[Sammelthread] CyanogenMod
Sauber, für meins zwar noch nicht freigeben, aber ein Großteil der Geräte haben sie schon.
Vielen Dank für die Information.
Revert "New AT&T APN data" (android_vendor_cyanogen)
Update Russian translation. CMParts - New LED Settings (android_packages_apps_CMParts)
Czech: added translation (android_packages_apps_Pacman)
AWEXT: Add started and stopped wpa_msg statements (android_external_wpa_supplicant)
New AT&T APN data (android_vendor_cyanogen)
Update german translation (android_frameworks_base)
Show correct summary if resource not available. (android_packages_apps_CMParts)
Add support for new 6-band equalizer. (android_packages_apps_DSPManager)
Add a sub-bass eq band at 16 Hz (android_frameworks_base)
Update the ringer mode when adjusting ring volume. Related to "Don't lock out volume dialog in silent mode" under packages/apps/Settings. (android_frameworks_base)
Don't lock out volume dialog in silent mode. Related to "Update the ringer mode..." in frameworks/base. (android_packages_apps_Settings)
Add headset icon toggle (CMParts) (android_packages_apps_CMParts)
Add headset icon toggle (Framework) (android_frameworks_base)
french: advanced options translation (android_packages_apps_Camera)
Phone: Double check mode before changing (android_packages_apps_Phone)
Czech: some corrections, added missing strings (android_packages_apps_Gallery3D)
Add german translation for tablet overlay (android_vendor_cyanogen)
Update german translations (android_packages_apps_FM)
Updated Slovak Language (android_packages_apps_CMParts)
Updated Slovak Language (android_packages_apps_ADWLauncher)
Updated Slovak Language (android_packages_apps_AndroidTerm)
Updated Slovak Language (android_packages_apps_CMStats)
Updated Slovak Language (android_packages_apps_CMWallpapers)
Updated Slovak Language (android_packages_apps_GanOptimizer)
extended German translation (android_packages_apps_ADWLauncher)
Support Motorola Custom libcamera Parameters (android_frameworks_base)
Fix can't change in-call volume with screen off (android_frameworks_base)
cmparts: Updated Italian translations (android_packages_apps_CMParts)
Always make sure the timezone of the date parser is correct prior to parsing. (android_packages_apps_Contacts)
Add settings for devices that can use led settings but have no colors (android_packages_apps_CMParts)
Ensure actual delay in vibrate pattern (android_frameworks_base)
Format quiet hours according to locale (android_packages_apps_CMParts)
Fix for the race in Wallpaperservice (android_frameworks_base)
Fix to unbind BluetoothHeadset service (android_frameworks_base)
Remove unused strings (android_packages_apps_Superuser)
Remove unused strings (android_packages_apps_FileManager)
Remove unused strings (android_packages_apps_Email)
Remove unused strings (android_packages_apps_DeskClock)
Remove unused strings (android_packages_apps_DSPManager)
Remove unused strings (android_packages_apps_Camera)
Remove unused strings (android_packages_apps_CMStats)
Remove unused strings (android_packages_apps_Bluetooth)
Remove unused strings (android_packages_apps_ADWLauncher)
Set rfkill power off if turning BT on fails. (android_system_bluetooth)
Fix typo in translation name (android_packages_apps_CMUpdateNotify)
Clamp the duration of rotary animations. (android_frameworks_base)
Update Russian translation. Settings (android_packages_apps_Settings)
SystemUI: Fix typo (android_frameworks_base)
Delete a word by pressing shift-backspace. (android_packages_inputmethods_LatinIME)
Fix A2DP not connecting while asleep. (android_frameworks_base)
SmtpSender: Send EHLO that adheres to RFC2821 (android_packages_apps_Email)
Add UI checkbox for muting camera shutter sound (android_packages_apps_CMParts)
Give consistent names to properties controlling camera shutter sound (framework part). (android_frameworks_base)
Updated Swedish translations (android_packages_apps_CMParts)
Add seperate preference category for lockscreen music controls (android_packages_apps_CMParts)
Android Issue #9307 fixed - Partial wake lock released (android_packages_apps_Email)
Support Korean SMS encoding (android_frameworks_base)
add the ability to include liblog in libcutils (android_system_core)
libaudio-msm7x30: aic3254 fix/cleanup (android_hardware_msm7k)
libloc: remove duplicate entry (android_hardware_qcom_gps)
Czech: added translation (android_packages_apps_DSPManager)
Czech: added translation (android_packages_apps_CMWallpapers)
Czech: added translation. (android_packages_apps_CMUpdateNotify)
Czech: added translation, corrected with help of Standa (android_packages_apps_FM)
Czech: added translation (android_packages_apps_FileManager)
libaudio-msm7x30: correct another fm ifdef derp (android_hardware_msm7k)
FM: Improved interaction with other android sounds (android_packages_apps_FM)
Touch to focus support for Atrix camera (android_packages_apps_Camera)
camera: Add touch-to-focus for OMAP4 cameras (android_packages_apps_Camera)
Add static busybox back (android_external_busybox)
libui: Add support for the Xperia Play jogdials (android_frameworks_base)
LGEStarRIL: Slight adjustments to init sequence (android_frameworks_base)
libaudio-msm7x30: call aic function only if enabled (android_hardware_msm7k)
libcore: Update cacerts from Guardian Project (android_libcore)
Add HTC Saga (Desire S) (android_vendor_cyanogen)
Explicitly specify the exact library dependency to liblog instead of libcutils (android_external_dnsmasq)
Phone: Set MSISDN on boot from saved setting if SIM returned empty "My Phone Number" (android_packages_apps_Phone)
libpixelflinger: Avoid conflict symbols by hiding (android_system_core)
libcutils: ripe off duplicated functions originally in liblog (android_system_core)
si4709: FM seek up/down support (android_frameworks_base)
Fix the frequncy unit mismatch between the FM app and the driver. (android_frameworks_base)
libaudio-msm7x30: fix ifdef derp (android_hardware_msm7k)
libaudio-msm7x30: turn off debug messages (android_hardware_msm7k)
libaudio-msm7x30: fix build without FM (android_hardware_msm7k)
Fix wrong category for envelope/explorer (android_packages_apps_CMParts)
Fix typo in APNs (android_vendor_cyanogen)
CMParts: Fix compile error (android_packages_apps_CMParts)
Dann werd ich auch mal wieder ein aktuelles Nightly flashen heute nach der Arbeit von 172 zu 203 :d
Ist das denn mittlerweile schon 2.3.6 oder noch 2.3.5?
Nutzt jemand von euch CM auf einem Galaxy S2? Ich finde es laeuft laggy (Homescreen, Browser) und die Farben vom Display sind verfaelscht. Kann man da was machen? Oder laeufts bei euch super?
Ich bin nun wieder mit einem angepassten Stock-Rom unterwegs und es fuehlt sich sehr viel flotter an...nur ich kann keine Lieder mehr skippen mit den Lautstaerke-Tasten :(
Ich nutze CM7 auf dem SGSII. Läuft einwandfrei. Hatte am Anfang auch leichte Ruckler, welche aber mit einem anderen Launcher nicht auftreten.
Sent from my GT-I9100 using Tapatalk
Das war der Grund warum ich im Moment von Cyanogen weg bin.
Scrollen über die Homescreens waren doch sehr laggy. Die anderen Probleme konnte ich nicht beobachten.
Kann es an CM liegen, dass das Handy andauernd bei Worms abschmiert?
Abschmieren heißt Neustart...
Hatte das vorher nie, aber da hatte ich auch Worms noch nicht. Zumindest habe ich das jetzt auch bei keinem einzigen Spiel oder so bis jetzt gehabt.
CM ist 7.0.3
Wenn das nur bei Worms auftritt, würde ich eher auf das Spiel tippen. Unterstützt dein Phone das Spiel denn?
Ich weiß nicht, ob mein handy das unterstützt, aber wieso nicht? ist ein desire, gehen solche spiele nicht bei jedem android handy?
was flashen wollt ich eigentlich nicht, funktioniert ja alles. wenn ich dann irgendwann ne 32gb sd kaufe flash ich mir irgendwas tolleres, wobei ich immer noch nicht verstanden hab, was nightly eigentlich ist :fresse:
Das Nexus S hat heute einen neuen Kernel bekommen, in diesem gibt es immer noch nicht die OC Funktion.
Beim Desire ging das ja problemlos.
Könnt ihr mal bitte schauen ob ihr das habt?
Ganz interessant wäre es auch bei einem Galaxy S, weil es ja die gleiche CPU ist.
Meine Vermutung ist das es mit dem Hummingbird zusammen hängt.
Heute wieder ein großes Update.
Man kann jetzt Kalendereinträge auf dem Lockscreen sehen.
Zudem lässt sich die Anordnung der Widgets auf dem Lockscreen ändern.
HTC Ril: initial support (android_frameworks_base)
if NO_RGBX_8888 is defined, use it for both substitutes (android_frameworks_base)
saga: AicBootFix not needed with source audio (android_vendor_cyanogen)
Testing page: Do not send extraneous setPreferredNetworkType request to system (android_packages_apps_Settings)
Lockscreen Widget Layout (2/2) (android_packages_apps_CMParts)
Lockscreen Widget Layout (1/2) (android_frameworks_base)
Added greek translation to CMUpdateNotify (android_packages_apps_CMUpdateNotify)
AicBootFix not needed with source audio Update DSP files for Inspire 4G (android_vendor_cyanogen)
Add saga support [Desire S] (htc-kernel-msm7x30)
htc: msm7x30: switch to source audio (android_device_htc_msm7x30-common)
Update DSP for ace to use source libaudio (android_device_htc_ace)
Lockscreen calendar improvements (2/2) (android_packages_apps_CMParts)
Lockscreen calendar improvements (1/2) (android_frameworks_base)
Lockscreen next calendar alarm (2/2) (android_packages_apps_CMParts)
Lockscreen next calendar alarm (1/2) (android_frameworks_base)
CameraService: Add support for YCrCb_420_SP overlay format (android_frameworks_base)
Fix for WiMAX signal indicator icon after 2.3.5 merge (android_frameworks_base)
FM: Don't disable on bluetooth toggle if bluetooth is not required (android_packages_apps_FM)
Enable SlidingTab animation when releasing slider (android_frameworks_base)
Use the actual charging status instead of the plugged status to determine if the battery is charging. (android_frameworks_base)
Avoid overhead of redundant task manipulation when it gains focus (android_frameworks_base)
Fix alignment issues in AVRCP 1.3 code. (android_external_bluetooth_bluez)
vold: extend the syntax of vold.fstab (android_system_vold)
vold: add class AutoVolume to support auto-mount and fake sdcard (android_system_vold)
Czech: fixed translation (ouch, who translate this?), added missing strings (android_packages_apps_Browser)
Update Russian translation - SMS/MMS (android_packages_apps_Mms)
Smooth biquad interpolation for equalizer (android_frameworks_base)
Optimize lenght of String (android_packages_apps_Settings)
FM: support seeking on broadcom hardware (android_frameworks_base)
libui: Always allocate buffers from gralloc (android_frameworks_base)
SurfaceFlinger.cpp: Check for NULL in removeLayer() (android_frameworks_base)
torch: remove galaxy s 2 from spagetti code, uses overlay now (android_packages_apps_Torch)
Fix uninitialized variable warning pointed out by gcc flag -fdata-sections (android_dalvik)
Updated Slovak Language (android_packages_apps_FileManager)
Updated Slovak Language (android_packages_apps_DSPManager)
Updated Slovak Language (android_packages_apps_Contacts)
Updated Slovak Language (android_packages_apps_CMUpdateNotify)
Updated Slovak Language (android_development)
Updated Slovak Language (android_packages_apps_FM)
Option to disable combo scan (android_external_wpa_supplicant_6)
Disable auth bypass, and reduce bad passwd auth to 3 tries (android_external_dropbear)
Phone: Double check mode before changing, part 2 (android_packages_apps_Phone)
Czech: added translation (android_packages_apps_Torch)
Updated Slovak Language (android_packages_apps_SoundRecorder)
Updated Slovak Language (android_packages_apps_Phone)
Czech: revised translation, added missing strings (android_packages_apps_Superuser)
Updated Slovak Language (android_packages_apps_VoiceDialer)
Updated Slovak Language (android_packages_apps_Torch)
Updated Slovak Language (android_frameworks_base)
Enabled Language Keyboard (android_packages_inputmethods_LatinIME)
PT-BR: Add missing translations (android_packages_apps_CMParts)
Update Russian translation. Headset icon toggle (android_packages_apps_CMParts)
Traditional Chinese: Update translations for loudness mode (android_packages_apps_DSPManager)
Czech: corrected some strings and added missing strings. (android_packages_apps_Settings)
Traditional Chinese: Update translations (android_packages_apps_CMParts)
french: shutter sound, headset icon, and camera button settings (android_packages_apps_CMParts)
Czech: minor changes and adding missing strings, 2nd try (android_packages_apps_Music)
Add Russian translation - GanOptimizer (android_packages_apps_GanOptimizer)
Added greek translation to CMStats (android_packages_apps_CMStats)
Added greek translation to CMParts.apk (android_packages_apps_CMParts)
Czech: added missing strings and made some corrections (android_packages_apps_DeskClock)
Czech: removed redundant strings from origin, added missing strings for timer shutter (android_packages_apps_Camera)
Use NumberFormat to format frequency (android_packages_apps_FM)
fix missing emulator sdcard support (android_system_core)
Cool, mal sehen, wann es für mein Handy ein Update gibt.
Habe im Moment habe ich noch eine Alph-Version auf meinem Atrix, wobei es sehr gut läuft.
Einzig was fehlt, ist die Unterstürzung für den Fingerabdruckscanner. Gibts dazu schon was neues?
mach doch einfach einen anderen kernel drauf der oc erlaubt...
Nein dann muss ich ja jeden Tag den Kernel mit flashen.
Heute wieder recht großes Upate, man kann nun wohl andere Endsperroptionen nutzen.
Werde ich mir gleich mal anschauen. :)
Gibt es eigentlich eine Möglichkeit beim flashen des Updates den vorherigen Kernel zu behalten?
Bin gerade dabei cm_bravo_full213.zip zu flashen, allerdings hängt er gerade schon seit 5min bei "Opening update Package..." Backup hab ich gemacht und Dalvik cache gewipte was soll ich jetzt machen erstmal weiter warten?
Ich gehe davon aus das die Datei beschädigt ist.
Erneut runterladen, auf das Telefon packen und noch einmal drüber installieren.
Ich habs jetzt nochmal drüber geflasht, hatte allerdings nen boot loop , weil ich dann Dalvik chache net wieder gelöscht hatte. Jetzt hab ich den gewipte und nochmal geflasht. Wenns jetzt wieder nicht geht lad ich mir die Zip nochmal neu.
es ging dann, aber iwie hat er die sync mit meinem google konto verloren. Ich spiel jetzt erstmal das backup zurück und flasht dann nochmal sauber drüber.
---------- Beitrag hinzugefügt um 14:28 ---------- Vorheriger Beitrag war um 13:41 ----------
jetzt sagt er mir "error: run 'nandroid-mobile.sh restore' via adb" ... bin dann mal das android sdk installieren und den restore per PC machen.
---------- Beitrag hinzugefügt um 15:31 ---------- Vorheriger Beitrag war um 13:41 ----------
so back über die adb shell zurück gespielt. Das erstemal booten hat ne ewig gedauert aber alles wieder da. reicht erstmal für heute mit rumfrickeln, bleib ich erstmal bei meinen nightly.
ich habe ohne Probleme Navigon aufm SGS unter CM7 #131 am Laufen. Was klappt denn nicht?
sobald ich die 2.6.1 auf meinem DHD installiert hab und diese starte, schmiert der prozess ab :fresse:
als ich noch das virtuous unity rom drauf hatte, liefs nicht da die cpu mit 1200 MHz getaktet war, doch unter CM7 hab ich die cpu atm lediglich auf 1024 MHz laufen und es läuft trotzdem nicht^^
Versuch es doch mal mit 2.6.2. :fresse2:
2.6 ging bei mir auch net 3.5.4 aber.
hm, laut ner anleitung solle man wohl erst 2.6.1 und danach die version 3.5.x installieren usw...aber wie gesagt, nicht mal die vorherige version läuft.
edit:
gerade gelesen, dass die 2.6.1 generell ab android version 2.3.x. wohl nicht mehr funktionieren soll. wie dem auch sei, ich werde es mal auf einen anderen weg versuchen ;)
