hast du auch nen Test zur Xonar DX?
Nine Inch Nails - Capital G (Epworth Phones remix): Our listeners detected little difference between the Xonar DX and D2X on this track. However, both preferred the DX to the X-Fi.
Amy Winehouse - He Can Only Hold Her: Again, the Xonar DX fared well against the D2X. Our listeners were quick to praise both, although one thought that the track's piano elements sounded slightly better on the D2X. When pitted against the X-Fi, the Xonar did a much better job balancing the track's vocal and instrumental elements. Both listeners found the X-Fi's background content a little muffled behind the song's strong foreground vocals.
U2 - Original of the Species: One of our listeners found the Xonar D2X's vocals a little fuller than those of the DX, but the other couldn't tell the difference between the two. However, both agreed that the DX sounded better than the X-Fi.
Johnny Cash - I Won't Back Down: There are plenty of technical differences between the Xonar D2X and DX, but our listeners didn't prefer one over the other with this song. They did, however, think that the X-Fi sounded a little better than the DX here.
Jet - Are You Gonna be my Girl?: The Xonars like to rock, and our listeners both thought they sounded great here. One did say the DX sounded just slightly better, but couldn't say why. Both were in agreement that the X-Fi fell a little flat when compared with the Xonar
unten rechts auf das Lautsprechersymbol, dann Aufnahmegeräte, Mikrofon anwählen und Eigenschaften. Da müsste es dann irgendwo Mic Boost geben![]()
Würde eher sagen, dass liegt an den besch**** Treibern von Creatvie unter Vista![]()
Ok mein obiges Problem hat sich gelöst, Soundkarte(X-fi Xtreme Gamer) wird wieder erkannt und auch Treiber gehen wieder. Jetzt hab ich allerdings ein neues Problem, und zwar stockt der Sound bei der Wiedergabe mit der Soundkarte alle paar Sekunden, bzw alle paar Sekunden kommt nur ein bisschen Sound kurz. Woran liegt das? Kann mir wer helfen?
MfG
System: Cpu: E 6600
Graka: 8800GT @ 256 MB ram
Ram: 2 GB -800 G.Skill ram
Betriebssystem: Windows XP
Falls das irgendwie wichtig ist.
ch besitze derzeit die Soundkarte Audigy ZS 2 und die Creative Lautsprecher Z-2300 (2.1). Seit der Umstellung auf Vista (32bit), gefällt mir der Sound nicht mehr so richtig. Jetzt bin ich am überlegen, ob ich mir evtl. eine neue Soundkarte hole.
Meine Frage: Lohnt es sich eine X-Fi zu holen?
Wichtig ist für mich, dass ich hörbare Unterschiede bei Musikhören festelle.
Als Kopfhörer verwende ich übrigens Ultrasone HFI 650.
Ich bin ein wenig enttäuscht von der karte wo so ein hype drum gemacht wirdIch werde ab nächste Woche die Asus Xonar DX haben. Dann kann ich dir sagen, ob es sich rechnet umzusteigen. Der Treiber soll ja unter Vista um einiges besser sein.
naja habe bis jetzt in spielen nur stereo sound und nicht die eax emulation obwohl ich es einstellen kann unter vista funzt sie habe sie aber noch nicht richtig getestet da ich mehr xp benutze schade finde ich das es da kein upmix gibt auf 5.1 bei musik z.b oder ich habe die option nicht gefundenJa? Funktioniert der Treiber wenigstens unter Win Vista 64 Bit.
Was gefällt dir an der Karte denn nicht?
Das scheint überwiegend an den älterne Spielen zu liegen. Mal sehen was die Zukunft bringt.
Ihr scheint ja die Karte bereits zu haben, ist es möglich den optischen Ausgang zu benutzen und das Mikrofon dann über die Frontausgänge laufen zu lassen?
Hat hier schonmal den neuen OFFIZIELLEN Alchemytreiber rungergeladen, der auch für AUDIGY 4 Nutzer EAX KOSTENLOS unterstützt?
Funzt der gut?
Keiner getestet?
Wenn Creative eine vernünftige karte rausbringt werde ich die xonar verkaufen
