Hi, ich weiss nicht ob es schon gepostet wurde, aber für alle AGP`ler ist es ziemlich interessant.
Auf der Webseite von Powercolor ist die erste? 3850 AGP Version gelistet worden. Da bin ich ja mal gespannt wie die so ist...
So sieht das gute Stück aus:
FEATURES:
2 Some custom resolutions require user configuration
3 HDCP support for playback of protected content requires connection to a HDCP capable display
SAPPHIRE Technology, industry leader in graphics solutions, has just announced support for legacy PC systems using the AGP graphics bus with a new product in its HD 3000 series which brings the latest graphics architectures and features to this industry standard platform.
The SAPPHIRE HD 3850 AGP is available with 512MB of GDDR3 memory, running at 846MHz (1.7GHz effective) and has a core clock speed of 700MHz. It is a standard ATX format card, compatible with the industry standard AGP interface and with its slim fan assisted cooler the card occupies only a single expansion slot in the PC.
The SAPPHIRE HD 3850 AGP shares the 320 stream processors and 512-bit internal ring bus memory controller of the latest PCI-Express models together with multiple rendering units and a programmable tessellation unit. This new product’s unified shader architecture with support for Shader Model 4.0 and the forthcoming DirectX 10.1 combine to deliver the most outstanding graphics performance ever available to AGP users.
Now manufactured in a new 55nm process technology, the GPU in the HD 3000 series delivers high performance with lower power consumption than previous generations. A new feature known as ATI PowerPlay actively reduces power consumption depending on loading. On the AGP model, additional power is required via the 8-pin PCI-Express connector fitted, which can be provided from a standard power supply with an adapter cable (supplied).
The SAPPHIRE HD 3850 AGP incorporates the latest ATI Avivo™ HD Technology for enhanced Video display and features a built in UVD (Unified Video decoder) for the hardware accelerated decoding of Blu-ray™ and HD DVD content for both VC-1 and H.264 codecs, considerably reducing CPU loading. Two independent display output controllers provide support for two dual link DVI displays as well as TV-out and HD TV options. HDCP is supported.
SAPPHIRE HD 3000 series graphics cards are Microsoft Windows Vista™ Premium certified and supported by the ATI Catalyst® suite of software, ensuring customers have ongoing access to software updates for performance, stability and added features.
Specifications: SAPPHIRE HD 3850 AGP
Model
FEATURES:
- Graphics Engine: RADEON HD3850
- Video Memory: 512MB GDDR3
- Engine Clock: 668MHz
- Memory Clock: 828MHz x 2
- Memory Interface: 256bit
- DirectX Support: 10.1
- Bus Standard: AGP x8
- 666 million transistors on 55nm fabrication process
- 256-bit GDDR3/GDDR4 memory interface
- Ring Bus Memory Controller
- Fully distributed design with 512-bit internal ring bus for memory reads and writes
- Dynamic load balancing and resource allocation for vertex, geometry, and pixel shaders
- Microsoft® DirectX® 10.1 support
- Shader Model 4.1
- 32-bit floating point texture filtering
- Indexed cube map arrays
- Independent blend modes per render target
- Pixel coverage sample masking
- Read/write multi-sample surfaces with shaders
- Gather4 texture fetching
- Unified Superscalar Shader Architecture
- 320 stream processing units
- Common instruction set and texture unit access supported for all types of shaders
- Dedicated branch execution units and texture address processors
- 128-bit floating point precision for all operations
- Command processor for reduced CPU overhead
- Shader instruction and constant caches
- Up to 80 texture fetches per clock cycle
- Up to 128 textures per pixel
- Fully associative multi-level texture cache design
- DXTC and 3Dc+ texture compression
- High resolution texture support (up to 8192 x 8192)
- Fully associative texture Z/stencil cache designs
- Double-sided hierarchical Z/stencil buffer
- Early Z test, Re-Z, Z Range optimization, and Fast Z Clear
- Lossless Z & stencil compression (up to 128:1)
- Lossless color compression (up to 8:1)
- 8 render targets (MRTs) with anti-aliasing support
- Physics processing support
- Anti-aliasing features
- Multi-sample anti-aliasing (2, 4, or 8 samples per pixel)
- Up to 24x Custom Filter Anti-Aliasing (CFAA) for improved quality
- Adaptive super-sampling and multi-sampling
- Temporal anti-aliasing
- Gamma correct
- Super AA (ATI CrossFire™ configurations only)
- All anti-aliasing features compatible with HDR rendering
- Dynamic Geometry Acceleration
- High performance vertex cache
- Programmable tessellation unit
- Accelerated geometry shader path for geometry amplification
- Memory read/write cache for improved stream output performance
- Texture filtering features
- 2x/4x/8x/16x high quality adaptive anisotropic filtering modes (up to 128 taps per pixel)
- 128-bit floating point HDR texture filtering
- Bicubic filtering
- sRGB filtering (gamma/degamma)
- Percentage Closer Filtering (PCF)
- Depth & stencil texture (DST) format support
- Shared exponent HDR (RGBE 9:9:9:5) texture format support
- OpenGL 2.0 support
- ATI Avivo™ HD Video and Display Platform
- Dedicated unified video decoder (UVD) for H.264/AVC and VC-1 video formats
- High definition (HD) playback of both Blu-ray and HD DVD formats
- Hardware MPEG-1, MPEG-2, and DivX video decode acceleration
- Motion compensation and IDCT
- ATI Avivo Video Post Processor
- Color space conversion
- Chroma subsampling format conversion
- Horizontal and vertical scaling
- Gamma correction
- Advanced vector adaptive per-pixel de-interlacing
- De-blocking and noise reduction filtering
- Detail enhancement
- Inverse telecine (2:2 and 3:2 pull-down correction)
- Bad edit correction
- Two independent display controllers
- Drive two displays simultaneously with independent resolutions, refresh rates, color controls and video overlays for each display
- Full 30-bit display processing
- Programmable piecewise linear gamma correction, color correction, and color space conversion
- Spatial/temporal dithering provides 30-bit color quality on 24-bit and 18-bit displays
- High quality pre- and post-scaling engines, with underscan support for all display outputs
- Content-adaptive de-flicker filtering for interlaced displays
- Fast, glitch-free mode switching
- Hardware cursor
- Two integrated dual-link DVI display outputs
- Each supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI)2
- Each includes a dual-link HDCP encoder with on-chip key storage for high resolution playback of protected content3
- Two integrated 400 MHz 30-bit RAMDACs
- Each supports analog displays connected by VGA at all resolutions up to 2048x15362
- Integrated AMD Xilleon™ HDTV encoder
- Provides high quality analog TV output (component/S-video/composite)
- Supports SDTV and HDTV resolutions
- Underscan and overscan compensation
- MPEG-2, MPEG-4, DivX, WMV9, VC-1, and H.264/AVC encoding and transcoding
- Seamless integration of pixel shaders with video in real time
- VGA mode support on all display outputs
- ATI PowerPlay™
- Advanced power management technology for optimal performance and power savings
- Performance-on-Demand
- Constantly monitors GPU activity, dynamically adjusting clocks and voltage based on user scenario
- Clock and memory speed throttling
- Voltage switching
- Dynamic clock gating
- Central thermal management – on-chip sensor monitors GPU temperature and triggers thermal actions as required
SAPPHIRE SUPPORTS AGP with HD 3850 Now latest graphics architecture fits legacy systems
Model
- SAPPHIRE HD3850 AGP
Graphics Processor
- ATI Radeon HD 3850
Form Factor
- ATX 231.19 x 111.99 mm
Bus Interface
- AGP 4X/8X
Memory
- GDDR3 512MB /256-bit interface
Clock Speed
- 702MHz core / 846MHz memory
Cooling System
- Single Slot Active Fan Cooler
Bracket
- Full Height
Display Support
- DL DVI-I /TVO / DL DVI-I
- HDTV(via cable)
HDCP
- Yes
External Power
- PCIe Graphic External Power(2x4Pin)
Regulatory Standards
- CE; FCC; UL
Specifications correct at time of writing but may be subject to change.
All trademarks and registration marks acknowledged.
cu
