[Sammelthread] DFI LANparty DK 790FXB-M2RS / -M2RSH / -M3H5 / 790GX-M2RS (AMD 790FX / 790GX) [2]
Sammelthread
Inhaltsverzeichniss:
top
AM2+
AM3
Anhang:
AM2+
AM3
Vorwort:
Da die Boards nahezu identisch ausgestattet sind habe ich nur die Details zusammengefasst, die sich von den anderen unterscheiden. Die Features die fehlen, kann man vom M2RSH übernehmen.
Nun gehts also los mit dem Sammelthread der DFI Lanparty DK series:
AM2+:
790FXB
DFI Lanparty DK 790FXB-M2RS
I. Technische Details zum Board:
CPU:
  • AMD Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
  • Socket 940 AM2 65nm
Chipset:
  • Northbridge: AMD 790FX
  • Southbridge: AMD SB750
System Memory:
  • Four 240-pin DDR2 DIMM sockets
  • Supports DDR2 667 and DDR2 800 DIMMs
  • Supports dual channel (128-bit wide) memory interface
  • Supports up to 8GB system memory
  • Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots
    - 2-way or 4-way CrossFire at x16/x16/NC bandwidth
    - 3-way CrossFire at x16/x8/x8 bandwidth
    - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
  • 3 PCI slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM overclocking
  • CPU/DRAM/Chipset overvoltage
  • 8Mbit flash memory
  • AM3 support ab BIOS-Version R7SD327 (beta), bzw. R7SD421 (final)
Audio:
  • Realtek ALC885 8-channel HD Audio Codec
  • High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
LAN:
  • Marvell 88E8053 PCIE Gigabit LAN controller
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
Power Management:
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 Keyboard/Mouse
  • Wake-On-USB Keyboard/Mouse
  • Wake-On-Ring
  • Wake-On-LAN
  • RTC timer to power-on the system
  • AC power failure recovery
Hardware Monitor:
  • Monitors CPU/system/chipset temperature
  • Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature during system boot-up
IDE:
  • One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Serial ATA with RAID:
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O:
  • 1 mini-DIN-6 PS/2 mouse port
  • 1 mini-DIN-6 PS/2 keyboard port
  • 1 optical S/PDIF-out port
  • 1 coaxial RCA S/PDIF-out port
  • 6 USB 2.0/1.1 ports
  • 1 RJ45 LAN port
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
Internal I/O:
  • 2 connectors for 4 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 front audio connector
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 4 Serial ATA connectors
  • 1 40-pin IDE connector
  • 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 6 fan connectors
  • EZ touch switches (power switch and reset switch)
PCB:
  • ATX form factor
  • 24.5cm (9.64") x 30.5cm (12")
II. Layout:
III. Reviews:
http://www.ur-hardware.com/mainboard/40-review-dfi-lanparty-dk-790fx
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...ormal&mode=view&downloadFlag=false&itemId=539
Treiber: http://www.dfi.com.tw:8080/portal/C...normal&mode=view&downloadFlag=true&itemId=539
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383889.html
M2RSH
DFI Lanparty DK 790FX-M2RSH
CPU:
  • AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron
  • HyperTransport 3.0 (5200MT/s for AM2+)
  • AMD OverDrive provides tuning options using the new“Advanced Clock Calibration” overclocking feature.
  • Socket 940 AM2+ 65nm
Chipset:
System Memory:
  • Supports DDR2 667/800/1066 MHz DIMMs
Expansion Slots:
  • 3 PCI slots
II. Layout:
III. Reviews:
http://www.modreactor.com/english/R...XB-M2RSH-AMD-LanParty-Motherboard-Review.html
http://www.overclock.net/amd-motherboards/399854-smt-review-dfi-lanparty-790fxb-m2rsh.html
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Treiber: http://www.dfi.com.tw:8080/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=driverTab&windowstate=normal&mode=view&downloadFlag=true&itemId=547
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383891.html
790GX
DFI Lanparty DK 790GX-M2RS
CPU:
Chipset:
  • Northbridge: AMD 790GX (RS780)
Expansion Slots:
  • 2 PCI Express (Gen 2) x16 slots
    - Hybrid CrossFireX - combination of the integrated graphics and a discretegraphics card in a PCIE slot (8-lane port).
    - Two graphics cards support CrossFireX; each operating at x8 (8-lane ports)bandwidth
  • 1 PCI Express x1 slot
  • 3 PCI slots
Graphics:
  • Integrated ATI Radeon HD 3300 graphics core
  • One DVI-I connector for digital LCD display (ACHTUNG!! DVI Anschluss nur als Pin-Connector ausgeführt)
  • Microsoft® DirectX 10
  • Hybrid CrossFireX technology combines the onboard GPU and adiscrete PCIE graphics card
  • Onboard Performance cache for added performance
II. Layout:
III. Reviews:
http://www.madshrimps.be/?action=getarticle&articID=894
IV. Links:
Link zum "DVI-Problem": http://www.csd.dficlub.org/forum/showthread.php?t=8221
Treiber: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a356442.html
Lanparty JR Sammelthread: http://www.hardwareluxx.de/community/showthread.php?t=590779
hex
Anhang:
Für erweiterte Optionen im BIOS F9 drücken!
Achtung an alle Extrem-OC´er: das Board zeigt nur maximal -83°C an !
Hexcode Tabellen Für CPU-NB-VID und NB-Multi(790FXBM2RS/H):
tabelle
Vergleich zwischen den Boards:
kühler
Kompatible Kühler:
790FXB-M2RS(H):
passt:
Cooler Master Hyper TX (bläst nach hinten)
EKL Alenföhn Groß Clock'ner Blue Edition (bläst nach hinten)
EKL Alpenföhn Brocken (bläßt nach oben)
Scythe Infinity/Mugen (bläst nach oben)
Thermalright IFX-14 (bläst nach hinten), (ACHTUNG: bei verwendung der Thermalright Backplate auf Isolierung achten!)
Thermaltake GunMetal Orb (bläst nach unten)
OCZ Vanquisher (bläst nach oben)
Xigmatek HDT-S1283 (bläst nach oben)
Zalman CNPS 9500AM2 (nach hinten)
passt mit Modifikationen:
passt nicht:
790GX-M2RS:
passt:
passt nicht:
passende Wasserkühler für NB/SB und Spawa´s gibt es bei Anfi-tec oder Watercool
Lochabstände vom NB-kühler, Danke an Andreoid von Anfi-tec :bigok:
ram
RAM Kompatibilitätsliste:
790FX-M2RS/H:
läuft:
Cellshock 2x 1GB DDR2-667 (CS2110650)
GeIL DIMM 4 GB kit DDR2-800 (GX24GB6400C4UDC)
G.Skill Pi Series 4GB DDR2 1100 (F2-8800CL5D-4GBPI)
G.Skill 4GB kit DDR-1000 (F2-8000CL5D-4GBPQ)
Kingston HyperX 4GB kit DDR-1066 (KHX8500D2K2/4G)
Mushkin 4GB kit DDR-1066 (996599)
OCZ Platinum XTC 4GB kit DDR-800 (OCZ2P10004GK)
OCZ Titanium 4GB kit DDR-1150 (OCZ2T11504GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800C32GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800EB2GK)
OCZ Reaper HPC 2x2GB kit DDR2-1066 (OCZ2RPR10662G), (Tony´s SPD)
OCZ XTC Platinum 2 GB kit DDR2-1066 (OCZ2N10662GK)
macht Probleme:
läuft nicht:
Vollbestückung:
4GB
2x1GB OCZ Reaper (OCZ2RPR800C32GK) + 2x1GB OCZ Reaper (OCZ2RPR800EB2GK)
DDR800 | CL4-4-4-12 | Vdimm 2,0V
4x1GB Aenon Xtune DDR1066 | CL5-5-5-15 | Vdimm 1,85V
6GB
2x2GB Geil Ultra Plus (GX24GB6400C4UDC) + 2x1GB Cellshock
DDR800 | CL4-4-4-10 | Vdimm 1,85V
8GB
4x2GB G.Skill Pi Series (F2-8800CL5D-4GBPI) | DDR800 | CL5-5-5-18 | Vdimm 1,9V
2x4GB kit Mushkin XP2-8000 (996591) | DDR1000 | CL5-5-5-15 | Vdimm 2,1V
2x4GB kit
Mushkin DDR-1066 (996599) | DDR1066 | CL5-5-5-15 | Vdimm 2,05V
790GX-M2RS:
läuft:
Aeneon Xtune DIMM 2 GB DDR2-1066 Kit (AXT760UD00-19DM97-K-2G)
macht Probleme:
OCZ Reaper HPC 2 GB DDR2-1066 Kit (OCZ2RPR10662GK); (abstürtze mit 1066Mhz)
läuft nicht:
Vollbestückung:
4GB
6GB
8GB
Tipps für 8GB RAM bei 1066Mhz *klick*
FAQ
FAQ:
Q: Ab welcher BIOS-Version bietet das Board Deneb-Support?
A: Ab FinalVersion R7SDC26
Q: Ab welcher BIOS-Version bietet das Board AM3-Support?
A: Ab Final Bios R7SD421 bzw. ab Beta R7SD327
Q: Mit welcher BIOS-Version lassen sich die X3´s freischalten?
A: Beta Version R7SD310A
Q: Wie flashe ich mein BIOS mit einem USB-Stick?
A: Tutorial auf der DFI-Club-Seite *klick*
Eine deutsche Übersetzung der POST Codes aus dem Handbuch findet ihr HIER
under construction...
AM3:
m3h5
DFI Lanparty DK 790FXB-M3H5
CPU:
  • AMD Phenom II processor
  • HyperTransport 3.0 (5200MT/s), HyperTransport 1.0 (2000/1600MT/s)
  • AMD OverDrive provides tuning options using the new "Advanced Clock Calibration" overclocking feature.
  • Socket 938 AM3 45nm
Chipset:
System Memory:
  • Four 240-pin DDR3 DIMM sockets
  • Supports DDR3 1600 (O.C.)/1333/1066Mhz
  • Supports non-ECC unbuffered DIMMs
  • Supports up to 16GB system memory
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots - 2-way crossfire at x16/x16 or x16/x4 bandwith - 3-way crossfire at x16/x16/x4 bandwith
  • 3 PCI-Slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM Overclocking
  • CPU/DRAM/Chipset Overvolting
  • 8Mbit SPI Flash Memory
Audio:
Lan:
  • Marvell 88E8056 PCIE Gigabit LAN controller
  • SATA speed up to 3GB/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
IDE:
  • One IDE connector allows up to two UltraDMA 133Mbps hard drives
Rear Panel I/O Ports:
  • 1 RJ45 LAN port
  • line-in, line-out (front R/L) and mic-in jacks
I/O Connectors:
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 6 Serial-ATA connectors
  • 6 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power and reset switch)
Power Management:
  • ACPI STR (Suspend to RAM) funktion
  • Wake-On-Ring
  • Wake-On-LAN
Hardware Monitor:
  • Monitors 12V/5V/3,3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • CPU Over Heat Protection function monitors CPU temperature during system boot-up
PCB:
  • ATX form factor
  • 24,5cm (9,64") x 30,5cm (12")
II. Layout:
III. Reviews:
User-Review von Öse:
http://www.hardwareluxx.de/community/showpost.php?p=11771090&postcount=1
http://www.ninjalane.com/reviews/motherboards/lanpartydk-790fxb-m3h5
IV: Links:
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a417781.html
kühler
Anhang:
Kompatible Kühler:
Die Sockelhalterung entspricht exakt der AM2(+) version, daher passen alle Kühler die auch mit dem M2RS(H) kompatibel sind.
Passende Wasserkühler:
Das Boardlayout entspricht ebenfalls dem des M2RSH, daher passen alle Wasserkühler die auch mit dem 790FXB-M2RS(H) verwendet werden können.
Ich muss sagen in Zusammenhang mit Win 7 stinkt das Board echt zum Himmel.
In Hoffnung auf Besserung und Finalität hab ich vorgestern schließlich Win 7 final installiert (hatte vorher lange den RC), doch alle meine alten Problemchen sind die selben geblieben. Keine Weltbewegenden aber allesamt nervig.
a) Nach ca. 10 Reboots eines frisch aufgesetzten Systems inkl. Installation der notwendigsten Treiber und Updates passiert jedes Mal wieder das gleiche: Windoof schaltet den Rechner nicht ordentlich aus. Das drückt sich darin aus, dass wenn ich Neustarten will, der Rechner nach dem runterfahren hängen bleibt und ich ihn per Reset zum Neustart bewegen muss. Oder wenn ich den Rechner heruntergefahren hab und wieder anmachen möchte (ohne ihn zwischenzeitlich vom Strom getrennt zu haben) bleibt der Bildschirm schwarz und der Rechner bootet nicht (gibt auch keinen Piep von sich). Ich kann ausschließen dasses von Treibern verursacht wird, das hab ich bereits ausprobiert.
b) Mit aktiviertem AHCI braucht Windows eeeeeewig zum booten (gemeint ist der "Windows wird gestartet..." Bildschirm). Über 40 Sekunden braucht er dann an dieser Stelle. Wenn ich den SATA Mode auf IDE umstelle, ist er nach ca. 10 Sekunden damit durch. Will aber AHCI :(
Hi B0s
ich kann dem nicht beipflichten, meins rennt seit der RC unter win 7 wie ein binchen, keine Probs damit, klar ahci könnte schneller sein aber das stört mich weniger.
Hast du das mit übertaktung oder ohne deine Stabilitäts probleme?
lg
Wie ist das mit der AHCI Performance merkt man das nur beim Booten !? Meine SSD macht zumindest bei den Benchmarks mit AHCI unter Win7 an der SB750 ein sehr gute Figur. Aber das Windows wird gestartet, dauert bei mir auch seeehr lange, habt ihr mal den AHCI Treiber upgedatet !?
Ist das DFI LANPARTY DK 790X-M2RS gut?
Auf Alternate hat es der eine schlecht bewertet mit Freezes usw....
ich stehe grad vor einer Entscheidung und brauche Rat bezüglich des Ram-Ocens beim DK 790FXB-M2RSH :
Situation:
Entweder ich verkaufe meine 4x1GB Kingston HyperX 9600 (Schaffen die 1200 auf einem P45 locker[Micron GKX]) und kaufe mir neuen DDR3 Speicher + ein AM3 Board
oder
ich behalte den Speicher und lege mir das DK 790FXB-M2RSH zu.
Meine Frage ist, ob das M2RSH die 1200 oder 1100@scharfen Timings mitmacht? Mein aktuelles Gigabyte 790X UD4 kann den Speicher nicht annähernd ausreizen bzw. beschränkt die Timings automatisch ab 1066 auf 4 - 5- 5...ich erreiche auch nur max. 1120 bei rel. entspannten Timings.
Als CPU habe ich einen PII 965 BE
Hi B0s
lg
Also Probleme mit Stabilität habe ich keine, nur besagte Probleme, welche eher in die Kategorie "nervig" fallen. Ich betreibe meinen PII 940 quasi seit der ersten Stunde mit 3,4 GHz Core, 2,4 NB und 2 HT was ohne Anhebung irgendwelcher Spannungen schon immer stabil funzt. Ich werds mal auf Default testen, allerdings seh ich da so erstmal keinen Zusammenhang.
Ich hatte bei meiner letzten Win 7 RC Installation mal den ATI AHCI Treiber per Datenträger eingebunden. Die "Windows wird gestartet."-Zeit verkürzte sich merklich, aber nicht auf das gleiche Niveau wie im IDE Modus. Außerdem war es dann unter Windows nichtmehr möglich die SMART-Werte inkl. der HDD-Temperatur auszulesen. Da mir sonst keine Unterschiede zwischen den Treibern aufgefallen sind, habich ihn diesmal wieder außenvor gelassen.
Ich hab übrigens heute mal mein BIOS von der offiziellen April-Version auf die momentane Beta vom Oktober aktualisiert, was jedoch keine Änderung brachte.
Hi Armageddons3dge
hm also ich hoffe dir ist bewust das die Hochtaktung des speichers bei den AMD Prozzessoren schwerer ist wie bei den derzeitigen intel.
Ok soweit so gut ich hab meine 800 bisher auf 1100 gebracht aber wenn das bei dir
ähnlich läuft brauchst du dazu viele nerven und gedult.
ansonsten viel spass.
lg
A: Einstell möglichkeiten sollte das DFI in jedemfall genug bieten.
B: Hast du es beim AMD wirklich schwerer denn da hinzubringen wo du ihn haben willst, ich würde auf 1066er gehen und die Timing so hart anziehen wie möglich, sollte sowieso das meiste bringen..
C: Ist vollbestückung immer etwas mehr arbeit für dem MC, obwohl das bei 4x1GB nicht sooo schlimm ist wie bei 4x4gb.
D: Sind Ram settings sowieso nicht soooo wichtig, es sei den du willst SuperPi oder Everest zocken.
Mal ne Frage. Bindet ihr Sata treiber ein wenn ihr euer Windows neu aufsetzt?. Und welchen Silicon version hat das M2RSH blick da mal gerade net durch
Hi blackbandt
wenn du AHCI nutzen möchtest mit Win XP wirst du da nicht drum herum kommen das bei der Installation einzubinden.In Vista Win7 sollte eine installation mit legace IDE problemlos möglich sein und dann nach der Treiber Installation den Mode im Bios auf AHCI ändern.
Welcher zusatzkontroller da drauf ist ka. ich installiere immer den DFI Treiber und da ist alles bei, leider ist der was größer ;)
lg
hmmm Ok also den DFI chipsatz Treiber von der Hp?
Genau, bzw. einfach den von AMD, ist ja bei allen SB750 MoBos gleich. DFI hat nämlich keinen Zusatzcontroller verbaut.
ok alles klaro
Hi
naja bei AMD bekommst du ihn einzeln, bei DFI als Paket mit allen Treibern samt USB Chipsatz Audio etc.
lg
Hat noch irgendwer nen Tipp für mich und meine zwei Problemchen?
Sollten sie sich nicht in den Griff kriegen lassen, ziehe ich ernsthaft in Erwägung auf ein anderes Board umzusteigen...
Hi
also ich gelaube nicht das mit ahci viele boards wirklich schneller sind?
das liegt an der umsetzung als eigenständiger Controller Modus
ähnlich einem zusatzkontroller SATA oder SCSI dort wurde auch immer
erst nachher ein Scan der Laufwerke aktiv und das dauert leider immer
länger wie native ide implementationen.
Ich hoffe das meintest du.
Habe die letzten tage festgestellt das ich ab und an komische Fehler
bekommen beim Spielen eines Spieles, und werden mal die Chipsatztreiber
von Vista auf win 7 updaten, da zu meiner instalationszeit diese noch
nicht verfügbar waren, ausserdem hat der Cat. 9.9 einige schöne bugs.
lg
Naja Ziel der AHCI Aktion ist ja bestimmte SATA-Features nutzen zu können, wie Hot-Swap und NCQ.
Dass der Scan nach SATA Laufwerken zusätzlich Zeit in Anspruch nimmt, da es ja ein eigener Controller ist, ist selbstverständlich, auch wenn das bei mir nicht zutrifft, da ich den IDE-Controller gänzlich deaktiviert habe. Wie dem auch sei, diese Zeit meine ich nicht.
Die Zeit die beim "Windows wird gestartet." Bildschirm vergeht ist mit AHCI einfach deutlich länger als mit IDE. Als ob er da ne Denkpause macht.
Die Catalyst Chipsatz Treiber hab ich btw noch nie installiert bringt das irgendwas?
Hi B0s
ja es würde etwas bringen aber ich empfehle dir den neuen w7/vist treiber von DFi der hat bei mir zumindestens diese Probleme nicht erbracht wie du sie beschreibst.
Ich habe auch nach deinen Fragen auf AHCI wieder umgestellt und habe nicht gemerkt das sich da signifikant etwas geändert hätte dadurch. Einzig das das Booten bis ich das System Boot auswählen kann ist um einiges langsamer.
lg
Hallo! :wink:
Ich erwarte in Kürze mein allererstes DFI LANparty MB, nämlich dass "DK 790FXB-M2RSH", welches ich zum Schnäppchenpreis von 60 Mücken bei einem gewissen Onlineversandhändler im hohen Norden (weiß nicht ob man den Namen hier ausschreiben darf), erworben habe.
Hinzu kommt ein Phenom II X4 955 Black Edition + 4 GiB RAM DDR2-1150 OCZ XTC Titanium (welches ich bei passender Gelegenheit auf dann 8 GiB zu erweitern gedenke), aber dies nur nebenbei.
Ich werde von einem Q6600 auf Standardtakt, welcher auf einem BIOSTAR MB, nämlich dem GF7050V-M7 sitzt (4 GiB DDR2-667), wechseln, ich weiß, jetzt werdet ihr mich bestimmt auslachen, aber als ich mir diese Kombination zulegte, so Ende 2007, Anfang 2008 herum, da war dies nach jahrelanger PC Abstinenz mein Wiedereinstieg in die Welt der Bits'n Bytes und in der Zwischenzeit hat man ja doch so einiges dazugelernt... :asthanos:
So, ich hoffe ich gehe mit meinen Fragen keinem der Alteingesessenen auf den Zeiger, aber kann mir einer 100% gesichert durchgeben, welches ABS Profil am aktuellsten für mein neues MB sind?
DFI Auto Boost Profile for LANPARTY DK 790FXB-M2RSH. Ver.R7SDA17
DFI Auto Boost Profile for LANPARTY DK 790FXB-M2RSH. Ver.R7SDA30
DFI Auto Boost Profile for LANPARTY DK 790FXB-M2RSH. Ver.R7SD706
sind so, ohne weiteren Angaben für mich nämlich eher erst einmal kryptisch... :confused:
Wenn ich diese Hürde genommen habe, habe ich vor aufs aktuellste Beta BIOS mit Datum vom 8. Oktober 2010 (ja, ich weiß was Beta bedeutet und traue mir dies zu) zu flashen, irgendwelche Einwände bzw. Vorsichtsmaßnahmen durch eventuell vorher zu aktualisierendes ABS Profil o. ä.? Ob ich per .zip oder per .exe auf einem bootbaren USB-Stick flashe, dürfte ja egal sein, richtig?
So, noch ein paar letzte Fragen (vorläufig):
Welchen der beiden LAN Treiber auf der DFI Seite benötige ich?
Diesen "USB resume from S3 patch file for USB Keyboard" Treiber benötigt man wofür genau?
Mir dünkt, wenn ich weder Ruhezustand noch Standby nutze, dann eh obsolet für meinereiner, auch wieder richtig?
Ich habe vor, den 955 BE von 3.2 GHz auf dann stabil laufende 3.6-3.7 GHz zu bringen, denke mal dies dürfte drin sein, irgendwelche Erfahrungsberichte bzw. Ratschläge insbesondere mit Vorgabe 24/7 Betrieb?
Oder würdet ihr diese Übertaktung lieber ganz bleiben lassen, da es den "Braten eh nicht fett macht"?
Alsdann, DFI Jünger... :hail:
moin colonel,
herzlich willkommen bei DFI ;)
willst du ABS nutzen? ich halte es für ne sinnlose spielerei. die BIOS-profile kannst du auch direkt im BIOS speicher (4 stück) un d auch dort direkt laden.
falls doch, das aktuelle profil ist das R7SD706.
wenn du mit dem flashen per USB vertraut bist, nimm die .zip und schieb die dateien manuall auf den stick.
nimm erstmal den von der CD. später dann direkt bei marvell nach dem aktuellsten schauen oder über windows-update ( je nach BS )
garnicht, ist auch nicht mehr verfügbar bei DFI.
guckst du da mal rein ;)
http://www.hardwareluxx.de/community/showthread.php?t=627914
viel erfolg
Hi B0s
lg
Danke für den Tipp, die Treiber von der DFI Seite hab ich bisher nie beachtet. Werde ich gleich mal ausprobieren.
BTW: Hurray!!! Die DFI Seite funzt mittlerweile auch im Opera! (früher musste ich immer den IE bemühen um nach BIOS-Updates etc. zu schauen)
EDITH schimpft: na toll, es ist genau eingetreten, was ich vermutet hab: Das ist der gleiche unnütze MoBo Treiber wie auf der AMD Seite: nämlich der stinknormale GraKa-Treiber. Steht nur Mobo dran weil die IGPs damit versorgt werden können.
Allerdings sehe ich gerade, dass ENDLICH mal die Chipsatz Treiber Sektion auf game.amd.com aktualisiert wurde und jetzt steck ich meine Hoffnung mal dort hinein. Bis gleich, gebe dann Rückmeldung
Da ich mein DK 790GX von Bestseller Comp. (nach 6 Wochen ...) nicht mehr zurückbekomme, da der Lieferant es nicht mehr vorrätig hat :fresse:, werde ich das Angebot annehmen und auf ein 790FXB wechseln. Denke mal, wenn ich das heute bestätige, wird das Ding bis Ende der nächsten Woche da sein.
Deswegen hab ich mir den alten und diesen Fred nochmal komplett durchgelesen (ging ganz schnell :stupid:) und folgende Frage:
Ist man für X3->X4 Freischaltung immer noch auf das alte Beta-BIOS vom März angewiesen oder ist da schon was gemodeltes in Aussicht bzw. gibts schon Alternativen?
(Und vllt. noch was bissl ot: Da ich ja dann auch volle 2x16 Lanes nutzen kann, wäre es eher sinnvoll auf ne 4870 oder die 5770 zu setzen? Ich weiß, dass erstere noch schneller ist [und zum fast gleichen Preis mit guter Kühlung auch mit 2048MiB zu haben]. Aber die Hauptfrage ist: Kann die 5770 überhaupt von 16 Lanes profitieren oder limitiert da vorher schon deren Speicherarchitektur?)
Hi Zero nein es gibt ein neues dafür mitlerweile.
R7SD820A.exe (aktuelle bios normal)
R7SDA08.zip (aktuelle betabios)
sind die derzeitigen
lg
PS:zu der Grafikkarte, naja das derzeit ne gute Frage die 5770 hat halt Dx 11, ansonsten sollten sie sich nicht so viel nehmen beide.
Perfekt. Als kleiner Update-Junkie käm ich mir mit sonem alten BIOS komisch vor.
Wegen der GraKa gibts mehrere Faktoren: DX11 vs. DX10.1, 108 vs. 157 Watt unter Last. Mein NT hat 500W (mein "vielleicht bald System"). Is also irgendwie die Frage, ob das überhaupt mit zwei 4870 klarkäme. Andrerseits bin ich nich so der Leistungfreak, aber gern auf dem Stand der Technik. ^^
Wenn es ne 5770 mit alternativer Kühlung, wie die der Vapor-Serie von Sapphire, gäbe, viele die Entscheidung dafür aus. Vermute aber, dass da noch nichts in Sicht ist, oder? Ich weiß, ich bin ot, aber verpacks auch extra. ;)
Zu dem etwas zurückliegenden MindStarDeluxe-Link: Gibts da irgendwelche Einschränkungen, die ich nur nicht sehe? Von Zeit zu Zeit ist die Seite einfach leer.
(Sonst würd ich mich von Bestseller einfach auszahlen lassen und das Brettchen bei MF holen. Immerhin hat das 790GX mal 120€ gekostet.)
Korrigiere schonmal auf 10: Habs eben bestellt und überwiesen. Danke auf jeden Fall für den Tipp. Bestelle zwar hin und wieder bei MF, aber MindStarDeluxe ist mir noch nie aufgefallen. :wink:
Jetzt muss ich das nur noch mit Bestseller klarmachen. Wenn die sich querstellen sollten, muss ich da eben dann meine GraKa bestellen (auch wenn die da je nach Modell ~30€ teurer ist :motz:). Hab aber erstmal Kaufpreiserstattung und Rückmeldung bis Montag 13:00 Uhr angesetzt.
Weiß jemand zufällig, ob der 965 aufs 790FXB-M2RSH drauf passt bzw. ohne Probleme betrieben werden könnte?
Bin nämlich gerade am Überlegen, ob ich dann den 955 dadurch ersetzen lasse... oder würdet ihr generell eher von dieser Überlegung abraten, da der Unterschied 955 <-> 965 nicht so gravierend ist?
Bin nämlich anhand dieser Tabelle hier darauf gekommen, in der der 955 ja um fünf Plätze hinter dem 965 liegt, welcher de facto AMDs Flaggschiff ist... (und davon abgesehen behagt mir der Gedanke nicht, mit dem 955 immer noch hinter einem 9550 bzw. 9650 zu liegen, die i5/7 Reihe ist klar).
Bevor ich es vergesse: Danke dir vielmals @ tupax für die freundliche Begrüßung nebst Rückantworten, hat mir schon ein bisschen besser geholfen da nun durchzublicken... :wink:
Hi Colonel Faulkner
normal sollte er laufem leider ist er in keinem dfi board gelistet, scheinbar fehlt da nen update, du kannst ja gerne mal den dfi support anschreiben per mail.
lg
Läuft ohne probleme, ich habe auf beinden Boards AM2+ und AM3 790FX jeweils das aktuellste Betabios drauf, und läuft ohne probleme.
Ähnliche Themen
