ATI HD 4870 RV770XT "Sammel-Thread + FAQ" Bitte bei Fragen die erste Seite lesen 2
Danke! also werde ich doch nicht zusätzlich XP neben Vista installieren !
ich hoffe mal das Hardwareluxx in ihren test noch eine CF 4870 aufnimmt
aber mal ehrlich es gibt so viele test und überall steht was anderes.... aber ich muss schon sagen die HD4870 kommt beim Luxx test echt gut weg ^^
wann ist denn der test fertig?
Die haben ja auch den zur Zeit besten Treiber für die HD4k genommen
Nicht wie manche andere Seiten :rolleyes:
Diamond Releases Radeon HD 4870 XOC Unlocked Black Edition
Diamond Multimedia (www.diamondmm.com), a leading manufacturer of PC graphics cards, sound cards and communications products, launched today along with boutique system builder Smoothcreations, and Water cooling mavens, Danger Den the ATI Radeon™ HD 4870 XOC Black Edition graphics card. This card offers exquisite gaming capabilities combined with state of the art efficiency.
The HD 4870 is a smoking gun dual slot card, PCIE 2.0, with 512MB of DDR5 memory and a clock speed of 800 MHz. The memory speed is 1100 MHz and is designed with 800 stream processors. The HD 4870 provides plug-and-play ATI CrossFireX™ upgradeability with up to quad-GPU support. Continuing with ATI’s Power Play and 55nm processing technology, this card is the fastest and efficient. “The Diamond Radeon HD 4870 XOC Black Edition was clocked to kick some ass”. We didn’t just want a fast card out in the market, we wanted the fastest card that could kick the living daylights and bust some performance records, say Mario Gastelum, Director of Product Development & Engineering. “we wanted a card that kicked the competitions teeth into the curb”, and that’s exactly what our engineers accomplished”. “The firmware was custom designed to enable end users to go beyond the normal over clocked speeds and allow them to push their cards for higher performance via the catalyst control center.” The GPU’s custom firmware has been unlocked to push cards to GPU settings of up to 950 MHz and Memory of up 1200 MHz.
Diamond Teamed up with Premier Boutique system builder, SmoothCreations, to offer these powerful graphics cards to Smoothcreations legendary beauty and performance pc system platforms. “We wanted to complement beauty, artisan craftsmanship, and performance power to a gaming system, and Diamond helped us accomplish that”, says Jim Saling, CEO of SmoothCreations. In collaboration with Danger Den, Smoothcreations will be offering a water cooled edition as well.
All Diamond video cards carry the Diamond guarantee of quality assurance. Unlike many cards that are simply first to market, Diamond carefully tests and retests every new model for its ratio of performance to reliability. Diamond is legendary in the PC video card business for its less than 1 percent return rate. Diamond cards use superior connectors, cables and components, as well as undergo more thorough testing for heat susceptibility and durability.
Availability
Diamond Multimedia’s ATI Radeon HD 4870 XOC Black Edition will be available for purchase starting July 01, 2008 and will be available Exclusively at Premier Boutique System Builder Smoothcreations.
http://www.techpowerup.com/
hab mir nun auch mal eine 4870 bestellt, muss ich da irgendetwas grundlegendes beachten? oc, af usw. läst
sich wahrscheinlich ähnlich regeln wie bei nvidia, oder?
probleme zwischen nforce chipsätzen (650i oa) sind nicht bekannt, oder?
gibt es unterschiede zwischen den einzelnen herstellern? habe ne saphirre genommen und hoffe das ich
da nix falsch gemacht habe...
danke im vorraus
Da wird sich zocker wieder schwer tun :lol:
:shot:
Aber nicht schlecht die Karte, eine HD 4870 blablabla mit 800/1100 die sich im CCC bis auf 950/1200 übertakten lässt
(ich freue mich schon auf die extrem übertakten Karten)
soll er doch :lol:
gut, Ich hab mich noch entschlossen zu warten, sogar auf die 1Gb Version.
Ich hab ja ein Mainboard mit PciE 2.0, folglich könnte eine Karte bis zu 300 Watt aus dem Bus beziehen, was für eine HD4870 ja wohl auch locker reichen würde. Jetzt stellt sich mir die Frage, ob ich überhaupt die PciE Stecker anschließen muss. Auf der Karte sind ja noch 2 * 6 Pin Stecker verbaut, da PciE 2.0 noch lange nicht Standart ist. Muss ich auch mit einem entsprechenden Mainboard die Stromversorgung anschließen, oder bezieht die Karte, falls möglich, den nötigen Strom über den Bus?
MFG
MFG
ohne die 2x6er stecker geht nix :)
Ah ok, habs mir eigentlich schon gedacht, allerdings wäre es mir ohne diese ewigen Kabel lieber, muss ich nicht so viel verstecken... ;D
Edit: Manno, GER - ESP 0:1
Sorry da spielt ja die Kindergarten Mannschaft von nebenan besser als die Deutschen , die kriegen ordentlich einen auffen Sack und haben daran auch selber schuld......
Sicher wäre es schöner , aber noch ist das Spiel ja nicht vorbei. :)
Kein Wunder bei Ballacks versteck Spiel.Ein führungsspieler?Ne Ballack versteckt sich nur aufm platzt und spielt die bälle am besten gleich nach hinten.Oh man,hab ich gehoft das ballack heute verletzt ist.Dann hätte de vielleicht ne chance...
Naja, zwei 4870er von GeCube sind bestellt, bei Alternate...
Hoffentlich kommen sie Dienstags oder Mittwochs an...
Wenn sie da sind, gibbts n paar Pics und Benches. Hat schon jemand CF auf einem AMD Chipsatz mit Phenom am Laufen?
zocker hatte mal CF mit AMD laufen. lohtn sich nur bei hoheren auflösungen mit AA und AF. Ansosten werden die karten ausgebremst von der CPU.
Naja, ich denke wer sich ein CF kauft, will damit auch net in 1280x1024 ohne AA und AF rumgurcken...
Ich spiele eigentlich immer in 1680x1050 mit AA und AF, so hoch es meine Hardware eben zulässt. Und SSAA frisst doch schon einiges an Performance.
Wenn ich mir jetzt ne Standard Karte kaufe und mir später ne von Haus aus übertaktete Karte dann taktet die von Haus aus übertaktete doch runter seh ich das richtig?
Also lohnt es sich nicht sich später so eine zu kaufen oder?
Ich denk schon ja...
Allerdings habe ich noch nie übertaktete Karten gehabt, ich hab bis jetzt einfach immer selbst ein Bios geflasht, funktioniert einwandfrei!
MFG
Das streich mal schnell wieder, das war ne falsche Info von mir. Die Spezi sagt nur, dass Karten eingebaut werden dürfen die bis zu 300W verbrauchen, die Power dabei aber nicht aus dem Slot kommen brauch.
Siehe hier. Tut mir Leid!
Ähm atm funktioniert des mit dem Bios bei der 4870er noch nicht. Bei meiner HD2900XT gings so: 1) Bios mit dem ATI Tool von der Karte speichern. 2) Bios mit einem Hexeditor oder dem RBE editieren. 3) Bios mit ATI Winflash wieder auf die Karte(n) spielen
Okey klingt ja zimelich einfach.
Was wird denn dann wohl besser sein?
Eine IceQ KLarte von HIS kaufen wenn se raus ist oder eine normale und bei der den Kühler austauschen und BIOS flashen?
Ja ja, werd mir morgen ne neue Platte besorgen und Vista draufhauen. Obwohl ichs ja eigentlich immer noch net mag;)
Naja, bei der normalen ist halt die Garantie weg. Aber wyne ;D
Zusätzlich hast du bei der OC-Edition die Garantie, dass die Karte die Taktraten auch schafft, bei der normalen hingegen nicht. Allerdings sind die meisten übertakteten eh nicht weit von den normalen entfernt, so dass das kein Probelm sein sollte. Ein alternativer Kühler wie ein Thermalright oder ein S1 wird denke ich besser sein, als ein HIS IceQ aber sicher sagen kann das jetzt auch noch niemand.
