[Sammelthread] DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [11]
Zitat:
  • CPU
    • LGA 775 socket for:
      - Intel® Core2 Quad and Intel® Core2 Duo
    • Supports Intel Enhanced Memory 64 Technology (EMT64T)
    • Supports Enhanced Intel SpeedStep Technology (EIST)
    • Supports Intel Hyper-Threading Technology
    • Supports 1333/1066/800MHz FSB
  • Intel® chipset
    • Intel® chipset
      - Northbridge:
      Intel® P45 Express chipset
      Intel® Fast Memory Access technology
      - Southbridge: Intel® ICH10R
  • Memory
    • Four 240-pin DDR2 DIMM sockets
    • Supports DDR2 1200(O.C.)/1066/800/667 MHz
    • Delivers up to 12.8Gb/s bandwidth
    • Supports dual channel (128-bit wide) memory interface
    • Supports non-ECC unbuffered DIMMs
    • Supports up to 16GB system memory
  • Expansion Slots
    • 2 PCI Express (Gen 2) x16 slots - 2-way CrossFire: One slot operating at x16 (16-lane port) or two slots each operating at x8 (8-lane ports) bandwidth
    • 2 PCI Express x1 slots
    • 2 PCI slots
  • BIOS
    • Award BIOS
    • 8Mbit SPI flash BIOS
    • CMOS Reloaded
  • Audio
    • Realtek ALC885 High Definition audio CODEC
    • 8-channel audio output
    • DAC SNR/ADC SNR of 106dB/101dB
    • Full-rate lossless content protection technology
    • Optical S/PDIF-out and coaxial RCA S/PDIF-out interfaces
  • LAN
    • Marvell 88E8053 PCIE Gigabit LAN controller
    • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
  • IDE
    • JMicron JMB363 PCI Express to PATA host controller
    • Supports up to 2 UltraDMA 33/66/100Mbps IDE devices
  • Serial ATA with RAID
    • Intel Matrix Storage technology
    • Supports up to 6 SATA devices
    • SATA speed up to 3Gb/s
    • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • Rear Panel I/O Ports
    • 1 mini-DIN-6 PS/2 mouse port
    • 1 mini-DIN-6 PS/2 keyboard port
    • 1 optical S/PDIF-out port
    • 1 coaxial RCA S/PDIF-out port
    • 6 USB 2.0/1.1 ports
    • 1 RJ45 LAN port
    • Center/subwoofer, rear R/L and side R/L jacks
    • Line-in, line-out (front R/L) and mic-in jacks
  • Power Management
    • ACPI and OS Directed Power Management
    • ACPI STR (Suspend to RAM) function
    • Wake-On-PS/2 Keyboard/Mouse
    • Wake-On-USB Keyboard/Mouse
    • Wake-On-LAN
    • Wake-On-Ring
    • RTC timer to power-on the system
    • AC power failure recovery
  • Hardware Monitor
    • Monitors CPU/system/Northbridge temperature and overheat alarm
    • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
    • Monitors the speed of the cooling fans
    • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
  • PCB
    • 4 layers, ATX form factor
    • 24.5cm (9.64") x 30.5cm (12")
Wasserkühlung NB-SB-Mosfets:
Wasserkühlung Zusammenstellungen vom "riverdief":
Luftkühlung:
Passt mit Problemen:
EKL Alpföhn Groß Clockner ( passt nur mit Modifikationen ...entweder am Kühler oder Chipsatzkühler )
Scythe Andi Samurai (gedreht)
Scythe Mugen 2 (der Lüfter muss 5mm verschoben werden)
Thermalright HR-01 Plus (gedreht)
Kompatibler Arbeitsspeicher:
A-DATA Vitesta Extreme Edition 2 GB PC2 9600
Cellshock DIMM Kit 2GB PC2-8500U CL5-5-5-15 (DDR2-1066) (CS2221550)
Chaintech Apogee GT DIMM Kit 4GB PC2-8500U CL5-5-5-15
Chaintech Apogee GT DIMM Kit 4GB PC2-9200U CL5-5-5-15 (DDR2-1150)R2-1150-4GDHS
Corsair DIMM 4 GB DDR2-800 DHX Kit (TWIN2X4096-6400C4DHX)
Corsair XMS2 Dominator 2GB PC2-8500U CL5-5-5-15 TWIN2X2048-8500C5D
Crucial Ballistix Tracer PC8500 1066MHz BL12864AL1065.8FE5
GeiL Value DIMM Kit 2GB PC2-6400U CL5-5-5-15 (DDR2-800) (GX22GB6400DC)
GeIL Ultra DIMM Kit 2GB PC2-8500U CL5-5-5-12 (DDR2-1066) (GX22GB8500UDC)
G.Skill Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (F2-6400CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8000U CL5-5-5-15 (DDR2-1000) (F2-8000CL5D-4GBPQ)
G.Skill Kit 4GB PC2-8500U CL5-5-5-15 (DDR2-1066) (F2-8500CL5D-4GBPI-B)
G.Skill Kit 4GB PC2-8800U CL5-5-5-15 (DDR2-1100) (F2-8800CL5D-4GBPI)
G.Skill Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
G.Skill Trident Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBTD)
G.Skill DIMM Kit 4GB PC2-9600U CL5-5-5-15 (DDR2-1200) (F2-9600CL5D-4GBPI)
Kingston HyperX DIMM Kit 4GB PC2-6400U CL5-5-5-15 (DDR2-800) (KHX6400D2K2/4G)
OCZ Flex II 4GB Kit PC2-9200 CL5-5-5-18 (OCZ2FXT11504GK)
OCZ Reaper HPC Edition Kit 2GB PC2-9200U CL5-5-5-18 (OCZ2RPR11502GK)
OCZ Flex XLC Edition 4 x 1024 MB PC2-9600U @ 1200 Mhz
OCZ Reaper HPC Edition 2GB Kit PC2-9600 CL5-5-5-18 (OCZ2RPR12002GK)
OCZ Blade Low Voltage DIMM Kit 4GB PC2-9600U CL5-5-5-18 (DDR2-1200) (OCZ2B1200LV4GK)
Patriot Viper DDR2-800 4 GB
takeMS Mach2 2GB PC2-8500U CL5-5-5-18 TMS1GB264C082-105EP
TeamGroup Xtreem Dark 4GB Kit PC2-8500U CL5-5-5-15 TXDD4096M1066HC5DC-D​
Kompatibler Netzteile:
Biosupdate mit USB Stick
Anleitung vom Fresh_Thing
1. Programm runterladen und installieren.
2. Dos files und Bios runterladen - Bios findest du hier -> http://img.lanparty.tw/Upload/BIOS/CM/D45PD320.zip
Dann den pfad für die Dos files im programm angeben und den USB-Stick formatieren
3. Die 3 datein die beim Bios dabei sind auf den Stick kopieren.
4. Im Bios die setup defaults laden und direkt den USB-Stick als erstes Bootgerät einstellen.
Dann einfach nur neustarten und der Flash nimmt seinen Lauf​
USB-Stick Bootfähig machen !!!
Downloads
Wichtige Links
Real Volt - Messung im Windows @ IDLE
mit einem Q9550 E0 @ FSB 500 @ 4255 Mhz​
Gemessen vom mahaudi
CPU PLL ( Bios 1.55v.) ......Real : 1.578v...........Droop : + ~ 0.03v.
NB Core ( Bios 1.420v.) .....Real : 1.420v...........Droop : nichts
VDIMM ( Bios 2.218v. ) .....Real : 2.245v. .........Droop : + ~ 0.03v.
VTT ( Bios 1.280v. ) .......Real : 1.298v. ..........Droop : + ~ 0.02v.​
Messpunkte DFI LP DK P45-T2RS Plus
Wie bekommt man den C1-Fehler weg?
Hier die Lösung vom Fresh_Thing
ohne Rams booten
dann PC am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen Ram reinstecken und PC starten
.....wenn das nicht geht :
ohne Rams booten
noch mal ohne Rams booten und am AN Schalter ausschalten (lange gedrückt halten) aber nicht am NT
einen ( Wichtig ) Ram reinstecken und PC starten​
VID-Bug Behebung!
Computer neu starten und ab ins BIOS
Load optimal Defaults
Computer herunterfahren
Netzteilstecker abziehen
Jumper umstecken und Batterie für ein paar Min. raus
Computer starten
Unter Hardware Monitoring nachschauen, ob die anliegende Spannung stimmt (C1E und EIST an!)
Mit F10 raus und wieder rein, dabei ist zu beachten, dass beim ersten Mal, niemals mehreren Einstellungen gleichzeitig getätigt werden dürfen
Sollte die anliegende Spannung stimmen, speichern und starten
Wenn das der Fall ist, seid Ihr den Bug für immer los!
Ansonsten, die CPU a+e!​
Smartguardian Design`s ( inkl.SG.exe vom UT P35 )
: http://rapidshare.com/files/18075196...DK_Edition.rar
Achtung!
Die mitgelieferten SATA-Kabeln können unter Umständen zum einem instabilen Betrieb führen, dies ist allerdings nicht immer der Fall.
Fazit:
Das Board kann echt eine Zicke sein und bestrafft auch den kleinsten Fehler mit einem Bluescreen/Reboot oder startet erst gar nicht, deshalb sollte man die Finger davon lassen, wenn man nicht genügend oder gar keine Erfahrung mitbringt, ansonsten bietet das Board mehr als genug Einstellungen und eine sehr gute Performance!;)
An dieser Stelle, möchte ich mich für die zur Verfügung gestellten Daten und wirklich gute Vorarbeit bei mahaudi bedanken!:hail:
Bildquellen:
patrock84 und [EKM] SeLecT , auch Euch beiden vielen Dank!:hail:
Alter Thread:
DFI LANparty DK P45-T2RS / T3RS / Plus (Intel P45) [10]
Moin!:wink:
FSB520 3,5 Std. Large, wäre schon was, dann wärst du noch 5MHz von FSB-Rekord @ Quad @ DFI/DK entfernt!;)
Moin,
Mal kurze frage wie lange hat das DFI Lanparty p45 non plus eig Garantie?
wie kann ich denn mit dem Board von USB Booten? Habe im Bios nur USB FDD, CD Rom und Zip zur Auswahl. Gibt es kein Bootmenu bei dem Board?
edit:
sorry war nen hirnfurz!
so, bin jetzt bei 491MHz angekommen, die laufen noch stabil mit Prime Large.
NB VCore 1,24V
FSB VTT 1,28v
GTLs alle auf 0,67x
wollte die GTLs mal testweise erhöhen um zu schauen ob ich so höher komme und habe festgestellt das es garnicht geht. Kann ich nur niedriger machen. Können auch niedrigere GTLs was bringen?
also ich habe die GTL 1/3 mal auf 65 gestellt. Dann blieb der Rechner beim Postscreen hängen. Denke die 67er GTLs für die CPU passen so. Leider brauche ich für 4173MHz schon 1,31V, ich dachte mit den GTLs kann ich die VCore noch ein bisschen senken, aber ich denke nicht das sich da was tun wird. Oder soll ichs nochmal probieren? Wollte eigentlich schon noch die 4250MHz knacken...
hey leute, hab ein problem. hab das case gewechselt und nu will das system nicht.
beim ersten start ganz normal in windows gekommen. ich musste nen neustart machen und bin dann wieder ins windows. da hat sich das system aufgehängt.
seit dem bekomm ich nur immer 88 auf der diagnose angezeigt. hab schon cmos gemacht, halbe stunde batterie raus, ram slots gewechselt, auch nur mit einem riegel und es funktioniert nichts. vor dem ausbau lief das system absolut stabil.
weiss grad net weiter
gruss
Pc mal vom Strom runter und die CPU raus nehmen. CPU wieder rein und neu Booten. RTC jumper mal umgestellt?
Morgen,
hab ich mir schon gedacht, das ich das machen muss. :( Das gibt wieder ein Finger gebreche.
ja, beide jumper auch schon versucht. kein Erfolg. Auch ohne Rams versucht zu booten. Kein Erfolg.
muss mich eben korrigieren. RTC-Jumper noch nicht umgesetzt. an den hab ich nicht mehr gedacht.
Werde ich heute Abend nach der Arbeit direkt versuchen.
ich glaub ich auch ganz am anfang. aber ist schon lang. war mir halt nur komisch, das auf allen bauteilen spannung ankommt, nur das board im prinzip nicht anspringt ;)
Dann würde ich mal auf CPU tippen. Als ich das hatte war ich ein paar CPU´s am testen und plötzlich wollte das Brett nicht mehr. Dachte erst das entweder Brett oder CPU kaputt sei. CPU noch mal rausgenommen wieder reingesetzt und schon lief es dann wieder:bigok: Hoffe das klappt bei dir auch :xmas:
ja wie war das, never change a running system ;)
hab auf der cpu den scythe big shurikan sitzen. das ist alles so eng und frimelig ist der helle wahnsinn.
jo prime,
lag wirklich daran. System schein wieder zu laufen.
Jetzt fängt das ganze theater mit der feinjustierung wieder an.
hab mir natürlich nichts aufgeschreiben *heul*
und es lief doch so gut :d
Das Board ist und bleibt ne Diva :d
aber schön das es wieder läuft. Hattest du dein Setting nicht gespeichert ???
Was für ein BIOS hast du drauf? Habe bei mir ein paar pics vom BIOS mit fsb471 gemacht. Kann man ganz gut als Anhaltspunkt nehmen. Hatte 1200er RAM. Mußt bei mir mal rein schauen :wink:
Ich habe das gleiche problem mit meine DK Plus.
Beim booten bekomme ich immer code 88.
Habe schon CPU, speicher, videokarte, NT gewechselt, stromkabel raus, beide jumper umgesetzt, clear CMOS. Alles mögliche, aber das board will nicht mehr booten. Immer code 88 beim booten.
Ärgerlich. :wall:
Ärgerlich. :wall:
Batterie auch schon raus gehabt? Den RTC Jumper auch umgesteckt gehabt? Ohne RAM booten oder nur mit einem Riegel. Viel mehr fällt mir auf die schnelle nicht ein.
Yep,
habe ich alles versucht.
Board auch 2-3 mal raus genommen und nachgeschaut, ob es kein schaden gab.
E8600, Q9650 und Q9550 probiert, mit 1 speicher modul (apogee GT und OCZ probiert) in alle 4 speicherplätze, ohne speicher, andere graka.
Fehler bleibt, code 88 kommt sofort beim booten.
Hatte zum glück noch ein UD3R liegen, da lauft es problemlos.
Vielleicht versuche ich es dieses wochenende noch ein letztes mal.
Hi, mein erster Post hier hehe.
Ich hab mal ne Frage zur weiteren Vorgehensweise bei meinem dk t2rs+.
Es geht mir zuerst mal um den FSB. Undzwar möchte ich 500FSB beim Quad stabil kriegen.
Allerdings schmiert mir nach 1 stunde Prime large immer worker 3 ab. Im normalen Windows- und Spielebetrieb gibts nach gut 2 Stunden nen Bluescreen.
Ich hab also vermutet, es liegt an GTL0/2, ist dieser Gedankengang schonmal richtig so? Das Board bietet für 0/2 aber nur sehr beschränkte Einstellungen. Zwischen 0,67 und 0,63 gibts einfach nichts.
Meine Settings bislang:
500FSB
Multi 6
vNB 1,39V
VTT 1,31
vDimm 2,2V (OCZ Speicher mit 2,2v)
GTL 0/2 0,67
GTL 1/3 0,64
GTL Ref 0,63
vRef 21
Ramteiler 333/667, 1066er Ram läuft also auf 1000
Nun, unter den Ram Settings habe ich bislang alles auf Auto. Ich hab aber kein Plan, wie ich was einstellen soll. Könnte daher die Instabilität kommen?
Welche CPU ?
Wie sind deine Temps ? (Smartguardian)
Beim Q9550 oder Q9650 liegen die GTL's meistens bei 67 67 63
Nach 1 Std. Prime einen Fehler, müsste meistens die VTT sein - 1 Stufe rauf !
Mach mal ein paar Pics von deinen Bios settings denn beim DK kommt es auch auf andere Einstellungen an !
Mehr als 1,35v auf der nb würde ich nicht geben. GTL´s wie Fresh schon sagte. Vielleicht hast du nicht die passende vref ;)
Ist ein Q9550
Smartguardian funktioniert leider nicht, es gibt da ja nur diese veraltete Version. Und die sagt mir immer, dass eine .dll Datei "itevio.dll" fehlt...
Ich Kühle die NB aber zusätzlich von oben mit einem 120 Lüfter, Handtest hat sie bestanden :d
Welche Screens brauchst du denn, gibt ja ziemlich viele beim DFI.
Ich habe grade die gesehen,dass tRFC bei mir auf 54 stand, anstatt 60,wie empfohlen. Hab das mal angepasst. Mal gucken,was Prime jetzt sagt,ansonsten probier ich nochmal 0,67/0,67/0,63 aus.
Achja zur vRef: Habe bei genannten Settings schon alles zwischen 21 und 28 ausprobiert, davon läuft nichts, ausser 21.
schonmal danke, für die schnellen Antworten :d
Meine Bios Settings sind beinahe identisch, ich mach gleich nochmal Pics, aber ich kann jetzt aus dem Gedächtnis schon sagen,
dass CPU Clock Amplitude bei mir auf 800mV steht, ich alle CPU Funktionen außer Multi Threading fürs Testen deaktiviert habe und tRFC steht bei mir halt auf 60, nicht auf 55.
Zu den ganzen fine delays kann ich jetzt nichts sagen, wie muss ich die denn einstellen und inwiefern wirken die sich auch die Stabilität aus.
Du musst wissen, ich komme von einem Gigabyte Board, das DFI fordert mich schon ein "wenig" mehr. :d
Stell die Fine Delays mal so ein wie auf den Pics. Brauchst eigentlich nur 3 Optionen auf nominal oder relaxed stellen was dir Stabilität verschafft. Die tRFC stehen schon richtig bei dir ;)
Waren 1,39vnb und 1,31vtt Bios eingestellte Werte?
Dann können 1,39vnb ca. 1,35v (real) entsprechen. Welches Bios hast du zur Zeit drauf? Mit der vtt hst du noch ein wenig Luft nach oben ;) Bei dem brett heißt aber weniger ist mehr :d also immer schön mit kleinen Spannungen anfangen und dann immer nur eine Option ändern. Und weiter testen :d .... das waren noch Zeiten :fresse:
Ja könnte sein, ich sehe auch immer dieses smartguardian,kriege es aber nicht zum Laufen(w7 64 bit), jemand eine Idee? Dann könnte ich wenigstens die realen Spannungen auslesen.
Meinst du etwa, die Spannung wäre zu hoch und deswegen macht es zicken?
Die Sache ist die, bei 500 sind bei mir 0,67/0,64/0,63 bei allen VTTs, die ich bis jetzt ausprobiert habe,die stabilsten Einstellungen. Habe auch schon etliche VTTs durch.
Mal gucken, im Moment läuft prime large noch anstandslos, jetzt schon 1h20m,vielleicht wars ja wirklich die tRFC.
