[Sammelthread] DFI LANparty DK 790FXB-M2RS / -M2RSH / -M3H5 / 790GX-M2RS (AMD 790FX / 790GX) [2]
Sammelthread
Inhaltsverzeichniss:
top
AM2+
AM3
Anhang:
AM2+
AM3
Vorwort:
Da die Boards nahezu identisch ausgestattet sind habe ich nur die Details zusammengefasst, die sich von den anderen unterscheiden. Die Features die fehlen, kann man vom M2RSH übernehmen.
Nun gehts also los mit dem Sammelthread der DFI Lanparty DK series:
AM2+:
790FXB
DFI Lanparty DK 790FXB-M2RS
I. Technische Details zum Board:
CPU:
  • AMD Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
  • Socket 940 AM2 65nm
Chipset:
  • Northbridge: AMD 790FX
  • Southbridge: AMD SB750
System Memory:
  • Four 240-pin DDR2 DIMM sockets
  • Supports DDR2 667 and DDR2 800 DIMMs
  • Supports dual channel (128-bit wide) memory interface
  • Supports up to 8GB system memory
  • Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots
    - 2-way or 4-way CrossFire at x16/x16/NC bandwidth
    - 3-way CrossFire at x16/x8/x8 bandwidth
    - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
  • 3 PCI slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM overclocking
  • CPU/DRAM/Chipset overvoltage
  • 8Mbit flash memory
  • AM3 support ab BIOS-Version R7SD327 (beta), bzw. R7SD421 (final)
Audio:
  • Realtek ALC885 8-channel HD Audio Codec
  • High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
LAN:
  • Marvell 88E8053 PCIE Gigabit LAN controller
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
Power Management:
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 Keyboard/Mouse
  • Wake-On-USB Keyboard/Mouse
  • Wake-On-Ring
  • Wake-On-LAN
  • RTC timer to power-on the system
  • AC power failure recovery
Hardware Monitor:
  • Monitors CPU/system/chipset temperature
  • Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature during system boot-up
IDE:
  • One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Serial ATA with RAID:
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O:
  • 1 mini-DIN-6 PS/2 mouse port
  • 1 mini-DIN-6 PS/2 keyboard port
  • 1 optical S/PDIF-out port
  • 1 coaxial RCA S/PDIF-out port
  • 6 USB 2.0/1.1 ports
  • 1 RJ45 LAN port
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
Internal I/O:
  • 2 connectors for 4 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 front audio connector
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 4 Serial ATA connectors
  • 1 40-pin IDE connector
  • 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 6 fan connectors
  • EZ touch switches (power switch and reset switch)
PCB:
  • ATX form factor
  • 24.5cm (9.64") x 30.5cm (12")
II. Layout:
III. Reviews:
http://www.ur-hardware.com/mainboard/40-review-dfi-lanparty-dk-790fx
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...ormal&mode=view&downloadFlag=false&itemId=539
Treiber: http://www.dfi.com.tw:8080/portal/C...normal&mode=view&downloadFlag=true&itemId=539
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383889.html
M2RSH
DFI Lanparty DK 790FX-M2RSH
CPU:
  • AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron
  • HyperTransport 3.0 (5200MT/s for AM2+)
  • AMD OverDrive provides tuning options using the new“Advanced Clock Calibration” overclocking feature.
  • Socket 940 AM2+ 65nm
Chipset:
System Memory:
  • Supports DDR2 667/800/1066 MHz DIMMs
Expansion Slots:
  • 3 PCI slots
II. Layout:
III. Reviews:
http://www.modreactor.com/english/R...XB-M2RSH-AMD-LanParty-Motherboard-Review.html
http://www.overclock.net/amd-motherboards/399854-smt-review-dfi-lanparty-790fxb-m2rsh.html
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Treiber: http://www.dfi.com.tw:8080/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=driverTab&windowstate=normal&mode=view&downloadFlag=true&itemId=547
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383891.html
790GX
DFI Lanparty DK 790GX-M2RS
CPU:
Chipset:
  • Northbridge: AMD 790GX (RS780)
Expansion Slots:
  • 2 PCI Express (Gen 2) x16 slots
    - Hybrid CrossFireX - combination of the integrated graphics and a discretegraphics card in a PCIE slot (8-lane port).
    - Two graphics cards support CrossFireX; each operating at x8 (8-lane ports)bandwidth
  • 1 PCI Express x1 slot
  • 3 PCI slots
Graphics:
  • Integrated ATI Radeon HD 3300 graphics core
  • One DVI-I connector for digital LCD display (ACHTUNG!! DVI Anschluss nur als Pin-Connector ausgeführt)
  • Microsoft® DirectX 10
  • Hybrid CrossFireX technology combines the onboard GPU and adiscrete PCIE graphics card
  • Onboard Performance cache for added performance
II. Layout:
III. Reviews:
http://www.madshrimps.be/?action=getarticle&articID=894
IV. Links:
Link zum "DVI-Problem": http://www.csd.dficlub.org/forum/showthread.php?t=8221
Treiber: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a356442.html
Lanparty JR Sammelthread: http://www.hardwareluxx.de/community/showthread.php?t=590779
hex
Anhang:
Für erweiterte Optionen im BIOS F9 drücken!
Achtung an alle Extrem-OC´er: das Board zeigt nur maximal -83°C an !
Hexcode Tabellen Für CPU-NB-VID und NB-Multi(790FXBM2RS/H):
tabelle
Vergleich zwischen den Boards:
kühler
Kompatible Kühler:
790FXB-M2RS(H):
passt:
Cooler Master Hyper TX (bläst nach hinten)
EKL Alenföhn Groß Clock'ner Blue Edition (bläst nach hinten)
EKL Alpenföhn Brocken (bläßt nach oben)
Scythe Infinity/Mugen (bläst nach oben)
Thermalright IFX-14 (bläst nach hinten), (ACHTUNG: bei verwendung der Thermalright Backplate auf Isolierung achten!)
Thermaltake GunMetal Orb (bläst nach unten)
OCZ Vanquisher (bläst nach oben)
Xigmatek HDT-S1283 (bläst nach oben)
Zalman CNPS 9500AM2 (nach hinten)
passt mit Modifikationen:
passt nicht:
790GX-M2RS:
passt:
passt nicht:
passende Wasserkühler für NB/SB und Spawa´s gibt es bei Anfi-tec oder Watercool
Lochabstände vom NB-kühler, Danke an Andreoid von Anfi-tec :bigok:
ram
RAM Kompatibilitätsliste:
790FX-M2RS/H:
läuft:
Cellshock 2x 1GB DDR2-667 (CS2110650)
GeIL DIMM 4 GB kit DDR2-800 (GX24GB6400C4UDC)
G.Skill Pi Series 4GB DDR2 1100 (F2-8800CL5D-4GBPI)
G.Skill 4GB kit DDR-1000 (F2-8000CL5D-4GBPQ)
Kingston HyperX 4GB kit DDR-1066 (KHX8500D2K2/4G)
Mushkin 4GB kit DDR-1066 (996599)
OCZ Platinum XTC 4GB kit DDR-800 (OCZ2P10004GK)
OCZ Titanium 4GB kit DDR-1150 (OCZ2T11504GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800C32GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800EB2GK)
OCZ Reaper HPC 2x2GB kit DDR2-1066 (OCZ2RPR10662G), (Tony´s SPD)
OCZ XTC Platinum 2 GB kit DDR2-1066 (OCZ2N10662GK)
macht Probleme:
läuft nicht:
Vollbestückung:
4GB
2x1GB OCZ Reaper (OCZ2RPR800C32GK) + 2x1GB OCZ Reaper (OCZ2RPR800EB2GK)
DDR800 | CL4-4-4-12 | Vdimm 2,0V
4x1GB Aenon Xtune DDR1066 | CL5-5-5-15 | Vdimm 1,85V
6GB
2x2GB Geil Ultra Plus (GX24GB6400C4UDC) + 2x1GB Cellshock
DDR800 | CL4-4-4-10 | Vdimm 1,85V
8GB
4x2GB G.Skill Pi Series (F2-8800CL5D-4GBPI) | DDR800 | CL5-5-5-18 | Vdimm 1,9V
2x4GB kit Mushkin XP2-8000 (996591) | DDR1000 | CL5-5-5-15 | Vdimm 2,1V
2x4GB kit
Mushkin DDR-1066 (996599) | DDR1066 | CL5-5-5-15 | Vdimm 2,05V
790GX-M2RS:
läuft:
Aeneon Xtune DIMM 2 GB DDR2-1066 Kit (AXT760UD00-19DM97-K-2G)
macht Probleme:
OCZ Reaper HPC 2 GB DDR2-1066 Kit (OCZ2RPR10662GK); (abstürtze mit 1066Mhz)
läuft nicht:
Vollbestückung:
4GB
6GB
8GB
Tipps für 8GB RAM bei 1066Mhz *klick*
FAQ
FAQ:
Q: Ab welcher BIOS-Version bietet das Board Deneb-Support?
A: Ab FinalVersion R7SDC26
Q: Ab welcher BIOS-Version bietet das Board AM3-Support?
A: Ab Final Bios R7SD421 bzw. ab Beta R7SD327
Q: Mit welcher BIOS-Version lassen sich die X3´s freischalten?
A: Beta Version R7SD310A
Q: Wie flashe ich mein BIOS mit einem USB-Stick?
A: Tutorial auf der DFI-Club-Seite *klick*
Eine deutsche Übersetzung der POST Codes aus dem Handbuch findet ihr HIER
under construction...
AM3:
m3h5
DFI Lanparty DK 790FXB-M3H5
CPU:
  • AMD Phenom II processor
  • HyperTransport 3.0 (5200MT/s), HyperTransport 1.0 (2000/1600MT/s)
  • AMD OverDrive provides tuning options using the new "Advanced Clock Calibration" overclocking feature.
  • Socket 938 AM3 45nm
Chipset:
System Memory:
  • Four 240-pin DDR3 DIMM sockets
  • Supports DDR3 1600 (O.C.)/1333/1066Mhz
  • Supports non-ECC unbuffered DIMMs
  • Supports up to 16GB system memory
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots - 2-way crossfire at x16/x16 or x16/x4 bandwith - 3-way crossfire at x16/x16/x4 bandwith
  • 3 PCI-Slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM Overclocking
  • CPU/DRAM/Chipset Overvolting
  • 8Mbit SPI Flash Memory
Audio:
Lan:
  • Marvell 88E8056 PCIE Gigabit LAN controller
  • SATA speed up to 3GB/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
IDE:
  • One IDE connector allows up to two UltraDMA 133Mbps hard drives
Rear Panel I/O Ports:
  • 1 RJ45 LAN port
  • line-in, line-out (front R/L) and mic-in jacks
I/O Connectors:
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 6 Serial-ATA connectors
  • 6 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power and reset switch)
Power Management:
  • ACPI STR (Suspend to RAM) funktion
  • Wake-On-Ring
  • Wake-On-LAN
Hardware Monitor:
  • Monitors 12V/5V/3,3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • CPU Over Heat Protection function monitors CPU temperature during system boot-up
PCB:
  • ATX form factor
  • 24,5cm (9,64") x 30,5cm (12")
II. Layout:
III. Reviews:
User-Review von Öse:
http://www.hardwareluxx.de/community/showpost.php?p=11771090&postcount=1
http://www.ninjalane.com/reviews/motherboards/lanpartydk-790fxb-m3h5
IV: Links:
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a417781.html
kühler
Anhang:
Kompatible Kühler:
Die Sockelhalterung entspricht exakt der AM2(+) version, daher passen alle Kühler die auch mit dem M2RS(H) kompatibel sind.
Passende Wasserkühler:
Das Boardlayout entspricht ebenfalls dem des M2RSH, daher passen alle Wasserkühler die auch mit dem 790FXB-M2RS(H) verwendet werden können.
Kann mir bitte jemand helfen wie ich das BIOS update mache. Wie erstelle ich den USB Boot Stick und was dann ? Hat jemand ein gutes Howto ?
MfG
du brauchst das hp tool um den usb stick bootbar zu machen
HP USB Disk Storage Format Tool - Download - CHIP Online
dieses usb doss (kann sein das du in den ordner optionen einstellen musst versteckte systemdateian anzuzeigen)
USB-DOS - Download - CHIP Online
bei dem HP tool wählst du dann den usb stick aus, den du beschreiben willst. bei den drei auswahlkästchen wählst du dann das letzte (create a dos startup disk) untendrunter gibbst du dann den dateipfad zu den .com datei des zweiten links an und klickst auf start.
die dateien von dem bios schiebst du dann auch noch auf den usb stick, un gepackt.
dann musst du im Bios einstellen, das du von dem bearbeiteten usb stick booten möchtest. Wenn ich mich rechterinnere startet das flash tool dann von alleine. Dort gibbst du dann die bios datei an(wenn nur eine auf dem stick ist, ist die schon ausgewählt), den rest musst sollte dann auf dem bildschirm zu lesen sein
Danach Bios reset nicht vergessen
Wichtig Ich gebe keine Garantie, das es so Funktioniert
Der USB Stick wird beim booten ignoriert. Was mus sich da genau einstellen damit es funzt ?
MfG
du musst ihn dort fest einstellen, wo man auch die festplatte und das dvd laufwerk einstellt. nicht einfach usb-gedöhns, sondern die bezeichnung des sticks
Ich habe bei Boot Priority 5 positionen und da kommen an den ersten 2 Stellen meine beiden Festplatten dann der USB Stick und eine USB Festplatte. Obwohl es da steht kann ich die Priorität nicht ändern. Den Status des USB Stick habe ich von AUTO auf HDD Mode geändert. Würde es was bringen dei HDD´s kurz abzustecken und den Start zu machen ?
MfG
den status kannst du bei auto lassen
die positionen bei boot priority kannst du mit den Bild hoch und Bild runter tasten ändern, aufjedenfall ist das der entscheidende Menue punkt
wenn du alle für diesen fall unötige geräte aussteckst müsste es auch gehen
Ok hab gerade erfolgreich geflasht. Es lag an der HDD Boot Priority Device dort muss der USB Speicher an erster Stelle stehen. Das ging bei mri duchr meine Enermax Tastatur net diese ist so eien all in on micro und manche Tasten sind da mehrfach belegt und die Bild Up oder Down funktion ist nur durch drücken einer zusatztaste verfügbar. Das Teil ist neue und ich hatte mich damit noch nicht auseinandergesetzt. Naja nachdem es dann geklappt hat war nach einem Neustart automatisch awdflash im gange und das flashen ging Problemlos.
@Viper
Danke für deine Hilfe.
Jetzt kann endlich der 955 rein und dann steht der 940er zum verkauf.
MfG
schön das es ging, dann mal viel spaß mit dem 955,
also der 955 ist installiert und arbeitet nun mit meinem alten Scythe Mugen unhörbar in meinem PC. Nun taktet er jedoch im IDLE nicht runter. Das Bios ist noch auf den standard einstellungen ab werk. Soll ich die CPU Voltage manuell einstellen wenn ja welche bekommt der 955 ? Und dann ich habe im IDL eine kern Temperatur von 39° C. Ist das Ok. Zudem habe ich wiedersprüchliche anziegen was meine Voltage angeht CoeTemp gibt mir 1,4V an während CPU-Z nur 1,376 V ausgibt. Beides erscheint mir zu hoch.
MfG
Danke schonmal.
Von den Spezifikationen her ist die Voltage von 1,376V nicht zu hoch. Nur kann eine Reduzierung der VCore sicherlich nicht schaden. Die 39°C im Idle sind jedoch unbedenklich. Wichtiger und aussagekräftiger ist sowieso die Last-Temperatur. Wenn diese nicht zu hoch ist, ist alles ok.
C&Q sollte standardmäßig im Bios aktiviert sein. Zusätzlich musst du beispielsweise unter Windows 7 das Energieschema auf "Ausbalanciert" setzen.
Ok jetzt funzt das runtertaken endlich. Dankeschonmal nun mach ich mach ans OC 3,6 oder 3,8 mal sehen was er kann.
MfG
DFI LanParty DK 790FXB-M2RSH - C1 Fehler
Hallihallo,
ihr seit meine letzte Hoffnung. :/
Ich besitze das DFI LanParty DK 790FXB-M2RSH, vor zwei Tagen bekam ich meinen Phenom II X4 955BE, diesen möchte ich nun auf dem Mainboard betreiben. Ersetzt wurde ein X2 4000+. Dieser lief wunderbar mit dem Mainboard.
Der Phenom macht nun Probleme. Immer wenn ich den Computer herunterfahre und wieder neu starten möchte erscheint ein Fehler auf dem Mainboard: "CF -> C1 -> Stopp" es erscheint kein Bild. Ich muss den Stecker ziehen, warten bis die Status LED ausgeht und kann dann den Computer ganz normal starten.
In Windows selbst funktioniert der Prozessor wunderbar, Prime stabil, Spiele stabil. Memtest hat keine Fehler gefunden etc.
Habe wirklich schon alles probiert und bin am verzweifeln. :/
@ !_!Mr.Q!_!, für mich wäre ganz interessant ob es an dem Mainboard liegt. Toll wäre es also, dass du mir dein Mainboard leihst. Ich bezahle dir natürlich einen kleinen Obolus und die Versandkosten werde ich auch bezahlen. Ich hoffe aber, dass es nicht dazu kommt und mir schon so geholfen wird. :/
Hi
hast du das aktuelle Bios drauf? Auch mal ein BIOS reset gemacht?
Der fehler Code C1 weist auf RAM hin. Hast du CPU/Ram übertaktet? Wenn ja ver such mal mit den Standartwerten.
Was für Ram hast du denn eingebaut?
Passiert der Fehler nur beim Neustart aus Windows herraus, oder auch wenn du den PC richtig Herunterfährst und dann neu startest?
Torben
Das Board war erst vor ein paar Monaten (5-6 Monate? :d) in der RMA... .
Herr "Smith" meinte er habe alles geupdatet, ich selbst habe nur gesehen, dass er auf meinen "Revisionaufkleber" 001 geschrieben hat.
Wie dem auch sei, Bios ist von 11/2009.
Nichts übertacktet, habe schon oft ein Bios Reset gemacht... . :/
Der Fehler passiert immer. Fahre ich den Computer richtig herunter und will ihn dann wieder starten, muss ich den Stecker ziehen.
Will Windows 7 wegen einem Update neu starten und ich bestätige das, fährt er sich herunter, dann beim neu start erscheint C1 auf dem Display und nichts passiert.
Lustigerweise:
Fährt der Computer gerade herunter und ich ziehe den Stecker, fährt er danach "richtig" hoch. Nur die Meldung von Windows erscheint, dass der Pc nicht richtig herunter gefahren wurde.
P.S. Habe auch schon 1GB Kingston Riegel von meinem Bruder probiert.
Stecke ich wieder den X2 4000+ auf das Mainboard, fährt der Computer auch richtig hoch ohne Probleme. Anscheint mag er den Phenom nicht. :/
Was hast du denn für Netzteil, und hast du den P4 oder den P8 CPU stecker angeschlossen?
Eventuell passen der Phenom und der RAM nicht zusammen.
Propiere mal mit dem Phenom mal deine RAM Module einzeln durch, vielleicht leigt es nur an einem
Lustigerweise:
umm 11ter?^^
das last is vom 2009.10.xx
http://img.lanparty.tw/Upload/BIOS/CM/R7SDA08.zip
hier mach das vll noch mal drauf also die cpu geht auf jeden drauf... mach nach den bios update nen reset vlll auch mal bat für 2-3min raus nehmen
ram vll auch mal auf nur 667 stellen
Hast recht war doch der 10. :d
Habe ich schon erwähnt, dass ich gleich ausraste, weil ich schon 3x Windows neu installiert habe und der Computer netterweise sehr laut ist?
Diesen Thread habe ich von 2010 auch jetzt durchgelesen. :banana:
@ [db] habe mal meine Konfiguration angegeben. Seasonic X-750 :cool:
Auch wenn es nervig ist, werde ich den Computer mal herunter fahren. -.-"
P8 Stecker ist drauf. Meine zwei Module werde ich einzeln durch jede Bank jagen. Das Bios Update werde ich auch machen, auch wenn ich glaube ich das neuste drauf habe.
Erstmal vielen Dank. :) Über mehr Vorschläge würde ich mich freuen, hab ja noch Ferien. :d
#Edit.##
@ Mr, soll ich trotzdem ein Bios Update machen? Der nette Support Mitarbeiter Wendel Smith, hat das anscheint schon gemacht? :/
P.S. Die 0,8V im Idl funktionieren gut, hab das gerade erst gemacht, vorher war der Fehler auch vorhanden. :/
ich hab den C1 teilweise auch.
Komischerweise hab ich ihn dadurch behoben als ich nen 3pin luefter umgesteckt hatte.
danach gings ganz normal.
Habe eigentlich drei Lüfter am Mainboard.
Die zwei die sich steuern lassen (3Pin) und einen PWM, gesteuert via. SpeedFan.
Jetzt hängt nur einer dran an nem normalen 12V Anschluss auf dem Mainboard, leider behebt das mein Problem nicht. :(
#Edit.## Ram auf 667, bringt leider nichts. Gleich kommt der CMOS Reset, mal schauen. :/
Was auch komisch ist, bin ich im Bios und bootet dann der Pc neu, funktioniert das auch Prima. Nur wenn halt Windows geladen wurde. Ich weine gleich. ^^
#Edit.## Alle Bänke durch, mit einzelnen Riegeln. Windows startet normal, das Problem bleibt jedoch. :/
Ist noch Gewährleistung vorhanden? Ist mE ein Garantiefall, wobei es vielleicht mit nem anderen Netzteil funktionieren würde.
Du kannst es mit erhöhter Spannung bei NB, SB oder CPU-NB versuchen. Das kann helfen. viel Glück :)
Moin Erdbeere,
kann da auch nicht wirklich helfen. Hab das gleiche Netzteil mit der Rig in meiner Signatur. Sollte also nicht daran liegen, wenn es nicht kaputt ist ;)
BIOS alles reset auf default hat nichts gebracht. Etwas mehr Volt auf die CPU-NB könnte helfen, um die RAMs zum Leben zu erwecken ...
Viel Erfolg
Auch schon alles probiert. :/
Hoffentlich schreibt endlich dieser Wendel Smith zurück. :(
Nein aber schon bei der letzten RMA wurde mir, auch ohne Garantie geholfen. Hoffentlich hat sich das nicht geändert... .
Hi Erdbeere
wenn dein alte CPU funktioniert, gehe ich erstmal von einem Config Problem aus.
Schau mal bitte unter CPU Einstellungen ob du C1 aktiviert hast (bitte ausschalten), als nächsten schritt schaue auf welchen wert die CPU-NB VID steht beim CE sollte sie um 1,1volt stehen (memory Controller) diesen wert könnte man leicht erhöhen zum test ob es daran liegt.
lg
Guten Morgen. :)
Vielleicht sollte ich das auch erwähnen:
Ich habe gestern ganze vier Stunden gespielt., irgend wie muss ich ja Frust abbauen. Das zeigt aber, dass alles Stabil läuft.
Leider verstehe ich deine Angaben nicht wirklich, mit dieser Materie habe ich noch nicht wirklich auseinander gesetzt.
Was ist "CE"? Irgendwie kann ich die "CPU-NB VID" nicht einstellen, egal was ich auf "Enabled" (in diesem Menü) stelle, ich kann das nicht auswählen.
Wie macht man das also? :S
P.S. Die -0,2V beim Prozessor funktionieren super und es macht kein Unterschied ob diese leicht erhöht ist. Sollte es helfen setze ich diese natürlich sofort wieder auf normal.
#Edit.##
Dear Sir:
In that case I could only suggest trying an alternate power supply in the 800+ watt range. The issues you are describing could be resulting from a power issue, and to be honest I am no fan of Seasonic PSUs on DFI boards.
Ehm? Nicht toll? :(
Hi
im zweiten Bild erste einstellung, ist so ok, die Spannung könntest du zum test auf auto stellen.
Den CPU NB VID kannst du nur einstellen wenn du 1.Bild Cool & Quiet auf Auto hast.
Jetzt kannst du dann im Bild die CPU_NB Vid einstellen, es sei zu beachten das es Hex werte sind!
entweder du stellt 00 für standart deiner CPU oder 0F (1,1volt) oder zb. 14 für 1,175volt siehe bild
oben bitte auf S1 stellen
Cool' N' Quiet' ist auf Auto.
Trotzdem kann ich da nichts auswählen? :S
Ist auf S1 eingestellt. :)
Hi Erdbeere
hm das problem ist schonmal mit 955 aufgetreten welchen Steping hast du davon?
ein C2 oder ein C3, beim C3 könnte es probleme geben aber das ist ein "bug" den man mit dem letzten Beta bios gegentesten könnte, da im letzten Final bios dieses nur noch für BE Cpus verfügbar ist. Aber teste mit den anderen Einstellungen mal das verhalten von deinem PC.
lg
Ähnliche Themen
