nun habe ich die x-fi karte hier im pc, und bekomme den treiber nicht installiert.
weiß da jemand rat, oder kann mich auf ne seite verlinken, die da mehr wissen?
Also die Karte das Ramapage geht auf alle Fälle nicht in einem P5Q Pro. Denke mal in allen ROG Boards sollte sie funktionieren, allerdings ohne Gewähr.
das problem ist nur, das ich den treiber für die supremefx x-fi nicht installiert bekomme. bekomme immer die meldung, das die software für die hardware nicht installiert werden kann. die karte wird aber in everest richtig angezeigt, auch unter hardwaremanager.
ich habe win xp home 32bit.
daher war ja meine frage, ob das überhaubt funktioniert, das ich die x.fi auf meinem rampage formula betreiben kann. ich habe ja auch den extra steckplatz dafür. da ist ja auch meine supremefx2 drin.
Hallo Leute,
versuche seit wochen mein rechner stabiel zu bekommen,ohne erfolg...
Habe die Hoffnung das ihr mir helfen könnt.
Haubt Problem scheint mein Speicher zu sein,fsb bekomme ich bei 550fsb und höher stabiel.aber sobalt ich denn Ram(csx diablo 2000 2x2gb ins spiel bringe wars das mit stabiel..
was mache ich falsch?....
Mfg
Meine einstellungen:
Ai Overclock Tuner: Auto
FSB Frequency: 563
CPU Ratio Control: 6
- CPU Clock Skew: Auto
- NB Clock Skew: Auto
FSB Strap to North Bridge: 333
DRAM Frequency: 1802
DRAM Command Rate: 2N
- CAS# Latency: 8
- RAS# to CAS# Delay: 8
- RAS# PRE Time: 8
- RAS# ACT Time: 24
- RAS# to RAS# Delay: Auto
- REF Cycle Time: Auto
- Write Recovery Time: Auto
- Read to PRE Time: Auto
- Read to Write Delay(S/D): Auto
- Write to Read Delay(S): Auto
- Write to Read Delay(D): Auto
- Read To Read Delay(S): Auto
- Read To Read Delay(D): Auto
- Write To Write Delay(S): Auto
- Write To Write Delay(D): Auto
- Write to PRE Delay: Auto
- Read to PRE Delay: Auto
DRAM Static Read Control: Auto
DRAM Dynamic Write Control: Auto
DRAM Skew Control: Auto
- DRAM CMD Skew on Channel A/B: Auto
- DRAM CLK Skew on DIMM A1/A2/B1/B2: Auto
- DRAM CTL Skew on DIMM A1/A2/B1/B2: Auto
Ai Clock Twister:
- Ai Clock Skew for Channel A: Auto
- Ai Clock Skew for Channel B: Auto
- Common Performance Level: Auto
- Pull-In of CHA PH1: Auto
- Pull-In of CHA PH2: Auto
- Pull-In of CHA PH3: Auto
- Pull-In of CHA PH4: Auto
- Pull-In of CHA PH5: Auto
- Pull-In of CHB PH1: Auto
- Pull-In of CHB PH2: Auto
- Pull-In of CHB PH3: Auto
- Pull-In of CHB PH4: Auto
- Pull-In of CHB PH5: Auto
CPU Voltage: 1,22500
Load-Line Calibration: Aktiviert
FSB Termination Voltage: 1,49v
- CPU GTLVref (1): Auto
- CPU GTLVref (3): Auto
North Bridge Voltage: 1,70972v
- NB DDRVref: Auto
South Bridge 1.5 Voltage: Auto
South Bridge 1.05 Voltage: Auto
CPU Spread Spectrum: Auto
PCIE Spread Spectrum: Auto
PS:Habe CPU,NB mit Wakü...
Bei den Einstellungen stellt es mir die Haare auf, egal welche CPU da auf dem Board hast!
- Multi 6 läuft nie richtig, also mindestens 7!
- Ram läuft auf dem Board ohne Probleme in 1T!
- FSB Termination viel zu hoch, das deine CPU noch läuft wundert mich. Ich habe selbst bei 6,3Ghz unter LN2 nur 1,37 gebraucht!
- Von Rampage zu Rampage verschieden, meine NB skaliert mit Spannung und mit den 1,7V habe ich 630Mhz FSB geschafft!
- Eventuell ist der 333 Strap nichts, mal 400 testen!
Die 3,3 Ghz sollte das Board mit E8600 bei allen Einstellungen auf Auto machen!
Erstmal informieren! Hauptsache Spannungen drauf ohne Ende, das dann eher kontraproduktiv, nur verstehen das viele Leute einfach nicht!
Hy Andy :wink:
da kann ich dir nur zustimmen :d Ausser bei der VTT.... ich hab hier einen liegen der braucht für 6,6 mind. 1,51 VTT das er rund läuft :fresse: is aber eher die Ausnahme :d
Servus Peter,
du musst bedenken, er kühlt nur mit Wasser und nicht LN2 ;)
Es liegt auch nur Standardtaktung an :d
ja ich wollt halt auch was dazu sagen.... :d Hast recht :d
die NB is VIEL zu hoch angesetzt.... bei dem FSB reicht locker 1,56
der VTT müsste theroretisch auf 1,34 reichen.... das is alles viel zu hoch junge... das kann nicht stabil sein
Der Batch seiner CPU wäre noch interessant! Es kann auch sein, das er ein Rampage hat, das mit 1,4V die 600Mhz macht. Ich hab 1,6V für 600 gebraucht, also können deine 1,56V hingekommen bzw unsere Boards sind ähnlich.
VTT reicht wahrscheinlich sogar 1,3V, aber er muss es halt sinnvoll testen.
Der Batch meiner cpu ist Q822A825....
habe es mal mit denn einstellungen versucht die mir nahe gelegt würden,
fährt nicht hoch.
Mein Ziel ist es die Cpu und denn Ram so hoch wie möglich für denn altäglichen gebrauch zu takten...
