[Sammelthread] EVGA X58 SLi LE (Intel X58) [2]
EVGA x58 SLI LE
1. Technische Details
Performance
Based on Intel X58/ICH10R chipset
Supports Intel Core i7 Processors
133 Mhz QPI
Memory
6 x 240-pin DIMM sockets
Triple Channel DDR3
Maximum of 12GB of DDR3 1600MHz+
Expansion Slot
4 x PCIe x16/x8/x4, 1 x PCIe x1, 1 x PCI
1 x 32-bit PCI, support for PCI 2.1
Storage I/O
0 x UltraDMA133
6 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1, RAID5, JBOD
Integrated Peripherals
8 Channel High Definition
10/100/1000
Multi I/O
1 x PS2 Keyboard
12 x USB2.0 ports (8 external + 4 internal headers)
Audio connector (Line-in, Line-out, MIC)
FireWire 1394A
Form Factor
ATX Form Factor
Length: 12in � 304.8mm
Width: 9.6in - 243.6mm
2. Der X58 Chipsatz
3. Wasserkühlung
EK-Fullcover Prototyp
Mips
4. Bilder des Boards
5. Verpackung
Die Verpackung ist wie immer von EVGA perfekt es gibt mehrere Schutzsiegel und alles ist gut gepolstert.
6. BIOS
Bios-Template
Frequency/Voltage Control:
Dummy OC [disabled]
Extreme cooling [disabled]
>Memory Feature:
Memory SPD [Standard]
Memory Control Setting [Enabled]
Memory Frequency []
Target Memory Frequency [Mhz]
Channel Interleave Setting [6 Way]
Rank Interleave Setting [4 Way]
Memory Low Gap [Auto]
Parameters
tCL Setting [auto]
tRCD Setting [auto]
tRP Setting [auto]
tRAS Setting [auto]
tRFC Setting [auto]
Command Rate [auto]
>Voltage Control:
EVGA VDroop Control [With VDroop]
CPU VCore [auto]
CPU VTT Voltage [auto]
CPU PLL VCore [auto]
QPI PLL VCore [auto]
DIMM Voltage [auto]
DIMM DQ Vref [+0mV]
IOH VCore [auto]
IOH/ICH I/O Voltage [auto]
ICH VCore [auto]
>CPU Feature:
Intel SpeedStep [Disabled]
Turbo Mode Function [Enabled]
CxE Function [Disabled]
Execute Disable Bit [Enabled]
Virtualization Technology [Disabled]
*****Logical Processor Setting*****
Intel HT Technology [Enabled]
Active Processor Cores [ALL]
*****QPI Controller Setting*****
QPI Control Settings [Enabled]
QPI Link Fast Mode [Enabled]
QPI Frequency Selection [Auto]
CPU Clock Ratio [20 X]
CPU Host Frequency(Mhz) [133]
Target CPU Frequency []
Target Memory Frequency []
MCH Strap [Auto]
CPU Uncore Frequency(Mhz) [Auto]
CPU Clock Skew [0 ps]
Spread Spectrum [Disabled]
PCIE Frequency(Mhz) [100]
OC Recovery [Disabled]
Bios Fotos kommen noch muss Mein MB erst einbauen
Danksagungen:
graebens
Ihr solltet dort echt mal anrufen denn
ich hab da gerade angerufen und gefragt ob mein Board denn schon verschickt wurde.
Antwort:
Noch nicht,
es ist zwar wieder bei denen mit einem neuen Sockel doch beim Testen stürzt es immer ab !
Wahrscheinlich wurde es beim Sockeltausch beschädigt.
Der nette Hr. Ungermann bot mir direkt einen Austausch an und zwar das farbige SLI, aber das geht ja garnet die Farbe ...
Daraufhin wollte er sich melden.
5 Min später rief er wieder an und bot mir das EVGA X58 FTW³ an :)
Da die gerade um 15Uhr eine Lieferung mit den FTW³ bekommen haben.
Also Leute,direkt dort anrufen falls ihr was in RMA habt :wink:
Hört sich ja nicht schlecht an Artur. Paßt da der EK kühler auch auf's Board .... bin mal gespannt ;)
Keine Ahnung Micha,den hab ich eh schon verkauft ...
und der Kollege wollte mein altes LE auch net mehr haben,das passiert wenn man die Sachen zurückhält ...
Nun bekomm ich wenigstens noch ein paar gutes €uros fürs Board :)
habe folgendes "Problem":
Wenn ich den PC neustarte oder die BIOS Einstellungen verändere und deswegen rebooten muss, schaltet sich das Board inkl. alles Komponenten immer für ca. 3 Sekungen komplett aus.
Ich denke mal nicht, dass das sooo gut für die Festplatten ist auf Dauer. Kommen ja dann doch schon einige restarts zusammen, wenn man ein bisschen im BIOS rumspielt.
Hat jemand ne Ide wie ich das Problemchen lösen kann, gibts da eine bestimmte Einstellung die ich evtl. noch nicht gefunden habe?
Aktuellste Firmware ist drauf.
afaik ist das "Normal" bzw so gewollt.
Sobald du Änderungen am BIOS vornimmst testet das Board die neuen Einstellungen innerhalb der ~3 Sekunden. Hat mich anfangs auch immer ein wenig verwundert. Ob die Festplatten allerdings anlaufen weiß ich nicht...
naja, das kommt auch vor wenn ich einen ganz normalen Neustart über Windows mache.
Jo bei EVGA ist das so,würde mir da aber keine Sorgen machen ;)
mein DFI hat dafür eine ganz tolle Funktion,nennt sich "OC Shut Down Free"
damit kannste das abstellen das der Rechner nicht immer ganz ausgeht
Kann mir jemand sagen, welche Crystal Link Tubes ich von Bitspower bestellen muss? Ich will weg vom SChlauch zu den Plexi röhrchen, weiss aber nicht welche Länge ich benötige... Ob 2 Slots, 3 Slots oder 4 Slots...
Danke für Eure Antworten.
Edit: Hab gerade gemerkt, dass ich da was falsch verstanden habe, hat sich erledigt.
hat einer von euch ne U3S6 von Asus an seinem LE?
ich hab ma gelesen, dass man es irgendwie hinkriegen kann dass man mit dem controller booten kann, weiß da jemand zufällig wie?
Hey Leute, kann ich auf nem EVGA X58 SLI LE auch 2 x 8Gb Ram betreiben? In der Anleitung steht nur bis 4Gb pro Slot. Bin mir da irgendwie unsicher...
