[Sammelthread] Asus Sabertooth 990fx
Inhalt:
  • Spezifikationen
  • Bilder
  • Bios
  • Review´s / Test´s
  • Downloads
  • Kompatibilität
  • Preis
  • FAQ
Spezifikationen:
CPU
AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
Supports AM3+ 32 nm CPU
Supports CPU up to 8 cores
Supports CPU up to 140 W
AMD Cool 'n' Quiet™ Technology​
Chipset
AMD 990FX/SB950​
AMD 990FX/SB950
Memory
4 x DIMM, Max. 32GB, DDR3 1866/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture​
Expansion Slots
3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8) *1
1 x PCIe 2.0 x16 (x4 mode, black)
1 x PCIe 2.0 x1
1 x PCI​
Storage
AMD SB950 controller :
6 x SATA 6Gb/s port(s), brown
Support Raid 0, 1, 5, 10
JMicron® JMB362 controller :
2 x SATA 3Gb/s port(s), black
1 x Power eSATA 3Gb/s port(s), green
1 x eSATA 3Gb/s port(s), red​
LAN
Realtek® 8111E , 1 x Gigabit LAN Controller(s)​
Audio
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- Blu-ray audio layer Content Protection
- ASUS Noise Filter
- Optical S/PDIF out port(s) at back panel
IEEE 1394
VIA® 6308P controller
2 x IEEE 1394a port(s)
(1 at mid-board, 1 at back panel)​
USB Ports
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
14 x USB 2.0 port(s) (10 at back panel, black+red, 4 at mid-board)​
Special Features
ASUS Dual Intelligent Processors 2 with DIGI+ VRM
TUF ENGINE! Power Design :
- 8 +2 Digital Phase Power Design
- TUF Components (Alloy choke, Cap. & MOSFET; certified by military-standard)
- ASUS DIGI+ VRM Utility
- E.S.P. : Efficient Switching Power Design
Ultimate COOL! Thermal Solution :
- TUF CeraM!X Heatsink Coating Tech.
- TUF Thermal Radar​
ASUS Exclusive Features
- MemOK!
- AI Suite II
- Anti-Surge
- ESD Guards
- Front Panel USB 3.0 Support
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Profile
- ASUS EZ Flash 2
- ASUS MyLogo 2
- Multi-language BIOS
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector​
Back I/O Ports
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
1 x LAN (RJ45) port(s)
2 x USB 3.0
10 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)​
Internal I/O Ports
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x COM port(s) connector(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
4 x Chassis Fan connector(s) (3 x 4 -pin, 1 x 3 -pin)
1 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x Clear CMOS jumper(s)​
Accessories
User's manual
ASUS Q-Shield
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x TUF Certification card(s)
1 x TUF 5 Year Warranty manual(s) (by region)​
BIOS
32 Mb Flash ROM, UEFI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2,​
Manageability
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc Drivers
Anti-virus software (OEM version)
ASUS Update
ASUS Utilities​
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )​
Bilder:
Bilder von Huddel (nochmals danke)
Bilder von JACK RABBITz
(Quelle: User Huddel, Asus, JACK RABBITz)
Bios:
(0402)
Review´s/Test´s
Deutsch
HWLUXX
hartware.net
pcgameshardware
Tom´s Hardware
Englisch
guru3d.com
hardwarecanucks.com
legitreviews.com
Downloads
ASUS Sabertooth Downloadbereich
Asus FTP-Server derzeit wieder mal offline :-(
Betabios 0607 -Fan ignore Bug gefixed, CPU-Lüfter Monitor lies sich nicht abschalten, dadurch kam eine Fehlermeldung beim Booten
Bios 0705
1. Enhance RAID expansion card compatibility.
2. Enable support for Spanish and Russian Language.
3. Enhance RAID0 performance with SB950 native SATA ports.
4. Enable support for UEFI RAID Driver to support RAID partition above 2.2TB
Bios 0810
Bios 0813
1. Improve memory compatibility
2. Improve system stability
Bios 0901
Probleme mit X6 CPU´s, Board startet nicht mehr!
Bios 1102
1.Improve system stability.
2.Enhance compatibility with some USB devices.
3.Patch system hanged when use AM3 1090T or 1100T CPU.
Bios 1208
Bios 1304
Bios 1503
Kompatibilität
Arbeitsspeicher
-Kingston HyperX 2133Mhz 4x 2GB
-G.Skill Ripjaws-X 8GB Kit
-G.SKILL 8GB Kit DDR3-1600 F3-12800CL8D-8GBECO / 1,35V
inkompatibler Arbeitsspeicher
-2x2GB G.Skill F3-10666CL8D-4GBRM 8-8-8-24 1,5v (kein Boot möglich)
Luftkühlung
-Prolimatech Megahalems (mit Retentionmodul)
Wasserkühlung für Chipsatz
Preis
HWLUXX
FAQ
Asus Supportforum
Ich hoffe das geht erstmal soweit (Ist mein erster Sammelthread :)), ich versuche alles aktuell zu halten, nun her mit den Erfahrungen und Informationen...
@bytefuzzy
Welches Prime nutzt du? Und welche Einstellung ? Ich hab mit Prime nur probs...
Prime95 v26.6
Welche Probleme hast du denn?
Produkt: Mersenne Prime 95
Version: 26.66
Webseite: www.mersenne.org/freesoft.htm
grEEtz
fuzzy
@Mageastor
Du kannst die .ROM Datei auch auf einem FAT32 formatiertem USB-Stick speichern und bei EZ-Flash dann leichter auswählen als sie erst auf LW:C zu suchen.
good luck
fuzzy
Ich bekomme halt immer Fehler und dann werden zwei Cores abgeschalten.....weis nicht wie ich was einstelle bei Prime
Hast du mal mit der vDDR Spannung rumexperimentiert?
Nein, VDDR läuft als mit 1,2V, im Grunde läuft fast alles auf minimal Wert (default Spannung)!
Spiele Vordergründig nur an CPU, CPU/NB, CPU VDDA (falls nötig) und DRAM Spannung rum!
Erst wenn ich das auf 1.4V stelle scheint der Ram stabiler zu sein.
Interessant. Hat es eine Taktsteigerung gebracht?
@sushi: CPU übertaktet?
Jop. Max Takt war damit höher.
Mit den RipjawsX bin ich damit bis 1384MHz gekommen. Bei 1.2V ist er schon beim booten abgeschmiert.
Nope sind RipjawsX 2133 7-10-7 auch mit PSC Chips. Die PI werden aber auch noch auf Max Takt auf dem Board getestet.
Top Score, Glückwunsch. Unter Wasser? Max. Temp.? :bigok:
oki doki
fuzzy
Nix Wasser:coolblue: alles unter Luft CPU-Temp gar nicht so wild bei 51 Grad.....
aber Super Pi ist jetzt auch nicht so wild......für Temps. Aber mein Netzteil macht
bald die Grätsche.....:d
Ich brauche ein neues, denke ein Cougar CMX 700 Watt....
Gruss Marco
Hi Leute. Eine kurze Frage. Was ist beim Sabertooth der "integrierte Grafikprozessor" und wofür soll der gut sein? Ist das so eine Art onboard Grafik? Wenn ja, wo ist der Anschluss. Sorry für meine dämliche Frage, ich habe aber im I-net nix Erklärendes gefunden.
Das Sabertooth 990FX hat keine integrierte Grafik!
Wo hast Du das gelesen?
Hallo zusammen,
ich habe mal eine Frage zu Overclocking via Multi und C&Q:
Ich habe einen FX 6100 übertaktet via Mulit au 4GHZ. Im Bios habe ich die VCore Spannung manuell auf 1,275V gesetz, diese Spannung hat das System dann auch im Idle, der Multi und Takt wird auch herabgesetzt nur leider geht der VCore nicht unter 1,275V unter last geht der VCORE hoch auch 1,308V wodurch das System PrimeStable läuft. CPU Load Line Calibration ist auf Auto, wenn ich den VCORE senke und die CPU Load Line Calibration auf Medium (25%) setze wird das Sys bei 4GHZ instabil.
Gibt es eine Vorgehensweise, dass der VCORE bei C&Q mit runter geht?
Schonmal vielen Dank!
@kai84m. Du musst die Spannung auf "Offset Mode" setzen. Nur damit funktioniert auch C&Q. Dort aber dann nicht die gewünschte Spannung als Wert eintragen sondern den VID der CPU + oder - 0.xxxV.
Hat geklappt!
Vielen Dank!!!
FX 6100 4GHZ @ 1,296V CPU-NB 2,2GHZ
Sehr schön :)
Aber 1.45V auf CPU/NB :eek: ? Das ist nicht die vid oder?
stellt mit auto teilweise sehr hoch die nb vcore
ich mache da +0,006 dann bleibst bei standard nb vcore
NB/VCore Standard??
@oese
Kannst du das für mich bitte mal ein wenig ausführlicher erklären? :confused:
Was ist denn der Standard-Wert? Nicht die bei mir angezeigten 1,45V bei Einstellung "Auto"?
Wie ist denn der Wert wenn du dort +0,006 eingibst?
Danke für eine verständliche Erklärung.
oki doki
fuzzy
Ich vermute mal er meint die vid + 0.006V ?
Das höchste was ich bei CPU/NB bei meinen FX gesehen habe waren 1.25V. Bei 1.45V kannst die NB ja auf über 2.6GHz takten :d
Stell am besten mal deutlich weniger ein und teste ob er noch stabil ist. Mein Sahnestückchen 8150 hat sogar nur 1.15V ;)
ja, bei mir kann ich durch + 0,006 die nb vid bei 1,25v halten. Das ist bei mir stock. Wenn ich auf auto lasse und die nb, egal ob über multi oder htref, übertakte, geht die vid in zwei stufen hoch, zuerst auf 1,35v, dann auf 1,45v. Ist mir auch bischen viel und mit + oder - orientiert er sich wieder an der stock nb vid, so dass man es gut einstellen kann.
Bei mir reicht 1,25v für 2400 nb aus.. 2600 bringt eh nix gegenüber 2400 also bleibt es bei 2400 @ 1,25v :)
Ich danke euch für die Hinweise. :bigok:
Jetzt habe ich die NB/Core mal auf 1,250V eingestellt. HT auf 2400 und NB auch auf 2400.
VCore bei 1,4V und Multi auf 21,5, also 4,3GHz. :drool:
Momentan läuft der AIDA Stresstest. Wenn der 2 Std. hinter sich hat mach ich mal neue screens für euch. :popcorn:
oki doki
fuzzy
Bekommt man den NB Takt beim BD nicht höher?
Ich hatte mit meinem Thuban X6 schon ganz easy über 3 GHz NB Takt anliegen bei unter 1,3v CPU/NB Spannung!
Laut Uefi ja aber in der Praxis bekommst das mit einem FX nicht hin.
Für 2.6 brauchst du schon 1.3+V bei den guten. Bei 2.8 1.4+V was meiner Meinung für 24/7 schon ziemlich viel ist.
das ist heftig!
seit ich das Sabertooth habe, geht mein PII beim cpu/nb mit 1,175V auf 2,8Ghz....keine Probleme auf meinem CH IV kam ich nicht so hoch...
Aber was anders interessiert mich....und zwar die Leistungsaufnahme des PC....das kann man zwar nicht zu 100% vergleichen, aber so ein Richtwert wäre nicht schlecht.
Ich hab mir mal die Mühe gemacht und nur meinen PC an ein Energiemessgerät gehangen....
Im Idel verbrät das Teil schon 160 Watt :eek: unter Last 230Watt
Dabei eben halt der P II 1090T @3,6Ghz@1,325V die cpu/Nb auf 2800@1,175V 4x4Gb G.Skill Sniper 1866 @ 1,475V 1x SSD AData 2x1TB von Samsung und aquasteam XT + Poweradjust2 für 9x120erLüfter und halt das schöne Sabertooth Board:asthanos:
Das ganze wird mit einem 850Watt enermax NT befeuert....
Ist dieser Leistungsverbrauch nun normal unter diesem Setting? im idel hätte ich mir viel weniger vorgestellt....
oder ich müßte mal testen, ob das auch so mit COOL n Quiet funzt....
Bei meinem momentan laufenden AIDA-Stresstest habe ich die NB auf 2600MHz bei 1,250V. Die erste Stunde hat er* so überstanden! *Der FX6100 :coolblue: :coffee:
bis denne
fuzzy
