[Sammelthread] DFI LANparty DK 790FXB-M2RS / -M2RSH / -M3H5 / 790GX-M2RS (AMD 790FX / 790GX) [2]
Sammelthread
Inhaltsverzeichniss:
top
AM2+
AM3
Anhang:
AM2+
AM3
Vorwort:
Da die Boards nahezu identisch ausgestattet sind habe ich nur die Details zusammengefasst, die sich von den anderen unterscheiden. Die Features die fehlen, kann man vom M2RSH übernehmen.
Nun gehts also los mit dem Sammelthread der DFI Lanparty DK series:
AM2+:
790FXB
DFI Lanparty DK 790FXB-M2RS
I. Technische Details zum Board:
CPU:
  • AMD Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
  • Socket 940 AM2 65nm
Chipset:
  • Northbridge: AMD 790FX
  • Southbridge: AMD SB750
System Memory:
  • Four 240-pin DDR2 DIMM sockets
  • Supports DDR2 667 and DDR2 800 DIMMs
  • Supports dual channel (128-bit wide) memory interface
  • Supports up to 8GB system memory
  • Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots
    - 2-way or 4-way CrossFire at x16/x16/NC bandwidth
    - 3-way CrossFire at x16/x8/x8 bandwidth
    - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
  • 3 PCI slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM overclocking
  • CPU/DRAM/Chipset overvoltage
  • 8Mbit flash memory
  • AM3 support ab BIOS-Version R7SD327 (beta), bzw. R7SD421 (final)
Audio:
  • Realtek ALC885 8-channel HD Audio Codec
  • High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
LAN:
  • Marvell 88E8053 PCIE Gigabit LAN controller
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
Power Management:
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 Keyboard/Mouse
  • Wake-On-USB Keyboard/Mouse
  • Wake-On-Ring
  • Wake-On-LAN
  • RTC timer to power-on the system
  • AC power failure recovery
Hardware Monitor:
  • Monitors CPU/system/chipset temperature
  • Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature during system boot-up
IDE:
  • One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Serial ATA with RAID:
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O:
  • 1 mini-DIN-6 PS/2 mouse port
  • 1 mini-DIN-6 PS/2 keyboard port
  • 1 optical S/PDIF-out port
  • 1 coaxial RCA S/PDIF-out port
  • 6 USB 2.0/1.1 ports
  • 1 RJ45 LAN port
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
Internal I/O:
  • 2 connectors for 4 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 front audio connector
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 4 Serial ATA connectors
  • 1 40-pin IDE connector
  • 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 6 fan connectors
  • EZ touch switches (power switch and reset switch)
PCB:
  • ATX form factor
  • 24.5cm (9.64") x 30.5cm (12")
II. Layout:
III. Reviews:
http://www.ur-hardware.com/mainboard/40-review-dfi-lanparty-dk-790fx
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...ormal&mode=view&downloadFlag=false&itemId=539
Treiber: http://www.dfi.com.tw:8080/portal/C...normal&mode=view&downloadFlag=true&itemId=539
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383889.html
M2RSH
DFI Lanparty DK 790FX-M2RSH
CPU:
  • AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron
  • HyperTransport 3.0 (5200MT/s for AM2+)
  • AMD OverDrive provides tuning options using the new“Advanced Clock Calibration” overclocking feature.
  • Socket 940 AM2+ 65nm
Chipset:
System Memory:
  • Supports DDR2 667/800/1066 MHz DIMMs
Expansion Slots:
  • 3 PCI slots
II. Layout:
III. Reviews:
http://www.modreactor.com/english/R...XB-M2RSH-AMD-LanParty-Motherboard-Review.html
http://www.overclock.net/amd-motherboards/399854-smt-review-dfi-lanparty-790fxb-m2rsh.html
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Treiber: http://www.dfi.com.tw:8080/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=driverTab&windowstate=normal&mode=view&downloadFlag=true&itemId=547
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383891.html
790GX
DFI Lanparty DK 790GX-M2RS
CPU:
Chipset:
  • Northbridge: AMD 790GX (RS780)
Expansion Slots:
  • 2 PCI Express (Gen 2) x16 slots
    - Hybrid CrossFireX - combination of the integrated graphics and a discretegraphics card in a PCIE slot (8-lane port).
    - Two graphics cards support CrossFireX; each operating at x8 (8-lane ports)bandwidth
  • 1 PCI Express x1 slot
  • 3 PCI slots
Graphics:
  • Integrated ATI Radeon HD 3300 graphics core
  • One DVI-I connector for digital LCD display (ACHTUNG!! DVI Anschluss nur als Pin-Connector ausgeführt)
  • Microsoft® DirectX 10
  • Hybrid CrossFireX technology combines the onboard GPU and adiscrete PCIE graphics card
  • Onboard Performance cache for added performance
II. Layout:
III. Reviews:
http://www.madshrimps.be/?action=getarticle&articID=894
IV. Links:
Link zum "DVI-Problem": http://www.csd.dficlub.org/forum/showthread.php?t=8221
Treiber: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a356442.html
Lanparty JR Sammelthread: http://www.hardwareluxx.de/community/showthread.php?t=590779
hex
Anhang:
Für erweiterte Optionen im BIOS F9 drücken!
Achtung an alle Extrem-OC´er: das Board zeigt nur maximal -83°C an !
Hexcode Tabellen Für CPU-NB-VID und NB-Multi(790FXBM2RS/H):
tabelle
Vergleich zwischen den Boards:
kühler
Kompatible Kühler:
790FXB-M2RS(H):
passt:
Cooler Master Hyper TX (bläst nach hinten)
EKL Alenföhn Groß Clock'ner Blue Edition (bläst nach hinten)
EKL Alpenföhn Brocken (bläßt nach oben)
Scythe Infinity/Mugen (bläst nach oben)
Thermalright IFX-14 (bläst nach hinten), (ACHTUNG: bei verwendung der Thermalright Backplate auf Isolierung achten!)
Thermaltake GunMetal Orb (bläst nach unten)
OCZ Vanquisher (bläst nach oben)
Xigmatek HDT-S1283 (bläst nach oben)
Zalman CNPS 9500AM2 (nach hinten)
passt mit Modifikationen:
passt nicht:
790GX-M2RS:
passt:
passt nicht:
passende Wasserkühler für NB/SB und Spawa´s gibt es bei Anfi-tec oder Watercool
Lochabstände vom NB-kühler, Danke an Andreoid von Anfi-tec :bigok:
ram
RAM Kompatibilitätsliste:
790FX-M2RS/H:
läuft:
Cellshock 2x 1GB DDR2-667 (CS2110650)
GeIL DIMM 4 GB kit DDR2-800 (GX24GB6400C4UDC)
G.Skill Pi Series 4GB DDR2 1100 (F2-8800CL5D-4GBPI)
G.Skill 4GB kit DDR-1000 (F2-8000CL5D-4GBPQ)
Kingston HyperX 4GB kit DDR-1066 (KHX8500D2K2/4G)
Mushkin 4GB kit DDR-1066 (996599)
OCZ Platinum XTC 4GB kit DDR-800 (OCZ2P10004GK)
OCZ Titanium 4GB kit DDR-1150 (OCZ2T11504GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800C32GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800EB2GK)
OCZ Reaper HPC 2x2GB kit DDR2-1066 (OCZ2RPR10662G), (Tony´s SPD)
OCZ XTC Platinum 2 GB kit DDR2-1066 (OCZ2N10662GK)
macht Probleme:
läuft nicht:
Vollbestückung:
4GB
2x1GB OCZ Reaper (OCZ2RPR800C32GK) + 2x1GB OCZ Reaper (OCZ2RPR800EB2GK)
DDR800 | CL4-4-4-12 | Vdimm 2,0V
4x1GB Aenon Xtune DDR1066 | CL5-5-5-15 | Vdimm 1,85V
6GB
2x2GB Geil Ultra Plus (GX24GB6400C4UDC) + 2x1GB Cellshock
DDR800 | CL4-4-4-10 | Vdimm 1,85V
8GB
4x2GB G.Skill Pi Series (F2-8800CL5D-4GBPI) | DDR800 | CL5-5-5-18 | Vdimm 1,9V
2x4GB kit Mushkin XP2-8000 (996591) | DDR1000 | CL5-5-5-15 | Vdimm 2,1V
2x4GB kit
Mushkin DDR-1066 (996599) | DDR1066 | CL5-5-5-15 | Vdimm 2,05V
790GX-M2RS:
läuft:
Aeneon Xtune DIMM 2 GB DDR2-1066 Kit (AXT760UD00-19DM97-K-2G)
macht Probleme:
OCZ Reaper HPC 2 GB DDR2-1066 Kit (OCZ2RPR10662GK); (abstürtze mit 1066Mhz)
läuft nicht:
Vollbestückung:
4GB
6GB
8GB
Tipps für 8GB RAM bei 1066Mhz *klick*
FAQ
FAQ:
Q: Ab welcher BIOS-Version bietet das Board Deneb-Support?
A: Ab FinalVersion R7SDC26
Q: Ab welcher BIOS-Version bietet das Board AM3-Support?
A: Ab Final Bios R7SD421 bzw. ab Beta R7SD327
Q: Mit welcher BIOS-Version lassen sich die X3´s freischalten?
A: Beta Version R7SD310A
Q: Wie flashe ich mein BIOS mit einem USB-Stick?
A: Tutorial auf der DFI-Club-Seite *klick*
Eine deutsche Übersetzung der POST Codes aus dem Handbuch findet ihr HIER
under construction...
AM3:
m3h5
DFI Lanparty DK 790FXB-M3H5
CPU:
  • AMD Phenom II processor
  • HyperTransport 3.0 (5200MT/s), HyperTransport 1.0 (2000/1600MT/s)
  • AMD OverDrive provides tuning options using the new "Advanced Clock Calibration" overclocking feature.
  • Socket 938 AM3 45nm
Chipset:
System Memory:
  • Four 240-pin DDR3 DIMM sockets
  • Supports DDR3 1600 (O.C.)/1333/1066Mhz
  • Supports non-ECC unbuffered DIMMs
  • Supports up to 16GB system memory
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots - 2-way crossfire at x16/x16 or x16/x4 bandwith - 3-way crossfire at x16/x16/x4 bandwith
  • 3 PCI-Slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM Overclocking
  • CPU/DRAM/Chipset Overvolting
  • 8Mbit SPI Flash Memory
Audio:
Lan:
  • Marvell 88E8056 PCIE Gigabit LAN controller
  • SATA speed up to 3GB/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
IDE:
  • One IDE connector allows up to two UltraDMA 133Mbps hard drives
Rear Panel I/O Ports:
  • 1 RJ45 LAN port
  • line-in, line-out (front R/L) and mic-in jacks
I/O Connectors:
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 6 Serial-ATA connectors
  • 6 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power and reset switch)
Power Management:
  • ACPI STR (Suspend to RAM) funktion
  • Wake-On-Ring
  • Wake-On-LAN
Hardware Monitor:
  • Monitors 12V/5V/3,3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • CPU Over Heat Protection function monitors CPU temperature during system boot-up
PCB:
  • ATX form factor
  • 24,5cm (9,64") x 30,5cm (12")
II. Layout:
III. Reviews:
User-Review von Öse:
http://www.hardwareluxx.de/community/showpost.php?p=11771090&postcount=1
http://www.ninjalane.com/reviews/motherboards/lanpartydk-790fxb-m3h5
IV: Links:
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a417781.html
kühler
Anhang:
Kompatible Kühler:
Die Sockelhalterung entspricht exakt der AM2(+) version, daher passen alle Kühler die auch mit dem M2RS(H) kompatibel sind.
Passende Wasserkühler:
Das Boardlayout entspricht ebenfalls dem des M2RSH, daher passen alle Wasserkühler die auch mit dem 790FXB-M2RS(H) verwendet werden können.
jo das habe ich mir auch gedacht. bräuchte noch einen RAM Tip für das M3H5. 4GB KIt mit 1333 MHz habe da welche von GEIL mit cl6 gesehen die sollen mit 1,7V laufen ist das in ordnung oder zu hohe spannung für das board?
im gegensatz zum i7 is der deneb nich so empfindlich mit höheren Vdimm´s ;) 1,7V sollten kein problem sein, mit ner ram empfehlung musst du aber warten bis sich jemand mit nem M3H5 meldet, ich selber habe noch DDR2
Hi rneon
sche dir mal das hier an.
lg
jo sieht nicht schlecht aus aber die crucial woher bekommt man die?
hmm, ist mir ja fast ein bisschen peinlich, aber wie flashe ich das bios ohne floppy? hab nen ipod der ja auch als "usb-stick" funktioniert. mit dem hab ich alles vorherige geflasht...
€: hab das R7SD706 als exe runtergeladen...
hallo,
das UT 790FX DDR2 ist seit heute wieder lieferbar und wollte fragen da mir ein UT Board lieber wäre ob auf dem der neue Phenom II 965 laufen würde wegen TDP 140W und AM3?
Hi flak
dann sollte das auch bei dem board gehen wenn der als Stick erkannt wird.
(in der zip ist eine startdatei bei mit den jeweiligen optionen dann gehts automatisch)
Hi RNeon
da das UT digitale Spannungswandler hat sollte die TDP kein Problem sein, einzig die CPU unterstützung könnte ein Problem bei einem zu alten Bios werden.Dann bräuchtest du eventuell eine cpu für ein bios update.
lg
kann man den Bios chip rausnehmen? weil so kann ich mir im falle eines Falles ein Bioschip mit dem neusten Bios bestellen. und die boards sind seit langem erst heute wieder nur bei mix und alternate lieferbar also kann es sein das die schon das neuste drauf haben evtl. oder?
Hi RNeon
ja beim UT geht das ;) aber du kannst das auch bei einem guten händler um die ecke für um die 5-10euro ein biosupdate machen lassen können, beim UT FX kenne ich mich leider nicht so aus aber das FXB konnte meinen 720BE wenigstens als unbekannte CPU mit dem bios aus dem jan.09 wie das beim fx läuft müsstest du im dem sammel thema mal nachschaun.
lg
das mit dem ut kann ich vergessen. mix hat mich angerufen und gesagt das die eins bekommen hatten und sich die bestellunge mit einer anderen überschnitten hatten. leider wird das nichts mit dem UT
Hi Lord habs gefunden ;)
dazu könnteste das mit dem Code 88 und NT bei erstbetrieb zufügen.
lg
Hi da bin ich nochmal :-D
Ich hab schon wieder ein Problem nachdem es jetzt mein 3. DFI M2RSH Board ist.
Nachdem ich mein Win neustarte lässt sich der PC nur noch per Reset booten.
Hat jemand vieleicht auch dieses Problem? ich hab leider noch nichts genaueres gefunden.
Danke schonmal für Eure hilfe
hatte ich bis vor kurzem auch, lag bei mir irgendwie an der graka. hatte sie zufaellig draussen und nachdem sie wieder drin steckte, waren alle bootprobleme z.b. erst booten nachdem man reset drueckt...
ja das war ja mein Erstes Problem der erste slot rennt nur mit 8 x und ich hab die jetzt im 2. Hatte zwar nicht vor CF zu betreiben aber ist trozdem kurious.
Werds gleich mal testen.
Kleinen X2 550 mal auf das DFI geschnallt .
Mal sehen ob er Stabiel läuft.
lg
is ja noch im ausbau, wenn dir noch mehr dazu einfällt, wir haben ja erst per pn geredet ;) das mit den fehlercodes werde ich wohl doch in ner übersetzung des handbuches machen, knapp die hälfte hab ich eh schon
so, hab nochmal bisschen rumprobiert. aber ich bekomm die 3,6 ghz nicht stabil.
habs nochmal in schoen und zusammengefasst: (bios und cpu-z screens)
cpu-z screen
bios I
bios PWM
bios RAM
werte sind glaube ich alle da die ihr braucht, wenn nicht, nochmal bescheid sagen bitte. hab mittlerweile wirklich keine ahnung mehr, was ich noch tun kann...
lg jan
hier noch jemand eine ahnung oder idee?
wird wohl die cpu am ende sein, 3,6ghz is für nen 920er nich übel, allerdings hast du etwas viel spannung drauf, die cpu´s sind nur bis 1,45V spezifiziert, mit was kühlst du?
post #1 hat wieder nen update, deutsche übersetung der POST Codes ist jetzt eingefügt :wink:
ja, hab halt das fuer mich absoltue max im screenshot ausprobiert, normal rennt er mit 1,488 @ 3,55ghz. wakü im rechner, aber einfallen tut dir auch nichts mehr, oder?
hab schon mit nem kleineren multi und mehr fsb versucht, aber das geht mal gar nicht mit dem 920er von mir...
mehr ref-takt is in deinem fall keine gute idee, gut möglich das bei 260mhz schluss ist, die meisten boards scheinen zwar mit nem deneb nen recht hohen ref-takt zu schaffen, heist aber nicht dass es nich doch das ein oder andere board gibt was recht früh dicht macht ;)
das einzige was du noch versuchen könntest wäre die cpu-nb-vid auf 1,2V zu stellen wenn die noch auf default ist, das hat bei meinem 955er 100mhz mehr gebracht
ja scheint mir auch so mit dem ref takt, der is bei 257 bis 260 so im maximalen bereich bei mir, schaetze ich. werd das nachher mal probieren mit der cpu-nb-vid. danke :)
Hi Flak
im bios screen unten die option Biso Fix auf desable stellen bitte,
Die Ht voltage zurück auf 1,27 volt die hat mit dem ref nichts zu tun.
Die NB Core sollte max 1,42 betragen (laut DFI empfehlung der übertaktung)
Hast du die rams mal mit entspannteren timings getestet tref ist schon weng scharf zb.
es kann sein das du um 260 kein ref bekommt zumindst beim ersten mal (typisch Frau)
nee spass bei seite ich hatte bei mir auch erst bei 260 nen hänger wie ne wand nix ging, bin dann mal alles entspannt die nb core auf 1,4 die CPU NB vid auf 1,25 aund ab auf 162 und es lief ;) ging sogar noch bis 280 dann ham die speicher schlapp gemacht.
lg
Ist das vom 421 aber vergiss es Unlocken kannst du zwar mit dem DFI, aber es läuft nie Stable.
Hab gestern alle Bios Version ab 224 inkl. Betas probiert, es geht einfach nicht stable mit dem DFI.Das Problem liegt hier bei DFI, da ich schon 2 Unlockbare CPUs hatte und beide nun auf anderen Boards Stable laufen.
Hi Cbot
wenn du mit stabil prime meinst stimmt, aber der rest läuft zumind bei meinem.
lg
Hi Cbot
lg
Ja das mein ich, der rest läuft bei mir ja auch.Aber Firefox macht Probleme irgennd wie, das Fenster ist nach oben verschoben und oft ist die Schrift dann verwaschen.
Der IE hingegen läuft Problemlos, weiß jetzt nicht ob ich mir ein GB Board holen soll oder nicht.Keine Lust ein neues board zu holen und dann läuft er doch nicht mit 4 Kernen.
Edit:Lustiger Effekt, hab mit Bios 224 und Aktiviertem ACC das neuste Bios geflasht und nun hab ich 4 aktive Kerne obwohl ACC auf Disbaled steht.Dabei hatte ich das neuste gestern schon einmal drauf aber damit lies sich der 550er nicht Unlocken.
Hi CBOT
ja das passiert fast immer wenn du unlockt dieses flasht nur beim cmos resett ist es dann vorbei ;)
lg
PS:vieleicht schaft öse es noch das wir auch nen neues freischaft bios bekommen für die DDR2 board (für ddr3 hat er eins auf stand letzte beta bios)
Ja ich weiß bei der DDR3 Version ging das sofort ohne Probleme leider,naja ich hau das DFI jetzt in denn MP und kauf mal wieder ein GB AM3 Board samt Ram mal sehen was damit geht.
Juhu schau mal Link
neues Freischaft bios für LANPARTY DK 790FXB-M2RS DDR2 *Lacht und sich freut*
um nicht zu sagen Tau frisch 20.8.09 :P
