[Sammelthread] Asus Rampage II Extreme R.o.G. (Intel X58) [5]
[blockquote]
Spezifikationen Spezifikationen
CPU
  • Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor
  • Supports Intel® Dynamic Speed Technology
  • Supports 4.8GT/s & 6.4GT/s QuickPath Interconnection
Intel® chipset
  • Northbridge:
    - Intel® X58 Express chipset
  • Southbridge:
    - Intel® ICH10R
Memory
  • 6 x DIMM, Max. 12 GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 Non-ECC,Un-buffered Memory
    - Triple channel memory architecture
    - * Supports Intel® Extreme Memory Profile (XMP)
    - **Due to Intel spec definition, DIMMs of DDR3-1333 or above are out of spec.
Expansion Slots
  • 3 x PCIe 2.0 x16 support at x16, x8, x8, or dual x16 speed
  • 2 x PCIe 2.0 x 1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 1 x PCI 2.2
Multi-GPU Support
  • Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
    - * We recommend that you use full tower chassis for building a 3-Way SLI system.
Storage
  • Intel ICH10R controller
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 xUltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
    - 1 xSATA 3.0 Gb/s port
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8 -Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2 Support Teaming Technology
Internal I/O Connectors
  • 3 x USB connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector
  • 7 x SATA connectors
  • 1 x IEEE 1394a connector
  • 1 x Chassis Fan connector
  • x 8-pin ATX 12V Power connector
  • 24-pin ATX Power connector
  • 1 x EL I/O Shield Connector
  • 3 x thermal sensor connector
  • 1 x En/Dis-able Clr CMOS connector
  • System Panel
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 8 x ProbeIt connectors
  • 1 x LCD Poster connector
  • 1 x BIOS FlashBack boot up selection header
  • 1 x ROG light connector
Back Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Special Features
  • External LCD Poster
  • Onboard Switches: Power / Reset / Clr CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ROG BIOS Wallpaper
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Accessories
  • ProbeIt Cable
  • 3-Way SLI Cable
  • SLI Cable
  • ASUS Optional Fan
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
BilderBilder
Das Mainboard
Die Verpackung und das Zubehör
(Quelle: Xfastest.com)​
Das BiosDas Bios
- Bilder folgen
Biostemplate (Extreme Tweaker)Biostemplate (Extreme Tweaker)
Code:
Extreme Tweaker
CPU Level Up:
Memory Level Up:
Ai Overclock Tuner:
OC From CPU Level Up:
OC From Memory Level Up:
CPU Ratio Setting:
BCLK Frequency:
PCIE Frequency:
DRAM Frequency:
UCLK Frequency:
QPI Frequency:
EPU II Phase Control:
Loadline Calibration:
CPU Differential Amplitude:
Extreme OV:
CPU Voltage:
CPU PLL Voltage:
QPI/DRAM Core Voltage:
IOH Voltage:
IOH PCIE Voltage:
ICH Voltage:
ICH PCIE Voltage:
DRAM Bus Voltage:
Debug Mode:
Keyboard TweakIt Control:
CPU Spread Spectrum:
PCIE Spread Spectrum:
CPU Clock Skew:
IOH Clock Skew:
CPU-Configuration
CPU Ratio Setting:
C1E Support:
Hardware Prefetcher:
Adjacent Cache Line Prefetch:
Intel(R) Virtualization Tech:
CPU TM Function:
Execute Disable Bit:
Intel(R) HT Technology:
Active Processor Cores:
A20M:
Intel(R) C-STATE Tech:
-C State package limit setting:
DRAM Timing Control
DRAM CAS# Latency:
DRAM RAS# to CAS# Delay:
DRAM RAS# PRE Time:
DRAM RAS# ACT Time:
DRAM RAS# to RAS# Delay:
DRAM REF Cycle Time:
DRAM WRITE Recovery Time:
DRAM READ to PRE Time:
DRAM FOUR ACT WIN Time:
DRAM WRITE to READ Delay:
DRAM Timing Mode:
DRAM Round Trip Latency on CHA:
DRAM Round Trip Latency on CHB:
DRAM Round Trip Latency on CHC:
DRAM WRITE to READ Delay(DD):
DRAM WRITE to READ Delay(DR):
DRAM WRITE to READ Delay(SR):
DRAM READ to WRITE Delay(DD):
DRAM READ to WRITE Delay(DR):
DRAM READ to WRITE Delay(SR):
DRAM READ to READ Delay(DD):
DRAM READ to READ Delay(DR):
DRAM READ to READ Delay(SR):
DRAM WRITE to WRITE Delay(DD):
DRAM WRITE to WRITE Delay(DR):
DRAM WRITE to WRITE Delay(SR):
DRAM REF Voltage
DRAM DATA REF Voltage on CHA/B/C:
DRAM CTRL REF Voltage on CHA/B/C:
DownloadsDownloads
Bios Downloads
  • Bios 0407
    - First release Bios
  • Bios 0503
    - Revised QPI/DRAM Core Voltage setting in CPU Level Up
  • Bios 0602
    - Fix system may hang after resume from S3
    - Improvie Memory compatibility
  • Bios 0701 (beta)
    - keine Changelog
  • Bios 0705
    - Fixed the CPU ratio setting incorrect in TweakIt Batch File function.
    - Revised the default value of keyboard TweakIt control hotkey to "P" in BIOS setup
  • Bios 0804
    - Updated EC firmware (Fixed system would hang at POST with ADAPTEC SAS RAID Controllers ASR-5405 attached.)
  • Bios 0901
    - Fixes Bug issues with 4870X2's in Crossfire X not showing Video.
    - Fixed Memory Compatibility Issues
  • Bios 0903
    - Fixed the function for adjusting BCLK abnormal in TurboV when set BCLK > 200MHz in BIOS setup
  • Bios 0904
    - System Stability Improved When Overclocking Bclk High
  • Bios 1001
    - Fix AI suite report different CPU temperature as LCD Poster
  • Bios 1403 (beta)
    - keine Changelog
  • Bios 1504
    - Updated configuration table of OC Station.
    - Fixed Target DRAM Frequency incorrect for DDR3-1333 with non-extreme CPU when set DRAM Frequency to auto in BIOS setup.
    - Supported display warning message when set CPU Voltage or QPI/DRAM Core Voltage over 1.8V in TurboV.
  • Bios 1639
    - Improve memory compatibility
    - Updated ASUS EZ Flash 2 from V3.38 to V3.44
    - Updated ASUS O.C. Profile from V1.38 to V1.44
  • Bios 1704
    - Support new CPUs.
  • Bios 1802
    - Support new CPUs.
Wichtige InformationenWichtige Informationen
  • Achtet auf die Speicheranordnung, wenn die Riegel in den falschen Slots sind bootet das Mainboard nicht (hat mit dem IMC der CPU zu tun!)
    - Dazu bitte Seite 2-15 im Handbuch nachschlagen.
[/blockquote]
Hast recht. Man muss wie im angehängten Bild zu sehen den Jumper auf 1+2 setzen, dann geht die Auswahl im Menü im Bios unter Boot / Bios Boot Prority / Forced Bios Boot from (1 o. 2)
Je nachdem welcher da ausgewählt ist, der wird dann auch (Nach Neustart bei neuer Auswahl) geflashed.
So sollte es zumindest meiner Meinung nach sein. Ausprobiert habe ich das noch nicht.
Handbuch als PDF gibts auch nochmal hier: Link
Hi, ich habe aktuelle eine ältere XFi Music im PC, die muckt neuerdings etwas rum (Treiber deinstalliert sich ab und zu von selbst)
Ich meine es ist seit dem Service Pack 1 von Windows, aber bevor ich da groß rumdoktore wüßte ich gerne ob die Soundkarte von Asus was taugt und mit Windows 7 64bit läuft.
Bestätige, die läuft und für Onboard ist sie ganz okay, aber vergleiche nicht mit X-Fi oder ähnlichem ;)
Hallo
Mein neues Rampage II Extreme funktioniert nicht richtig . Übertackten geht fast garnicht und es gibt andauernd freezes. Cpu ist I7 950 und Ram 6 GB G skill 1600er. Und wenn ich die grafikkarte ( GTX 480 ) voll belaste geht auch nichts mehr . Cpu , bord und GTX 480 ist wassergekühlt , beim board alerdings nur ein fusion block . Desweiteren ist merkwürdig das die NB temperatur auch im idle beo ca 75 C ist .
Bitte um Hilfe
MFG
Ferndiagnosen sind immer schwierig, aber lt. deiner Aussage würde ich sagen das 75°C im Idle min. 25°C zu viel sind und der Fusionblock wahrscheinlich verkantet aufsitzt und durch die hohe Temp. das Board instabil wird und abschmiert.
hab eben aufstandertkühler gewechselt , hat jetzt zwar nur noch max 55C aber die garafikkarte geht noch immer niicht
Wer hat den Grafikkartenkühler verbaut und gab es eine visuelle Kontaktkontrolle/-prüfung, ob alle wichtigen Bauteile vernünftigen Kontakt mit dem Kühler haben? Kühler nach Montage noch einmal abgenommen um zu sehen, ob überall Abdrücke in Wärmeleitpaste und Pads gleichzeitig herrscht?
Wenn die Grafikkarte nach Umbau nicht funktioniert, ist das meist ein Hinweis auf unsachgemäße Montage, was allein beim Fusionblock ja hier schon der Fall war. Vorsichtig, die Grafikkarte könnte gänzlich zerstört werden beim Betrieb ohne vernünftige Montage.
Was denn hier los ????
Keiner mehr das Board?
Ps: Neuestes BIOS bringt bissl max RAM Takt
MfG
Doch gibt noch einige die das Board haben, nur ist bei mir im mom die Luft raus;) Welches BIOS meinst du denn genau? Kam mit meinen Tridents nie über 1700-1800MHz hinaus, vielleicht geht da ja noch was mitm BIOS. Hab länger nicht mehr rumgetestet. Hab mom 3,2GHz Sommerconfig und keine Lust den Prozzi zu quälen, aber bissl RAM-Ocing kann nicht schaden, auch wenn's nicht soo viel bringt. Dafür beeindrucken die Zahlen;)
läuft wie geschnitten brot ... 4,4ghz i7 960 ... komischerweise komme ich KEIN EINZIGES MHZ (bzw. keinen EINZIGEN BLCK Wert) höher ...
Welches weis ich jetzt garnicht,, meine aber das neuste auf der Asus HP
19xx glaube .
Beim Kollegen der mein altes Board hat hat's was gebracht, konnte nun mit 2000mhz Booten vorher max 1850 zwar nicht stable zu bekommen aber immerhin bootbar
Mfg
Bei welchen bclk bleibst du hängen?
Mal mit PCIe Takt Erhöhung probiert?
Ist es das board oder CPU die dicht macht?
mann ... fix mich nicht an - nach einem Jahr stabilem System - wieder in den OC Wahn zu verfallen :bigok: :wink: .... muss ich nachher gucken ... hab ich echt keine Ahnung mehr ... auf jeden Fall ist der 24/7 seit knapp nem Jahr nur zum Zocken am laufen ... und das OHNE jedgliche Probleme ;) ... aber schon richtig: 4,6ghz sehn schon geil aus ;)
wie gesagt, guck nachher mal :)
@toyzruz Du könntest mal SB Spannung und PCI E auf 107 (hat bei mir richtig was geholfen) stellen, Spread Spectrum aus, und halt LCC usw. richtig einstellen :d
könnt ich nachher mal gucken ... aber ihr wisst schon, dass ich für 4,4 einiges hochgeschraubt hab ;)
Das ist aber dann gleich mal die Keule .
SB Spannung musst du in den seltensten fällen an heben ( da bringt dich das anheben der NB weiter) und PCIe 107 kannst auf Dauer auch nur mit ner ATI machen, mal abgesehen davon das es dem Board auf Dauer auch nicht egal ist.
Für 24/7 würde ich max 105 PCIe geben.
LLC würd ich höchstens für Benches einstellen, ansonsten Haut das Strom,Temp etc, alles in die höhe. 107Mhz PCIe ist auf dauer auch bissl viel...BTW, steigert PCIe noch etwas die Grafikleistung?
Reicht eigentlich der Fusionblock, wenn ich die CPU wässern will?
Oder doch besser einen Fullcover?
Soll ja nicht sooooo weit übertacket werden.
Der Fusionblock reicht dicke für leichtes OC, denn für ca. 200-210 BCLK braucht man nicht mal die Voltage vom Board anheben (bei mir zumindest). Fullcover ist hier mehr Optik/Wunsch für den User.
hallo!
ich habe ein problem mit meinem bike-tacho.
wenn ich den per USB anschliesse kommt immer eine fehlermeldung:
"COM Port Error: PurgeComm function failed on COM15"
woran kann das liegen??
Win7 64bit
MfG
Doch doch, das Dingen lüppt schon seit Release hier, kann mich nicht beklagen :bigok:
Aber iwie zickt es mich grad bissl an...
Hab meinen 920er gegen einen XeonW3520 getauscht, der "pretested" im Forum auf 4,4Ghz war... naja, auf meinem Brettchen macht er keine 4GHz rockstable...
Hab leider keine Zeit und Lust das auszuloten, aber vllt. hat hier jemand einen guten Tipp, bei welchen Settings sich das Suchen und Probieren lohnt, Vcore kanns nicht sein :asthanos:^^
:heuldoch:
Ich werde mein X58 Platinum auch gegen ein REII eintauschen.
Soll als 24/7 Plattform dienen, mein REIII bleibt zum testen. :bigok:
Gruss.
Gruss.
Hi mein bester
Warum geht das MSI doch weg?
Hat dich doch so lange treu begleitet ?
Das RIIE ist zwar auch ne gute Wahl aber bringen wird's dir doch eh nix.
Sent from my iPhone 4
Hi mein bester
Hi Marvin.
Bringen wirds nix, das stimmt.
Aber nach fast 3 Jahren lässt es nach in Sachen USB Spannung etc.
Die Grundperformance von dem Brett ist immernoch beachtlich, aber davon wird es nicht mehr besser.
Da ich vor einiger Zeit ja ein REII als Benchplattform hatte und jetzt ein fast neues äusserst günstig von einem lieben Kumpel bekommen habe, wird es als *Workstation* herhalten.
Gruss Micha.
Hi Leute ich hab mir bei ebay ne neue CPU geholt,dabei handelt es sich um ein Engineering Sample Xeon Q3NE der ist bauglich mit dem L5639.
Ich hab mir das neue 2002er Bios aufgespielt alles läuft soweit ganz gut mit ocen und benchen nur zeigt mir Windows 7 64Bit und Cinebench 11.5 64Bit 3.40GHz an. Obwohl ich im Bios 3.60GHz eingestellt habe (17X212). CPUZ und Everest zeigen es mir die vollen 3.60GHz richtig an. Auch die CPU bezeichnung ist nicht richtg da steht 000.
Gibts da ein Beta Bios das alles einwandfrei klappt?
