[Sammelthread] Asus Rampage II Extreme R.o.G. (Intel X58) [5]
[blockquote]
Spezifikationen Spezifikationen
CPU
  • Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor
  • Supports Intel® Dynamic Speed Technology
  • Supports 4.8GT/s & 6.4GT/s QuickPath Interconnection
Intel® chipset
  • Northbridge:
    - Intel® X58 Express chipset
  • Southbridge:
    - Intel® ICH10R
Memory
  • 6 x DIMM, Max. 12 GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 Non-ECC,Un-buffered Memory
    - Triple channel memory architecture
    - * Supports Intel® Extreme Memory Profile (XMP)
    - **Due to Intel spec definition, DIMMs of DDR3-1333 or above are out of spec.
Expansion Slots
  • 3 x PCIe 2.0 x16 support at x16, x8, x8, or dual x16 speed
  • 2 x PCIe 2.0 x 1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 1 x PCI 2.2
Multi-GPU Support
  • Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
    - * We recommend that you use full tower chassis for building a 3-Way SLI system.
Storage
  • Intel ICH10R controller
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 xUltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
    - 1 xSATA 3.0 Gb/s port
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8 -Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2 Support Teaming Technology
Internal I/O Connectors
  • 3 x USB connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector
  • 7 x SATA connectors
  • 1 x IEEE 1394a connector
  • 1 x Chassis Fan connector
  • x 8-pin ATX 12V Power connector
  • 24-pin ATX Power connector
  • 1 x EL I/O Shield Connector
  • 3 x thermal sensor connector
  • 1 x En/Dis-able Clr CMOS connector
  • System Panel
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 8 x ProbeIt connectors
  • 1 x LCD Poster connector
  • 1 x BIOS FlashBack boot up selection header
  • 1 x ROG light connector
Back Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Special Features
  • External LCD Poster
  • Onboard Switches: Power / Reset / Clr CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ROG BIOS Wallpaper
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Accessories
  • ProbeIt Cable
  • 3-Way SLI Cable
  • SLI Cable
  • ASUS Optional Fan
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
BilderBilder
Das Mainboard
Die Verpackung und das Zubehör
(Quelle: Xfastest.com)​
Das BiosDas Bios
- Bilder folgen
Biostemplate (Extreme Tweaker)Biostemplate (Extreme Tweaker)
Code:
Extreme Tweaker
CPU Level Up:
Memory Level Up:
Ai Overclock Tuner:
OC From CPU Level Up:
OC From Memory Level Up:
CPU Ratio Setting:
BCLK Frequency:
PCIE Frequency:
DRAM Frequency:
UCLK Frequency:
QPI Frequency:
EPU II Phase Control:
Loadline Calibration:
CPU Differential Amplitude:
Extreme OV:
CPU Voltage:
CPU PLL Voltage:
QPI/DRAM Core Voltage:
IOH Voltage:
IOH PCIE Voltage:
ICH Voltage:
ICH PCIE Voltage:
DRAM Bus Voltage:
Debug Mode:
Keyboard TweakIt Control:
CPU Spread Spectrum:
PCIE Spread Spectrum:
CPU Clock Skew:
IOH Clock Skew:
CPU-Configuration
CPU Ratio Setting:
C1E Support:
Hardware Prefetcher:
Adjacent Cache Line Prefetch:
Intel(R) Virtualization Tech:
CPU TM Function:
Execute Disable Bit:
Intel(R) HT Technology:
Active Processor Cores:
A20M:
Intel(R) C-STATE Tech:
-C State package limit setting:
DRAM Timing Control
DRAM CAS# Latency:
DRAM RAS# to CAS# Delay:
DRAM RAS# PRE Time:
DRAM RAS# ACT Time:
DRAM RAS# to RAS# Delay:
DRAM REF Cycle Time:
DRAM WRITE Recovery Time:
DRAM READ to PRE Time:
DRAM FOUR ACT WIN Time:
DRAM WRITE to READ Delay:
DRAM Timing Mode:
DRAM Round Trip Latency on CHA:
DRAM Round Trip Latency on CHB:
DRAM Round Trip Latency on CHC:
DRAM WRITE to READ Delay(DD):
DRAM WRITE to READ Delay(DR):
DRAM WRITE to READ Delay(SR):
DRAM READ to WRITE Delay(DD):
DRAM READ to WRITE Delay(DR):
DRAM READ to WRITE Delay(SR):
DRAM READ to READ Delay(DD):
DRAM READ to READ Delay(DR):
DRAM READ to READ Delay(SR):
DRAM WRITE to WRITE Delay(DD):
DRAM WRITE to WRITE Delay(DR):
DRAM WRITE to WRITE Delay(SR):
DRAM REF Voltage
DRAM DATA REF Voltage on CHA/B/C:
DRAM CTRL REF Voltage on CHA/B/C:
DownloadsDownloads
Bios Downloads
  • Bios 0407
    - First release Bios
  • Bios 0503
    - Revised QPI/DRAM Core Voltage setting in CPU Level Up
  • Bios 0602
    - Fix system may hang after resume from S3
    - Improvie Memory compatibility
  • Bios 0701 (beta)
    - keine Changelog
  • Bios 0705
    - Fixed the CPU ratio setting incorrect in TweakIt Batch File function.
    - Revised the default value of keyboard TweakIt control hotkey to "P" in BIOS setup
  • Bios 0804
    - Updated EC firmware (Fixed system would hang at POST with ADAPTEC SAS RAID Controllers ASR-5405 attached.)
  • Bios 0901
    - Fixes Bug issues with 4870X2's in Crossfire X not showing Video.
    - Fixed Memory Compatibility Issues
  • Bios 0903
    - Fixed the function for adjusting BCLK abnormal in TurboV when set BCLK > 200MHz in BIOS setup
  • Bios 0904
    - System Stability Improved When Overclocking Bclk High
  • Bios 1001
    - Fix AI suite report different CPU temperature as LCD Poster
  • Bios 1403 (beta)
    - keine Changelog
  • Bios 1504
    - Updated configuration table of OC Station.
    - Fixed Target DRAM Frequency incorrect for DDR3-1333 with non-extreme CPU when set DRAM Frequency to auto in BIOS setup.
    - Supported display warning message when set CPU Voltage or QPI/DRAM Core Voltage over 1.8V in TurboV.
  • Bios 1639
    - Improve memory compatibility
    - Updated ASUS EZ Flash 2 from V3.38 to V3.44
    - Updated ASUS O.C. Profile from V1.38 to V1.44
  • Bios 1704
    - Support new CPUs.
  • Bios 1802
    - Support new CPUs.
Wichtige InformationenWichtige Informationen
  • Achtet auf die Speicheranordnung, wenn die Riegel in den falschen Slots sind bootet das Mainboard nicht (hat mit dem IMC der CPU zu tun!)
    - Dazu bitte Seite 2-15 im Handbuch nachschlagen.
[/blockquote]
Dann werde ich das auch mal testen..
bin nicht zufrieden, mein W3520 geht nicht so gut wie er sollte.
Hi, mein Mainboard taktet den Multi runter.
Multi steht fest auf 21, Stromsparmodi (C1E, CPU Throttle...) sind aus. Wenn ich ab 4300 MHz Prime starte, taktet der den Multi von 21 auf 20 runter.
Sobald der laut AIDA über 104 Watt zieht ist Ende. Gibts da einstellungen im Bios wie man das auschalten kann? Temps sind vollkommen ok.
Ja gibt es Weiß nicht genau wie sie heißt irgend was mit" turbo Limit auf off "
Ist bei der Seite zum bclk und ramtakt verstellen mit dabei.
Gibts ein Changelog dazu ? Gleichmal testen, ob ASUS endlich mal die aktuellen Versionen des JMicron & Intel ICH ROM eingepflegt hat.
Edit:
Rampage II Extreme 2101 BIOS
1. Improve memory compatibility
2. Improve system stability
3. Support new CPUs. Please refer to our website at: ASUSTeK Computer Inc. -Support- CPU Support
ROM des Jmicron & Intel sind weiterhin alt :heul:.
Aber nichts desto trotz find ich es toll, dass ASUS das Brett weiterhin aktuell hält :banana:.
Also meine REII Läuft mit den neuen Bios einwandfrei.
Ich bin mit den RE II so zufrieden das ich echt überlege den Sandy e zu überspringen und auf die Nächste Generation warte.
Das ein-zigste ist ich werde mir im MP günstig einen i7 980X zulegen
Zu dem Zeitpunkt, als ich das Bios 2101 (asus ftp) entdeckte, gab es noch kein changelog...und auf der Asus Web-Seite war es auch noch nicht gelistet.
es ist fein, da gebe ich dir recht, daß asus das board einigermaßen aktuell hält, wobei es schade ist, daß Asus nicht auf die aktuellen Rom Versionen von JMicron und Intel ICH aktualisiert...
aber, vielleicht hat ja jemand von hier einen Draht zu Asus...und könnte da mal vorsprechen, oder schreiben... :hail:
Jop, der Meinung bin ich ebenfalls. Bin auch super zufrieden.
Werde auch noch versuchen einen günstigen i7 980 zu bekommen und dann überspringe ich Sandy Bridge E.
Wenn die auch noch die ROMs updaten wäre das genial. Der JMicron zickt mit meiner eSATA Platte ab und zu gern einmal.
Verdammt, was muss ich nochmal alles einstellen, damit ich mit dem Board Wake on LAN per Fritzbox hinbekomme?
ist schon enabled. Lüüpt nicht. In Win 7 ist auch bei beiden LAN-Anschlüssen aktiviert und Magic Packet only hab ich den Haken entfernt, damit er generell reagieren kann. Reagiert nicht auf die Fritzbox. Noch ne andere Idee?
Wenn jemand Interesse an einem RIIIE hat, meins wird die Tage frei .
Mfg
hallo!
ich habe jetzt eine 2te 5870er und will mir damit crossfire testen!
in welche slots soll ich die 2 GPUs stecken?? vermutlich in die blauen - oder??
das wird dann aber eng mit der wakü.....
Rtfm
Da steht wie die slots beschaltet sind. Wenn Du nix gegen 16x8 hast ist nix gegen den unteren zu sagen.
Gesendet von meinem GT-I9000 mit der Hardwareluxx App
Hallo HL Gemeinde, ich habe ein seltsames Problem.
ich habe beobachtet,
a-) der Platine ausgeschaltete zu stand Leuchtet dauerhaft die erste Netzwerkschnittstelle Rechts grün ohne Netzwerkkabel und die CLR_CMOS Knopf auch.
b-)die EXTREME OC Knöpfe (Start, Reset und select) leuchten auch ausgeschaltete zu stand dauerhaft.
c-) die OC MOD Led immer wieder selbe Abstände geht an und wieder aus, aus geschaltete zu stand. Die Soundkarte Leuchtet auch.
d-) PC wurde mit Windows 7 Ultimate neu Installiert, alles läuft normal bis die erste Netzwerkschnittstelle wird nicht erkannt. Komisch ist auch die Q Kontakt die HD LED leuchtet dauerhaft und die Power LED leuchtet wie die Festplatten LED blinkt.
e-) ich kann nicht alle Treiber installieren wie (JMicron JMB36X Controller Driver V1.17.48 und die Intel(R) Matrix Storage Manager Driver V8.9.0.1023) kommt Fehlermeldung "System erfüllt nicht Anforderungen)
Ich habe mit alte und neu BIOS auch versucht immer die selber Problem.
meine Frage wenn System ausgeschaltet ist warum fließt die Strom immer noch durch die Platine.
Danke voraus für die Antwort und Lösung ansetze.
Du hast HDD und Power-Led vertauscht? Oder die HDD-Led falsch rum drauf?
Gibt es da keine andere Möglichkeit die Controller zu aktualisieren?
Mit etwas Ahnung von der Materie, könnte man sich die aktuelle ROM`s selbst in das BIOS patchen...
Ich habe es aber auch noch nicht versucht / gewagt mit dem ROM-Updatetool für den Jmicron z.Bsp. , die Firmware selbst zu aktualisieren...kA ob der das mitmacht?
---------- Beitrag hinzugefügt um 17:52 ---------- Vorheriger Beitrag war um 14:23 ----------
Habe mich mal belesen und festgestellt, dass es garkeine schwierige Sache ist, die neuen ROM`s ins BIOS zu patchen :d
folgende Änderungen habe ich im aktuellen BIOS 2102 gemacht:
Intel Rapid Storage von ROM 8.0.0.1038 -> 10.1.0.1008
JMicron JMB36X von ROM 1.07.14 -> 1.07.28 ( endlich wird die eSATA HDD korrekt erkannt :banana:)
Es gibt zwar noch aktuellere ROM`s zum Intel Rapid Storage, dies ist allerdings die letzte supporte Version seitens Intel.
Bei interesse einfach per PM melden, da ich nicht weiss ob es gestattet ist, das "Mod-Bios" per DL zu verteilen :confused:.
Wäre interessant zu wissen, ob damit dan Wake on LAN ginge. Habe ein etwas älteres Bios drauf und erkannt wir die Netzwerkschnittstelle, aber starten will da nichts.
Ja fein!
Hast ne PN :)
Auf eigene Gefahr^^. Wo ist der Link? *g*
Wozu gibts Dual-Bios-Boards wie unseres.
Dann hier:
rampageii-asus-extreme-2101…zip (970,14 KB) - uploaded.to
Nach dem flashen noch ggf. die Treiber für den Intel RST & JMicron eSATA aktualisieren.
Link:
ASUS RampageII Extrem bios & drivers
---------- Beitrag hinzugefügt um 21:11 ---------- Vorheriger Beitrag war um 21:07 ----------
Ich denke nicht das sich daran was ändert, da ich den ROM nicht gepatch habe.
Hast du den Marvell Yukon schon mal auf Rev. 14 aktualisiert ?
Marvell Yukon 88E8056 eeprom
Danke für das Mod-Bios ;)
wo bzw. mit was für einem Programm kann ich denn die ROM-Version vom Intel Rapid Storage sehen? :confused:
(die vom JMicron sehe ich beim booten)
Die ROM-Version siehst du nur wenn im BIOS unterhalb von Hauptmenü->Speicherkonfiguration->Configure as [RAID] aktivierst.
Nachdem dem BIOS Post, erscheint dies hier:
d49eb498741714a372c6207bd9db3578
Kommt auf den Sprung der Version an.Manchmal, oder auch nicht.
