[Sammelthread] Asus Rampage Extreme R.o.G. (Intel X48) [2]
[blockquote]
InhaltInhalt des Sammelthreads
Spezifikationen Spezifikationen
CPU
  • LGA 775 socket for:
    - Intel® Core™2 Extreme/Core™2 Quad/ Core™2
  • Supports Intel Enhanced Memory 64 Technology (EMT64T)
  • Supports Enhanced Intel SpeedStep Technology (EIST)
  • Supports Intel Hyper-Threading Technology
  • Supports 1600/1333/1066/800MHz FSB
Intel® chipset
  • Northbridge:
    - Intel® X48 Express chipset
    - Intel® Fast Memory Access technology
  • Southbridge:
    - Intel® ICH9R
Memory
  • 4 x DIMM, Max. 8 GB, DDR3 2000(O.C.)/1800(O.C.)/1600/1333/1066/800
  • ECC,Non-ECC,Un-buffered Memory
  • Dual Channel memory architecture
    *Overclock speed
    - Supports Intel® Extreme Memory Profile (XMP)
    - For the X.M.P. support, CPUs with FSB 1333 or above are recommended
Expansion Slots
  • 2 x PCIe 2.0 x16 , support at full x16, x16 speed
  • 3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 2 x PCI 2.2
BIOS
  • AMI BIOS
  • 16 Mb Flash ROM
  • DMI 2.0
  • PnP
  • WfM 2.0
  • SM BIOS 2.4
  • ACPI 2.0a
  • Multi-language BIOS
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8-channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2
  • Support Teaming Technology
IDE
  • Marvell® 88SE6121 controller
    - 1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
Serial ATA with RAID
  • Southbridge:
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • Silicon Image Sil5723 controller:
    - 2 x SATA 3.0 Gb/s port
    - Supports RAID 0, 1
Rear Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector for two devices
  • 6 x SATA connectors (Blue)
  • 2 x Speeding HDD SATA connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 3 x thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x LCD Poster connector
  • 1 x EL I/O Shield connector
  • 1 x Chassis Intrusion connector
  • 24-pin ATX Power connector
  • 8-pin ATX 12V Power connector
  • 1 x En/Dis-able Clr CMOS slide switch
  • System panel connector
Accessories
  • Fusion Block System Accessory
  • Optional Thermal Kit for NB and MOS
  • DIY Pedestal
  • ASUS Optional Fan
  • External LCD Poster
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • Floppy disk drive cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
Overclocking Features
  • Fusion Block System with optional thermal kit on MOS and NB
  • Extreme Tweaker
  • TweakIt
  • Extreme Engine
    - 16-phase CPU power design
    - 3-phase NB power design
    - 2-phase DDR3 power design
    - ML Caps on CPU, memory and NB respectively
  • Speeding HDD
  • iROG
  • BIOS Flashback
  • Loadline Calibration
  • Intelligent overclocking tools:
    - CPU Level Up
    - Memory Level Up
    - AI Gear 3 + ™
    - ASUS AI Booster Utility
    - O.C Profile
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Special Features
  • Onboard Switches: TweakIt / Power / Reset / Cls CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Form Factor
  • ATX Form Factor
  • 30.5cm x 24.5cm
BilderBilder
Verpackung & Accessoires
Layout
Zusatzkühler für den Betrieb mit Lukü montiert
Bauteile im Detail
Das BiosDas Bios
OC VerhaltenOC Verhalten
Vom Board bereitgestellte Spannungen im Bios:
  • CPU Spannung: 0.85v ~ 2.50v in 0.00625 Volt Schritten
  • CPU PLL Spannung: 1.50v ~ 3.00v in 0.013 Volt Schritten; Standard 1.50 Volt
  • FSB Termination Spannung: 1.10v ~ 2.00v in 0.013 Volt Schritten; Standard 65nm = 1.20 Volt / 45nm = 1.10 Volt
  • DRAM Spannung: 1.50v ~ 2.80v in 0.013 Volt Schritten; Standard 1.50 Volt
  • Northbridge Spannung: 1.25v ~ 2.05v in 0.013 Volt Schritten; Standard 1.25 Volt
  • Southbridge 1.05v Spannung: 1.05v ~ 1.96v in 0.013 Volt Schritten; Standard 1.05 Volt
  • Southbridge 1.50v Spannung: 1.05v ~ 2.05v in 0.013 Volt Schritten; Standard 1.50 Volt
  • NB DDRVref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
  • DDR3 Channel A/B Vref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
Biostemplate für das Extreme Tweaker Menü:
Code:
Ai Overclock Tuner:
OC From CPU Level UP:
OC From Memory Level UP:
FSB Frequency:
CPU Ratio Control:
- CPU Configuration:
- CPU Clock Skew:
- NB Clock Skew:
FSB Strap to North Bridge:
PCI-E Frequency:
DRAM Frequency:
DRAM Command Rate:
DRAM Timing Control:
- CAS# Latency:
- RAS# to CAS# Delay:
- RAS# PRE Time:
- RAS# ACT Time:
- RAS# to RAS# Delay:
- REF Cycle Time:
- Write Recovery Time:
- Read to PRE Time:
- Read to Write Delay(S/D):
- Write to Read Delay(S):
- Write to Read Delay(D):
- Read To Read Delay(S):
- Read To Read Delay(D):
- Write To Write Delay(S):
- Write To Write Delay(D):
- Write to PRE Delay:
- Read to PRE Delay:
DRAM Static Read Control:
DRAM Dynamic Write Control:
DRAM Skew Control:
- DRAM CMD Skew on Channel A/B:
- DRAM CLK Skew on DIMM A1/A2/B1/B2:
- DRAM CTL Skew on DIMM A1/A2/B1/B2:
Ai Clock Twister:
- Ai Clock Skew for Channel A:
- Ai Clock Skew for Channel B:
Ai Transaction Booster:
- Common Performance Level:
- Pull-In of CHA PH1:
- Pull-In of CHA PH2:
- Pull-In of CHA PH3:
- Pull-In of CHA PH4:
- Pull-In of CHA PH5:
- Pull-In of CHB PH1:
- Pull-In of CHB PH2:
- Pull-In of CHB PH3:
- Pull-In of CHB PH4:
- Pull-In of CHB PH5:
EPU II Phase Control:
CPU Voltage:
Load-Line Calibration:
CPU PLL Voltage:
FSB Termination Voltage:
- CPU GTLVref (0):
- CPU GTLVref (1):
- CPU GTLVref (2):
- CPU GTLVref (3):
North Bridge Voltage:
DRAM Voltage:
- NB DDRVref:
- DDR3 ChannelA Vref:
- DDR3 ChannelB Vref:
South Bridge 1.5 Voltage:
South Bridge 1.05 Voltage:
CPU Spread Spectrum:
PCIE Spread Spectrum:
Ein paar OC Ergebnisse von OnePageBook (OCX)
500FSB Everest & Orthos:
600FSB Everest & Orthos:
Speicher KompatibilitätslisteSpeicher Kompatibilitätsliste
2x1024MB Kits
  • 2x1GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x1GB Kit OCZ Intel Extreme PC3-12800
  • 2x1GB Kit Patriot Viper PC3-12800
  • 2x1GB Kit Patriot Viper PC3-14400
  • 2x1GB Kit Patriot Viper PC3-15000 (Micron D9GTR)
  • 2x1GB Kit TeamGroup Xtreem PC3-12800 (Micron D9GTR)
2x2048MB Kits
  • 2x2GB Kit Adata XSeries PC3-12800
  • 2x2GB Kit Chaintech APOGEE GT Blazer PC3-14400
  • 2x2GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x2GB Kit OCZ Intel Extreme PC3-12800
Passende Kühler (Lukü)Passende CPU Kühler (Lukü)
Luftkühler:
  • Zalman CNPS 9500 AT
FAQFAQ
F: Wie funktionieren die GTL Einstellungen?
A: Beim Rampage Extreme funktioniert dies über einen festen GTL Multi und einer justierbaren Spannung (-155mV bis +155mV).
Die festen Multis sehen wie folgt aus:
  • CPU 0 = 0.635
  • CPU 1 = 0.67
  • CPU 2 = 0.635
  • CPU 3 = 0.67
Die GTL Voltage wird so eingestellt / berechnet:
  • VTT (FSB Spannung) x GTL Multi +/- xxx mV = GTL Spannung
  • 1.16v (VTT) x 0.635 (Multi) - 25mV (Spannung) = 0.7116v
F: Ist mein altes Backplate noch ohne weiteres nutzbar?
A: Aufgrund des zusätzlichen Fujitsu Chips auf der Rückseite des Sockels kann man nicht ohne weiteres jedes Backplate
nutzen oder man muss es bearbeiten. Für diejenigen die sich lieber ein passendes Kaufen weil sie nicht die möglichkeit
haben es zu bearbeiten hat der User "Navigator1" ein passendes rausgesucht, hier der Link zu dem passenden Post
DownloadsDownloads
Bios Downloads (Flashen auf eigene Gefahr!)
Treiber & restliche Downloads
[/blockquote]
Weiss jemand ob auf das Board ein Megahalems mit 2 Lüftern ohne Probleme passt ?
kann mir mal einer sagen wie es um das board mit dem q9550 steht? sprich ich möchte gern oc und es gibt kaum noch p45 boards. nun da springt das rampage extreme ins auge. nur is die frage krieg ich hiermit mit nem 45nm quad auch meine 500fsb hin?
Hallo zusammen,
hab seid kurzem auch das Rampage Extreme und versuch gerade meinen Q9650 auf 4 GHz zu taken. Meine genaue Ausstatung siehe Signatur.
Also 3,6 GHz hab ich mittlerweile stabil. Nach langem herumprobieren und mehreren abstürzen hab ich festgestellt das es reicht den FSB auf 400 zu stellen den RAM auf 1600 und die Timings Manuel 9-9-9-24. Die Spannung des CPU hab ich auf 1,2250 gestellt, das ist die Standard VID meiner CPU und der rest läuft auf default Settings. Seid dem keine Probleme.
Die 4 bekomm ich einfach nicht hin. Prime stoppt entweder sofort die ersten beiden Kerne oder innerhalb von 5 Minuten. Vllt. kann mir ja einer helfen, kenn mich jetzt auch nicht so gut damit aus.
Mfg
Red1982
@ Red1982
Poste mal dein Template hier.
Ein funktionierendes für den Quad bekommst du unten.
Benutzung auf eigene Gefahr. Ich übernehme keine Haftung für Schäden
Code:
Rampage Extreme 1202 Bios Template
Extreme Tweaker
Ai Overclock Tuner           [Manual]
OC From Memory Level Up      [Auto]
FSB Frequency                [450]
CPU Ratio Setting            [9]
> CPU configuration
C1E Support                  [Disabled]
CpU TM Function              [Enabled]
Max CPUID Value Limit        [Disabled]
Vanderpool Technology        [Enabled]
Execute Disable Bit          [Enabled]
Core MultiPprocessing        [Enabled]
* CPU clock skew             [Delay 300ps]
* NB clock skew              [Delay 100ps]
FSB Strap to North Bridge    [400]
PCIE Frequency               [100]
DRAM Frequency               [1800] hier event. weniger testen
DRAM Command Rate            [2N]
DRAM Timing Control          [Manual]
1st information
CAS# Latency                 [9]
RAS# to CAS# Delay           [9]
RAS# PRE Time                [9]
RAS# ACT Time                [24]
RAS# to RAS# Delay           [Auto]
REF Cycle Time               [Auto]
WRITE Recovery Time          [Auto]
READ to PRE Time             [Auto]
2nd information
READ to WRITE Delay(S/D)     [Auto]
WRITE to READ Delay(S)       [Auto]
WRITE to READ Delay(D)       [Auto]
READ to READ Delay(S)        [Auto]
READ to READ Delay(D)        [Auto]
WRITE to WRITE Delay(S)      [Auto]
WRITE to WRITE Delay(D)      [Auto]
3rd information
WRITE to PRE Delay           [Auto]
READ to PRE Delay            [Auto]
PRE to PRE Delay             [Auto]
ALL PRE to ACT Delay         [Auto]
ALL PRE to REF Delay         [Auto]
DRAM Static Read Control     [Disabled]
DRAM Dynamic Write Control   [Disabled]
> DRAM Skew Control :
DRAM CMD Skew on Channel A   [Auto]
DRAM CLK Skew on DIMM A1     [Auto]
DRAM CLK Skew on DIMM A2     [Auto]
DRAM CTL Skew on DIMM A1     [Auto]
DRAM CLT Skew on DIMM A2     [Auto]
DRAM CMD Skew on Channel B   [Auto]
DRAM CLK Skew on DIMM B1     [Auto]
DRAM CLK Skew on DIMM B2     [Auto]
DRAM CTL Skew on DIMM B1     [Auto]
DRAM CTL Skew on DIMM B2     [Auto]
Ai Clock Twister             [Moderate]
Ai Transaction Booster       [Manual]
(-- Manual --)
Common Performance Level     [10]
Pull in of CHA PH1           [Disabled]
Pull in of CHA PH2           [Disabled]
Pull in of CHB PH1           [Disabled]
Pull in of CHB PH2           [Disabled]
(-- Manual --)
EPU II Phase Control         [Auto]
*** Please key in numbers or select voltage!***
CPU Voltage                  [1.35] 1.36250 beim Q9650 für 24/7 und 1.45 max
Load-Line Calibration        [Auto]
CPU PLL Voltage              [1.51106]
FSB Termination Voltage   [1.31] 1.35 beim Q9650 für 24/7 und 1.45 max
CPU GTLVref(0)               [+60mV]
CPU GTLVref(1)               [+50mV]
CPU GTLVref(2)               [+60mV]
CPU GTLVref(3)               [+50mV]
NB GTLVref                   [+60mV]
North Bridge Voltage         [1.51]
DRAM Voltage                 [1.85] bis max
NB DDRVref                   [Auto]
DDR3 Channel A Vref          [Auto]
DDR3 Channel B Vref          [Auto]
South Bridge 1.5 Voltage     [1.51106]
South Bridge 1.05 Voltage    [1.06039]
CPU Spread Spectrum          [Disabled]
PCIE Spread Spectrum         [Disabled]
Hab ja nicht so viel verändert. Wie gesagt
DRAM Frequency [1600]
CAS# Latency [9]
RAS# PRE Time [9]
RAS# ACT Time [24]
CPU Voltage [1.2250]
FSB Frequency [400]
CpU TM Function [Disabled]
Die Settings die du gepostet hast laufen schon mal leider nicht. Der Ram ist übrigens low volage und sollte laut Angaben der Herstellers bei 1,65 V auf 2000 8-8-8-24 laufen.
Dann teste mal mit dem niedrigsten Multi [6] deinen max FSB.
Kurzzeitig kannst du dabei auch max Spannungen fahren.
Damit sieht man zunächst mal, was die CPU schafft.
Zum RAM kann ich nicht viel sagen wie dass ich den nicht auf dem Board fahren würde.
2 x 2 und Quad oc ist schon so eine Sache, wenn aber 2 x 2 dann den CSX Diablo mit Micron D9GTR und nicht einen Low Voltage, der gar nicht für das Board vorgesehen ist....
Der Diablo 2 x 2 macht wenigstens 1700MHz 7-7-7-21 2.00V (command rate: 1T) auf dem X 48....
Mein 2 x 1 sogar über 2000 Mhz...
Und einen G0 SLB8W kenne ich nicht, nur einen E0. ;)
Mhhh das natürlich blöd bin noch in der 2 Wochen rückgabe frist
4096MB OCZ PC3-16000 CL8 KIT FlexEX
Was denn mit dem? Das der einzigste den die in dem laden haben der nicht low voltage ist.
Sieht schon besser aus, (OCZ ist eine gute Marke), der RAM sollte zu 95% auf dem Board laufen, hat wenn ich recht weiß Samsung HCF0 Chips drauf, die den Microns nicht so extrem weit nachstehen und ist zumindest für 2000 Mhz bei 2.0 V zertifiziert, was aber nicht heißt, dass er das auch auf dem Board macht.
Aber mit etwas Feintuning sollten mit dem Quad 450 - 465 FSB mit Multi 9 machbar sein und dabei 1800 - 1860 Mhz RAM Takt.
Dabei rede ich von Prime Stable und nicht reines oc.
Dann werd ich wohl Montag zum laden und umtauschen gehen. Hatte gerade noch mal getestet mit nem 4GB kit von OZC aber nur 1333 Reaper X Headpipe oder so... . Lief auch nicht stabil.
Bei 2 RAM Riegel nicht vergessen sie in A2 und B2 zu fahren, also die weißen RAM Bänke. ;)
Dann mach das mit dem RAM Tausch am Montag, dann sehen wir weiter bzw. heizen dem Quad kräftig ein, nicht für umsonst ist das Rampage Extreme das Board DESIGNED FOR OVERCLOCKING. :bigok:
Erneute Weltrekorde mit dem Rampage Extreme und einem selektierten Intel e8600 aufgestellt von Weltklasse Overclocker stummerwinter im 3DM03 mit Singlekarte und Multikarte (CF).
Dabei lief der e8600 mit 6500 Mhz durch die Benches.
3DMark03 Singlekarte: 160740 Punkte
3DMark03 Multikarte (CF): 197074 Punkte
Dabei gebe ich gerne folgendes Zitat aus dem Link wieder
Dies beweist, dass der schon etwas betagte Sockel 775 trotzdem noch für den ein oder anderen Weltrekord gut ist.
http://www.awardfabrik.de/awardfabr...merwinter-holt-2-neue-weltrekorde-im-3dm.html
Weiter so stuwi. :hail:
Rampage Extreme + stummerwinter --> rules :banana:
kannst du dir mal kurz die heatpipes beider boards anschauen, da sind doch nur verschiedene sticker drauf oder nicht? also für mich schauen sid oberflächlich identisch aus,auch die fugen etc sind bei beiden identisch auf dem großen block bei der sb
hab mir gerade nen qx 9770 bestellt (350€) hrhr.
Hat jemand oc erfahrung mit dem prozzi und dem board? alles details zu meiner hardware siehe unten. (achtung hab 8 gb Speicher drin.) Board und prozzi haben wakü wasser temp ist ca 28° bei 23° zimmer temp. momentane prozzi temp ist 50° unter volllast board um die 40° aber eben alles Zimmertemperatur abhängig.
also jemand da mit oc erfahrung bei der menge speicher dem board und dem prozzi?
@ opa.oi
Probier mal das hier im Template für den QX9770, beim Preis gibts nichts zu meckern, hat mal gut über 1300,-- € gekostet, wenn du jetzt noch ne gute Batch erwischt hast......
Einstellungen wie immer auf eigene Gefahr, übernehme keinerlei Haftung für Schäden. ;)
http://www.heise.de/preisvergleich/a300710.html
Code:
Extreme Tweaker
FSB Frequency                [450]
> CPU configuration
1st information
CAS# Latency                 [9]
RAS# PRE Time                [9]
RAS# ACT Time                [24]
2nd information
3rd information
> DRAM Skew Control :
(-- Manual --)
(-- Manual --)
CPU Voltage                  [1.4]
CPU GTLVref(0)               [+90mV]
CPU GTLVref(2)               [+90mV]
NB GTLVref                   [+60mV]
DRAM Voltage                 [1.85]
NB DDRVref                   [Auto]
Hallo zusammen / Hallo RonnyD
hab jetzt endlich meinen neuen Speicher bekommen, ist dieser geworden als 4GB Kit
http://www.ocztechnology.com/products/memory/ocz_ddr3_pc3_14400_platinum_edition
Ich bekomm trotzdem meinen Q9650 nicht übertaktet. Bzw. bekomm ich den schon übertaktet. Derzeit versuch ich es auf 3,6 GHz, Ziel ist 4GHz. Hab schon alles Mögliche an Einstellungen versucht. Das ganze läuft dann so ab.
Rechner bootet prime läuft 2 bis 3 Stunden stabil und ich denk na endlich hat alles geklappt. Nächster Tag ich mach den Rechner an und der hängt sich beim booten oder direkt bei der windows anmeldung auf.
Versteh das irgendwie nicht.
@ Red1982
Der RAM lässt sich auf gut über 1800 Mhz oc ist also ok. ;)
Ermittle zu aller erst mal den max FSB des Quad mit kleinstem Multi, 475 sollte er minimum erreichen, denn für 4 Ghz benötigst du schon 450 x 9 = 4050 Mhz.
Speicher unbedingt auf 2T.
Dann lässt du ihn mal mit deinen Einstellungen die verschiedenen Prime Tests durchlaufen und schaust wo/wann er aussteigt, dann kannst du nachschauen, ob es an der Vcore, GTL's, VTT usw. lag...
Ich verlinke dir mal ein PRIME how to, lies das mal durch, damit du weißt, um was es geht.
http://www.hardwareluxx.de/community/showthread.php?t=508101&highlight=prime95
Schau auch drauf, dass du, falls du einen 400er NB Strap fährst, den Ai Clock Twister auf zunächst mal Moderate fährst und den Ai Transaction Booster logischerweise auf Manual und mit dem Common Performance Level entschärfst.
@RonnyD
hab noch nicht so viel geschafft, hatte keine Zeit. Bisher konnte ich testen das die 475 auf 1,275 im small test stabil liefen. Sollte die aber noch etwas erhöhen da Windows nicht ganz rund lief. Auf 1,3 gabs keine Probleme. Also Feineinstellung.
480 hab ich nicht stabil bekommen und über die 1,3 wollte ich erstmal nicht gehen. Werd heute mal weiter machen.
EDIT: Kleiner Zahlenfehler :-)
Hallo..
bin auch stolzer besitzer eines RE mit e8600 und 2 mal 4gb kit Ocz flex ex...
Weil ihr hier wegen heatpipes diskutiert.. habe das hier gefunden:
http://www.aquatuning.de/product_in...NL-NSB-Twin-Asus-Rampage-Extreme-schwarz.html
zwar nicht lieferbar aber offiziell für das Rampage extreme so wie es aussieht.
habe auch vor meine heatpipe auszutauschen... aber erstmal brauch ich ne wakü, leider fehlt mir noch das nötige kleingeld im moment. Aber mein e8600 läuft auch auf seiner vid von 1,25v und sogar weniger auf 4,0ghz (400x10) stabil.
Die Rams, die ja offiziell für 2000mhz geeignet sind, habe ich bisher nicht so zum laufen bekommen, auch bei 1800mhz hatte ich immer nach einiger zeit probleme, 1600 läuft prima, aber kann auch sein, dass es an meinem halbwissen liegt...
