[Sammelthread] Evga X79 Classified (Intel X79)
IceTea666
Liquidluxxer
Mattersburg City
Welcome to the future of high performance computing !
EVGA X79 Classified LGA 2011​
___________________________________________________________________
spec sheet
Based on Intel X79 chipset
Supports Intel Socket 2011 Processors
Memory
4 x 240-pin DIMM sockets
Quad Channel DDR3
Maximum of 32GB of DDR3 2133MHz+
Expansion Slot
5 x PCIe x16/x8, 1 x PCIe x1
Storage I/O
0 x UltraDMA133
4 x Serial ATA 300MB/sec (4x Internal) with support for RAID 0, RAID1, RAID 0+1, RAID5, RAID10 and JBOD
4 x Serial ATA 600MB/sec (2x Internal + 2x E-SATA) with support for RAID 0 and RAID1
Integrated Peripherals
8 Channel High Definition
2 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
10 x USB2.0 ports (2 external + 8 internal headers)
10 x USB3.0 ports (8 external + 2 internal headers)
Audio connector (Line-in, Line-out, MIC)
FireWire 1394B (1 external)
Form Factor
XL-ATX Form Factor
Length: 13.5in - 345.4mm
Width: 10.375in - 263.5mm
Product Warranty
This product comes with a 3 year limited warranty. Registration is recommended
EVGA offers several warranty solutions for our customers to choose from. Please refer to the suffix of the part number and our warranty terms for details.
Operating System Support
Windows 7 32/64bit, Windows Vista 32/64bit, Windows XP 32/64bit
Notes:
The next generation of Classified motherboards have arrived. The EVGA X79 Classified is the ultimate motherboard with a 12+2 Phase PWM Power Design, 100% POSCAP Capacitors, a 300% Increase in CPU Socket Gold Content, Dual 8pin CPU Power Connectors and more. If you are looking for the ultimate overclocking machine this is the motherboard for you. Additionally, support for next generation features like USB 3.0, SATA 6G and onboard Bluetooth give you the storage and connectivity support you desire. Oh, and did we mention this board has the capability to support NVIDIA 4-way SLI for the ultimate in extreme graphics performance?
CPU und Memory Support
CPU Support
X79 Series Motherboard (LGA 2011)
Sandy Bridge E
Core i7 3960X - 3.30 GHz
Core i7 3930K - 3.20 GHz
Memory Support
X79 Series Motherboard (DDR3, Quad Channel)
DDR3-2300
G.SKILL F3-18400CL8T6GBPIS 2GB
DDR3-2200
G.SKILL F3-17600CL8D-8GBPS 2GB
G.SKILL F3-17600CL7D-4GBPIS 2GB
DDR3-2133
G.SKILL F3-17066CL9D-8GBPID 2GB
G.SKILL F3-17066CL9T-6GBTD 2GB
G.SKILL F3-17066CL9D-4GBTDS 2GB
G.SKILL F3-17066CL8D-4GBPS 2GB
Kingston KHX2133C9AD3X2K2 2GB
DDR3-2000
ADATA AX3U2000GC2G9B-3G 2GB
G.SKILL F3-16000CL9T-6GBTD 2GB
G.SKILL F3-16000CL9D-4GBTD 2GB
G.SKILL F3-16000CL6T-6GBPIS 2GB
G.SKILL F3-16000CL8T-3GBPS 1GB
OCZ OCZ3N2000SR2GK 1GB
OCZ OCZ3P2000LV4GK 2GB
OCZ OCZ3B2000LV6GK 2GB
DDR3-1800
Corsair CM3X1024-1800C7D 1GB
Corsair CM3X1024-1800C7DIN 1GB
Kingston KHX1800C9D3LK2 2GB
OCZ OCZ3N1800SR4GK 1GB
DDR3-1600
Corsair CM3X1G1600C8D4 1GB
Corsair CMD8GX3M4A1600C8 2GB
Corsair CMG4GX3M2A1600C7 2GB
Corsair CMG4GX3M2A1600C9 2GB
Corsair CMX8GX3M4A1333C9 2GB
Corsair CMX8GX3M4A1600C9 2GB
Corsair TR3X6G1600C8D 2GB
G.SKILL F3-12800CL7D-4GBECO 2GB
G.SKILL F3-12800CL9D-4GBECO 2GB
OCZ OCZ3P1600LV6GK 2GB
OCZ OCZ3G1600LV6GK 2GB
OCZ OCZ3X1600LV6GK 2GB
SUPER TALENT WP160UX4G8 2GB
SUPER TALENT WP160UX4G9 2GB
DDR3-1333
G.SKILL F3-10666CL8D-4GBECO 2GB
Kingston KHX1333C9D3UK2 2GB
Kingston KVR1333D3N9 2GB
Feautres
Key Features
Intel X79 Express Chipset
4 DIMM Quad-Channel DDR3 2133MHz+ (up to 32GB)
8 Channel High Definition Audio + Optical
12+2 Phase PWM
PCI Express 3.0 Ready
E-LEET Software Support
EVGA EVBot Support
Triple BIOS Support
EZ Voltage Read Points
Onboard CPU Temp Monitor
CLEAR CMOS, Power and Reset
Dual 8 Pin CPU Power
PCIE/DIMM Disable Switches
Das Handbuch (Online)
http://www.evga.com/support/manuals/files/EVGA_Manual_DE.pdf
Rewievs,Links und News
EVGA X79 Classified Extreme OC by kingpin
Bios & Updates
NEUSTE VERSION Version 2.06 (19.12.2013) 151-SE-E779 Download
Ältere Versionen:
Version 41 (05.10.2012) 151-SE-E779 Download
Version 39 (10.09.2012) 151-SE-E779 Download
Version 38 (10.07.2012) 151-SE-E779 Download
Version 37 (30.04.2012) 151-SE-E779 Download
Version 36 (11.04.2012) 151-SE-E779 Download
Version 35 (28.03.2012) 151-SE-E779 Download
Version 34 (16.02.2012) 151-SE-E779 Download
Version 33 (10.02.2012) 151-SE-E779 Download
Version 32 (20.01.2012) 151-SE-E779 Download
Version 29 (23.12.2011) 151-SE-E779 Download
Version 28 (19.12.2011) 151-SE-E779 Download
Wasserkühlung
EK Waterblocks bietet für das X79 Classified 3 Modelle von Wasserkühlsets an !
EK Water Blocks EK-FB KIT EVGA X79 Classified - Acetal
Bilder
EK Water Blocks EK-FB KIT EVGA X79 Classified - Acetal+EN (Nickel)
Bilder
Bild EK Water Blocks EK-FB KIT EVGA X79 CLASSY CSQ - Acetal + Nickel
Bilder
Grüße IceTea666
Hallo, danke für das Erstellen des Threads. Hast du das Board schon vorbestellt?
Ein paar Vorschläge von mir...
1) Die Produktbilder kannst du auch nebeneinander anordnen.
2) Die Arbeitsspeicher mit dem [ LIST ] [ * ] [ * ] [ /LIST ] tag übersichtlicher machen (lässt sich auch verschachteln).
3) Da die EVGA Modelle in letzter Zeit nur wenig Beachtung fanden hier im Forum (auch weil sie sehr spät kamen), würde ich vorschlagen du nimmst die anderen Modelle auch mit in diesen Thread auf... überleg es dir mal :)
Verlinkt in der X79 Übersicht und der alphabetischen Sammelthread Übersicht.
Gruß, emi
Kein Thema,immer wieder gerne:)
Das Mainbord habe ich schon hier. Bilder sind auch gemacht. Leider nur mit nem iPhone 4S. Soll ich dennoch wagen,die Bilder hochzuladen? :)
zu 1.)Könntest du mir sagen,wie ich sie nebeneinander anordnen kann?
zum 2.) Die Frage ist wie? :d Bin da Neuland.
zum 3.) Welche anderen modelle sind damit gemeint?
Bin sehr gerne bereit auch andere Modelle hier in den Thread zu beziehen.
Vllt noch die Evga GTX 580 Classified? Habe 3 von deren hier.
Und vllt noch die EVGA Frostibite Wärmeleitpaste. Die soll einer der Besten sein. (Zufälligerweise kam die gerade mit der Post)
Wo genau soll ich da verlinken?
Heusti
1) Einfach die Zeilenumbrüche entfernen ;)
2) Ok, ich habe dir mal ein paar Beispiele vorbereitet:
EVGA X79 Classified Mainbord
PART NUMBER: 151-SE-E779-KR. LGA 2011 / Intel X79
Nun zu den Spezifikationen und Ausstattung:
  • Based on Intel X79 chipset
  • Supports Intel Socket 2011 Processors
  • Memory
    • 4 x 240-pin DIMM sockets
    • Quad Channel DDR3
    • Maximum of 32GB of DDR3 2133MHz+
  • Expansion Slot
    • 5 x PCIe x16/x8, 1 x PCIe x1
  • Storage I/O
    • 0 x UltraDMA133
    • 4 x Serial ATA 300MB/sec (4x Internal) with support for RAID 0, RAID1, RAID 0+1, RAID5, RAID10 and JBOD
    • 4 x Serial ATA 600MB/sec (2x Internal + 2x E-SATA) with support for RAID 0 and RAID1
  • Integrated Peripherals
    • 8 Channel High Definition
    • 2 x 10/100/1000
  • Multi I/O
    • 1 x PS2 Keyboard
    • 10 x USB2.0 ports (2 external + 8 internal headers)
    • 10 x USB3.0 ports (8 external + 2 internal headers)
    • Audio connector (Line-in, Line-out, MIC)
    • FireWire 1394B (1 external)
  • Form Factor
    • XL-ATX Form Factor
    • Length: 13.5in - 345.4mm
    • Width: 10.375in - 263.5mm
  • Product Warranty
    • This product comes with a 3 year limited warranty. Registration is recommended. EVGA offers several warranty solutions for our customers to choose from. Please refer to the suffix of the part number and our warranty terms for details.
  • Operating System Support
    • Windows 7 32/64bit, Windows Vista 32/64bit, Windows XP 32/64bit
Notes:
CPU Support
  • Sandy Bridge E
    • Core i7 3960X - 3.30 GHz
    • Core i7 3930K - 3.20 GHz
Memory Support
  • DDR3-2300
    • G.SKILL F3-18400CL8T6GBPIS 2GB
  • DDR3-2200
    • G.SKILL F3-17600CL8D-8GBPS 2GB
    • G.SKILL F3-17600CL7D-4GBPIS 2GB
  • DDR3-2133
    • G.SKILL F3-17066CL9D-8GBPID 2GB
    • G.SKILL F3-17066CL9T-6GBTD 2GB
    • G.SKILL F3-17066CL9D-4GBTDS 2GB
    • G.SKILL F3-17066CL8D-4GBPS 2GB
    • Kingston KHX2133C9AD3X2K2 2GB
  • DDR3-2000
    • ADATA AX3U2000GC2G9B-3G 2GB
    • G.SKILL F3-16000CL9T-6GBTD 2GB
    • G.SKILL F3-16000CL9D-4GBTD 2GB
    • G.SKILL F3-16000CL6T-6GBPIS 2GB
    • G.SKILL F3-16000CL8T-3GBPS 1GB
    • OCZ OCZ3N2000SR2GK 1GB
    • OCZ OCZ3P2000LV4GK 2GB
    • OCZ OCZ3B2000LV6GK 2GB
  • DDR3-1800
    • Corsair CM3X1024-1800C7D 1GB
    • Corsair CM3X1024-1800C7DIN 1GB
    • Kingston KHX1800C9D3LK2 2GB
    • OCZ OCZ3N1800SR4GK 1GB
  • DDR3-1600
    • Corsair CM3X1G1600C8D4 1GB
    • Corsair CMD8GX3M4A1600C8 2GB
    • Corsair CMG4GX3M2A1600C7 2GB
    • Corsair CMG4GX3M2A1600C9 2GB
    • Corsair CMX8GX3M4A1333C9 2GB
    • Corsair CMX8GX3M4A1600C9 2GB
    • Corsair TR3X6G1600C8D 2GB
    • G.SKILL F3-12800CL7D-4GBECO 2GB
    • G.SKILL F3-12800CL9D-4GBECO 2GB
    • OCZ OCZ3P1600LV6GK 2GB
    • OCZ OCZ3G1600LV6GK 2GB
    • OCZ OCZ3X1600LV6GK 2GB
    • SUPER TALENT WP160UX4G8 2GB
    • SUPER TALENT WP160UX4G9 2GB
  • DDR3-1333
    • G.SKILL F3-10666CL8D-4GBECO 2GB
    • Kingston KHX1333C9D3UK2 2GB
    • Kingston KVR1333D3N9 2GB
Du kannst dir den BB-Code ansehen, in dem du meinen Beitrag zitierst.
3) Ich meinte die anderen X79 Modelle von EVGA, da es ja ein Mainboard Sammelthread ist^^
Eigene Bilder sind immer gut, wenn du später noch bessere mit einer richtigen Kamera machen kannst, dann würde ich mir die Mühe mit dem Eierphone aber sparen =)))
Puh, im Evga Forum kommen die Bords ja nicht gut weg.. hoffe Du hast ein problemloses Board erwischt!
Sent from my iPhone using Hardwareluxx app
@moderator.
Das werde ich dann in die Tat umsetzen,sobald ich wieder am PC bin
An den mainbords is nichts..
Lediglich das BIOS macht Probleme.(genauer gesagt,das OC macht probleme) das war damals bei den Evga x58 mainbords auch der fall.. Als Evga dann aber ein ordentliches BIOS rausbrachte,rannten die mainbords richtig. Sind zwar zickige mainbords,aber wenn man die richtige Einstellung gefunden hat,dann sind sie kaum zu toppen.
Sie sind aber am arbeiten.
Kenne kein Evga X79 classified mainbord,dass im Evga Forum als Defekt analysiert wurde.
Übeigens,habe gesehen,dass mein mainbord ein Revision 1.0 is..
Würde gern wissen,was an Revision 0.0 war.
MfG
Also, was man so in verschiedenen Foren ließt, sind die Board extreme Zicken. Das Problem ist meistens das beschissen umgesetzte Bios. Hoffen wir mal das da noch was geht.
Mainbord Läuft.
OC is auch schon möglich.
Das Board an sich ist ersta Sahne,wenn das Bios Optimiert werden würde.
Das Bios macht noch einige Probleme..
Wenn man aber im Forum von EVGA rummliest,kann man erkennen,dass sich EVGA um JEDEN Fehler kümmert..
Neue Bios Updates sind fast alle 2-3 Wochen vorhanden.
Bin auch mit EVGA in Kontakt.
Die sind sich sicher,dass es Bald keine Bugs mehr in sachen BIOS mehr geben wird.
Ich bin mir ganz sicher,dass wenn EVGA das Ultimative Bios zu Erscheinung bringt,dass es dann das Rampage IV Exreme schlagen wird.
Hier noch ein paar keine Bilder,sind nichts besonderes.
Ich wünsche es Evga das die alles noch im Griff bekommen!
Kann man die Speicher auch bei Evga nachschauen?
Vermisse den die 32GB Corsair 1866CL9.
BTW: gibts Stromverbrauchsmessungen? :d
Da bin ich sehr guter Dinge.
Jedes BIOS is immer besser geworden.
Das nächste,spätestens übernächstes wird mit Sicherheit der Knaller und dann kann asus einpacken
Kann ich gerne machen.
Welche Spannungen soll ich messen?
Warum meldest du dich nicht auf meine PN wegen deinen Schulden des iPad 2?
Bin heute nicht mehr dazu gekommen mit dem messen,werde ich Dann am Wochenende machen.
Soweit klappt alles.
Hast du vor,dir das Mainboard zu nehmen?
Hey,
bitte fasse die Bilder und bekannte Probleme mit dem BIOS im ersten Beitrag zusammen, das wird sonst im Laufe der Zeit zu unübersichtlich. Meine Entwürfe für die Spezifikationen und Speicherliste aus Beitrag 4, kannst du bei der Gelegenheit auch direkt mit einbauen ;)
@Heusti
Ich interessiere mich evtl. für ein 2011er System,
daher halt ich mal ausschau :d
Kandidaten:
ASUS P9X79 WS
ASUS Rampage IV Extreme
EVGA X79 Classified
Intel DX79SI
Mit den Asus RE II+III habe ich nur postive Erfahrungen gemacht, möchte aber etwas "sparsameres im Stromverbrauch" im Idle sind es mal eben 31 Watt als z.B. beim Intel.
Intel läuft meist nur innerhalb der strengen Vorgaben, Speicher werden nicht ständig eingepflegt..
Bei EVGA stören mich die 4 RAM Bänke (kann man aber bei einem OC Board evtl. verschmerzen, aber das REIV bietet ja auch vier.)
Das WS ist halt so ein mittelding aus dem Intel +besserem RAM Support.
Darüberhinaus kommt ja noch das ASRock X79 Extreme11...aber das ist wohl eine Spur zu krass! :d
(da wird nix mit sparsam...)
BTW: gerade ist ein neues Bios (V035) für's EVGA erschienen:
http://www.evga.com/forums/tm.aspx?m=1519386
Evga gibt sich sichtlich Mühe.
Was Hast du mit dem Pc vor,dass is die frage
Da freu ich mich grad wie so en kleines Kind.
BIOS werde ich gleich überspielen :)
Allerdings gibt sich Evga Mühe,die nehmen alles auf,was User und Leute an Fehlern finden und setzten es in die Tat und verbessern.
Nabend,
Ich bin grade dabei mir ein neues System zusammenzustellen und als Hauptplatine ist meine Wahl auf das EVGA X79 Classified gefallen.
Nun hab ich einige Fragen und hoffe das ihr mir die beantworten könnt. :)
1. Hat EVGA den Trend zum schlanken oc freudigen UEFI fortgesetzt und bootet das Board genauso schnell wie die Bretter mit 6er Chipsatz "damals" ?
2. Ist der verbaute SATAIII Raidcontroller Bootfähig, sprich kann ich zwei SSD´s im RAID0 als Systemplatten verwenden ?
3. Ist es Sinnvoll Spwas und Chipsatz mit einer Wakü zu besetzten oder erhält man dadurch kein zusätzliches oc potential ?
Der Startbeitrag wurde seit Monaten nicht mehr aktualisiert, leider.
Wenn jemand den Thread übernehmen will und was zum Thema (offene Fragen) beitragen kann --> PM.
War grade am Benchen und würd euch gerne mal zeigen was mit dem Onboard RAID Controller vom X79 möglich ist :teufel:
Das sind 2x WD RE4 Enterprise 1TB Laufwerke in RAID0 mit eingeschaltetem WBC
ICh finds krass...
Ein direkter Vergleich zwischen Single-Drive, Dual-RAID0 und 4xRAID0 wäre ganz interessant. Damit man die Werte besser beurteilen kann :)
Is das Mobo so schlecht oder was is hier los?!
Bin am überlegen ob ich mein Asus X79 Formula gegen das EVGA EVGA X79 Classified oder FTW austauschen soll.... Hmmm
Grüße
Sharie
Das würde ich mir an deiner Stelle nochmal überlegen. Du hast immo das "beste" X79 Board. Die Evgas können kein Offset und haben immer wieder Bios Probleme. Ram-OC geht auch nur sehr bescheiden.
Bleib bei deinem Formula!
@Shariela Tagchen, willkommen im Thread...
Der Thread ist nich so leer weil das Board so schlecht ist sondern weil es nur sehr wenige haben. Aber bei Fragen oder ähnlichem stehen wir dir gerne zur Verfügung.
@shorty71 ob das X79 von ASUS wirklich das beste X79 Board ist ist fraglich...sicher es bringt einige Features mehr mit aber ich bin vom Rampage IV zum CLassified gewechselt weil mir das ASUS Brett einfach zu überladen war und damit kein vernüftiges OC möglich war.
Noch dazu hat das Classified keine schlechten Referenzen, immerhin wurden alle derzeitigen Graka OC Weltrekorde mit dem Brett aufgestelt. Und den Datendurchsatz den der verbaute RAID Controller liefert hab ich so noch bei keinem anderen Board gesehen.
Das einzige was mich Stört ist das die Netzwerkkarten kein Offload beherrschen.
ps. Wenn man ein BIOS richtig flasht hat man auch keine BIOS Probleme, DOS ftw ...
