[Sammelthread] DFI LANparty UT X58-T3eH8 (Intel X58) [1]
DFI LANPARTY UT X58-T3eH8​
Inhalt des Sammelthreads:
  • Spezifikationen
  • Bilder
  • Das Bios
  • Downloads
  • Wichtige Informationen
  • Wichtige Links
Spezifikationen:
  • CPU
  • LGA 1366 socket for Intel® Core™ i7 processors
  • Intel® QuickPath Interconnect (QPI) technology - point-to-point interface that connects to X58; providing a dynamically scalable interconnect for increased bandwidth, lower latency and stability
  • Integrated Memory Controller (IMC) supports 3 channels of DDR3
  • Intel Hyper-Threading Technology delivers 8-threaded performance
  • 8-phase digital PWM provides stable voltage to the CPU
    Chipset
  • Intel chipset
  • Northbridge: Intel X58 Express chipset
  • Southbridge: Intel ICH10R
    QPI
  • System bus - 4.8GT/s to 6.4GT/s
    System Memory
  • Six 240-pin DDR3 DIMM sockets
  • DDR3 800/1066/1333/1600(O.C.) MHz DIMMs
  • Triple-channel memory architecture
  • Supports up to 24GB system memory
  • Delivers up to 43.2GB/s bandwidth
  • Unbuffered x8/x16, non-ECC and ECC, up to 4Gb DDR3 devices
    Expansion Slots
  • 3 PCI Express (Gen 2) x16 slots
  • a. 2-way CrossFire at x16/x16 transfer rate lanes; or
  • b. 3-way SLI at x16/x8/x8 transfer rate lanes
  • 1 PCI Express x4 slot
  • 2 PCI slots
    BIOS
  • Award BIOS
  • 8Mbit SPI flash memory
  • CMOS Reloaded
  • Graphics
  • Multiple GPUs (Graphics Processing Unit)
  • 3 graphics cards in 3-way SLI or Quad CrossFireX configuration
    Audio
  • Bernstein audio module
  • Realtek ALC889 8-channel High Definition Audio CODEC
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
  • 2 coaxial RCA S/PDIF-in/out jacks
  • 1 optical S/PDIF connector
  • 1 CD-in connector
  • 1 front audio connector
  • 108dB Signal-to-Noise ratio (SNR) playback (DAC) quality and 104dB SNR recording (ADC) quality
    LAN
  • Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers with Teaming technology
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
    Storage
  • Intel ICH10R chip
  • Intel Matrix Storage technology
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • JMicron JMB363 PCI Express to SATA and PATA host controller
  • Supports up to 2 UltraDMA 100Mbps IDE devices
  • Supports 2 SATA devices
  • RAID 0 and RAID 1
  • IEEE 1394
  • VIA VT6308P
  • Supports two 100/200/400 Mb/sec IEEE 1394a ports
    Rear Panel I/O
  • 1 Mini-DIN-6 PS/2 mouse port
  • 1 Mini-DIN-6 PS/2 keyboard port
  • 1 IEEE 1394 port
  • 6 USB 2.0 ports
  • 2 RJ45 LAN ports
  • Internal I/O
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 connector for an IEEE 1394 port
  • 1 connector for the Bernstein audio module
  • 1 IrDA connector and 1 CIR connector
  • 8 Serial ATA connectors
  • 1 40-pin IDE connector and 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 8 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power switch and reset switch)
    Power Management
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 / Wake-On-USB Keyboard/Mouse
  • Wake-On-LAN and Wake-On-Ring
  • RTC timer to power-on the system
  • AC power failure recovery
    Hardware Monitor
  • Monitors CPU/system/Northbridge temperature and overheat alarm
  • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
    PCB
  • 6 layers, ATX form factor;
  • 24.5cm (9.64") x 30.5cm (12")
Bilder:
Die Verpackung und das Zubehör:
Das Board selbst:
Quelle: XtremeSystems.org (Thanks to AndreYang for sharing the Pics!)​
Das Bios:
Special THANKS to: :wink:eva2000:wink: from i4memory.com! great SHARING!​
Bios Template vom Bios LX58DC18 "Genie Bios"
Code:
Genie BIOS Setting
CPU Feature
Set VR Current Limit Max: Disabled
Thermal Management Control: Disabled
EIST Function: Disabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
TDC Enable: Disabled
x TDC Limit: 0
TDP Enable: Disabled
x TDP Limit: 0
***** Logical Processor Setting *****
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Timing
Memory Control Setting: AUTO
Memory LowGap: 1536M
DRAM Command Rate: AUTO/1N/2N etc
CAS Latency Time (tCL): 9
RAS# to CAS# Delay (tRCD): 9
RAS# Precharge (tRP): 9
Precharge Delay (tRAS): 24
REF to ACT Delay (tRFC): AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Row Cycle Time (tRC): AUTO
Read CAS# Precharge (tRTP): AUTO
Four ACT WIN Time (tFAW): AUTO
Voltage Setting
O.C. Shut Down Free: Enable O.C.S.D.F
CPU VID Control: AUTO
CPU VID Special Add Limit: Enabled
CPU VID Special Add: Auto
Vcore Droop Control: Enabled
DRAM Bus Voltage: 1.605v
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add: AUTO
CPU VTT Voltage: 1.21v
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.11v
IOH Analog Voltage: 1.10v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
ADDR/CMD VREF Control: Disabled
x DIMM 1/2 ADDR/CMD Bus VREF: 110
x DIMM 3/4 ADDR/CMD Bus VREF: 110
x DIMM 5/6 ADDR/CMD Bus VREF: 110
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Disabled
1 core Max Turbo Ratio: 26x
2 core Max Turbo Ratio: 25x
3 core Max Turbo Ratio: 25x
4 core Max Turbo Ratio: 25x
CPU Non-Turbo Clock Ratio: 20x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: AUTO/4.8GT/s/5.866GT/s/6.4GT/s
CPU Base Clock (BCLK): 133 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 100 Mhz
DRAM Frequency: AUTO/800Mhz/1067Mhz/1333Mhz/1600Mhz/1866Mhz/2133Mhz (ratio referenced to default 133 bclk - so 1333Mhz /133Mhz = 10x DRAM multiplier)
UnCore Frequency: AUTO/1600/2133/2400/2666/2933/3200/3466/3733/4000/4266 (optimal to keep Uncore at 2x DRAM Frequency)
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
Downloads:
Bios Downloads:
Major Reasons of Change:
1. Fixed CPU turbo ratio can't over 30.
2. DDR3 1066 can't boot with Intel i7 "C0" stepping CPUs.
3. ICH10 STAT can't boot from DVD rom on AHCI and RAID mode.
Wichtige Links:
P.S: Das ist mein erster Sammelthread überhaupt, ich hoffe er ist gut geworden! Wenn was Falsch sein sollte oder irgendwas zu bemängeln gibt bitte lasst es mich wissen! LOB & Kritik sind also erwünscht!
Frohe schlacht!
Wer hat Mipse auf dem Board, werde noch kirre, jeder erzählt was anderes, der eine nutzt ein Pad der andere WLP!? Und warum den NB Kühler entfernen wenn man auch einen Fusionblock nehmen kann???
hi meld mich auch mal wieder.
Frage: PWM, NB und CPU unter Wasser setzen mit nen quad Radiator zum OCen natürlich.....wird das noch alles dann gut gekühlt werden?....oder gleich zum Mora2 oder ähnliches! Will kein übermäßiges OC betreiben max 4,2 ghz dann reichts mir auch!
Also mit den PWM's würde ich schon einen Nova 1080 von Phobya nehmen, muss ja nicht gleich vollbestückt werden mit Luffis...
Wie machst du das mit den PWM's, Pad oder WLP!?
Ich denke was wirklich wichtig ist beim DFI board sind die PWMs.....die sollten gut gekühlt werden, die NB geht bei mir nicht über 50grad unter LASt ist nen guter wert denke ich ...nur wie soll man nur die PWMs kühlen wenn es alles zusammenhängt :-(
Gute frage hab das gleiche prob wie du hab schon beide Varianten gehört lieber wärs mir mit WLP
meinst echt ich sollte nen nova nehmen bin gerade soweit das ich nen passendes gehäuse gefunden habe was mir gefällt, wo dann auch nen quad reinpasst .....wollte erst nur die cpu kühlen ...nur wird es dann zuwenig luftstrom geben für das board...denke ich
---------- Beitrag hinzugefügt um 23:04 ---------- Vorheriger Beitrag war um 23:01 ----------
@ hardy hast du in dein lian li deine komplette wakü bekommen ohne Radiator versteht sich
http://hwbot.org/community/submission/940609_westsider_3dmark_2006_radeon_hd_5850_29959_marks
benutze MX2 on pwm and CPLs
http://www.overclockers.ge/forum/index.php?showtopic=13&st=1040
---------- Beitrag hinzugefügt um 23:16 ---------- Vorheriger Beitrag war um 23:15 ----------
warum denn?
hab tripple und kommt sehr gut klar
3Xlüfter@900rpm
es reicht vollkommend
hauptsache wasser muss nah an lufttemperatur bleiben
mehr kann man nicht erreichen
egal sogar mit 5 stück quad monsta
mit tripple kann ich 4.660 vantage benchen 4core/8thread
---------- Beitrag hinzugefügt um 23:18 ---------- Vorheriger Beitrag war um 23:15 ----------
verstehe nie warum man so ne radi kauft
thermodinamik sollte man nachlesen
es bringt nichts
gute tripple mit 600-1500rpm lüfter ist universal und gut
@westsider... also kann ich getrost nen quad mit 8 luffis nehmen und werd nicht unglücklich damit?
"es reicht vollkommend
mehr kann man nicht erreichen"...das mir auch klar von Thermodynamik hab ich jetzt nicht so den plan aber das das wasser nahe an raumtemperatur ran kommen sollte ist klar ..hätte nur gedacht das mehr radi fläche auch mehr bringt bzw die wassertemperatur auch senkt
2 doofe ein gedanke :-) lach
q Hardy wie hast du deine wäkü im lian li x-1000 verbaut ...kannst du da mal was posten ist echt nen schickes gehäuse.
ok kann ich nachvollziehen
Ja bin immer davon ausgegangen das es so ist, naja seis drum mein Radi war mit gutem Gestell, CPC Kupplungen und 9x Loonies so billig, da musste ich zugreifen und jetzt wo er auf der Terasse steht bin ich um so Glücklicher:bigok:
---------- Beitrag hinzugefügt um 23:37 ---------- Vorheriger Beitrag war um 23:35 ----------
Also die Pumpe steht auf dem Boden in der Mitte und den Rest kannst dir ja denken!
---------- Beitrag hinzugefügt um 23:38 ---------- Vorheriger Beitrag war um 23:35 ----------
Warum gerade Vantage als Beispiel?
ja das kann ich mir vorstellen! macht ja auch bock bei solchen temps zu benchen
---------- Beitrag hinzugefügt um 23:42 ---------- Vorheriger Beitrag war um 23:40 ----------
@ westsider ...wie schauts denn mit den temps aus cpu pwm und nb unter last zb prime oder so
schau mal
du brauchst wasser immer nah an lufttemperatur
sollst immer berechnen nach ausgegebene wärme
womit ist wasser gut.es kann auf einmal viel wärme aufnehmen.
unterscheide bitte wärme und temperatur
das sind zwei unterschiedliche sachen
und weil wasser mehr wärmekapazität hat sprich es wird langsamer warm,damit ist es besser als luft
aber was du brauchst ist ,wasser immer unter 35 grad
sonst wird es wärmen anstatt zu kühlen
ein tripple radiator@3x120mm 800-100rpm kann wasser sehr nah (ca 3-4 grad untershied) an lufttemperatur halten
wenn du 3 stück quad radis kaufst,wirst genau gleiche wassertemperatur haben
und wenn du 30 stück radis hast wirst trotzdem gleiche wassertemperatur erreichen
warum?wel man wasser in solche bedingungen nie unter lufttemperatur bringen kann
angenommen luft=25 grad
tripple radi schafft 29 grad wassertemp
4xquad schaffen vielleicht 27-28
und willst kaum an 25 grad rankommen
vielleicht 27 grad
und egal wieviel radis du hast und wie schnell die lüfter sind
deswegen es ist absolut sinlos dass man so viele radis einbaut
ich sehe hier ville besipiele davon
es ist besser ein tripple radi und high-flow system zu bauen als flow mit mehrere verbindungen und radis zu verhindern
sorry für mein deutsch
ich hab versucht logik zu folgen
---------- Beitrag hinzugefügt um 23:46 ---------- Vorheriger Beitrag war um 23:43 ----------
weil es 4 kerne mit 8 aufgaben belastet
in erstem test sind es reine FPU berechnungen
zweite test verlangt komplette CPU leistung
es ist einfach disaster test für CPU
kein benchmark kann cpu so belasten wie vantage
sogar wprime1024 mit 8 threads gibt ca 5grad weniger als vantage unter gleiche takt
und wprime1024 ist gleich mit prime95 kod
ich kann auch chess testen
aber es ist mehr FPU+RAm basiert
---------- Beitrag hinzugefügt um 23:49 ---------- Vorheriger Beitrag war um 23:43 ----------
[/COLOR]@ westsider ...wie schauts denn mit den temps aus cpu pwm und nb unter last zb prime oder so
unglaublich :)
glaub mir ich war unter schok :d
komme nie und nieeemals über 50 grad
sogar mit 4.8GHz+ 8 thread
PWM bleiben auf ca 45-47 grad
mit normale OC wie 4.2-4.4 hab ich 45 grad konstant
also mips pwm kühler hält sehr stabile temperatur
es variert mit -/+5 grad mehr nicht
originale kühler und 920@4.95GHz hab noch screen davon ging über 105 grad
und mit PWM unter wasser erreiche ich bessere OC ergebnisse
Board kommt weiter mit
CPU bleibt mit weniger spannung stabil
merk ich schon grosse unterschied
Kein prob danke für deine Erläuterung!
Hab nur schon so viele Test gelesen in dem ein zb ein mora sehr nah an die lufttemperatur herangekommen ist.
Aber wenn ich dir jetzt glauben schenke was ich gerne tue ist das ganze nicht so wichtig sondern nur das an abwärme abgefürt werden kann und das wasser aufnehmen kann.
dann ist es also auch so das "mehr Wasser" nur ein wenig verzögert bis es die maximale aufnahmeleistung erhält.....ist das richtig
---------- Beitrag hinzugefügt um 23:53 ---------- Vorheriger Beitrag war um 23:49 ----------
...dann bin ich also mit nen quadradiator gut unterwegs und mach mir dann da keine sorgen mehr wenn ich alles unter wasser setze...Pwm NB und Cpu
Hoffe du glaubst jezt nicht das du dich mit na wand unterhälst .-)
mehr wasser,mehr radis=nein
mehr flow=besser
ausreichend wasser,gute radiator,gute radi geeignete lüfter mit gutem air pressure
und sehr high flow durchdachte system
so was bringt mir möglichkeit nehalem mit 1.8V zu booten
fals jemand nicht glaubt kann ich gleich takten und screens posten :)
und CPU kühler sollte kein spielzeug sein
Heatkiller 3.0 ist ein monster stück
kein kühler kommt nah in extreme OC
es hat 500 gramm Cu
und damit kann weit mehr wärme abnehmen als jede andere
gleiche werte sieht man unter 4.2-.4.4
aber 4.7-4.8 ;) ist was anderes
da ist HK 3.0 wahre King
diese ergebniss sagt 100 mal mehr als alle wörte
http://hwbot.org/community/submission/931093_westsider_wprime_1024m_xeon_w3540_2min_29sec_100ms
sollte jede unter wasser versuchen nah zu kommen
mir egal sogar wenn weltmeister von OC
ich habs unter wasser gemacht und1024 8thread 4.830 zu benchen ist sogar unter DICe schwer für manche
hier fast 250 Baseclock
http://valid.canardpc.com/show_oc.php?id=815808
gekühlte PWM gibt viel raum
auch unter wasser ;)
Dann schaut euch das mal an ob das ok ist mein dfi board und cpu zu befeuern!
pumpe ist schwach
ausserdem für was brauchst du so viele zeug
verhinderst damit flow
hast weniger leistung
und musst sogar dafür haufen geld zahlen
pumpe ist zu schwach ? welche wär denn angebracht und was soll ich rausschmeißen??
Ah ich dachte man kann die Heatpipe die zu den PWM's führt ab nehmen und der rest bleibt drauf, für MultiGPU geht doch eh nur die original SB. Aber was hast du an Durchfluss?
Was hast du an Durchfluss?
meine pumpe ist mit 2 meter förderhöhe
750 LPH
aber so was erreicht man niemals
tatsächliche flow liegt auf ca 1.4-1.6 GPM
so 350 LPH
mehr flow kannst mit bessere pumpe erreichen
wird aber ganz wenig bringen,haufen geld kosten und unerträglich laut sein
heatkiller als low restrictive und high flow kühler skaliert nicht mehr weit ab 1.6GPM
es hat etwas vorteil bis 1.7GPM
danach nichts mehr
ja ist klar das ich das als fusion block nutzen kann aber gehen dann auch die pwm temps runter und nicht nur die NB
Ja da reicht meine Laing dann doch dicke und ist für mich nicht zu hören. Ich habe je nach Config um die 300 LPH und bin vollkommen zufrieden!
ich hab so nur koolance gehabt und es gab NB unter 45 grad aber 3-4 grad kühlere PWM
ist aber nicht der rede wert
ob ich 90 oder 85 grad habe ist mir egal
ich glaub bei dfi geht nur NB kühler runter und da kannste dann den NBwasserkühler drauf setzen
Bei Aquatuning steht das man den Mips NB auch als Fusionblock nutzen kann, schrauben mit der richtigen Länge liegen bei:
hab ich auch, hab noch keinen Bock die Hidepipe zu zerschneiden.... :d
komme mit 3.8 :fresse: nicht über 44 Grad >SPAWA
