[Sammelthread] DFI LANparty UT X58-T3eH8 (Intel X58) [1]
DFI LANPARTY UT X58-T3eH8​
Inhalt des Sammelthreads:
  • Spezifikationen
  • Bilder
  • Das Bios
  • Downloads
  • Wichtige Informationen
  • Wichtige Links
Spezifikationen:
  • CPU
  • LGA 1366 socket for Intel® Core™ i7 processors
  • Intel® QuickPath Interconnect (QPI) technology - point-to-point interface that connects to X58; providing a dynamically scalable interconnect for increased bandwidth, lower latency and stability
  • Integrated Memory Controller (IMC) supports 3 channels of DDR3
  • Intel Hyper-Threading Technology delivers 8-threaded performance
  • 8-phase digital PWM provides stable voltage to the CPU
    Chipset
  • Intel chipset
  • Northbridge: Intel X58 Express chipset
  • Southbridge: Intel ICH10R
    QPI
  • System bus - 4.8GT/s to 6.4GT/s
    System Memory
  • Six 240-pin DDR3 DIMM sockets
  • DDR3 800/1066/1333/1600(O.C.) MHz DIMMs
  • Triple-channel memory architecture
  • Supports up to 24GB system memory
  • Delivers up to 43.2GB/s bandwidth
  • Unbuffered x8/x16, non-ECC and ECC, up to 4Gb DDR3 devices
    Expansion Slots
  • 3 PCI Express (Gen 2) x16 slots
  • a. 2-way CrossFire at x16/x16 transfer rate lanes; or
  • b. 3-way SLI at x16/x8/x8 transfer rate lanes
  • 1 PCI Express x4 slot
  • 2 PCI slots
    BIOS
  • Award BIOS
  • 8Mbit SPI flash memory
  • CMOS Reloaded
  • Graphics
  • Multiple GPUs (Graphics Processing Unit)
  • 3 graphics cards in 3-way SLI or Quad CrossFireX configuration
    Audio
  • Bernstein audio module
  • Realtek ALC889 8-channel High Definition Audio CODEC
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
  • 2 coaxial RCA S/PDIF-in/out jacks
  • 1 optical S/PDIF connector
  • 1 CD-in connector
  • 1 front audio connector
  • 108dB Signal-to-Noise ratio (SNR) playback (DAC) quality and 104dB SNR recording (ADC) quality
    LAN
  • Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers with Teaming technology
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
    Storage
  • Intel ICH10R chip
  • Intel Matrix Storage technology
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • JMicron JMB363 PCI Express to SATA and PATA host controller
  • Supports up to 2 UltraDMA 100Mbps IDE devices
  • Supports 2 SATA devices
  • RAID 0 and RAID 1
  • IEEE 1394
  • VIA VT6308P
  • Supports two 100/200/400 Mb/sec IEEE 1394a ports
    Rear Panel I/O
  • 1 Mini-DIN-6 PS/2 mouse port
  • 1 Mini-DIN-6 PS/2 keyboard port
  • 1 IEEE 1394 port
  • 6 USB 2.0 ports
  • 2 RJ45 LAN ports
  • Internal I/O
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 connector for an IEEE 1394 port
  • 1 connector for the Bernstein audio module
  • 1 IrDA connector and 1 CIR connector
  • 8 Serial ATA connectors
  • 1 40-pin IDE connector and 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 8 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power switch and reset switch)
    Power Management
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 / Wake-On-USB Keyboard/Mouse
  • Wake-On-LAN and Wake-On-Ring
  • RTC timer to power-on the system
  • AC power failure recovery
    Hardware Monitor
  • Monitors CPU/system/Northbridge temperature and overheat alarm
  • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
    PCB
  • 6 layers, ATX form factor;
  • 24.5cm (9.64") x 30.5cm (12")
Bilder:
Die Verpackung und das Zubehör:
Das Board selbst:
Quelle: XtremeSystems.org (Thanks to AndreYang for sharing the Pics!)​
Das Bios:
Special THANKS to: :wink:eva2000:wink: from i4memory.com! great SHARING!​
Bios Template vom Bios LX58DC18 "Genie Bios"
Code:
Genie BIOS Setting
CPU Feature
Set VR Current Limit Max: Disabled
Thermal Management Control: Disabled
EIST Function: Disabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
TDC Enable: Disabled
x TDC Limit: 0
TDP Enable: Disabled
x TDP Limit: 0
***** Logical Processor Setting *****
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Timing
Memory Control Setting: AUTO
Memory LowGap: 1536M
DRAM Command Rate: AUTO/1N/2N etc
CAS Latency Time (tCL): 9
RAS# to CAS# Delay (tRCD): 9
RAS# Precharge (tRP): 9
Precharge Delay (tRAS): 24
REF to ACT Delay (tRFC): AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Row Cycle Time (tRC): AUTO
Read CAS# Precharge (tRTP): AUTO
Four ACT WIN Time (tFAW): AUTO
Voltage Setting
O.C. Shut Down Free: Enable O.C.S.D.F
CPU VID Control: AUTO
CPU VID Special Add Limit: Enabled
CPU VID Special Add: Auto
Vcore Droop Control: Enabled
DRAM Bus Voltage: 1.605v
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add: AUTO
CPU VTT Voltage: 1.21v
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.11v
IOH Analog Voltage: 1.10v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
ADDR/CMD VREF Control: Disabled
x DIMM 1/2 ADDR/CMD Bus VREF: 110
x DIMM 3/4 ADDR/CMD Bus VREF: 110
x DIMM 5/6 ADDR/CMD Bus VREF: 110
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Disabled
1 core Max Turbo Ratio: 26x
2 core Max Turbo Ratio: 25x
3 core Max Turbo Ratio: 25x
4 core Max Turbo Ratio: 25x
CPU Non-Turbo Clock Ratio: 20x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: AUTO/4.8GT/s/5.866GT/s/6.4GT/s
CPU Base Clock (BCLK): 133 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 100 Mhz
DRAM Frequency: AUTO/800Mhz/1067Mhz/1333Mhz/1600Mhz/1866Mhz/2133Mhz (ratio referenced to default 133 bclk - so 1333Mhz /133Mhz = 10x DRAM multiplier)
UnCore Frequency: AUTO/1600/2133/2400/2666/2933/3200/3466/3733/4000/4266 (optimal to keep Uncore at 2x DRAM Frequency)
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
Downloads:
Bios Downloads:
Major Reasons of Change:
1. Fixed CPU turbo ratio can't over 30.
2. DDR3 1066 can't boot with Intel i7 "C0" stepping CPUs.
3. ICH10 STAT can't boot from DVD rom on AHCI and RAID mode.
Wichtige Links:
P.S: Das ist mein erster Sammelthread überhaupt, ich hoffe er ist gut geworden! Wenn was Falsch sein sollte oder irgendwas zu bemängeln gibt bitte lasst es mich wissen! LOB & Kritik sind also erwünscht!
Frohe schlacht!
Tjo das ist der Wahn nach dem DFI. Jeder anderer Premium Hersteller ob Asus oder GB usw.
akzeptiert das als RMA Fall nur DFI nicht. Aber hauptsache DFI. Ist ja genau wie der Aberglaube EVGA sortiert für ihre FTW Karten die GPU's. Auf einen DFI lässt sich genau so schlecht bzw. gut übertakten wie auf anderen Board's
MfG Jaimewolf3060
Bei GB und Asus bekommst du da definitiv "Eigenverschulden oder falsche Handhabung" an die Backe geheftet? :shot:
ich habe heute "Bulldog72" eine Nachricht geschickt, ein Pin von meinem CPU Socket ist gebrochen, ich habe gefragt ob man den Socket tauschen kann, hoffe das alles reibungslos abläuft.
hab mit dem Support von DFI gesprochen, 45 € inkl. MwSt kostet ein neues Socket für mein Board :)
werde das Board die nächsten Tage nach Holland schicken...
Mal eine Frage ist es richtig das Speichermodule in den Gelben Slots nicht funktionieren.
Frage weil ich die Gelben benutzen wollte wegen CPU Kühler denn der blockiert 2 Ram Bänke wenn ich aber in den Gelben ein Modul reinsteckeBootet der Rechner garnicht erst.
steht auf seite 17 im manual, dass er bei dual oder triple-channel den dimm1 braucht und das ist der zweite von der cpu aus gesehen, also der erste grüne.
Moin :d
Hab auch so ein T3eH8 bei mir im Rechner und will es eigentlich verkaufen. Da ich atm eh kein extremes OC mache bin ich auf der Suche nach nem weniger zickigen Board.
Wie ihr seht ist das hier ja mein erster Post im Luxx, bin normal bei PCGHX unterwegs... Hab auch schon versucht das da zu verkaufen aber gibt anscheinend keine wirklichen Interessenten. Vllt ist mein Preis mit etwa 170€ noch zu hoch angesetzt? Denkt ihr das es problematisch ist hier als Einmalposter auf dem Marktplatz zu verkaufen?
Greetz
Kann sein das einige nach Vorabversand fragen oder anderen Referenzen (ebay z.b.) da du noch keine Positive Bewertung hast :wink:
mein Board ist seit dem 20.07.2010 bei DFI in der RMA, wie lange dauert es in der Regel bis das Board zurück kommt? bei mir muss der CPU Socket getauscht werden, wenn ich die RMA Nummer auf der Homepage eingebe, wird der Status noch nicht angezeigt, da steht nur RMA am 16.07 mit meinem Namen beantragt...
Nur zur Info bei DFI hatte ich es noch nicht das man sagen kann wie lange es dauert aber bei Biostar habe ich mal 4 Monate gewartet trotz mermaliger anrufe und schreiben an Biostar.
4 Monate das muss man sich mal auf der Zunge zergehen lassen.
Will mir das Board in meinem neuen Rechner mit dem xeon 3520 auch kaufen ist das empfehlenswert? Wäre über ne Antwort dankbar und werde mich parallel bisschen durch den Thread lesen.
Leute nochmal eine Frage ich will mir ja die micro atx version holen ne welche Nachteile hat die genau. Slots sind mir egal. Ist das Bios und die Spannungswandler die gelciehn und schaffe ich damit auch die oc werte vom normalen?
Mal eine Frage wie oder wo sieht man es welches Bios man drau hat.
Auf der DFI Page sehe ich nur z.b LX58D429.exe aber woher weis ich welche Version das ist und wo sieht mann es um es zu vergleichen
Beim booten zB.???
Und ja das Board lässt auch die Xeons laufen, W3520 hatte ich selber drauf! Mit etwas lesen oder nutzen der Suchfunktion hättet ihr euch die Fragen selbst beantworten können:fresse2:
Ne das steht 6.00PG aber egal... War bei mir nie anders, egal welches T3eH8 und BIos looool... Also wenn du den rechner startest und das Bios kommt, da drückste die Pause taste und siehst unten oder oben (muss ich lügen...) dein LX58D429 und da guckst auf der DFi seite von wann das ist usw...
Das mit CPU Z war ein guter Vorschlag.
Danke.
Noch eine Frage bei meinen ASUS Board früher konnte man das Bios unter Windows flashen geht das bei dem DFI auch ?
Ah da fällt mir gerade noch was Wichtiges ein wenn man ein Bios Update macht dann sind doch die Profile wo man die Bios Einstellungen gemacht hat und abgespeichert hat weg oder ?
Wenn ja kann man die Profile irgendwie wo anders sichern irgendwie ?
Noch was anderes kann es sein das das DFI T3EH8 mit 6GB nicht klar kommt
Habe 3x2 GB G.Skill ECO Cl 7,8,7,24 wenn ich 2x2 GB drin habe alles Paletti aber wenn 3x3 GB drin sind und ich Videos abrufe egal ob DVDs oder AVI Files dann Freezt mein System ab und zu.
Am Video liegt es nicht da der Freez x beliebig auftritt.
Riegel alle mit Memtest einzeln getestet ohne Fehler.
Hat jemand einen Rat oder selber Erfahrung mit 3x3 GB G.Skill ECO
Bios Update am besten mit dem USB Stick. das klappt wunderbar deim DFI Board. Deine Settings gehen nicht verloren. Die bleiben abgespeichert.
Wie bitte bekommt man 3x3 GB hin oder meintest du 2x2GB gehen nur 3x2 laufen nicht richtig?
