[Sammelthread] DFI LANparty UT X58-T3eH8 (Intel X58) [1]
DFI LANPARTY UT X58-T3eH8​
Inhalt des Sammelthreads:
  • Spezifikationen
  • Bilder
  • Das Bios
  • Downloads
  • Wichtige Informationen
  • Wichtige Links
Spezifikationen:
  • CPU
  • LGA 1366 socket for Intel® Core™ i7 processors
  • Intel® QuickPath Interconnect (QPI) technology - point-to-point interface that connects to X58; providing a dynamically scalable interconnect for increased bandwidth, lower latency and stability
  • Integrated Memory Controller (IMC) supports 3 channels of DDR3
  • Intel Hyper-Threading Technology delivers 8-threaded performance
  • 8-phase digital PWM provides stable voltage to the CPU
    Chipset
  • Intel chipset
  • Northbridge: Intel X58 Express chipset
  • Southbridge: Intel ICH10R
    QPI
  • System bus - 4.8GT/s to 6.4GT/s
    System Memory
  • Six 240-pin DDR3 DIMM sockets
  • DDR3 800/1066/1333/1600(O.C.) MHz DIMMs
  • Triple-channel memory architecture
  • Supports up to 24GB system memory
  • Delivers up to 43.2GB/s bandwidth
  • Unbuffered x8/x16, non-ECC and ECC, up to 4Gb DDR3 devices
    Expansion Slots
  • 3 PCI Express (Gen 2) x16 slots
  • a. 2-way CrossFire at x16/x16 transfer rate lanes; or
  • b. 3-way SLI at x16/x8/x8 transfer rate lanes
  • 1 PCI Express x4 slot
  • 2 PCI slots
    BIOS
  • Award BIOS
  • 8Mbit SPI flash memory
  • CMOS Reloaded
  • Graphics
  • Multiple GPUs (Graphics Processing Unit)
  • 3 graphics cards in 3-way SLI or Quad CrossFireX configuration
    Audio
  • Bernstein audio module
  • Realtek ALC889 8-channel High Definition Audio CODEC
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
  • 2 coaxial RCA S/PDIF-in/out jacks
  • 1 optical S/PDIF connector
  • 1 CD-in connector
  • 1 front audio connector
  • 108dB Signal-to-Noise ratio (SNR) playback (DAC) quality and 104dB SNR recording (ADC) quality
    LAN
  • Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers with Teaming technology
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
    Storage
  • Intel ICH10R chip
  • Intel Matrix Storage technology
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • JMicron JMB363 PCI Express to SATA and PATA host controller
  • Supports up to 2 UltraDMA 100Mbps IDE devices
  • Supports 2 SATA devices
  • RAID 0 and RAID 1
  • IEEE 1394
  • VIA VT6308P
  • Supports two 100/200/400 Mb/sec IEEE 1394a ports
    Rear Panel I/O
  • 1 Mini-DIN-6 PS/2 mouse port
  • 1 Mini-DIN-6 PS/2 keyboard port
  • 1 IEEE 1394 port
  • 6 USB 2.0 ports
  • 2 RJ45 LAN ports
  • Internal I/O
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 connector for an IEEE 1394 port
  • 1 connector for the Bernstein audio module
  • 1 IrDA connector and 1 CIR connector
  • 8 Serial ATA connectors
  • 1 40-pin IDE connector and 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 8 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power switch and reset switch)
    Power Management
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 / Wake-On-USB Keyboard/Mouse
  • Wake-On-LAN and Wake-On-Ring
  • RTC timer to power-on the system
  • AC power failure recovery
    Hardware Monitor
  • Monitors CPU/system/Northbridge temperature and overheat alarm
  • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
    PCB
  • 6 layers, ATX form factor;
  • 24.5cm (9.64") x 30.5cm (12")
Bilder:
Die Verpackung und das Zubehör:
Das Board selbst:
Quelle: XtremeSystems.org (Thanks to AndreYang for sharing the Pics!)​
Das Bios:
Special THANKS to: :wink:eva2000:wink: from i4memory.com! great SHARING!​
Bios Template vom Bios LX58DC18 "Genie Bios"
Code:
Genie BIOS Setting
CPU Feature
Set VR Current Limit Max: Disabled
Thermal Management Control: Disabled
EIST Function: Disabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
TDC Enable: Disabled
x TDC Limit: 0
TDP Enable: Disabled
x TDP Limit: 0
***** Logical Processor Setting *****
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Timing
Memory Control Setting: AUTO
Memory LowGap: 1536M
DRAM Command Rate: AUTO/1N/2N etc
CAS Latency Time (tCL): 9
RAS# to CAS# Delay (tRCD): 9
RAS# Precharge (tRP): 9
Precharge Delay (tRAS): 24
REF to ACT Delay (tRFC): AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Row Cycle Time (tRC): AUTO
Read CAS# Precharge (tRTP): AUTO
Four ACT WIN Time (tFAW): AUTO
Voltage Setting
O.C. Shut Down Free: Enable O.C.S.D.F
CPU VID Control: AUTO
CPU VID Special Add Limit: Enabled
CPU VID Special Add: Auto
Vcore Droop Control: Enabled
DRAM Bus Voltage: 1.605v
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add: AUTO
CPU VTT Voltage: 1.21v
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.11v
IOH Analog Voltage: 1.10v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
ADDR/CMD VREF Control: Disabled
x DIMM 1/2 ADDR/CMD Bus VREF: 110
x DIMM 3/4 ADDR/CMD Bus VREF: 110
x DIMM 5/6 ADDR/CMD Bus VREF: 110
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Disabled
1 core Max Turbo Ratio: 26x
2 core Max Turbo Ratio: 25x
3 core Max Turbo Ratio: 25x
4 core Max Turbo Ratio: 25x
CPU Non-Turbo Clock Ratio: 20x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: AUTO/4.8GT/s/5.866GT/s/6.4GT/s
CPU Base Clock (BCLK): 133 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 100 Mhz
DRAM Frequency: AUTO/800Mhz/1067Mhz/1333Mhz/1600Mhz/1866Mhz/2133Mhz (ratio referenced to default 133 bclk - so 1333Mhz /133Mhz = 10x DRAM multiplier)
UnCore Frequency: AUTO/1600/2133/2400/2666/2933/3200/3466/3733/4000/4266 (optimal to keep Uncore at 2x DRAM Frequency)
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
Downloads:
Bios Downloads:
Major Reasons of Change:
1. Fixed CPU turbo ratio can't over 30.
2. DDR3 1066 can't boot with Intel i7 "C0" stepping CPUs.
3. ICH10 STAT can't boot from DVD rom on AHCI and RAID mode.
Wichtige Links:
P.S: Das ist mein erster Sammelthread überhaupt, ich hoffe er ist gut geworden! Wenn was Falsch sein sollte oder irgendwas zu bemängeln gibt bitte lasst es mich wissen! LOB & Kritik sind also erwünscht!
Frohe schlacht!
Also wenn du dich genau an die Prozedur hällst kann es keine Probleme geben, ich mache es genau so :p
ist das egal ob ich jetzt fat 32 lasse oder ntsf
---------- Beitrag hinzugefügt um 19:01 ---------- Vorheriger Beitrag war um 18:33 ----------
oder muss ich ihn hinten anschließen beim mobo :confused::confused:
kriege es nicht hin wen sagt er mir immer disk boot fehler
http://csd.dficlub.org/forum/showthread.php?t=1136
http://www.hardwareluxx.de/community/showthread.php?t=478004
---------- Beitrag hinzugefügt um 08:30 ---------- Vorheriger Beitrag war um 08:04 ----------
Funktionieren die USB Ports an deinem Gehäuse nicht?
So habe alles nun mit den bios update geschafft habe jetzt nen weiteres problem habe seit heute das mein rechner garnicht mehr hochfährt mache ich an alles geht an aber er macht einfach nichts bei der led post steht cf was heißst das kann mir einer bitte helfen das wer sehr nett weiß grad echt nicht weiter
Sagt mal wo sitzt der PLL (phase locked load) controller, kann vllt. einer ein Foto machen oder ein Bild laden und das ganze markieren.
Oder vllt. kann mir einer sagen mit welchem Takt der PLL arbeitet, bzw. mit welcher Mhz Frequenz das Quartz schwingt?
der fred hier scheint leider total tod zu sein :(
keiner weis was,oder will was sagen :(
"noch" keine.;)
wenn ich mal die zeit finde,das gute teil zusammenzuschrauben und mitm ocen anfange,kommen die aber bestimmt ziemlich schnell^^
@ all die>SPAWA unter Wasser
Habt ihr die Hidepipe hinter der NB abgeknipst, oder wie habt ihr das geändert (SB)?
brauchst etwas mit T3eH8?dann bist richtig hier
nun schreib mal bitte deine frage und wir versuchen dir zu helfen
---------- Beitrag hinzugefügt um 09:17 ---------- Vorheriger Beitrag war um 09:16 ----------
ich habs abgeknipst
also SB unter originale Kühlung
rest unter wasser
es gibt fast kein so gute Kühler der mir originale ersetzen konnte
entweder sind die zu hoch oder zu klein
besser geht es leider nicht
wenn man multi gpu braucht ist es einzigste lösung
dafür meine spawas gehen mit 4.2Ghz unter vollast nie über 45
und 5Ghz vollast unter dice nie über 54 grad
Hi Leute, ich wollt von meinem MSI Eclipse SLI umsteigen: hab mit dem msi komische erfahrungen gemacht:manchmal merkts sichs die bioseinstellungen nicht, dann startet es wieder mit factory settings, die nb hat beim booten schon 89°C laut bios, dieses LCD Modul zeigt nur murx an etc...
ja und jetzt ist mir das DFI UT X58-T3eH8 ins auge gesprungen: digitale VRMs, 3 pcie slots, triple sli
meine fragen:
a) was erreicht ihr so an max. bclk?
b) was macht das evga 3xsli ohne Nforce200 classified noch besser, dass es fast das doppelte kostet wie das dfi hier?
c) mit welchen wasserkühlern kühlt ihr eure dfis? kann man die ganzen originalkühler abnehmen und später wieder dran machen wie es war?
d) sind die aufsteckbaren heatpipes, die dann so hoch sind wie ein towerkühler, dabei oder muss man die extra kaufen? braucht man die wirklich? oder sind die nur für extreme OClocking?
e) laufen auch i7 xeons/gulftown auf dem T3eH8?
f) geht auch die pciex4 asus usb3/sata6 addon karte U3S6 auf dem board? (siehe http://geizhals.at/a480158.html)
danke
laut bios screenshot auf der ersten seite dieses sammelthreads ist die niedrigste spannungseinstellung 1.45v!
Kann man beim
T3eH8
VDimm 1,35 einstellen für die G.Skill ECOs
Die 1,45V sind real dann aber 1,40-1,41 und as ist okay!
---------- Beitrag hinzugefügt um 05:42 ---------- Vorheriger Beitrag war um 05:38 ----------
meine fragen:
f) geht auch die pciex4 asus usb3/sata6 addon karte U3S6 auf dem board? (siehe http://preisvergleich.hardwareluxx.de/a480158.html)
danke
a) westsider max. 255 - alle 230 oder mehr
e) ab der neuen beta 6.1.10
b) evga ist teuer (hat mehr Optionen im Bios) P/L ist hier beim DFI viel besser
d) du meinst den flame-freezer? Der wird ja hinten montiert und schaut an der Blende aus dem Gehäuse so das der Lüfter hinten drauf pustet.......
f) wieso sollte die nicht laufen? Muß man halt probieren, aber denke schon
Ich wird die Woche ja auch ein DFI UT X58-T3eH8 erreichen, ... welches Bios ist zur Zeit das beste/sinnvollste, dann werde ich dieses gleich mal zu Beginn draufflashen.
meine fragen:
danke
ich hab 250 base clock unter wasser gemacht
http://hwbot.org/searchResults.do?d...etId=6102&modelId=0&manufacturerId=0&offset=0
nforce200 bringt gar keine vorteile und das kann ich beweisen jedem wer anders denkt :)
hier diskussion und argumente
http://www.hardwareluxx.de/community/showthread.php?t=677214&page=2
ich kühle mit MIPS spawa+koolance NB+stock SB
extra heatpipes braucht man nicht.bringt ca 1-2 grad nur
ja xeons laufen sehr gut
T3eH8 ist ein sehr gutes board
und ja für letzte frage
also mit gutem 920 D0 und unter -100 grad kann man mit T3eH8 ohne weitere probleme 260+ Bclk erreichen
es hat keine probleme oder bugs wie zum beispiel asus,gigabyte usw
T3eH8 ist ein fehlerfreies OC monster
gebrauchte kriegst so für 170 euro und damit kannst mit jedem EVGA aufnehmen :)
hab selber classified unter Ln2 gehabt
ich fand T3eH8 viel besser
classified konnte nur bis 220 booten sogar unter ln2
mit T3eh8 konnte ich ab 238 anfangen
http://i4memory.com/f80/dfi-ut-x58-t3eh8-bios-download-change-log-13966/
---------- Beitrag hinzugefügt um 06:53 ---------- Vorheriger Beitrag war um 06:50 ----------
ich habs abgeknipst
rest unter wasser
abknipsen ist auch wohl das einzig "sinnvollste" :d , beim komplett Abbau der Hidepipe würde der kleine Chip über der SB garnix abbekommen.
Mal versucht im Backofen das Röhrchen aus der NB rauzubekommen?
Aber Garantie....mal sehen was ich mache den Mipse SPAWA hab ich ja da.
jap kannste draufpacken, wenn du kein W7 hast würd ich das 5.08 flashen, hätt ich auch noch drauf aber mit der Final W7 bekomm ich den Turbo nicht mehr ans laufen.
Beim OC mußte etwas "umdenken"
Ich halte das zb. so >VC nur auto und Einstellung über "ViD spezial"
Mußte nur dann beim OC mit Turbo aufpassen, da geht die VC extrem in die Höhe, mußte dann weit runter mit den VID %!
http://i4memory.com/f80/dfi-lp-ut-p35-t2r-dfi-lp-lt-x38-t2r-working-clk-fine-delay-4743/
eva kannste auch ansprechen ist sehr nett nur nicht so früh er mag glaube sehr Forsters :d
und nicht so ocen wie er :d die haben dort alle Klima :d
Danke, .. also Win7 wird installiert sein, also dann die neuste Beta?!
Beim OC umdenken werde ich nicht müssen, hab mit i7/W35xx noch garnix in Sachen OC gemacht, ... das wird alles neu für mich sein -.-
also garantie ist nicht weg
zumindest so ein kluger mensch wie wendel smith bei dfi support versteht wofür man DFI UT kauft und gibt garantie trotz modifizierte kühlung , aber in bestimmte fälle
Nimm nicht die neueste beta (06.01.) die hat einen Fehler, da wurden Blöcke vertauscht. Bei der Einstellung PPL kommt einiges an Unsinn zum Vorschein. Aber da kommt sicher sehr bald ne neue beta. Funktioniert zwar tadellos, hat aber den Anzeigefehler.
Danke, dann werde ich erstmal die etwas ältere offi. Version nehmen.
Edit:
Oder ehr die Beta vom 11.2009?
das bios vom 05.11.09 ist inzwischen auch final, musst mal direkt bei DFI schauen
