ATI Radeon HD4000 (R700) - [Speku-, News- & Sammelthread] (Part2)
Alles rund um die ATI Radeon HD4000 Grafikkartenserie
Vorraussichtliche technische Daten:
HD 4870 (RV770XT), 55 nm, 850 MHz Chiptakt, 1050 MHz Shaderdomain, 1935 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 1008 GFlops, 27.200 MT/s, 256 Bit Speicherinterface, 1024 MiB GDDR5, 123,8 GB/s Speicherbandbreite, 150 W TDP, $349 MSPR, Release Mai 2008
HD 4850 (RV770PRO), 55 nm, 650 MHz Chiptakt, 850 MHz Shaderdomain, 1728 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 816 GFlops, 20.800 MT/s, 256 Bit Speicherinterface, 512 MiB GDDR5, 110,5 GB/s Speicherbandbreite, 110 W TDP, $269 MSPR, Release Mai 2008
HD 4850 GDDR3 (RV770PRO), 55 nm, 650 MHz Chiptakt, 850 MHz Shaderdomain, 1143 MHz Speichertakt, 480 Streamprozessoren, 32 TMUs, 16 ROPs, 816 GFlops, 20.800 MT/s, 256 Bit Speicherinterface, 256/512 MiB GDDR3, 73,2 GB/s Speicherbandbreite, 110 W TDP
Quelle: Hartware.de
NEWS:
More RV770 and RV770X2 details
Die shrink with minor changes
ATI said a few things about its new upcoming RV770 chips, and as we've said before you can expect [...]
weiterlesen
RV770 will do GDDR 5 and GDDR3
Two flavours
We’ve learned that single chip RV770 card comes in two flavours. The first one [...]
weiterlesen
RV770XT supports 512-bit memory
Despite the claims
A German Website posted an interesting article with a lot of RV770XT and PRO specs, but [...]
weiterlesen
R700 to launch close to Computex
Or around, at leastRV770 chips are looking good and the highest end R700 based product might launch around Computex (starts at June 3 2008). We believe [...]
weiterlesen
RV770 is already in production
Test one
We learned
that the RV770 GPU already went to production and there is a big chance to see R700 generation much earlier than anyone [...]
weiterlesen
Bilder
X2 Kühler
770XT Kühler
770 Pro Kühler
Wer noch interessante Links hat, bitte per PN an mich weiterleiten!
iser aufgewacht^^ also 23 fps avg sind schon ganz gut, aber min fps wären noch interessant. und der core clock der gpu auf gpu-z ist auch lustig^^
Eher nein bzw. kauf dir lieber ein vernünftiges ala Seasonic 380 oder 430 W.
500w kanns auch gleich sein denn vorsorgen ist immer besser, falls du doch mal weiter aufrüsten willst, ich mit meinen überdimensionierten 620w *lalala*
Finde ich gar nicht mal so. Laut diversen Spekulationen soll die kleine 229 US-Dollar kosten. Die 20 Dollar machen den Kohl auch nicht fett, vllt hat man dann die Karten als einer der ersten! :)
:wink:
Glaub ich weniger , der hat sie nämlich nicht auf Lager ganz im Gegenteil zum eBay Händler der hat noch 7 Stck. aber hier möchte ja keiner mitbestellen :(
4 Fragen meinerseits:
1.) stimmen das: http://forums.legitreviews.com/about15370.html :d :d
2.) wann kommt das teil? :O
3.) wie teuer wird es?
4.) hat es die gleichen lochabstände wie die hd3870 wegen wasserkühlung?
thx & cheers ;)
1. ... sicher falsch ...
2. ... die 512MB Version wahrscheinlich nächste Woche oder am 25.06 ... 1GB später
3. ... 4870 geschätzt 300€, ... 1GB 350€
4. ... wahrscheinlich ja, aber nicht sicher!
erstmal launch und benches abwarten, sehen wie weit die preise runtergehen und dann bei guter Preis/Leistung eine kaufen.
1. sehr schade. das hätte gerockt :love:
2. ja nächste 2 wochen ist suppa =)
3. bei 300 euro kann man aber schon leistung erwarten :eek:
4. wenns die gleichen sind, kauf ich sie mir 100%, sonst mal abwarten. :drool:
Leider gibts noch rein gar nix zur 4870, ... von der 4850 gibts ja schon jede Menge geleakte Benches und Tests, .. aber 4870 scheint noch keiner zu haben, das ist schon komisch!
viel viel watt verbraucht ein gesammtsystem mit 4850? ist das schon getestet worden?
Was mich wundert, ist der im Vergleich zur G92 doch etwas höhere Stromverbrauch. Das hätte ich nach den ganzen vielversprechenden Ankündigungen so nicht unbedingt erwartet.
Habe nämlich mit der 4850 idle etwas über 110Watt, da war die G92 mit rund 100 Watt doch sparsamer.
Unter Last geht die 4850 sogar hoch bis auf über 180 Watt, bei der G92 kam ich max. bis auf ungefähr 160 W. So kann ich es mir nicht erklären, woher die allgemein vorherrschende Bewunderung über ATIs angeblich so vorbildlich guten Stromverbrauch kommt.
http://www.forum-3dcenter.org/vbulletin/showpost.php?p=6583140&postcount=1
Mal ein Gedanke: Wenn ATi das Crossfire bei der X2 verbessert hat und wirklich als eine GPU erkannt wird, kann man dann 4 X2's einsetzen? Ist zwar ein bissschen weit vorausgegriffen, aber theoretisch wäre das doch möglich?
Werde das zwar nie einsetzen aber mich interessiert halt die Technik dahinter :)
schon mal überlegt das 180W garnich sein kann? 75W übern slot und 75W übern 6pin anschluss, macht bei mir 150W maximal :d
treiber is noch beta, würde mal final abwarten, da komtmsicherlich noch was
Er meint sein Gesamtsystem!
Nachdenken, dann posten. :)
Daher scheint auch der Powerplaymode noch nicht korrekt zu funktionieren. Die Karte schaltet offensichtlich nicht in den 2D Modus.
Zitat von Schlammsau (3dcenter) :
hab hier mal eine kleine Zusammenfassung!
Jupp meinte sie Verbraucht in seinem System rund 10 Watt mehr als seine "alte" 8800GTS (G92) im Idle!
Laut xbit labs hat die GTS nen Idle Verbrauch von 38 Watt, ergo hätte die 4850 knapp 50 Watt Idle Verbrauch!
Eine 3870 hat 18 Watt Idle Verbrauch.
Also entweder die Karte schaltet aus irgendeinem Grund nicht in den Idle Mode, oder die ATi scheisst aufs Stromsparen.
http://www.forum-3dcenter.org/vbulletin/showpost.php?p=6585120&postcount=270
